The Z moves look to be inverted. What we really need to see is your design file from Fusion. It's likely you have something setup wrong.
C|
I'm new to the CNC world and I'm currently using Fusion 360 with WINPC NC post processor. I did a simple model in Fusion360 and loaded the gcode (.nc file) onto WINPC NC. I zeroed my XY&Z axis and start the machining process.
The CNC machine is following the Z & Y axis property, however instead of lowering the spindle to cut into the material, it is lifting it. So, it is doing completely the opposite of what the X-axis is supposed to do. I've set my work coordinate system & tried to flip the Z-axis and still not having any luck.
Is there any other option/config in Fusion 360 that I need to change to change the direction of the z-axis?
Note, that when I use Aspire Vectrix, it works fine but not with Fusion 360.
For your reference, see G-code below:
(upside)
(upside)
(T1 D=3. CR=1. - ZMIN=-19.5 - bullnose end mill)
N10 G90
N11 G71
(2D Adaptive1)
(CHANGE TOOL)
N12 T1 M06 (BULLNOSE END MILL D=3. 3MM BULLNOSE ENDMILL)
N13 S10000 M03
N14 G54
N15 G00 X9.706 Y6.562
N16 G00 Z-7.
N17 G00 Z-3.01
N18 G00 Z4.39
N19 G01 Z4.69 F1500
N20 G01 X9.708 Y6.57 Z4.757
N21 G01 X9.713 Y6.591 Z4.82
N22 G01 X9.722 Y6.626 Z4.877
N23 G01 X9.734 Y6.672 Z4.925
N24 G01 X9.748 Y6.727 Z4.96
N25 G01 X9.764 Y6.788 Z4.982
N26 G01 X9.78 Y6.853 Z4.99
N27 G03 X10.015 Y8.486 I-7.419 J1.9
N28 G01 Y8.576
N29 G01 X9.75 Y9.248
N30 G01 X9.608 Y9.956
N31 G01 X9.536 Y10.674
N32 G01 X9.499 Y11.395
N33 G01 X9.482 Y12.117
N34 G01 X9.473 Y12.839
N35 G01 X9.469 Y13.561
N36 G01 X9.467 Y14.283
N37 G01 X9.465 Y16.449
N38 G01 Y38.831
N39 G01 X9.578 Y39.174
N40 G01 X9.789 Y39.467
N41 G01 X10.328 Y39.947
N42 G01 X10.992 Y40.229
N43 G01 X11.698 Y40.381
N44 G01 X12.416 Y40.459
N45 G01 X13.137 Y40.498
N46 G01 X13.859 Y40.517
N47 G01 X14.581 Y40.526
N48 G01 X15.303 Y40.531
N49 G01 X16.025 Y40.533
N50 G01 X18.191 Y40.535
N51 G01 X29.02
N52 G01 X38.767
N53 G01 X39.117 Y40.446
N54 G01 X39.42 Y40.249
N55 G01 X39.918 Y39.727
N56 G01 X40.212 Y39.067
N57 G01 X40.372 Y38.363
N58 G01 X40.455 Y37.646
N59 G01 X40.496 Y36.925
N60 G01 X40.516 Y36.203
N61 G01 X40.526 Y35.481
N62 G01 X40.531 Y34.76
N63 G01 X40.533 Y34.038
N64 G01 X40.535 Y31.872
N65 G01 Y11.295
N66 G01 X40.504 Y11.117
N67 G01 X40.373 Y10.78
N68 G01 X40.152 Y10.495
N69 G01 X39.6 Y10.029
N70 G01 X38.931 Y9.758
N71 G01 X38.224 Y9.612
N72 G01 X37.506 Y9.538
N73 G01 X36.785 Y9.5
N74 G01 X36.063 Y9.482
N75 G01 X35.341 Y9.473
N76 G01 X34.619 Y9.469
N77 G01 X33.897 Y9.467
N78 G01 X31.731 Y9.465
N79 G01 X30.287
N80 G01 X12.237
N81 G01 X11.893 Y9.573
N82 G01 X11.592 Y9.772
N83 G01 X11.088 Y10.29
N84 G01 X10.848 Y10.433
N85 G01 X10.562 Y10.47
N86 G01 X10.382 Y10.467
N87 G01 X10.292 Y10.466
N88 G01 X10.251 Y10.486
N89 G01 X10.223 Y10.521
N90 G01 X10.214 Y10.565
N91 G01 X10.301 Y10.916
N92 G01 X10.343 Y11.358
N93 G01 X10.386 Y12.079
N94 G01 X10.403 Y12.801
N95 G01 X10.41 Y13.523
N96 G01 X10.413 Y14.245
N97 G01 X10.415 Y15.689
N98 G01 Y37.348
N99 G01 X10.508 Y38.064
N100 G01 X10.458 Y38.238
N101 G01 X10.469 Y38.599
N102 G01 X10.467 Y38.734
N103 G01 X10.506 Y38.816
N104 G01 X10.759 Y39.073
N105 G01 X11.072 Y39.253
N106 G01 X11.759 Y39.475
N107 G01 X12.48 Y39.513
N108 G01 X13.201 Y39.546
N109 G01 X13.923 Y39.562
N110 G01 X14.645 Y39.572
N111 G01 X15.367 Y39.578
N112 G01 X16.089 Y39.581
N113 G01 X17.533 Y39.584
N114 G01 X21.864 Y39.585
N115 G01 X37.748
N116 G01 X38.103 Y39.516
N117 G01 X38.462 Y39.551
N118 G01 X38.642 Y39.539
N119 G01 X38.687 Y39.538
N120 G01 X38.731 Y39.526
N121 G01 X38.811 Y39.486
N122 G01 X38.947 Y39.366
N123 G01 X39.072 Y39.237
N124 G01 X39.256 Y38.926
N125 G01 X39.463 Y38.234
N126 G01 X39.507 Y37.514
N127 G01 X39.561 Y36.794
N128 G01 X39.569 Y36.072
N129 G01 X39.575 Y35.35
N130 G01 X39.579 Y34.628
N131 G01 X39.582 Y33.906
N132 G01 X39.584 Y32.462
N133 G01 X39.585 Y26.686
N134 G01 Y16.578
N135 G01 Y12.246
N136 G01 X39.516 Y11.892
N137 G01 X39.551 Y11.532
N138 G01 X39.539 Y11.352
N139 G01 X39.531 Y11.308
N140 G01 X39.494 Y11.225
N141 G01 X39.38 Y11.086
N142 G01 X39.103 Y10.854
N143 G01 X38.435 Y10.58
N144 G01 X37.715 Y10.521
N145 G01 X37. Y10.425
N146 G01 X36.278 Y10.426
N147 G01 X34.112 Y10.418
N148 G01 X31.946 Y10.416
N149 G01 X13.896 Y10.415
N150 G01 X13.174 Y10.424
N151 G01 X12.682 Y10.505
N152 G01 X12.507 Y10.461
N153 G01 X12.327 Y10.464
N154 G01 X12.244 Y10.499
N155 G01 X11.678 Y10.948
N156 G01 X11.442 Y11.207
N157 G01 X11.342 Y11.252
N158 G01 X11.258 Y11.286
N159 G01 X11.173 Y11.315
N160 G01 X11.129 Y11.327
N161 G01 X11.085 Y11.338
N162 G01 X11.051 Y11.367
N163 G01 X11.032 Y11.408
N164 G01 X11.059 Y12.13
N165 G01 X11.105 Y12.328
N166 G01 X11.151 Y12.566
N167 G01 X11.198 Y12.866
N168 G01 X11.246 Y13.257
N169 G01 X11.294 Y13.818
N170 G01 X11.331 Y14.539
N171 G01 X11.349 Y15.261
N172 G01 X11.357 Y15.983
N173 G01 X11.361 Y16.705
N174 G01 X11.363 Y17.427
N175 G01 X11.365 Y19.593
N176 G01 Y27.535
N177 G01 Y37.643
N178 G01 X11.474 Y37.987
N179 G01 X11.452 Y38.166
N180 G01 X11.432 Y38.254
N181 G01 X11.424 Y38.344
N182 G01 X11.423 Y38.389
N183 G01 X11.441 Y38.43
N184 G01 X11.476 Y38.459
N185 G01 X12.179 Y38.626
N186 G01 X12.901 Y38.615
N187 G01 X13.622 Y38.616
N188 G01 X15.066 Y38.625
N189 G01 X15.788 Y38.631
N190 G01 X17.954 Y38.635
N191 G01 X38.17
N192 G01 X38.26 Y38.622
N193 G01 X38.304 Y38.617
N194 G01 X38.343 Y38.593
N195 G01 X38.39 Y38.516
N196 G01 X38.589 Y37.822
N197 G01 X38.603 Y37.1
N198 G01 X38.613 Y36.378
N199 G01 X38.631 Y35.656
N200 G01 X38.63 Y34.934
N201 G01 X38.634 Y32.768
N202 G01 X38.635 Y28.436
N203 G01 Y26.27
N204 G01 Y11.83
N205 G01 X38.621 Y11.741
N206 G01 X38.617 Y11.696
N207 G01 X38.593 Y11.658
N208 G01 X38.439 Y11.563
N209 G01 X37.735 Y11.404
N210 G01 X37.013 Y11.389
N211 G01 X36.293 Y11.338
N212 G01 X35.571 Y11.355
N213 G01 X34.849 Y11.362
N214 G01 X34.127 Y11.365
N215 G01 X32.683 Y11.366
N216 G01 X13.911 Y11.365
N217 G01 X13.19 Y11.373
N218 G01 X12.699 Y11.477
N219 G01 X12.611 Y11.459
N220 G01 X12.567 Y11.45
N221 G01 X12.523 Y11.46
N222 G01 X12.245 Y11.691
N223 G01 X12.056 Y11.946
N224 G01 X11.978 Y11.991
N225 G01 X11.938 Y12.012
N226 G01 X11.912 Y12.049
N227 G01 X11.904 Y12.093
N228 G01 X11.978 Y12.408
N229 G01 X12.043 Y12.737
N230 G01 X12.112 Y13.166
N231 G01 X12.171 Y13.641
N232 G01 X12.23 Y14.303
N233 G01 X12.268 Y15.024
N234 G01 X12.29 Y15.745
N235 G01 X12.301 Y16.467
N236 G01 X12.308 Y17.189
N237 G01 X12.311 Y17.911
N238 G01 X12.314 Y19.355
N239 G01 X12.315 Y20.799
N240 G01 Y37.405
N241 G01 X12.343 Y37.583
N242 G01 X12.368 Y37.67
N243 G01 X12.387 Y37.758
N244 G01 X12.393 Y37.803
N245 G01 X12.418 Y37.841
N246 G01 X12.457 Y37.863
N247 G01 X13.178 Y37.91
N248 G01 X13.42 Y37.866
N249 G01 X13.727 Y37.822
N250 G01 X14.13 Y37.779
N251 G01 X14.745 Y37.734
N252 G01 X15.466 Y37.707
N253 G01 X16.188 Y37.694
N254 G01 X16.91 Y37.689
N255 G01 X17.632 Y37.687
N256 G01 X19.798 Y37.685
N257 G01 X37.803
N258 G01 X37.843 Y37.665
N259 G01 X37.871 Y37.63
N260 G01 X37.88 Y37.585
N261 G01 X37.702 Y36.886
N262 G01 X37.691 Y36.164
N263 G01 X37.686 Y35.442
N264 G01 X37.684 Y34.72
N265 G01 Y33.276
N266 G01 X37.685 Y29.666
N267 G01 Y12.203
N268 G01 X37.665 Y12.162
N269 G01 X37.63 Y12.134
N270 G01 X37.585 Y12.125
N271 G01 X36.886 Y12.304
N272 G01 X36.164 Y12.305
N273 G01 X35.442 Y12.274
N274 G01 X34.721 Y12.295
N275 G01 X33.999 Y12.306
N276 G01 X33.277 Y12.311
N277 G01 X32.555 Y12.313
N278 G01 X31.111 Y12.315
N279 G01 X13.783
N280 G01 X13.061 Y12.328
N281 G01 X13.019 Y12.344
N282 G01 X12.976 Y12.36
N283 G01 X12.943 Y12.389
N284 G01 X12.911 Y12.422
N285 G01 X12.896 Y12.464
N286 G01 X12.991 Y13.18
N287 G01 X13.064 Y13.668
N288 G01 X13.129 Y14.238
N289 G01 X13.185 Y14.958
N290 G01 X13.219 Y15.679
N291 G01 X13.238 Y16.401
N292 G01 X13.25 Y17.123
N293 G01 X13.257 Y17.845
N294 G01 X13.26 Y18.567
N295 G01 X13.264 Y20.011
N296 G01 Y20.733
N297 G01 X13.265 Y31.563
N298 G01 Y37.158
N299 G01 X13.266 Y37.203
N300 G01 X13.286 Y37.244
N301 G01 X13.322 Y37.271
N302 G01 X13.366 Y37.28
N303 G01 X14.064 Y37.093
N304 G01 X14.258 Y37.043
N305 G01 X14.479 Y36.994
N306 G01 X14.755 Y36.944
N307 G01 X15.094 Y36.894
N308 G01 X15.549 Y36.843
N309 G01 X16.207 Y36.793
N310 G01 X16.929 Y36.764
N311 G01 X17.651 Y36.749
N312 G01 X18.373 Y36.742
N313 G01 X19.095 Y36.738
N314 G01 X20.539 Y36.736
N315 G01 X28.48 Y36.735
N316 G01 X37.054
N317 G01 X37.095 Y36.715
N318 G01 X37.122 Y36.68
N319 G01 X37.132 Y36.635
N320 G01 X36.953 Y35.936
N321 G01 X36.907 Y35.656
N322 G01 X36.86 Y35.292
N323 G01 X36.813 Y34.783
N324 G01 X36.771 Y34.062
N325 G01 X36.752 Y33.34
N326 G01 X36.743 Y32.618
N327 G01 X36.739 Y31.896
N328 G01 X36.737 Y31.174
N329 G01 X36.735 Y29.008
N330 G01 Y26.842
N331 G01 Y12.944
N332 G01 X36.715 Y12.903
N333 G01 X36.68 Y12.876
N334 G01 X36.635 Y12.866
N335 G01 X35.936 Y13.045
N336 G01 X35.593 Y13.097
N337 G01 X35.136 Y13.149
N338 G01 X34.478 Y13.201
N339 G01 X33.757 Y13.233
N340 G01 X33.035 Y13.249
N341 G01 X32.313 Y13.257
N342 G01 X31.591 Y13.261
N343 G01 X30.869 Y13.263
N344 G01 X28.703 Y13.265
N345 G01 X13.812
N346 G01 X13.631 Y13.268
N347 G01 X13.591 Y13.289
N348 G01 X13.564 Y13.325
N349 G01 X13.556 Y13.369
N350 G01 X13.746 Y14.066
N351 G01 X13.797 Y14.221
N352 G01 X13.849 Y14.406
N353 G01 X13.899 Y14.609
N354 G01 X13.952 Y14.858
N355 G01 X14.005 Y15.168
N356 G01 X14.059 Y15.556
N357 G01 X14.113 Y16.089
N358 G01 X14.16 Y16.809
N359 G01 X14.185 Y17.531
N360 G01 X14.199 Y18.252
N361 G01 X14.206 Y18.974
N362 G01 X14.21 Y19.696
N363 G01 X14.214 Y21.14
N364 G01 X14.215 Y24.75
N365 G01 Y26.194
N366 G01 Y36.483
N367 G03 X14.188 Y36.597 I-0.3 J-0.01
N368 G01 X14.16 Y36.657 Z4.982
N369 G01 X14.134 Y36.715 Z4.96
N370 G01 X14.111 Y36.767 Z4.925
N371 G01 X14.091 Y36.81 Z4.877
N372 G01 X14.076 Y36.843 Z4.82
N373 G01 X14.067 Y36.863 Z4.757
N374 G01 X14.064 Y36.87 Z4.69
N375 G00 Z-3.01
N376 G00 X13.464 Y13.548
N377 G00 Z4.39
N378 G01 Z4.69 F1500
N379 G01 X13.457 Y13.55 Z4.757
N380 G01 X13.436 Y13.557 Z4.82
N381 G01 X13.401 Y13.567 Z4.877
N382 G01 X13.356 Y13.581 Z4.925
N383 G01 X13.301 Y13.597 Z4.96
N384 G01 X13.241 Y13.615 Z4.982
N385 G01 X13.177 Y13.635 Z4.99
N386 G01 X13.064 Y13.668
N387 G01 X13.813 Y13.556
N388 G01 X13.98 Y13.473
N389 G01 X14.189 Y13.462
N390 G01 X14.41 Y13.543
N391 G01 X14.617 Y13.74
N392 G01 X14.72 Y14.149
N393 G01 X14.809 Y14.568
N394 G01 X14.891 Y15.026
N395 G01 X14.97 Y15.585
N396 G01 X15.04 Y16.239
N397 G01 X15.091 Y16.959
N398 G01 X15.121 Y17.68
N399 G01 X15.14 Y18.402
N400 G01 X15.15 Y19.124
N401 G01 X15.157 Y19.846
N402 G01 X15.16 Y20.568
N403 G01 X15.164 Y22.012
N404 G01 X15.165 Y25.622
N405 G01 Y36.271
N406 G01 X15.185 Y36.312
N407 G01 X15.22 Y36.34
N408 G01 X15.265 Y36.349
N409 G01 X15.964 Y36.17
N410 G01 X16.127 Y36.124
N411 G01 X16.322 Y36.076
N412 G01 X16.55 Y36.028
N413 G01 X16.831 Y35.979
N414 G01 X17.192 Y35.929
N415 G01 X17.684 Y35.879
N416 G01 X18.404 Y35.832
N417 G01 X19.126 Y35.808
N418 G01 X19.847 Y35.797
N419 G01 X20.569 Y35.791
N420 G01 X21.291 Y35.788
N421 G01 X22.735 Y35.786
N422 G01 X34.287 Y35.785
N423 G01 X36.363
N424 G01 X36.453 Y35.788
N425 G03 X36.481 Y35.79 I-0.01 J0.3
N426 G03 X36.404 Y36.386 I-0.038 J0.298
N427 G03 X36.165 Y35.973 I0.038 J-0.298
N428 G01 X36.623 Y34.866
N429 G03 X37.177 Y35.096 I0.277 J0.115
N430 G03 X36.949 Y35.277 I-0.277 J-0.115
N431 G01 X36.86 Y35.292
N432 G01 X36.831 Y35.295
N433 G01 X36.55 Y35.42
N434 G01 X36.349 Y35.422
N435 G01 X36.144 Y35.335
N436 G01 X36.094 Y35.135
N437 G01 X36.042 Y34.89
N438 G01 X35.988 Y34.587
N439 G01 X35.937 Y34.218
N440 G01 X35.885 Y33.715
N441 G01 X35.836 Y32.995
N442 G01 X35.811 Y32.273
N443 G01 X35.798 Y31.551
N444 G01 X35.792 Y30.829
N445 G01 X35.788 Y30.107
N446 G01 X35.786 Y28.663
N447 G01 X35.785 Y21.443
N448 G01 Y13.682
N449 G01 X35.765 Y13.641
N450 G01 X35.73 Y13.614
N451 G01 X35.685 Y13.605
N452 G01 X34.986 Y13.783
N453 G01 X34.842 Y13.829
N454 G01 X34.674 Y13.876
N455 G01 X34.472 Y13.925
N456 G01 X34.231 Y13.975
N457 G01 X33.939 Y14.024
N458 G01 X33.558 Y14.075
N459 G01 X33.038 Y14.125
N460 G01 X32.317 Y14.17
N461 G01 X31.596 Y14.192
N462 G01 X30.874 Y14.203
N463 G01 X30.152 Y14.209
N464 G01 X29.43 Y14.212
N465 G01 X27.986 Y14.214
N466 G01 X17.156 Y14.215
N467 G01 X15.306
N468 G01 X15.282 Y14.214
N469 G03 X15.287 Y14.054 I0.003 J-0.08
N470 G03 X15.343 Y14.189 I-0.003 J0.08
N471 G01 X14.864 Y14.705
N472 G03 X14.747 Y14.597 I-0.059 J-0.054
N473 G03 X14.786 Y14.573 I0.059 J0.054
N474 G01 X14.809 Y14.568
N475 G01 X14.964 Y14.534
N476 G01 X15.125 Y14.451
N477 G01 X15.327 Y14.437
N478 G01 X15.537 Y14.512
N479 G01 X15.726 Y14.687
N480 G01 X15.812 Y15.154
N481 G01 X15.895 Y15.722
N482 G01 X15.97 Y16.398
N483 G01 X16.025 Y17.118
N484 G01 X16.059 Y17.839
N485 G01 X16.081 Y18.561
N486 G01 X16.095 Y19.283
N487 G01 X16.103 Y20.005
N488 G01 X16.108 Y20.727
N489 G01 X16.111 Y21.449
N490 G01 X16.114 Y22.893
N491 G01 X16.115 Y27.225
N492 G01 Y35.528
N493 G01 X16.112 Y35.618
N494 G03 X15.512 Y35.597 I-0.3 J-0.01
N495 G03 X15.927 Y35.33 I0.3 J0.01
N496 G01 X16.978 Y35.766
N497 G03 X16.748 Y36.32 I-0.115 J0.277
N498 G03 X16.579 Y36.142 I0.115 J-0.277
N499 G03 X16.571 Y36.115 I0.283 J-0.099
N500 G01 X16.55 Y36.028
N501 G01 X16.544 Y36.
N502 G01 X16.399 Y35.729
N503 G01 X16.382 Y35.531
N504 G01 X16.453 Y35.321
N505 G01 X16.631 Y35.265
N506 G01 X16.848 Y35.206
N507 G01 X17.11 Y35.144
N508 G01 X17.386 Y35.089
N509 G01 X17.745 Y35.031
N510 G01 X18.177 Y34.976
N511 G01 X18.784 Y34.921
N512 G01 X19.505 Y34.881
N513 G01 X20.227 Y34.859
N514 G01 X20.949 Y34.848
N515 G01 X21.671 Y34.842
N516 G01 X22.393 Y34.839
N517 G01 X23.837 Y34.836
N518 G01 X29.613 Y34.835
N519 G01 X35.479
N520 G01 X35.503 Y34.836
N521 G03 X35.497 Y34.996 I-0.003 J0.08
N522 G03 X35.449 Y34.854 I0.003 J-0.08
N523 G01 X35.944 Y34.442
N524 G03 X36.047 Y34.565 I0.051 J0.062
N525 G03 X36.012 Y34.582 I-0.051 J-0.062
N526 G01 X35.988 Y34.587
N527 G01 X35.791 Y34.622
N528 G01 X35.616 Y34.682
N529 G01 X35.411 Y34.666
N530 G01 X35.207 Y34.558
N531 G01 X35.145 Y34.288
N532 G01 X35.089 Y34.004
N533 G01 X35.029 Y33.631
N534 G01 X34.974 Y33.185
N535 G01 X34.918 Y32.552
N536 G01 X34.88 Y31.831
N537 G01 X34.859 Y31.109
N538 G01 X34.848 Y30.387
N539 G01 X34.842 Y29.665
N540 G01 X34.839 Y28.943
N541 G01 X34.836 Y27.499
N542 G01 X34.835 Y21.723
N543 G01 Y14.413
N544 G01 X34.838 Y14.323
N545 G03 X34.84 Y14.295 I0.3 J0.01
N546 G03 X35.436 Y14.372 I0.298 J0.038
N547 G03 X35.05 Y14.62 I-0.298 J-0.038
N548 G01 X33.83 Y14.245
N549 G03 X34.007 Y13.671 I0.088 J-0.287
N550 G03 X34.202 Y13.86 I-0.088 J0.287
N551 G03 X34.21 Y13.887 I-0.284 J0.097
N552 G01 X34.231 Y13.975
N553 G01 X34.237 Y14.003
N554 G01 X34.381 Y14.274
N555 G01 X34.397 Y14.473
N556 G01 X34.325 Y14.682
N557 G01 X34.148 Y14.737
N558 G01 X33.934 Y14.795
N559 G01 X33.669 Y14.858
N560 G01 X33.389 Y14.913
N561 G01 X33.029 Y14.971
N562 G01 X32.586 Y15.026
N563 G01 X31.964 Y15.081
N564 G01 X31.243 Y15.12
N565 G01 X30.522 Y15.141
N566 G01 X29.8 Y15.152
N567 G01 X29.078 Y15.158
N568 G01 X28.356 Y15.161
N569 G01 X26.912 Y15.164
N570 G01 X21.136 Y15.165
N571 G01 X16.443
N572 G01 X16.402 Y15.185
N573 G01 X16.375 Y15.22
N574 G01 X16.365 Y15.265
N575 G01 X16.544 Y15.964
N576 G01 X16.594 Y16.106
N577 G01 X16.645 Y16.27
N578 G01 X16.699 Y16.468
N579 G01 X16.752 Y16.693
N580 G01 X16.806 Y16.965
N581 G01 X16.862 Y17.31
N582 G01 X16.918 Y17.75
N583 G01 X16.974 Y18.37
N584 G01 X17.014 Y19.091
N585 G01 X17.036 Y19.813
N586 G01 X17.048 Y20.535
N587 G01 X17.055 Y21.257
N588 G01 X17.059 Y21.979
N589 G01 X17.063 Y23.423
N590 G01 X17.065 Y26.311
N591 G01 Y34.614
N592 G01 X17.062 Y34.704
N593 G03 X16.462 Y34.683 I-0.3 J-0.01
N594 G03 X16.884 Y34.419 I0.3 J0.01
N595 G01 X17.82 Y34.834
N596 G03 X17.577 Y35.382 I-0.122 J0.274
N597 G03 X17.406 Y35.177 I0.122 J-0.274
N598 G01 X17.386 Y35.089
N599 G01 X17.355 Y34.935
N600 G01 X17.274 Y34.774
N601 G01 X17.263 Y34.574
N602 G01 X17.339 Y34.366
N603 G01 X17.517 Y34.179
N604 G01 X17.976 Y34.106
N605 G01 X18.529 Y34.038
N606 G01 X19.248 Y33.976
N607 G01 X19.969 Y33.938
N608 G01 X20.691 Y33.915
N609 G01 X21.413 Y33.902
N610 G01 X22.135 Y33.895
N611 G01 X22.857 Y33.89
N612 G01 X23.579 Y33.888
N613 G01 X25.023 Y33.886
N614 G01 X32.964 Y33.885
N615 G01 X34.499
N616 G01 X34.523 Y33.886
N617 G03 X34.517 Y34.046 I-0.003 J0.08
N618 G03 X34.47 Y33.904 I0.003 J-0.08
N619 G01 X34.987 Y33.485
N620 G03 X35.087 Y33.61 I0.05 J0.062
N621 G03 X35.053 Y33.626 I-0.05 J-0.062
N622 G01 X35.029 Y33.631
N623 G01 X34.873 Y33.656
N624 G01 X34.707 Y33.73
N625 G01 X34.506 Y33.734
N626 G01 X34.3 Y33.649
N627 G01 X34.12 Y33.464
N628 G01 X34.052 Y32.936
N629 G01 X33.987 Y32.256
N630 G01 X33.944 Y31.535
N631 G01 X33.919 Y30.814
N632 G01 X33.904 Y30.092
N633 G01 X33.896 Y29.37
N634 G01 X33.891 Y28.648
N635 G01 X33.888 Y27.926
N636 G01 X33.886 Y26.482
N637 G01 X33.885 Y20.706
N638 G01 Y15.381
N639 G01 X33.886 Y15.357
N640 G03 X34.046 Y15.363 I0.08 J0.003
N641 G03 X33.921 Y15.426 I-0.08 J-0.003
N642 G01 X33.261 Y14.973
N643 G03 X33.351 Y14.841 I0.045 J-0.066
N644 G03 X33.384 Y14.889 I-0.045 J0.066
N645 G01 X33.389 Y14.913
N646 G01 X33.395 Y14.941
N647 G01 X33.538 Y15.214
N648 G01 X33.553 Y15.413
N649 G01 X33.48 Y15.622
N650 G01 X33.274 Y15.685
N651 G01 X33.065 Y15.741
N652 G01 X32.806 Y15.801
N653 G01 X32.492 Y15.862
N654 G01 X32.128 Y15.919
N655 G01 X31.649 Y15.977
N656 G01 X30.985 Y16.034
N657 G01 X30.264 Y16.071
N658 G01 X29.542 Y16.091
N659 G01 X28.82 Y16.102
N660 G01 X28.098 Y16.108
N661 G01 X27.376 Y16.111
N662 G01 X25.932 Y16.114
N663 G01 X20.878 Y16.115
N664 G01 X17.178
N665 G01 X17.088 Y16.112
N666 G03 X17.109 Y15.512 I0.01 J-0.3
N667 G03 X17.386 Y15.897 I-0.01 J0.3
N668 G01 X17.032 Y17.092
N669 G03 X16.457 Y16.921 I-0.288 J-0.085
N670 G03 X16.639 Y16.725 I0.288 J0.085
N671 G03 X16.665 Y16.717 I0.105 J0.281
N672 G01 X16.752 Y16.693
N673 G01 X16.78 Y16.687
N674 G01 X17.046 Y16.535
N675 G01 X17.245 Y16.514
N676 G01 X17.456 Y16.579
N677 G01 X17.517 Y16.759
N678 G01 X17.581 Y16.978
N679 G01 X17.642 Y17.211
N680 G01 X17.703 Y17.487
N681 G01 X17.766 Y17.829
N682 G01 X17.826 Y18.228
N683 G01 X17.885 Y18.757
N684 G01 X17.941 Y19.477
N685 G01 X17.972 Y20.198
N686 G01 X17.991 Y20.92
N687 G01 X18.001 Y21.642
N688 G01 X18.007 Y22.364
N689 G01 X18.01 Y23.086
N690 G01 X18.013 Y24.53
N691 G01 X18.015 Y28.14
N692 G01 Y33.465
N693 G01 X18.035 Y33.505
N694 G01 X18.07 Y33.533
N695 G01 X18.115 Y33.542
N696 G01 X18.814 Y33.364
N697 G01 X18.975 Y33.315
N698 G01 X19.167 Y33.265
N699 G01 X19.4 Y33.213
N700 G01 X19.67 Y33.162
N701 G01 X20.021 Y33.109
N702 G01 X20.475 Y33.057
N703 G01 X21.144 Y33.004
N704 G01 X21.866 Y32.972
N705 G01 X22.587 Y32.955
N706 G01 X23.309 Y32.946
N707 G01 X24.031 Y32.941
N708 G01 X24.753 Y32.938
N709 G01 X26.197 Y32.936
N710 G01 X33.417 Y32.935
N711 G01 X33.458 Y32.915
N712 G01 X33.485 Y32.88
N713 G01 X33.495 Y32.835
N714 G01 X33.316 Y32.136
N715 G01 X33.268 Y31.956
N716 G01 X33.219 Y31.744
N717 G01 X33.168 Y31.483
N718 G01 X33.117 Y31.162
N719 G01 X33.065 Y30.736
N720 G01 X33.013 Y30.138
N721 G01 X32.976 Y29.417
N722 G01 X32.957 Y28.695
N723 G01 X32.946 Y27.973
N724 G01 X32.941 Y27.251
N725 G01 X32.938 Y26.529
N726 G01 X32.936 Y25.085
N727 G01 X32.935 Y18.587
N728 G01 Y16.331
N729 G01 X32.936 Y16.307
N730 G03 X33.096 Y16.313 I0.08 J0.003
N731 G03 X32.968 Y16.374 I-0.08 J-0.003
N732 G01 X32.361 Y15.921
N733 G03 X32.457 Y15.792 I0.048 J-0.064
N734 G03 X32.487 Y15.839 I-0.048 J0.064
N735 G01 X32.492 Y15.862
N736 G01 X32.498 Y15.89
N737 G01 X32.64 Y16.164
N738 G01 X32.654 Y16.363
N739 G01 X32.58 Y16.572
N740 G01 X32.375 Y16.634
N741 G01 X32.154 Y16.693
N742 G01 X31.897 Y16.752
N743 G01 X31.574 Y16.814
N744 G01 X31.206 Y16.871
N745 G01 X30.712 Y16.929
N746 G01 X30.024 Y16.987
N747 G01 X29.302 Y17.021
N748 G01 X28.581 Y17.041
N749 G01 X27.859 Y17.052
N750 G01 X27.137 Y17.058
N751 G01 X26.415 Y17.061
N752 G01 X24.971 Y17.064
N753 G01 X20.639 Y17.065
N754 G01 X18.202
N755 G01 X18.112 Y17.062
N756 G03 X18.133 Y16.462 I0.01 J-0.3
N757 G03 X18.4 Y16.877 I-0.01 J0.3
N758 G01 X17.968 Y17.915
N759 G03 X17.414 Y17.685 I-0.277 J-0.115
N760 G03 X17.616 Y17.51 I0.277 J0.115
N761 G01 X17.703 Y17.487
N762 G01 X17.835 Y17.458
N763 G01 X17.986 Y17.366
N764 G01 X18.181 Y17.338
N765 G01 X18.392 Y17.396
N766 G01 X18.587 Y17.553
N767 G01 X18.665 Y17.953
N768 G01 X18.737 Y18.404
N769 G01 X18.807 Y18.971
N770 G01 X18.869 Y19.691
N771 G01 X18.908 Y20.412
N772 G01 X18.931 Y21.133
N773 G01 X18.945 Y21.855
N774 G01 X18.953 Y22.577
N775 G01 X18.958 Y23.299
N776 G01 X18.961 Y24.021
N777 G01 X18.964 Y25.465
N778 G01 X18.965 Y29.797
N779 G01 Y32.775
N780 G01 X18.964 Y32.799
N781 G03 X18.804 Y32.794 I-0.08 J-0.003
N782 G03 X18.93 Y32.731 I0.08 J0.003
N783 G01 X19.529 Y33.151
N784 G03 X19.437 Y33.282 I-0.046 J0.066
N785 G03 X19.406 Y33.236 I0.046 J-0.066
N786 G01 X19.4 Y33.213
N787 G01 X19.393 Y33.185
N788 G01 X19.245 Y32.917
N789 G01 X19.225 Y32.719
N790 G01 X19.293 Y32.508
N791 G01 X19.462 Y32.316
N792 G01 X19.898 Y32.239
N793 G01 X20.391 Y32.169
N794 G01 X21.003 Y32.105
N795 G01 X21.723 Y32.055
N796 G01 X22.444 Y32.025
N797 G01 X23.166 Y32.008
N798 G01 X23.888 Y31.998
N799 G01 X24.61 Y31.992
N800 G01 X25.332 Y31.989
N801 G01 X26.776 Y31.986
N802 G01 X31.108 Y31.985
N803 G01 X32.732
N804 G01 X32.822 Y31.988
N805 G03 X32.802 Y32.588 I-0.01 J0.3
N806 G03 X32.528 Y32.192 I0.01 J-0.3
N807 G01 X32.903 Y31.075
N808 G03 X33.472 Y31.266 I0.284 J0.096
N809 G03 X33.282 Y31.455 I-0.284 J-0.096
N810 G03 X33.255 Y31.462 I-0.094 J-0.285
N811 G01 X33.168 Y31.483
N812 G01 X33.14 Y31.488
N813 G01 X32.866 Y31.63
N814 G01 X32.667 Y31.644
N815 G01 X32.459 Y31.57
N816 G01 X32.399 Y31.374
N817 G01 X32.344 Y31.163
N818 G01 X32.285 Y30.901
N819 G01 X32.227 Y30.594
N820 G01 X32.17 Y30.223
N821 G01 X32.114 Y29.741
N822 G01 X32.058 Y29.055
N823 G01 X32.025 Y28.334
N824 G01 X32.007 Y27.612
N825 G01 X31.997 Y26.891
N826 G01 X31.991 Y26.169
N827 G01 X31.988 Y25.447
N828 G01 X31.986 Y24.003
N829 G01 X31.985 Y18.949
N830 G01 Y17.324
N831 G01 X31.986 Y17.3
N832 G03 X32.146 Y17.306 I0.08 J0.003
N833 G03 X32.014 Y17.364 I-0.08 J-0.003
N834 G01 X31.438 Y16.869
N835 G03 X31.543 Y16.747 I0.052 J-0.061
N836 G03 X31.568 Y16.79 I-0.052 J0.061
N837 G01 X31.574 Y16.814
N838 G01 X31.599 Y16.947
N839 G01 X31.687 Y17.101
N840 G01 X31.709 Y17.297
N841 G01 X31.645 Y17.506
N842 G01 X31.456 Y17.566
N843 G01 X31.244 Y17.626
N844 G01 X31.012 Y17.682
N845 G01 X30.719 Y17.742
N846 G01 X30.38 Y17.799
N847 G01 X29.935 Y17.858
N848 G01 X29.353 Y17.915
N849 G01 X28.632 Y17.959
N850 G01 X27.911 Y17.984
N851 G01 X27.189 Y17.998
N852 G01 X26.467 Y18.005
N853 G01 X25.745 Y18.01
N854 G01 X25.023 Y18.012
N855 G01 X23.579 Y18.014
N856 G01 X20.691 Y18.015
N857 G01 X19.337
N858 G01 X19.247
N859 G01 X19.157 Y18.012
N860 G03 X19.178 Y17.412 I0.01 J-0.3
N861 G03 X19.44 Y17.837 I-0.01 J0.3
N862 G01 X18.979 Y18.841
N863 G03 X18.433 Y18.591 I-0.273 J-0.125
N864 G03 X18.649 Y18.421 I0.273 J0.125
N865 G01 X18.737 Y18.404
N866 G01 X18.872 Y18.383
N867 G01 X19.03 Y18.3
N868 G01 X19.228 Y18.285
N869 G01 X19.437 Y18.357
N870 G01 X19.493 Y18.544
N871 G01 X19.549 Y18.762
N872 G01 X19.609 Y19.034
N873 G01 X19.666 Y19.342
N874 G01 X19.727 Y19.746
N875 G01 X19.784 Y20.257
N876 G01 X19.84 Y20.977
N877 G01 X19.872 Y21.699
N878 G01 X19.89 Y22.42
N879 G01 X19.9 Y23.142
N880 G01 X19.906 Y23.864
N881 G01 X19.91 Y24.586
N882 G01 X19.913 Y26.03
N883 G01 X19.915 Y29.64
N884 G01 Y31.671
N885 G01 X19.912 Y31.761
N886 G03 X19.91 Y31.788 I-0.3 J-0.01
N887 G03 X19.314 Y31.712 I-0.298 J-0.038
N888 G03 X19.728 Y31.473 I0.298 J0.038
N889 G01 X20.818 Y31.929
N890 G03 X20.586 Y32.482 I-0.116 J0.277
N891 G03 X20.407 Y32.258 I0.116 J-0.277
N892 G01 X20.391 Y32.169
N893 G01 X20.387 Y32.141
N894 G01 X20.259 Y31.861
N895 G01 X20.255 Y31.66
N896 G01 X20.339 Y31.453
N897 G01 X20.549 Y31.398
N898 G01 X20.792 Y31.342
N899 G01 X21.1 Y31.283
N900 G01 X21.458 Y31.228
N901 G01 X21.943 Y31.17
N902 G01 X22.626 Y31.113
N903 G01 X23.347 Y31.079
N904 G01 X24.069 Y31.06
N905 G01 X24.791 Y31.049
N906 G01 X25.513 Y31.043
N907 G01 X26.235 Y31.039
N908 G01 X27.679 Y31.036
N909 G01 X30.567 Y31.035
N910 G01 X31.74
N911 G01 X31.83 Y31.038
N912 G03 X31.809 Y31.638 I-0.01 J0.3
N913 G03 X31.541 Y31.225 I0.01 J-0.3
N914 G01 X31.97 Y30.169
N915 G03 X32.526 Y30.395 I0.278 J0.113
N916 G03 X32.314 Y30.574 I-0.278 J-0.113
N917 G01 X32.227 Y30.594
N918 G01 X32.198 Y30.599
N919 G01 X31.924 Y30.74
N920 G01 X31.724 Y30.754
N921 G01 X31.516 Y30.679
N922 G01 X31.454 Y30.474
N923 G01 X31.395 Y30.248
N924 G01 X31.338 Y29.992
N925 G01 X31.277 Y29.665
N926 G01 X31.221 Y29.292
N927 G01 X31.163 Y28.787
N928 G01 X31.106 Y28.073
N929 G01 X31.074 Y27.351
N930 G01 X31.057 Y26.63
N931 G01 X31.047 Y25.908
N932 G01 X31.042 Y25.186
N933 G01 X31.039 Y24.464
N934 G01 X31.036 Y23.02
N935 G01 X31.035 Y18.237
N936 G01 X31.036 Y18.213
N937 G03 X31.196 Y18.218 I0.08 J0.003
N938 G03 X31.059 Y18.272 I-0.08 J-0.003
N939 G01 X30.579 Y17.794
N940 G03 X30.692 Y17.681 I0.056 J-0.057
N941 G03 X30.713 Y17.719 I-0.056 J0.057
N942 G01 X30.719 Y17.742
N943 G01 X30.75 Y17.896
N944 G01 X30.832 Y18.056
N945 G01 X30.844 Y18.255
N946 G01 X30.769 Y18.465
N947 G01 X30.593 Y18.652
N948 G01 X30.128 Y18.728
N949 G01 X29.588 Y18.797
N950 G01 X28.869 Y18.864
N951 G01 X28.148 Y18.905
N952 G01 X27.427 Y18.929
N953 G01 X26.705 Y18.944
N954 G01 X25.983 Y18.953
N955 G01 X25.261 Y18.958
N956 G01 X24.539 Y18.961
N957 G01 X23.095 Y18.964
N958 G01 X21.651 Y18.966
N959 G01 X20.929 Y18.963
N960 G01 X20.749 Y18.965
N961 G01 X20.162
N962 G01 X20.072 Y18.961
N963 G03 X20.094 Y18.362 I0.011 J-0.3
N964 G03 X20.357 Y18.783 I-0.011 J0.3
N965 G01 X19.918 Y19.776
N966 G03 X19.369 Y19.533 I-0.274 J-0.121
N967 G03 X19.579 Y19.361 I0.274 J0.121
N968 G01 X19.666 Y19.342
N969 G01 X19.8 Y19.317
N970 G01 X19.956 Y19.23
N971 G01 X20.153 Y19.21
N972 G01 X20.361 Y19.276
N973 G01 X20.551 Y19.44
N974 G01 X20.621 Y19.86
N975 G01 X20.691 Y20.383
N976 G01 X20.755 Y21.052
N977 G01 X20.8 Y21.773
N978 G01 X20.826 Y22.495
N979 G01 X20.842 Y23.216
N980 G01 X20.851 Y23.938
N981 G01 X20.857 Y24.66
N982 G01 X20.86 Y25.382
N983 G01 X20.863 Y26.826
N984 G01 X20.865 Y29.714
N985 G01 Y30.752
N986 G01 X20.862 Y30.842
N987 G03 X20.859 Y30.87 I-0.3 J-0.011
N988 G03 X20.264 Y30.793 I-0.298 J-0.038
N989 G03 X20.708 Y30.569 I0.298 J0.038
N990 G01 X21.558 Y31.042
N991 G03 X21.267 Y31.567 I-0.146 J0.262
N992 G03 X21.12 Y31.371 I0.146 J-0.262
N993 G01 X21.1 Y31.283
N994 G01 X21.062 Y31.087
N995 G01 X21. Y30.912
N996 G01 X21.013 Y30.707
N997 G01 X21.118 Y30.502
N998 G01 X21.33 Y30.328
N999 G01 X21.96 Y30.25
N1000 G01 X22.679 Y30.186
N1001 G01 X23.4 Y30.146
N1002 G01 X24.122 Y30.122
N1003 G01 X24.844 Y30.107
N1004 G01 X25.565 Y30.098
N1005 G01 X26.287 Y30.092
N1006 G01 X27.009 Y30.089
N1007 G01 X28.453 Y30.086
N1008 G01 X29.175 Y30.084
N1009 G01 X29.897 Y30.089
N1010 G01 X30.258 Y30.083
N1011 G01 X30.71 Y30.086
N1012 G01 X30.8 Y30.085
N1013 G01 X30.824 Y30.086
N1014 G03 X30.819 Y30.246 I-0.003 J0.08
N1015 G03 X30.758 Y30.117 I0.003 J-0.08
N1016 G01 X31.22 Y29.532
N1017 G03 X31.346 Y29.631 I0.063 J0.05
N1018 G03 X31.3 Y29.66 I-0.063 J-0.05
N1019 G01 X31.277 Y29.665
N1020 G01 X31.249 Y29.67
N1021 G01 X30.974 Y29.811
N1022 G01 X30.774 Y29.823
N1023 G01 X30.566 Y29.748
N1024 G01 X30.505 Y29.544
N1025 G01 X30.444 Y29.31
N1026 G01 X30.387 Y29.054
N1027 G01 X30.327 Y28.726
N1028 G01 X30.27 Y28.348
N1029 G01 X30.212 Y27.834
N1030 G01 X30.155 Y27.114
N1031 G01 X30.124 Y26.393
N1032 G01 X30.107 Y25.671
N1033 G01 X30.097 Y24.949
N1034 G01 X30.092 Y24.227
N1035 G01 X30.089 Y23.505
N1036 G01 X30.086 Y22.061
N1037 G01 X30.084 Y20.617
N1038 G01 X30.087 Y19.896
N1039 G01 X30.085 Y19.535
N1040 G01 Y19.354
N1041 G01 X30.065 Y19.313
N1042 G01 X30.03 Y19.286
N1043 G01 X29.985 Y19.277
N1044 G01 X29.286 Y19.455
N1045 G01 X29.138 Y19.503
N1046 G01 X28.962 Y19.553
N1047 G01 X28.75 Y19.605
N1048 G01 X28.507 Y19.655
N1049 G01 X28.202 Y19.708
N1050 G01 X27.812 Y19.761
N1051 G01 X27.274 Y19.815
N1052 G01 X26.554 Y19.861
N1053 G01 X25.832 Y19.886
N1054 G01 X25.11 Y19.899
N1055 G01 X24.389 Y19.906
N1056 G01 X23.667 Y19.91
N1057 G01 X22.945 Y19.912
N1058 G01 X22.223 Y19.918
N1059 G01 X21.862 Y19.913
N1060 G01 X21.681 Y19.915
N1061 G01 X21.275 Y19.914
N1062 G01 X21.234 Y19.934
N1063 G01 X21.207 Y19.969
N1064 G01 X21.197 Y20.014
N1065 G01 X21.373 Y20.714
N1066 G01 X21.422 Y20.875
N1067 G01 X21.473 Y21.069
N1068 G01 X21.525 Y21.296
N1069 G01 X21.577 Y21.566
N1070 G01 X21.631 Y21.914
N1071 G01 X21.684 Y22.36
N1072 G01 X21.738 Y23.009
N1073 G01 X21.773 Y23.73
N1074 G01 X21.792 Y24.452
N1075 G01 X21.802 Y25.174
N1076 G01 X21.808 Y25.895
N1077 G01 X21.811 Y26.617
N1078 G01 X21.813 Y27.339
N1079 G01 X21.817 Y28.061
N1080 G01 X21.808 Y28.783
N1081 G01 X21.819 Y29.144
N1082 G01 X21.816 Y29.325
N1083 G01 X21.815 Y29.641
N1084 G01 X21.835 Y29.681
N1085 G01 X21.871 Y29.709
N1086 G01 X21.915 Y29.718
N1087 G01 X22.615 Y29.54
N1088 G01 X22.791 Y29.49
N1089 G01 X22.993 Y29.441
N1090 G01 X23.235 Y29.39
N1091 G01 X23.542 Y29.338
N1092 G01 X23.925 Y29.286
N1093 G01 X24.46 Y29.233
N1094 G01 X25.18 Y29.187
N1095 G01 X25.902 Y29.163
N1096 G01 X26.624 Y29.15
N1097 G01 X27.345 Y29.144
N1098 G01 X28.067 Y29.139
N1099 G01 X28.789 Y29.131
N1100 G01 X29.15 Y29.137
N1101 G01 X29.331 Y29.136
N1102 G01 X29.827 Y29.138
N1103 G03 X29.941 Y29.165 I-0.011 J0.3
N1104 G01 X30.002 Y29.192 Z4.982
N1105 G01 X30.06 Y29.219 Z4.96
N1106 G01 X30.111 Y29.242 Z4.925
N1107 G01 X30.154 Y29.262 Z4.877
N1108 G01 X30.187 Y29.277 Z4.82
N1109 G01 X30.207 Y29.286 Z4.757
N1110 G01 X30.214 Y29.289 Z4.69
N1111 G00 Z-3.01
N1112 G00 X21.093 Y20.27
N1113 G00 Z4.39
N1114 G01 Z4.69 F1500
N1115 G01 X21.086 Y20.272 Z4.757
N1116 G01 X21.064 Y20.278 Z4.82
N1117 G01 X21.03 Y20.288 Z4.877
N1118 G01 X20.984 Y20.3 Z4.925
N1119 G01 X20.929 Y20.316 Z4.96
N1120 G01 X20.868 Y20.333 Z4.982
N1121 G01 X20.804 Y20.351 Z4.99
N1122 G01 X20.691 Y20.383
N1123 G01 X21.333 Y20.298
N1124 G01 X21.621 Y20.157
N1125 G01 X21.83 Y20.147
N1126 G01 X22.049 Y20.23
N1127 G01 X22.252 Y20.426
N1128 G01 X22.351 Y20.844
N1129 G01 X22.438 Y21.28
N1130 G01 X22.522 Y21.792
N1131 G01 X22.597 Y22.381
N1132 G01 X22.664 Y23.1
N1133 G01 X22.705 Y23.821
N1134 G01 X22.729 Y24.542
N1135 G01 X22.744 Y25.264
N1136 G01 X22.753 Y25.986
N1137 G01 X22.758 Y26.708
N1138 G01 X22.77 Y27.43
N1139 G01 X22.752 Y28.152
N1140 G01 X22.761 Y28.332
N1141 G01 X22.76 Y28.512
N1142 G01 X22.759 Y28.693
N1143 G01 X22.763 Y28.918
N1144 G03 X22.163 Y28.912 I-0.3 J-0.003
N1145 G03 X22.488 Y28.616 I0.3 J0.003
N1146 G01 X30.51 Y29.272
N1147 G02 X30.559 Y28.674 I0.024 J-0.299
N1148 G02 X30.438 Y28.688 I-0.024 J0.299
N1149 G01 X30.327 Y28.726
N1150 G01 X30.298 Y28.731
N1151 G01 X30.023 Y28.872
N1152 G01 X29.824 Y28.884
N1153 G01 X29.615 Y28.809
N1154 G01 X29.555 Y28.605
N1155 G01 X29.493 Y28.368
N1156 G01 X29.437 Y28.112
N1157 G01 X29.376 Y27.784
N1158 G01 X29.319 Y27.401
N1159 G01 X29.261 Y26.883
N1160 G01 X29.205 Y26.163
N1161 G01 X29.174 Y25.442
N1162 G01 X29.157 Y24.72
N1163 G01 X29.147 Y23.998
N1164 G01 X29.142 Y23.276
N1165 G01 X29.139 Y22.554
N1166 G01 X29.131 Y21.832
N1167 G01 X29.147 Y21.11
N1168 G01 X29.128 Y20.75
N1169 G01 X29.134 Y20.569
N1170 G01 X29.137 Y20.028
N1171 G01 X29.14 Y19.938
N1172 G03 X29.74 Y19.96 I0.3 J0.011
N1173 G03 X29.341 Y20.232 I-0.3 J-0.011
N1174 G01 X28.339 Y19.883
N1175 G03 X28.536 Y19.316 I0.099 J-0.283
N1176 G03 X28.726 Y19.518 I-0.099 J0.283
N1177 G01 X28.75 Y19.605
N1178 G01 X28.783 Y19.735
N1179 G01 X28.877 Y19.884
N1180 G01 X28.908 Y20.079
N1181 G01 X28.853 Y20.291
N1182 G01 X28.699 Y20.489
N1183 G01 X28.35 Y20.56
N1184 G01 X27.895 Y20.636
N1185 G01 X27.4 Y20.7
N1186 G01 X26.729 Y20.763
N1187 G01 X26.008 Y20.806
N1188 G01 X25.287 Y20.831
N1189 G01 X24.567 Y20.889
N1190 G01 X24.212 Y20.821
N1191 G01 X23.687 Y20.901
N1192 G01 X23.512 Y20.855
N1193 G01 X23.332 Y20.859
N1194 G01 X23.061 Y20.862
N1195 G01 X22.926 Y20.863
N1196 G03 X22.811 Y20.837 I0.009 J-0.3
N1197 G01 X22.75 Y20.809 Z4.982
N1198 G01 X22.693 Y20.783 Z4.96
N1199 G01 X22.641 Y20.76 Z4.925
N1200 G01 X22.597 Y20.741 Z4.877
N1201 G01 X22.565 Y20.726 Z4.82
N1202 G01 X22.545 Y20.717 Z4.757
N1203 G01 X22.538 Y20.714 Z4.69
N1204 G00 Z-3.01
N1205 G00 X23.378 Y29.783
N1206 G00 Z4.39
N1207 G01 Z4.69 F1500
N1208 G01 X23.375 Y29.776 Z4.757
N1209 G01 X23.368 Y29.755 Z4.82
N1210 G01 X23.355 Y29.722 Z4.877
N1211 G01 X23.339 Y29.677 Z4.925
N1212 G01 X23.32 Y29.624 Z4.96
N1213 G01 X23.298 Y29.564 Z4.982
N1214 G01 X23.276 Y29.501 Z4.99
N1215 G01 X23.235 Y29.39
N1216 G01 X23.23 Y29.363
N1217 G01 X23.085 Y29.091
N1218 G01 X23.068 Y28.892
N1219 G01 X23.139 Y28.683
N1220 G01 X23.32 Y28.626
N1221 G01 X23.532 Y28.568
N1222 G01 X23.796 Y28.505
N1223 G01 X24.081 Y28.448
N1224 G01 X24.44 Y28.39
N1225 G01 X24.886 Y28.333
N1226 G01 X25.505 Y28.276
N1227 G01 X26.226 Y28.235
N1228 G01 X26.947 Y28.213
N1229 G01 X27.667 Y28.158
N1230 G01 X28.022 Y28.226
N1231 G01 X28.289 Y28.184
N1232 G01 X28.469 Y28.183
N1233 G01 X28.83 Y28.181
N1234 G01 X28.92 Y28.182
N1235 G03 X29.034 Y28.212 I-0.017 J0.3
N1236 G01 X29.094 Y28.241 Z4.982
N1237 G01 X29.151 Y28.268 Z4.96
N1238 G01 X29.202 Y28.293 Z4.925
N1239 G01 X29.245 Y28.313 Z4.877
N1240 G01 X29.277 Y28.329 Z4.82
N1241 G01 X29.297 Y28.338 Z4.757
N1242 G01 X29.304 Y28.342 Z4.69
N1243 G00 Z-3.01
N1244 G00 X22.044 Y21.42
N1245 G00 Z4.39
N1246 G01 Z4.69 F1500
N1247 G01 X22.052 Y21.417 Z4.757
N1248 G01 X22.072 Y21.41 Z4.82
N1249 G01 X22.106 Y21.398 Z4.877
N1250 G01 X22.151 Y21.382 Z4.925
N1251 G01 X22.205 Y21.363 Z4.96
N1252 G01 X22.264 Y21.342 Z4.982
N1253 G01 X22.327 Y21.32 Z4.99
N1254 G01 X22.438 Y21.28
N1255 G01 X22.467 Y21.275
N1256 G01 X22.739 Y21.131
N1257 G01 X22.939 Y21.115
N1258 G01 X23.15 Y21.187
N1259 G01 X23.341 Y21.361
N1260 G01 X23.428 Y21.849
N1261 G01 X23.508 Y22.409
N1262 G01 X23.579 Y23.079
N1263 G01 X23.63 Y23.799
N1264 G01 X23.663 Y24.52
N1265 G01 X23.683 Y25.242
N1266 G01 X23.696 Y25.964
N1267 G01 X23.723 Y26.686
N1268 G01 X23.679 Y27.406
N1269 G01 X23.692 Y27.496
N1270 G01 X23.7 Y27.585
N1271 G01 X23.708 Y27.766
N1272 G01 X23.706 Y27.946
N1273 G03 X23.107 Y27.917 I-0.3 J-0.015
N1274 G03 X23.44 Y27.634 I0.3 J0.015
N1275 G01 X29.55 Y28.329
N1276 G02 X29.618 Y27.732 I0.034 J-0.298
N1277 G02 X29.488 Y27.746 I-0.034 J0.298
N1278 G01 X29.376 Y27.784
N1279 G01 X29.242 Y27.809
N1280 G01 X29.087 Y27.896
N1281 G01 X28.891 Y27.916
N1282 G01 X28.682 Y27.85
N1283 G01 X28.493 Y27.686
N1284 G01 X28.423 Y27.272
N1285 G01 X28.355 Y26.753
N1286 G01 X28.291 Y26.092
N1287 G01 X28.247 Y25.371
N1288 G01 X28.221 Y24.649
N1289 G01 X28.206 Y23.928
N1290 G01 X28.197 Y23.206
N1291 G01 X28.177 Y22.484
N1292 G01 X28.209 Y21.763
N1293 G01 X28.201 Y21.673
N1294 G01 X28.197 Y21.583
N1295 G01 X28.193 Y21.402
N1296 G01 X28.194 Y21.267
N1297 G01 Y21.222
N1298 G01 X28.174 Y21.181
N1299 G01 X28.138 Y21.154
N1300 G01 X28.094 Y21.145
N1301 G01 X27.395 Y21.327
N1302 G01 X27.242 Y21.379
N1303 G01 X27.078 Y21.428
N1304 G01 X26.882 Y21.479
N1305 G01 X26.641 Y21.533
N1306 G01 X25.931 Y21.665
N1307 G01 X25.611 Y21.786
N1308 G01 X24.89 Y21.753
N1309 G01 X24.717 Y21.807
N1310 G01 X24.533 Y21.823
N1311 G01 X24.443 Y21.816
N1312 G01 X24.353 Y21.805
N1313 G01 X24.174 Y21.779
N1314 G01 X24.13 Y21.787
N1315 G01 X24.094 Y21.814
N1316 G01 X24.074 Y21.854
N1317 G01 X24.073 Y21.9
N1318 G01 X24.381 Y22.553
N1319 G01 X24.448 Y22.996
N1320 G01 X24.514 Y23.568
N1321 G01 X24.572 Y24.288
N1322 G01 X24.608 Y25.009
N1323 G01 X24.637 Y25.731
N1324 G01 X24.667 Y26.452
N1325 G01 X24.686 Y27.174
N1326 G01 X24.658 Y27.259
N1327 G01 X24.648 Y27.349
N1328 G01 X24.649 Y27.439
N1329 G01 X24.655 Y27.71
N1330 G01 X24.675 Y27.75
N1331 G01 X24.711 Y27.778
N1332 G01 X24.755 Y27.786
N1333 G01 X25.452 Y27.598
N1334 G01 X26.152 Y27.42
N1335 G01 X26.424 Y27.284
N1336 G01 X27.145 Y27.244
N1337 G01 X27.45 Y27.222
N1338 G01 X27.863 Y27.198
N1339 G01 X27.948 Y27.229
N1340 G03 X27.722 Y27.785 I-0.113 J0.278
N1341 G03 X27.535 Y27.518 I0.113 J-0.278
N1342 G01 X27.301 Y20.705
N1343 G03 X27.895 Y20.636 I0.3 J-0.01
N1344 G01 X28.028 Y21.434
N1345 G01 X28.085 Y21.62
N1346 G01 X28.061 Y21.834
N1347 G01 X27.937 Y22.051
N1348 G01 X27.663 Y22.256
N1349 G01 X26.959 Y22.415
N1350 G01 X26.304 Y22.607
N1351 G01 X26.259 Y22.602
N1352 G01 X25.54 Y22.664
N1353 G01 X25.446 Y22.684
N1354 G01 X25.356 Y22.696
N1355 G01 X25.176 Y22.709
N1356 G01 X25.131
N1357 G01 X25.086 Y22.713
N1358 G01 X25.048 Y22.737
N1359 G01 X25.024 Y22.776
N1360 G01 X25.019 Y22.82
N1361 G01 X25.268 Y23.498
N1362 G01 X25.327 Y23.773
N1363 G01 X25.387 Y24.113
N1364 G01 X25.487 Y24.828
N1365 G01 X25.597 Y25.213
N1366 G01 X25.55 Y25.571
N1367 G01 X25.649 Y26.16
N1368 G01 X25.606 Y26.335
N1369 G01 X25.618 Y26.515
N1370 G01 X25.629 Y26.876
N1371 G01 X25.631 Y26.966
N1372 G03 X24.977 Y27.553 I-0.595 J-0.005
N1373 G03 X24.453 Y26.847 I0.06 J-0.592
N1374 G01 X25.482 Y21.569
N1375 G03 X26.641 Y21.533 I0.584 J0.114
N1376 G01 X26.955 Y22.942
N1377 G01 X26.917 Y23.159
N1378 G01 X26.783 Y23.362
N1379 G01 X26.554 Y23.512
N1380 G01 X26.376 Y23.543
N1381 G01 X26.016 Y23.576
N1382 G01 X25.926 Y23.584
N1383 G01 X25.888 Y23.607
N1384 G01 X25.863 Y23.645
N1385 G01 X25.858 Y23.69
N1386 G01 X25.873 Y23.732
N1387 G01 X26.283 Y24.138
N1388 G01 X26.431 Y24.505
N1389 G01 X26.426 Y24.686
N1390 G01 X26.562 Y25.104
N1391 G01 X26.527 Y25.463
N1392 G01 X26.52 Y26.185
N1393 G01 X26.544 Y26.316
N1394 G01 X26.563 Y26.495
N1395 G01 X26.572 Y26.675
N1396 G01 X26.593 Y26.715
N1397 G01 X26.63 Y26.741
N1398 G01 X26.674 Y26.749
N1399 G01 X26.717 Y26.736
N1400 G01 X27.12 Y26.366
N1401 G01 X27.469 Y26.245
N1402 G01 X27.559 Y26.251
N1403 G01 X27.65
N1404 G01 X27.69 Y26.231
N1405 G01 X27.717 Y26.195
N1406 G01 X27.726 Y26.151
N1407 G01 X27.715 Y26.107
N1408 G01 X27.383 Y25.725
N1409 G01 X27.27 Y25.366
N1410 G01 X27.308 Y25.007
N1411 G01 X27.221 Y24.381
N1412 G01 X27.27 Y24.207
N1413 G01 X27.228 Y23.486
N1414 G01 X27.266 Y23.127
N1415 G01 X27.255 Y23.038
N1416 G01 X27.247 Y22.948
N1417 G01 Y22.933 Z4.989
N1418 G01 X27.254 Y22.893 Z4.976
N1419 G01 X27.259 Y22.861 Z4.95
N1420 G01 X27.263 Y22.839 Z4.914
N1421 G01 X27.264 Y22.832 Z4.872
N1422 G00 Z-3.01
N1423 G00 X9.706 Y6.562
N1424 G00 Z9.38
N1425 G01 Z9.68 F1500
N1426 G01 X9.708 Y6.57 Z9.747
N1427 G01 X9.713 Y6.591 Z9.81
N1428 G01 X9.722 Y6.626 Z9.867
N1429 G01 X9.734 Y6.672 Z9.915
N1430 G01 X9.748 Y6.727 Z9.95
N1431 G01 X9.764 Y6.788 Z9.972
N1432 G01 X9.78 Y6.853 Z9.98
N1433 G03 X10.015 Y8.486 I-7.419 J1.9
N1434 G01 Y8.576
N1435 G01 X9.75 Y9.248
N1436 G01 X9.608 Y9.956
N1437 G01 X9.536 Y10.674
N1438 G01 X9.499 Y11.395
N1439 G01 X9.482 Y12.117
N1440 G01 X9.473 Y12.839
N1441 G01 X9.469 Y13.561
N1442 G01 X9.467 Y14.283
N1443 G01 X9.465 Y16.449
N1444 G01 Y38.831
N1445 G01 X9.578 Y39.174
N1446 G01 X9.789 Y39.467
N1447 G01 X10.328 Y39.947
N1448 G01 X10.992 Y40.229
N1449 G01 X11.698 Y40.381
N1450 G01 X12.416 Y40.459
N1451 G01 X13.137 Y40.498
N1452 G01 X13.859 Y40.517
N1453 G01 X14.581 Y40.526
N1454 G01 X15.303 Y40.531
N1455 G01 X16.025 Y40.533
N1456 G01 X18.191 Y40.535
N1457 G01 X29.02
N1458 G01 X38.767
N1459 G01 X39.117 Y40.446
N1460 G01 X39.42 Y40.249
N1461 G01 X39.918 Y39.727
N1462 G01 X40.212 Y39.067
N1463 G01 X40.372 Y38.363
N1464 G01 X40.455 Y37.646
N1465 G01 X40.496 Y36.925
N1466 G01 X40.516 Y36.203
N1467 G01 X40.526 Y35.481
N1468 G01 X40.531 Y34.76
N1469 G01 X40.533 Y34.038
N1470 G01 X40.535 Y31.872
N1471 G01 Y11.295
N1472 G01 X40.504 Y11.117
N1473 G01 X40.373 Y10.78
N1474 G01 X40.152 Y10.495
N1475 G01 X39.6 Y10.029
N1476 G01 X38.931 Y9.758
N1477 G01 X38.224 Y9.612
N1478 G01 X37.506 Y9.538
N1479 G01 X36.785 Y9.5
N1480 G01 X36.063 Y9.482
N1481 G01 X35.341 Y9.473
N1482 G01 X34.619 Y9.469
N1483 G01 X33.897 Y9.467
N1484 G01 X31.731 Y9.465
N1485 G01 X30.287
N1486 G01 X12.237
N1487 G01 X11.893 Y9.573
N1488 G01 X11.592 Y9.772
N1489 G01 X11.088 Y10.29
N1490 G01 X10.848 Y10.433
N1491 G01 X10.562 Y10.47
N1492 G01 X10.382 Y10.467
N1493 G01 X10.292 Y10.466
N1494 G01 X10.251 Y10.486
N1495 G01 X10.223 Y10.521
N1496 G01 X10.214 Y10.565
N1497 G01 X10.301 Y10.916
N1498 G01 X10.343 Y11.358
N1499 G01 X10.386 Y12.079
N1500 G01 X10.403 Y12.801
N1501 G01 X10.41 Y13.523
N1502 G01 X10.413 Y14.245
N1503 G01 X10.415 Y15.689
N1504 G01 Y37.348
N1505 G01 X10.508 Y38.064
N1506 G01 X10.458 Y38.238
N1507 G01 X10.469 Y38.599
N1508 G01 X10.467 Y38.734
N1509 G01 X10.506 Y38.816
N1510 G01 X10.759 Y39.073
N1511 G01 X11.072 Y39.253
N1512 G01 X11.759 Y39.475
N1513 G01 X12.48 Y39.513
N1514 G01 X13.201 Y39.546
N1515 G01 X13.923 Y39.562
N1516 G01 X14.645 Y39.572
N1517 G01 X15.367 Y39.578
N1518 G01 X16.089 Y39.581
N1519 G01 X17.533 Y39.584
N1520 G01 X21.864 Y39.585
N1521 G01 X37.748
N1522 G01 X38.103 Y39.516
N1523 G01 X38.462 Y39.551
N1524 G01 X38.642 Y39.539
N1525 G01 X38.687 Y39.538
N1526 G01 X38.731 Y39.526
N1527 G01 X38.811 Y39.486
N1528 G01 X38.947 Y39.366
N1529 G01 X39.072 Y39.237
N1530 G01 X39.256 Y38.926
N1531 G01 X39.463 Y38.234
N1532 G01 X39.507 Y37.514
N1533 G01 X39.561 Y36.794
N1534 G01 X39.569 Y36.072
N1535 G01 X39.575 Y35.35
N1536 G01 X39.579 Y34.628
N1537 G01 X39.582 Y33.906
N1538 G01 X39.584 Y32.462
N1539 G01 X39.585 Y26.686
N1540 G01 Y16.578
N1541 G01 Y12.246
N1542 G01 X39.516 Y11.892
N1543 G01 X39.551 Y11.532
N1544 G01 X39.539 Y11.352
N1545 G01 X39.531 Y11.308
N1546 G01 X39.494 Y11.225
N1547 G01 X39.38 Y11.086
N1548 G01 X39.103 Y10.854
N1549 G01 X38.435 Y10.58
N1550 G01 X37.715 Y10.521
N1551 G01 X37. Y10.425
N1552 G01 X36.278 Y10.426
N1553 G01 X34.112 Y10.418
N1554 G01 X31.946 Y10.416
N1555 G01 X13.896 Y10.415
N1556 G01 X13.174 Y10.424
N1557 G01 X12.682 Y10.505
N1558 G01 X12.507 Y10.461
N1559 G01 X12.327 Y10.464
N1560 G01 X12.244 Y10.499
N1561 G01 X11.678 Y10.948
N1562 G01 X11.442 Y11.207
N1563 G01 X11.342 Y11.252
N1564 G01 X11.258 Y11.286
N1565 G01 X11.173 Y11.315
N1566 G01 X11.129 Y11.327
N1567 G01 X11.085 Y11.338
N1568 G01 X11.051 Y11.367
N1569 G01 X11.032 Y11.408
N1570 G01 X11.059 Y12.13
N1571 G01 X11.105 Y12.328
N1572 G01 X11.151 Y12.566
N1573 G01 X11.198 Y12.866
N1574 G01 X11.246 Y13.257
N1575 G01 X11.294 Y13.818
N1576 G01 X11.331 Y14.539
N1577 G01 X11.349 Y15.261
N1578 G01 X11.357 Y15.983
N1579 G01 X11.361 Y16.705
N1580 G01 X11.363 Y17.427
N1581 G01 X11.365 Y19.593
N1582 G01 Y27.535
N1583 G01 Y37.643
N1584 G01 X11.474 Y37.987
N1585 G01 X11.452 Y38.166
N1586 G01 X11.432 Y38.254
N1587 G01 X11.424 Y38.344
N1588 G01 X11.423 Y38.389
N1589 G01 X11.441 Y38.43
N1590 G01 X11.476 Y38.459
N1591 G01 X12.179 Y38.626
N1592 G01 X12.901 Y38.615
N1593 G01 X13.622 Y38.616
N1594 G01 X15.066 Y38.625
N1595 G01 X15.788 Y38.631
N1596 G01 X17.954 Y38.635
N1597 G01 X38.17
N1598 G01 X38.26 Y38.622
N1599 G01 X38.304 Y38.617
N1600 G01 X38.343 Y38.593
N1601 G01 X38.39 Y38.516
N1602 G01 X38.589 Y37.822
N1603 G01 X38.603 Y37.1
N1604 G01 X38.613 Y36.378
N1605 G01 X38.631 Y35.656
N1606 G01 X38.63 Y34.934
N1607 G01 X38.634 Y32.768
N1608 G01 X38.635 Y28.436
N1609 G01 Y26.27
N1610 G01 Y11.83
N1611 G01 X38.621 Y11.741
N1612 G01 X38.617 Y11.696
N1613 G01 X38.593 Y11.658
N1614 G01 X38.439 Y11.563
N1615 G01 X37.735 Y11.404
N1616 G01 X37.013 Y11.389
N1617 G01 X36.293 Y11.338
N1618 G01 X35.571 Y11.355
N1619 G01 X34.849 Y11.362
N1620 G01 X34.127 Y11.365
N1621 G01 X32.683 Y11.366
N1622 G01 X13.911 Y11.365
N1623 G01 X13.19 Y11.373
N1624 G01 X12.699 Y11.477
N1625 G01 X12.611 Y11.459
N1626 G01 X12.567 Y11.45
N1627 G01 X12.523 Y11.46
N1628 G01 X12.245 Y11.691
N1629 G01 X12.056 Y11.946
N1630 G01 X11.978 Y11.991
N1631 G01 X11.938 Y12.012
N1632 G01 X11.912 Y12.049
N1633 G01 X11.904 Y12.093
N1634 G01 X11.978 Y12.408
N1635 G01 X12.043 Y12.737
N1636 G01 X12.112 Y13.166
N1637 G01 X12.171 Y13.641
N1638 G01 X12.23 Y14.303
N1639 G01 X12.268 Y15.024
N1640 G01 X12.29 Y15.745
N1641 G01 X12.301 Y16.467
N1642 G01 X12.308 Y17.189
N1643 G01 X12.311 Y17.911
N1644 G01 X12.314 Y19.355
N1645 G01 X12.315 Y20.799
N1646 G01 Y37.405
N1647 G01 X12.343 Y37.583
N1648 G01 X12.368 Y37.67
N1649 G01 X12.387 Y37.758
N1650 G01 X12.393 Y37.803
N1651 G01 X12.418 Y37.841
N1652 G01 X12.457 Y37.863
N1653 G01 X13.178 Y37.91
N1654 G01 X13.42 Y37.866
N1655 G01 X13.727 Y37.822
N1656 G01 X14.13 Y37.779
N1657 G01 X14.745 Y37.734
N1658 G01 X15.466 Y37.707
N1659 G01 X16.188 Y37.694
N1660 G01 X16.91 Y37.689
N1661 G01 X17.632 Y37.687
N1662 G01 X19.798 Y37.685
N1663 G01 X37.803
N1664 G01 X37.843 Y37.665
N1665 G01 X37.871 Y37.63
N1666 G01 X37.88 Y37.585
N1667 G01 X37.702 Y36.886
N1668 G01 X37.691 Y36.164
N1669 G01 X37.686 Y35.442
N1670 G01 X37.684 Y34.72
N1671 G01 Y33.276
N1672 G01 X37.685 Y29.666
N1673 G01 Y12.203
N1674 G01 X37.665 Y12.162
N1675 G01 X37.63 Y12.134
N1676 G01 X37.585 Y12.125
N1677 G01 X36.886 Y12.304
N1678 G01 X36.164 Y12.305
N1679 G01 X35.442 Y12.274
N1680 G01 X34.721 Y12.295
N1681 G01 X33.999 Y12.306
N1682 G01 X33.277 Y12.311
N1683 G01 X32.555 Y12.313
N1684 G01 X31.111 Y12.315
N1685 G01 X13.783
N1686 G01 X13.061 Y12.328
N1687 G01 X13.019 Y12.344
N1688 G01 X12.976 Y12.36
N1689 G01 X12.943 Y12.389
N1690 G01 X12.911 Y12.422
N1691 G01 X12.896 Y12.464
N1692 G01 X12.991 Y13.18
N1693 G01 X13.064 Y13.668
N1694 G01 X13.129 Y14.238
N1695 G01 X13.185 Y14.958
N1696 G01 X13.219 Y15.679
N1697 G01 X13.238 Y16.401
N1698 G01 X13.25 Y17.123
N1699 G01 X13.257 Y17.845
N1700 G01 X13.26 Y18.567
N1701 G01 X13.264 Y20.011
N1702 G01 Y20.733
N1703 G01 X13.265 Y31.563
N1704 G01 Y37.158
N1705 G01 X13.266 Y37.203
N1706 G01 X13.286 Y37.244
N1707 G01 X13.322 Y37.271
N1708 G01 X13.366 Y37.28
N1709 G01 X14.064 Y37.093
N1710 G01 X14.258 Y37.043
N1711 G01 X14.479 Y36.994
N1712 G01 X14.755 Y36.944
N1713 G01 X15.094 Y36.894
N1714 G01 X15.549 Y36.843
N1715 G01 X16.207 Y36.793
N1716 G01 X16.929 Y36.764
N1717 G01 X17.651 Y36.749
N1718 G01 X18.373 Y36.742
N1719 G01 X19.095 Y36.738
N1720 G01 X20.539 Y36.736
N1721 G01 X28.48 Y36.735
N1722 G01 X37.054
N1723 G01 X37.095 Y36.715
N1724 G01 X37.122 Y36.68
N1725 G01 X37.132 Y36.635
N1726 G01 X36.953 Y35.936
N1727 G01 X36.907 Y35.656
N1728 G01 X36.86 Y35.292
N1729 G01 X36.813 Y34.783
N1730 G01 X36.771 Y34.062
N1731 G01 X36.752 Y33.34
N1732 G01 X36.743 Y32.618
N1733 G01 X36.739 Y31.896
N1734 G01 X36.737 Y31.174
N1735 G01 X36.735 Y29.008
N1736 G01 Y26.842
N1737 G01 Y12.944
N1738 G01 X36.715 Y12.903
N1739 G01 X36.68 Y12.876
N1740 G01 X36.635 Y12.866
N1741 G01 X35.936 Y13.045
N1742 G01 X35.593 Y13.097
N1743 G01 X35.136 Y13.149
N1744 G01 X34.478 Y13.201
N1745 G01 X33.757 Y13.233
N1746 G01 X33.035 Y13.249
N1747 G01 X32.313 Y13.257
N1748 G01 X31.591 Y13.261
N1749 G01 X30.869 Y13.263
N1750 G01 X28.703 Y13.265
N1751 G01 X13.812
N1752 G01 X13.631 Y13.268
N1753 G01 X13.591 Y13.289
N1754 G01 X13.564 Y13.325
N1755 G01 X13.556 Y13.369
N1756 G01 X13.746 Y14.066
N1757 G01 X13.797 Y14.221
N1758 G01 X13.849 Y14.406
N1759 G01 X13.899 Y14.609
N1760 G01 X13.952 Y14.858
N1761 G01 X14.005 Y15.168
N1762 G01 X14.059 Y15.556
N1763 G01 X14.113 Y16.089
N1764 G01 X14.16 Y16.809
N1765 G01 X14.185 Y17.531
N1766 G01 X14.199 Y18.252
N1767 G01 X14.206 Y18.974
N1768 G01 X14.21 Y19.696
N1769 G01 X14.214 Y21.14
N1770 G01 X14.215 Y24.75
N1771 G01 Y26.194
N1772 G01 Y36.483
N1773 G03 X14.188 Y36.597 I-0.3 J-0.01
N1774 G01 X14.16 Y36.657 Z9.972
N1775 G01 X14.134 Y36.715 Z9.95
N1776 G01 X14.111 Y36.767 Z9.915
N1777 G01 X14.091 Y36.81 Z9.867
N1778 G01 X14.076 Y36.843 Z9.81
N1779 G01 X14.067 Y36.863 Z9.747
N1780 G01 X14.064 Y36.87 Z9.68
N1781 G00 Z-3.01
N1782 G00 X13.464 Y13.548
N1783 G00 Z9.38
N1784 G01 Z9.68 F1500
N1785 G01 X13.457 Y13.55 Z9.747
N1786 G01 X13.436 Y13.557 Z9.81
N1787 G01 X13.401 Y13.567 Z9.867
N1788 G01 X13.356 Y13.581 Z9.915
N1789 G01 X13.301 Y13.597 Z9.95
N1790 G01 X13.241 Y13.615 Z9.972
N1791 G01 X13.177 Y13.635 Z9.98
N1792 G01 X13.064 Y13.668
N1793 G01 X13.813 Y13.556
N1794 G01 X13.98 Y13.473
N1795 G01 X14.189 Y13.462
N1796 G01 X14.41 Y13.543
N1797 G01 X14.617 Y13.74
N1798 G01 X14.72 Y14.149
N1799 G01 X14.809 Y14.568
N1800 G01 X14.891 Y15.026
N1801 G01 X14.97 Y15.585
N1802 G01 X15.04 Y16.239
N1803 G01 X15.091 Y16.959
N1804 G01 X15.121 Y17.68
N1805 G01 X15.14 Y18.402
N1806 G01 X15.15 Y19.124
N1807 G01 X15.157 Y19.846
N1808 G01 X15.16 Y20.568
N1809 G01 X15.164 Y22.012
N1810 G01 X15.165 Y25.622
N1811 G01 Y36.271
N1812 G01 X15.185 Y36.312
N1813 G01 X15.22 Y36.34
N1814 G01 X15.265 Y36.349
N1815 G01 X15.964 Y36.17
N1816 G01 X16.127 Y36.124
N1817 G01 X16.322 Y36.076
N1818 G01 X16.55 Y36.028
N1819 G01 X16.831 Y35.979
N1820 G01 X17.192 Y35.929
N1821 G01 X17.684 Y35.879
N1822 G01 X18.404 Y35.832
N1823 G01 X19.126 Y35.808
N1824 G01 X19.847 Y35.797
N1825 G01 X20.569 Y35.791
N1826 G01 X21.291 Y35.788
N1827 G01 X22.735 Y35.786
N1828 G01 X34.287 Y35.785
N1829 G01 X36.363
N1830 G01 X36.453 Y35.788
N1831 G03 X36.481 Y35.79 I-0.01 J0.3
N1832 G03 X36.404 Y36.386 I-0.038 J0.298
N1833 G03 X36.165 Y35.973 I0.038 J-0.298
N1834 G01 X36.623 Y34.866
N1835 G03 X37.177 Y35.096 I0.277 J0.115
N1836 G03 X36.949 Y35.277 I-0.277 J-0.115
N1837 G01 X36.86 Y35.292
N1838 G01 X36.831 Y35.295
N1839 G01 X36.55 Y35.42
N1840 G01 X36.349 Y35.422
N1841 G01 X36.144 Y35.335
N1842 G01 X36.094 Y35.135
N1843 G01 X36.042 Y34.89
N1844 G01 X35.988 Y34.587
N1845 G01 X35.937 Y34.218
N1846 G01 X35.885 Y33.715
N1847 G01 X35.836 Y32.995
N1848 G01 X35.811 Y32.273
N1849 G01 X35.798 Y31.551
N1850 G01 X35.792 Y30.829
N1851 G01 X35.788 Y30.107
N1852 G01 X35.786 Y28.663
N1853 G01 X35.785 Y21.443
N1854 G01 Y13.682
N1855 G01 X35.765 Y13.641
N1856 G01 X35.73 Y13.614
N1857 G01 X35.685 Y13.605
N1858 G01 X34.986 Y13.783
N1859 G01 X34.842 Y13.829
N1860 G01 X34.674 Y13.876
N1861 G01 X34.472 Y13.925
N1862 G01 X34.231 Y13.975
N1863 G01 X33.939 Y14.024
N1864 G01 X33.558 Y14.075
N1865 G01 X33.038 Y14.125
N1866 G01 X32.317 Y14.17
N1867 G01 X31.596 Y14.192
N1868 G01 X30.874 Y14.203
N1869 G01 X30.152 Y14.209
N1870 G01 X29.43 Y14.212
N1871 G01 X27.986 Y14.214
N1872 G01 X17.156 Y14.215
N1873 G01 X15.306
N1874 G01 X15.282 Y14.214
N1875 G03 X15.287 Y14.054 I0.003 J-0.08
N1876 G03 X15.343 Y14.189 I-0.003 J0.08
N1877 G01 X14.864 Y14.705
N1878 G03 X14.747 Y14.597 I-0.059 J-0.054
N1879 G03 X14.786 Y14.573 I0.059 J0.054
N1880 G01 X14.809 Y14.568
N1881 G01 X14.964 Y14.534
N1882 G01 X15.125 Y14.451
N1883 G01 X15.327 Y14.437
N1884 G01 X15.537 Y14.512
N1885 G01 X15.726 Y14.687
N1886 G01 X15.812 Y15.154
N1887 G01 X15.895 Y15.722
N1888 G01 X15.97 Y16.398
N1889 G01 X16.025 Y17.118
N1890 G01 X16.059 Y17.839
N1891 G01 X16.081 Y18.561
N1892 G01 X16.095 Y19.283
N1893 G01 X16.103 Y20.005
N1894 G01 X16.108 Y20.727
N1895 G01 X16.111 Y21.449
N1896 G01 X16.114 Y22.893
N1897 G01 X16.115 Y27.225
N1898 G01 Y35.528
N1899 G01 X16.112 Y35.618
N1900 G03 X15.512 Y35.597 I-0.3 J-0.01
N1901 G03 X15.927 Y35.33 I0.3 J0.01
N1902 G01 X16.978 Y35.766
N1903 G03 X16.748 Y36.32 I-0.115 J0.277
N1904 G03 X16.579 Y36.142 I0.115 J-0.277
N1905 G03 X16.571 Y36.115 I0.283 J-0.099
N1906 G01 X16.55 Y36.028
N1907 G01 X16.544 Y36.
N1908 G01 X16.399 Y35.729
N1909 G01 X16.382 Y35.531
N1910 G01 X16.453 Y35.321
N1911 G01 X16.631 Y35.265
N1912 G01 X16.848 Y35.206
N1913 G01 X17.11 Y35.144
N1914 G01 X17.386 Y35.089
N1915 G01 X17.745 Y35.031
N1916 G01 X18.177 Y34.976
N1917 G01 X18.784 Y34.921
N1918 G01 X19.505 Y34.881
N1919 G01 X20.227 Y34.859
N1920 G01 X20.949 Y34.848
N1921 G01 X21.671 Y34.842
N1922 G01 X22.393 Y34.839
N1923 G01 X23.837 Y34.836
N1924 G01 X29.613 Y34.835
N1925 G01 X35.479
N1926 G01 X35.503 Y34.836
N1927 G03 X35.497 Y34.996 I-0.003 J0.08
N1928 G03 X35.449 Y34.854 I0.003 J-0.08
N1929 G01 X35.944 Y34.442
N1930 G03 X36.047 Y34.565 I0.051 J0.062
N1931 G03 X36.012 Y34.582 I-0.051 J-0.062
N1932 G01 X35.988 Y34.587
N1933 G01 X35.791 Y34.622
N1934 G01 X35.616 Y34.682
N1935 G01 X35.411 Y34.666
N1936 G01 X35.207 Y34.558
N1937 G01 X35.145 Y34.288
N1938 G01 X35.089 Y34.004
N1939 G01 X35.029 Y33.631
N1940 G01 X34.974 Y33.185
N1941 G01 X34.918 Y32.552
N1942 G01 X34.88 Y31.831
N1943 G01 X34.859 Y31.109
N1944 G01 X34.848 Y30.387
N1945 G01 X34.842 Y29.665
N1946 G01 X34.839 Y28.943
N1947 G01 X34.836 Y27.499
N1948 G01 X34.835 Y21.723
N1949 G01 Y14.413
N1950 G01 X34.838 Y14.323
N1951 G03 X34.84 Y14.295 I0.3 J0.01
N1952 G03 X35.436 Y14.372 I0.298 J0.038
N1953 G03 X35.05 Y14.62 I-0.298 J-0.038
N1954 G01 X33.83 Y14.245
N1955 G03 X34.007 Y13.671 I0.088 J-0.287
N1956 G03 X34.202 Y13.86 I-0.088 J0.287
N1957 G03 X34.21 Y13.887 I-0.284 J0.097
N1958 G01 X34.231 Y13.975
N1959 G01 X34.237 Y14.003
N1960 G01 X34.381 Y14.274
N1961 G01 X34.397 Y14.473
N1962 G01 X34.325 Y14.682
N1963 G01 X34.148 Y14.737
N1964 G01 X33.934 Y14.795
N1965 G01 X33.669 Y14.858
N1966 G01 X33.389 Y14.913
N1967 G01 X33.029 Y14.971
N1968 G01 X32.586 Y15.026
N1969 G01 X31.964 Y15.081
N1970 G01 X31.243 Y15.12
N1971 G01 X30.522 Y15.141
N1972 G01 X29.8 Y15.152
N1973 G01 X29.078 Y15.158
N1974 G01 X28.356 Y15.161
N1975 G01 X26.912 Y15.164
N1976 G01 X21.136 Y15.165
N1977 G01 X16.443
N1978 G01 X16.402 Y15.185
N1979 G01 X16.375 Y15.22
N1980 G01 X16.365 Y15.265
N1981 G01 X16.544 Y15.964
N1982 G01 X16.594 Y16.106
N1983 G01 X16.645 Y16.27
N1984 G01 X16.699 Y16.468
N1985 G01 X16.752 Y16.693
N1986 G01 X16.806 Y16.965
N1987 G01 X16.862 Y17.31
N1988 G01 X16.918 Y17.75
N1989 G01 X16.974 Y18.37
N1990 G01 X17.014 Y19.091
N1991 G01 X17.036 Y19.813
N1992 G01 X17.048 Y20.535
N1993 G01 X17.055 Y21.257
N1994 G01 X17.059 Y21.979
N1995 G01 X17.063 Y23.423
N1996 G01 X17.065 Y26.311
N1997 G01 Y34.614
N1998 G01 X17.062 Y34.704
N1999 G03 X16.462 Y34.683 I-0.3 J-0.01
N2000 G03 X16.884 Y34.419 I0.3 J0.01
N2001 G01 X17.82 Y34.834
N2002 G03 X17.577 Y35.382 I-0.122 J0.274
N2003 G03 X17.406 Y35.177 I0.122 J-0.274
N2004 G01 X17.386 Y35.089
N2005 G01 X17.355 Y34.935
N2006 G01 X17.274 Y34.774
N2007 G01 X17.263 Y34.574
N2008 G01 X17.339 Y34.366
N2009 G01 X17.517 Y34.179
N2010 G01 X17.976 Y34.106
N2011 G01 X18.529 Y34.038
N2012 G01 X19.248 Y33.976
N2013 G01 X19.969 Y33.938
N2014 G01 X20.691 Y33.915
N2015 G01 X21.413 Y33.902
N2016 G01 X22.135 Y33.895
N2017 G01 X22.857 Y33.89
N2018 G01 X23.579 Y33.888
N2019 G01 X25.023 Y33.886
N2020 G01 X32.964 Y33.885
N2021 G01 X34.499
N2022 G01 X34.523 Y33.886
N2023 G03 X34.517 Y34.046 I-0.003 J0.08
N2024 G03 X34.47 Y33.904 I0.003 J-0.08
N2025 G01 X34.987 Y33.485
N2026 G03 X35.087 Y33.61 I0.05 J0.062
N2027 G03 X35.053 Y33.626 I-0.05 J-0.062
N2028 G01 X35.029 Y33.631
N2029 G01 X34.873 Y33.656
N2030 G01 X34.707 Y33.73
N2031 G01 X34.506 Y33.734
N2032 G01 X34.3 Y33.649
N2033 G01 X34.12 Y33.464
N2034 G01 X34.052 Y32.936
N2035 G01 X33.987 Y32.256
N2036 G01 X33.944 Y31.535
N2037 G01 X33.919 Y30.814
N2038 G01 X33.904 Y30.092
N2039 G01 X33.896 Y29.37
N2040 G01 X33.891 Y28.648
N2041 G01 X33.888 Y27.926
N2042 G01 X33.886 Y26.482
N2043 G01 X33.885 Y20.706
N2044 G01 Y15.381
N2045 G01 X33.886 Y15.357
N2046 G03 X34.046 Y15.363 I0.08 J0.003
N2047 G03 X33.921 Y15.426 I-0.08 J-0.003
N2048 G01 X33.261 Y14.973
N2049 G03 X33.351 Y14.841 I0.045 J-0.066
N2050 G03 X33.384 Y14.889 I-0.045 J0.066
N2051 G01 X33.389 Y14.913
N2052 G01 X33.395 Y14.941
N2053 G01 X33.538 Y15.214
N2054 G01 X33.553 Y15.413
N2055 G01 X33.48 Y15.622
N2056 G01 X33.274 Y15.685
N2057 G01 X33.065 Y15.741
N2058 G01 X32.806 Y15.801
N2059 G01 X32.492 Y15.862
N2060 G01 X32.128 Y15.919
N2061 G01 X31.649 Y15.977
N2062 G01 X30.985 Y16.034
N2063 G01 X30.264 Y16.071
N2064 G01 X29.542 Y16.091
N2065 G01 X28.82 Y16.102
N2066 G01 X28.098 Y16.108
N2067 G01 X27.376 Y16.111
N2068 G01 X25.932 Y16.114
N2069 G01 X20.878 Y16.115
N2070 G01 X17.178
N2071 G01 X17.088 Y16.112
N2072 G03 X17.109 Y15.512 I0.01 J-0.3
N2073 G03 X17.386 Y15.897 I-0.01 J0.3
N2074 G01 X17.032 Y17.092
N2075 G03 X16.457 Y16.921 I-0.288 J-0.085
N2076 G03 X16.639 Y16.725 I0.288 J0.085
N2077 G03 X16.665 Y16.717 I0.105 J0.281
N2078 G01 X16.752 Y16.693
N2079 G01 X16.78 Y16.687
N2080 G01 X17.046 Y16.535
N2081 G01 X17.245 Y16.514
N2082 G01 X17.456 Y16.579
N2083 G01 X17.517 Y16.759
N2084 G01 X17.581 Y16.978
N2085 G01 X17.642 Y17.211
N2086 G01 X17.703 Y17.487
N2087 G01 X17.766 Y17.829
N2088 G01 X17.826 Y18.228
N2089 G01 X17.885 Y18.757
N2090 G01 X17.941 Y19.477
N2091 G01 X17.972 Y20.198
N2092 G01 X17.991 Y20.92
N2093 G01 X18.001 Y21.642
N2094 G01 X18.007 Y22.364
N2095 G01 X18.01 Y23.086
N2096 G01 X18.013 Y24.53
N2097 G01 X18.015 Y28.14
N2098 G01 Y33.465
N2099 G01 X18.035 Y33.505
N2100 G01 X18.07 Y33.533
N2101 G01 X18.115 Y33.542
N2102 G01 X18.814 Y33.364
N2103 G01 X18.975 Y33.315
N2104 G01 X19.167 Y33.265
N2105 G01 X19.4 Y33.213
N2106 G01 X19.67 Y33.162
N2107 G01 X20.021 Y33.109
N2108 G01 X20.475 Y33.057
N2109 G01 X21.144 Y33.004
N2110 G01 X21.866 Y32.972
N2111 G01 X22.587 Y32.955
N2112 G01 X23.309 Y32.946
N2113 G01 X24.031 Y32.941
N2114 G01 X24.753 Y32.938
N2115 G01 X26.197 Y32.936
N2116 G01 X33.417 Y32.935
N2117 G01 X33.458 Y32.915
N2118 G01 X33.485 Y32.88
N2119 G01 X33.495 Y32.835
N2120 G01 X33.316 Y32.136
N2121 G01 X33.268 Y31.956
N2122 G01 X33.219 Y31.744
N2123 G01 X33.168 Y31.483
N2124 G01 X33.117 Y31.162
N2125 G01 X33.065 Y30.736
N2126 G01 X33.013 Y30.138
N2127 G01 X32.976 Y29.417
N2128 G01 X32.957 Y28.695
N2129 G01 X32.946 Y27.973
N2130 G01 X32.941 Y27.251
N2131 G01 X32.938 Y26.529
N2132 G01 X32.936 Y25.085
N2133 G01 X32.935 Y18.587
N2134 G01 Y16.331
N2135 G01 X32.936 Y16.307
N2136 G03 X33.096 Y16.313 I0.08 J0.003
N2137 G03 X32.968 Y16.374 I-0.08 J-0.003
N2138 G01 X32.361 Y15.921
N2139 G03 X32.457 Y15.792 I0.048 J-0.064
N2140 G03 X32.487 Y15.839 I-0.048 J0.064
N2141 G01 X32.492 Y15.862
N2142 G01 X32.498 Y15.89
N2143 G01 X32.64 Y16.164
N2144 G01 X32.654 Y16.363
N2145 G01 X32.58 Y16.572
N2146 G01 X32.375 Y16.634
N2147 G01 X32.154 Y16.693
N2148 G01 X31.897 Y16.752
N2149 G01 X31.574 Y16.814
N2150 G01 X31.206 Y16.871
N2151 G01 X30.712 Y16.929
N2152 G01 X30.024 Y16.987
N2153 G01 X29.302 Y17.021
N2154 G01 X28.581 Y17.041
N2155 G01 X27.859 Y17.052
N2156 G01 X27.137 Y17.058
N2157 G01 X26.415 Y17.061
N2158 G01 X24.971 Y17.064
N2159 G01 X20.639 Y17.065
N2160 G01 X18.202
N2161 G01 X18.112 Y17.062
N2162 G03 X18.133 Y16.462 I0.01 J-0.3
N2163 G03 X18.4 Y16.877 I-0.01 J0.3
N2164 G01 X17.968 Y17.915
N2165 G03 X17.414 Y17.685 I-0.277 J-0.115
N2166 G03 X17.616 Y17.51 I0.277 J0.115
N2167 G01 X17.703 Y17.487
N2168 G01 X17.835 Y17.458
N2169 G01 X17.986 Y17.366
N2170 G01 X18.181 Y17.338
N2171 G01 X18.392 Y17.396
N2172 G01 X18.587 Y17.553
N2173 G01 X18.665 Y17.953
N2174 G01 X18.737 Y18.404
N2175 G01 X18.807 Y18.971
N2176 G01 X18.869 Y19.691
N2177 G01 X18.908 Y20.412
N2178 G01 X18.931 Y21.133
N2179 G01 X18.945 Y21.855
N2180 G01 X18.953 Y22.577
N2181 G01 X18.958 Y23.299
N2182 G01 X18.961 Y24.021
N2183 G01 X18.964 Y25.465
N2184 G01 X18.965 Y29.797
N2185 G01 Y32.775
N2186 G01 X18.964 Y32.799
N2187 G03 X18.804 Y32.794 I-0.08 J-0.003
N2188 G03 X18.93 Y32.731 I0.08 J0.003
N2189 G01 X19.529 Y33.151
N2190 G03 X19.437 Y33.282 I-0.046 J0.066
N2191 G03 X19.406 Y33.236 I0.046 J-0.066
N2192 G01 X19.4 Y33.213
N2193 G01 X19.393 Y33.185
N2194 G01 X19.245 Y32.917
N2195 G01 X19.225 Y32.719
N2196 G01 X19.293 Y32.508
N2197 G01 X19.462 Y32.316
N2198 G01 X19.898 Y32.239
N2199 G01 X20.391 Y32.169
N2200 G01 X21.003 Y32.105
N2201 G01 X21.723 Y32.055
N2202 G01 X22.444 Y32.025
N2203 G01 X23.166 Y32.008
N2204 G01 X23.888 Y31.998
N2205 G01 X24.61 Y31.992
N2206 G01 X25.332 Y31.989
N2207 G01 X26.776 Y31.986
N2208 G01 X31.108 Y31.985
N2209 G01 X32.732
N2210 G01 X32.822 Y31.988
N2211 G03 X32.802 Y32.588 I-0.01 J0.3
N2212 G03 X32.528 Y32.192 I0.01 J-0.3
N2213 G01 X32.903 Y31.075
N2214 G03 X33.472 Y31.266 I0.284 J0.096
N2215 G03 X33.282 Y31.455 I-0.284 J-0.096
N2216 G03 X33.255 Y31.462 I-0.094 J-0.285
N2217 G01 X33.168 Y31.483
N2218 G01 X33.14 Y31.488
N2219 G01 X32.866 Y31.63
N2220 G01 X32.667 Y31.644
N2221 G01 X32.459 Y31.57
N2222 G01 X32.399 Y31.374
N2223 G01 X32.344 Y31.163
N2224 G01 X32.285 Y30.901
N2225 G01 X32.227 Y30.594
N2226 G01 X32.17 Y30.223
N2227 G01 X32.114 Y29.741
N2228 G01 X32.058 Y29.055
N2229 G01 X32.025 Y28.334
N2230 G01 X32.007 Y27.612
N2231 G01 X31.997 Y26.891
N2232 G01 X31.991 Y26.169
N2233 G01 X31.988 Y25.447
N2234 G01 X31.986 Y24.003
N2235 G01 X31.985 Y18.949
N2236 G01 Y17.324
N2237 G01 X31.986 Y17.3
N2238 G03 X32.146 Y17.306 I0.08 J0.003
N2239 G03 X32.014 Y17.364 I-0.08 J-0.003
N2240 G01 X31.438 Y16.869
N2241 G03 X31.543 Y16.747 I0.052 J-0.061
N2242 G03 X31.568 Y16.79 I-0.052 J0.061
N2243 G01 X31.574 Y16.814
N2244 G01 X31.599 Y16.947
N2245 G01 X31.687 Y17.101
N2246 G01 X31.709 Y17.297
N2247 G01 X31.645 Y17.506
N2248 G01 X31.456 Y17.566
N2249 G01 X31.244 Y17.626
N2250 G01 X31.012 Y17.682
N2251 G01 X30.719 Y17.742
N2252 G01 X30.38 Y17.799
N2253 G01 X29.935 Y17.858
N2254 G01 X29.353 Y17.915
N2255 G01 X28.632 Y17.959
N2256 G01 X27.911 Y17.984
N2257 G01 X27.189 Y17.998
N2258 G01 X26.467 Y18.005
N2259 G01 X25.745 Y18.01
N2260 G01 X25.023 Y18.012
N2261 G01 X23.579 Y18.014
N2262 G01 X20.691 Y18.015
N2263 G01 X19.337
N2264 G01 X19.247
N2265 G01 X19.157 Y18.012
N2266 G03 X19.178 Y17.412 I0.01 J-0.3
N2267 G03 X19.44 Y17.837 I-0.01 J0.3
N2268 G01 X18.979 Y18.841
N2269 G03 X18.433 Y18.591 I-0.273 J-0.125
N2270 G03 X18.649 Y18.421 I0.273 J0.125
N2271 G01 X18.737 Y18.404
N2272 G01 X18.872 Y18.383
N2273 G01 X19.03 Y18.3
N2274 G01 X19.228 Y18.285
N2275 G01 X19.437 Y18.357
N2276 G01 X19.493 Y18.544
N2277 G01 X19.549 Y18.762
N2278 G01 X19.609 Y19.034
N2279 G01 X19.666 Y19.342
N2280 G01 X19.727 Y19.746
N2281 G01 X19.784 Y20.257
N2282 G01 X19.84 Y20.977
N2283 G01 X19.872 Y21.699
N2284 G01 X19.89 Y22.42
N2285 G01 X19.9 Y23.142
N2286 G01 X19.906 Y23.864
N2287 G01 X19.91 Y24.586
N2288 G01 X19.913 Y26.03
N2289 G01 X19.915 Y29.64
N2290 G01 Y31.671
N2291 G01 X19.912 Y31.761
N2292 G03 X19.91 Y31.788 I-0.3 J-0.01
N2293 G03 X19.314 Y31.712 I-0.298 J-0.038
N2294 G03 X19.728 Y31.473 I0.298 J0.038
N2295 G01 X20.818 Y31.929
N2296 G03 X20.586 Y32.482 I-0.116 J0.277
N2297 G03 X20.407 Y32.258 I0.116 J-0.277
N2298 G01 X20.391 Y32.169
N2299 G01 X20.387 Y32.141
N2300 G01 X20.259 Y31.861
N2301 G01 X20.255 Y31.66
N2302 G01 X20.339 Y31.453
N2303 G01 X20.549 Y31.398
N2304 G01 X20.792 Y31.342
N2305 G01 X21.1 Y31.283
N2306 G01 X21.458 Y31.228
N2307 G01 X21.943 Y31.17
N2308 G01 X22.626 Y31.113
N2309 G01 X23.347 Y31.079
N2310 G01 X24.069 Y31.06
N2311 G01 X24.791 Y31.049
N2312 G01 X25.513 Y31.043
N2313 G01 X26.235 Y31.039
N2314 G01 X27.679 Y31.036
N2315 G01 X30.567 Y31.035
N2316 G01 X31.74
N2317 G01 X31.83 Y31.038
N2318 G03 X31.809 Y31.638 I-0.01 J0.3
N2319 G03 X31.541 Y31.225 I0.01 J-0.3
N2320 G01 X31.97 Y30.169
N2321 G03 X32.526 Y30.395 I0.278 J0.113
N2322 G03 X32.314 Y30.574 I-0.278 J-0.113
N2323 G01 X32.227 Y30.594
N2324 G01 X32.198 Y30.599
N2325 G01 X31.924 Y30.74
N2326 G01 X31.724 Y30.754
N2327 G01 X31.516 Y30.679
N2328 G01 X31.454 Y30.474
N2329 G01 X31.395 Y30.248
N2330 G01 X31.338 Y29.992
N2331 G01 X31.277 Y29.665
N2332 G01 X31.221 Y29.292
N2333 G01 X31.163 Y28.787
N2334 G01 X31.106 Y28.073
N2335 G01 X31.074 Y27.351
N2336 G01 X31.057 Y26.63
N2337 G01 X31.047 Y25.908
N2338 G01 X31.042 Y25.186
N2339 G01 X31.039 Y24.464
N2340 G01 X31.036 Y23.02
N2341 G01 X31.035 Y18.237
N2342 G01 X31.036 Y18.213
N2343 G03 X31.196 Y18.218 I0.08 J0.003
N2344 G03 X31.059 Y18.272 I-0.08 J-0.003
N2345 G01 X30.579 Y17.794
N2346 G03 X30.692 Y17.681 I0.056 J-0.057
N2347 G03 X30.713 Y17.719 I-0.056 J0.057
N2348 G01 X30.719 Y17.742
N2349 G01 X30.75 Y17.896
N2350 G01 X30.832 Y18.056
N2351 G01 X30.844 Y18.255
N2352 G01 X30.769 Y18.465
N2353 G01 X30.593 Y18.652
N2354 G01 X30.128 Y18.728
N2355 G01 X29.588 Y18.797
N2356 G01 X28.869 Y18.864
N2357 G01 X28.148 Y18.905
N2358 G01 X27.427 Y18.929
N2359 G01 X26.705 Y18.944
N2360 G01 X25.983 Y18.953
N2361 G01 X25.261 Y18.958
N2362 G01 X24.539 Y18.961
N2363 G01 X23.095 Y18.964
N2364 G01 X21.651 Y18.966
N2365 G01 X20.929 Y18.963
N2366 G01 X20.749 Y18.965
N2367 G01 X20.162
N2368 G01 X20.072 Y18.961
N2369 G03 X20.094 Y18.362 I0.011 J-0.3
N2370 G03 X20.357 Y18.783 I-0.011 J0.3
N2371 G01 X19.918 Y19.776
N2372 G03 X19.369 Y19.533 I-0.274 J-0.121
N2373 G03 X19.579 Y19.361 I0.274 J0.121
N2374 G01 X19.666 Y19.342
N2375 G01 X19.8 Y19.317
N2376 G01 X19.956 Y19.23
N2377 G01 X20.153 Y19.21
N2378 G01 X20.361 Y19.276
N2379 G01 X20.551 Y19.44
N2380 G01 X20.621 Y19.86
N2381 G01 X20.691 Y20.383
N2382 G01 X20.755 Y21.052
N2383 G01 X20.8 Y21.773
N2384 G01 X20.826 Y22.495
N2385 G01 X20.842 Y23.216
N2386 G01 X20.851 Y23.938
N2387 G01 X20.857 Y24.66
N2388 G01 X20.86 Y25.382
N2389 G01 X20.863 Y26.826
N2390 G01 X20.865 Y29.714
N2391 G01 Y30.752
N2392 G01 X20.862 Y30.842
N2393 G03 X20.859 Y30.87 I-0.3 J-0.011
N2394 G03 X20.264 Y30.793 I-0.298 J-0.038
N2395 G03 X20.708 Y30.569 I0.298 J0.038
N2396 G01 X21.558 Y31.042
N2397 G03 X21.267 Y31.567 I-0.146 J0.262
N2398 G03 X21.12 Y31.371 I0.146 J-0.262
N2399 G01 X21.1 Y31.283
N2400 G01 X21.062 Y31.087
N2401 G01 X21. Y30.912
N2402 G01 X21.013 Y30.707
N2403 G01 X21.118 Y30.502
N2404 G01 X21.33 Y30.328
N2405 G01 X21.96 Y30.25
N2406 G01 X22.679 Y30.186
N2407 G01 X23.4 Y30.146
N2408 G01 X24.122 Y30.122
N2409 G01 X24.844 Y30.107
N2410 G01 X25.565 Y30.098
N2411 G01 X26.287 Y30.092
N2412 G01 X27.009 Y30.089
N2413 G01 X28.453 Y30.086
N2414 G01 X29.175 Y30.084
N2415 G01 X29.897 Y30.089
N2416 G01 X30.258 Y30.083
N2417 G01 X30.71 Y30.086
N2418 G01 X30.8 Y30.085
N2419 G01 X30.824 Y30.086
N2420 G03 X30.819 Y30.246 I-0.003 J0.08
N2421 G03 X30.758 Y30.117 I0.003 J-0.08
N2422 G01 X31.22 Y29.532
N2423 G03 X31.346 Y29.631 I0.063 J0.05
N2424 G03 X31.3 Y29.66 I-0.063 J-0.05
N2425 G01 X31.277 Y29.665
N2426 G01 X31.249 Y29.67
N2427 G01 X30.974 Y29.811
N2428 G01 X30.774 Y29.823
N2429 G01 X30.566 Y29.748
N2430 G01 X30.505 Y29.544
N2431 G01 X30.444 Y29.31
N2432 G01 X30.387 Y29.054
N2433 G01 X30.327 Y28.726
N2434 G01 X30.27 Y28.348
N2435 G01 X30.212 Y27.834
N2436 G01 X30.155 Y27.114
N2437 G01 X30.124 Y26.393
N2438 G01 X30.107 Y25.671
N2439 G01 X30.097 Y24.949
N2440 G01 X30.092 Y24.227
N2441 G01 X30.089 Y23.505
N2442 G01 X30.086 Y22.061
N2443 G01 X30.084 Y20.617
N2444 G01 X30.087 Y19.896
N2445 G01 X30.085 Y19.535
N2446 G01 Y19.354
N2447 G01 X30.065 Y19.313
N2448 G01 X30.03 Y19.286
N2449 G01 X29.985 Y19.277
N2450 G01 X29.286 Y19.455
N2451 G01 X29.138 Y19.503
N2452 G01 X28.962 Y19.553
N2453 G01 X28.75 Y19.605
N2454 G01 X28.507 Y19.655
N2455 G01 X28.202 Y19.708
N2456 G01 X27.812 Y19.761
N2457 G01 X27.274 Y19.815
N2458 G01 X26.554 Y19.861
N2459 G01 X25.832 Y19.886
N2460 G01 X25.11 Y19.899
N2461 G01 X24.389 Y19.906
N2462 G01 X23.667 Y19.91
N2463 G01 X22.945 Y19.912
N2464 G01 X22.223 Y19.918
N2465 G01 X21.862 Y19.913
N2466 G01 X21.681 Y19.915
N2467 G01 X21.275 Y19.914
N2468 G01 X21.234 Y19.934
N2469 G01 X21.207 Y19.969
N2470 G01 X21.197 Y20.014
N2471 G01 X21.373 Y20.714
N2472 G01 X21.422 Y20.875
N2473 G01 X21.473 Y21.069
N2474 G01 X21.525 Y21.296
N2475 G01 X21.577 Y21.566
N2476 G01 X21.631 Y21.914
N2477 G01 X21.684 Y22.36
N2478 G01 X21.738 Y23.009
N2479 G01 X21.773 Y23.73
N2480 G01 X21.792 Y24.452
N2481 G01 X21.802 Y25.174
N2482 G01 X21.808 Y25.895
N2483 G01 X21.811 Y26.617
N2484 G01 X21.813 Y27.339
N2485 G01 X21.817 Y28.061
N2486 G01 X21.808 Y28.783
N2487 G01 X21.819 Y29.144
N2488 G01 X21.816 Y29.325
N2489 G01 X21.815 Y29.641
N2490 G01 X21.835 Y29.681
N2491 G01 X21.871 Y29.709
N2492 G01 X21.915 Y29.718
N2493 G01 X22.615 Y29.54
N2494 G01 X22.791 Y29.49
N2495 G01 X22.993 Y29.441
N2496 G01 X23.235 Y29.39
N2497 G01 X23.542 Y29.338
N2498 G01 X23.925 Y29.286
N2499 G01 X24.46 Y29.233
N2500 G01 X25.18 Y29.187
N2501 G01 X25.902 Y29.163
N2502 G01 X26.624 Y29.15
N2503 G01 X27.345 Y29.144
N2504 G01 X28.067 Y29.139
N2505 G01 X28.789 Y29.131
N2506 G01 X29.15 Y29.137
N2507 G01 X29.331 Y29.136
N2508 G01 X29.827 Y29.138
N2509 G03 X29.941 Y29.165 I-0.011 J0.3
N2510 G01 X30.002 Y29.192 Z9.972
N2511 G01 X30.06 Y29.219 Z9.95
N2512 G01 X30.111 Y29.242 Z9.915
N2513 G01 X30.154 Y29.262 Z9.867
N2514 G01 X30.187 Y29.277 Z9.81
N2515 G01 X30.207 Y29.286 Z9.747
N2516 G01 X30.214 Y29.289 Z9.68
N2517 G00 Z-3.01
N2518 G00 X21.093 Y20.27
N2519 G00 Z9.38
N2520 G01 Z9.68 F1500
N2521 G01 X21.086 Y20.272 Z9.747
N2522 G01 X21.064 Y20.278 Z9.81
N2523 G01 X21.03 Y20.288 Z9.867
N2524 G01 X20.984 Y20.3 Z9.915
N2525 G01 X20.929 Y20.316 Z9.95
N2526 G01 X20.868 Y20.333 Z9.972
N2527 G01 X20.804 Y20.351 Z9.98
N2528 G01 X20.691 Y20.383
N2529 G01 X21.333 Y20.298
N2530 G01 X21.621 Y20.157
N2531 G01 X21.83 Y20.147
N2532 G01 X22.049 Y20.23
N2533 G01 X22.252 Y20.426
N2534 G01 X22.351 Y20.844
N2535 G01 X22.438 Y21.28
N2536 G01 X22.522 Y21.792
N2537 G01 X22.597 Y22.381
N2538 G01 X22.664 Y23.1
N2539 G01 X22.705 Y23.821
N2540 G01 X22.729 Y24.542
N2541 G01 X22.744 Y25.264
N2542 G01 X22.753 Y25.986
N2543 G01 X22.758 Y26.708
N2544 G01 X22.77 Y27.43
N2545 G01 X22.752 Y28.152
N2546 G01 X22.761 Y28.332
N2547 G01 X22.76 Y28.512
N2548 G01 X22.759 Y28.693
N2549 G01 X22.763 Y28.918
N2550 G03 X22.163 Y28.912 I-0.3 J-0.003
N2551 G03 X22.488 Y28.616 I0.3 J0.003
N2552 G01 X30.51 Y29.272
N2553 G02 X30.559 Y28.674 I0.024 J-0.299
N2554 G02 X30.438 Y28.688 I-0.024 J0.299
N2555 G01 X30.327 Y28.726
N2556 G01 X30.298 Y28.731
N2557 G01 X30.023 Y28.872
N2558 G01 X29.824 Y28.884
N2559 G01 X29.615 Y28.809
N2560 G01 X29.555 Y28.605
N2561 G01 X29.493 Y28.368
N2562 G01 X29.437 Y28.112
N2563 G01 X29.376 Y27.784
N2564 G01 X29.319 Y27.401
N2565 G01 X29.261 Y26.883
N2566 G01 X29.205 Y26.163
N2567 G01 X29.174 Y25.442
N2568 G01 X29.157 Y24.72
N2569 G01 X29.147 Y23.998
N2570 G01 X29.142 Y23.276
N2571 G01 X29.139 Y22.554
N2572 G01 X29.131 Y21.832
N2573 G01 X29.147 Y21.11
N2574 G01 X29.128 Y20.75
N2575 G01 X29.134 Y20.569
N2576 G01 X29.137 Y20.028
N2577 G01 X29.14 Y19.938
N2578 G03 X29.74 Y19.96 I0.3 J0.011
N2579 G03 X29.341 Y20.232 I-0.3 J-0.011
N2580 G01 X28.339 Y19.883
N2581 G03 X28.536 Y19.316 I0.099 J-0.283
N2582 G03 X28.726 Y19.518 I-0.099 J0.283
N2583 G01 X28.75 Y19.605
N2584 G01 X28.783 Y19.735
N2585 G01 X28.877 Y19.884
N2586 G01 X28.908 Y20.079
N2587 G01 X28.853 Y20.291
N2588 G01 X28.699 Y20.489
N2589 G01 X28.35 Y20.56
N2590 G01 X27.895 Y20.636
N2591 G01 X27.4 Y20.7
N2592 G01 X26.729 Y20.763
N2593 G01 X26.008 Y20.806
N2594 G01 X25.287 Y20.831
N2595 G01 X24.567 Y20.889
N2596 G01 X24.212 Y20.821
N2597 G01 X23.687 Y20.901
N2598 G01 X23.512 Y20.855
N2599 G01 X23.332 Y20.859
N2600 G01 X23.061 Y20.862
N2601 G01 X22.926 Y20.863
N2602 G03 X22.811 Y20.837 I0.009 J-0.3
N2603 G01 X22.75 Y20.809 Z9.972
N2604 G01 X22.693 Y20.783 Z9.95
N2605 G01 X22.641 Y20.76 Z9.915
N2606 G01 X22.597 Y20.741 Z9.867
N2607 G01 X22.565 Y20.726 Z9.81
N2608 G01 X22.545 Y20.717 Z9.747
N2609 G01 X22.538 Y20.714 Z9.68
N2610 G00 Z-3.01
N2611 G00 X23.378 Y29.783
N2612 G00 Z9.38
N2613 G01 Z9.68 F1500
N2614 G01 X23.375 Y29.776 Z9.747
N2615 G01 X23.368 Y29.755 Z9.81
N2616 G01 X23.355 Y29.722 Z9.867
N2617 G01 X23.339 Y29.677 Z9.915
N2618 G01 X23.32 Y29.624 Z9.95
N2619 G01 X23.298 Y29.564 Z9.972
N2620 G01 X23.276 Y29.501 Z9.98
N2621 G01 X23.235 Y29.39
N2622 G01 X23.23 Y29.363
N2623 G01 X23.085 Y29.091
N2624 G01 X23.068 Y28.892
N2625 G01 X23.139 Y28.683
N2626 G01 X23.32 Y28.626
N2627 G01 X23.532 Y28.568
N2628 G01 X23.796 Y28.505
N2629 G01 X24.081 Y28.448
N2630 G01 X24.44 Y28.39
N2631 G01 X24.886 Y28.333
N2632 G01 X25.505 Y28.276
N2633 G01 X26.226 Y28.235
N2634 G01 X26.947 Y28.213
N2635 G01 X27.667 Y28.158
N2636 G01 X28.022 Y28.226
N2637 G01 X28.289 Y28.184
N2638 G01 X28.469 Y28.183
N2639 G01 X28.83 Y28.181
N2640 G01 X28.92 Y28.182
N2641 G03 X29.034 Y28.212 I-0.017 J0.3
N2642 G01 X29.094 Y28.241 Z9.972
N2643 G01 X29.151 Y28.268 Z9.95
N2644 G01 X29.202 Y28.293 Z9.915
N2645 G01 X29.245 Y28.313 Z9.867
N2646 G01 X29.277 Y28.329 Z9.81
N2647 G01 X29.297 Y28.338 Z9.747
N2648 G01 X29.304 Y28.342 Z9.68
N2649 G00 Z-3.01
N2650 G00 X22.044 Y21.42
N2651 G00 Z9.38
N2652 G01 Z9.68 F1500
N2653 G01 X22.052 Y21.417 Z9.747
N2654 G01 X22.072 Y21.41 Z9.81
N2655 G01 X22.106 Y21.398 Z9.867
N2656 G01 X22.151 Y21.382 Z9.915
N2657 G01 X22.205 Y21.363 Z9.95
N2658 G01 X22.264 Y21.342 Z9.972
N2659 G01 X22.327 Y21.32 Z9.98
N2660 G01 X22.438 Y21.28
N2661 G01 X22.467 Y21.275
N2662 G01 X22.739 Y21.131
N2663 G01 X22.939 Y21.115
N2664 G01 X23.15 Y21.187
N2665 G01 X23.341 Y21.361
N2666 G01 X23.428 Y21.849
N2667 G01 X23.508 Y22.409
N2668 G01 X23.579 Y23.079
N2669 G01 X23.63 Y23.799
N2670 G01 X23.663 Y24.52
N2671 G01 X23.683 Y25.242
N2672 G01 X23.696 Y25.964
N2673 G01 X23.723 Y26.686
N2674 G01 X23.679 Y27.406
N2675 G01 X23.692 Y27.496
N2676 G01 X23.7 Y27.585
N2677 G01 X23.708 Y27.766
N2678 G01 X23.706 Y27.946
N2679 G03 X23.107 Y27.917 I-0.3 J-0.015
N2680 G03 X23.44 Y27.634 I0.3 J0.015
N2681 G01 X29.55 Y28.329
N2682 G02 X29.618 Y27.732 I0.034 J-0.298
N2683 G02 X29.488 Y27.746 I-0.034 J0.298
N2684 G01 X29.376 Y27.784
N2685 G01 X29.242 Y27.809
N2686 G01 X29.087 Y27.896
N2687 G01 X28.891 Y27.916
N2688 G01 X28.682 Y27.85
N2689 G01 X28.493 Y27.686
N2690 G01 X28.423 Y27.272
N2691 G01 X28.355 Y26.753
N2692 G01 X28.291 Y26.092
N2693 G01 X28.247 Y25.371
N2694 G01 X28.221 Y24.649
N2695 G01 X28.206 Y23.928
N2696 G01 X28.197 Y23.206
N2697 G01 X28.177 Y22.484
N2698 G01 X28.209 Y21.763
N2699 G01 X28.201 Y21.673
N2700 G01 X28.197 Y21.583
N2701 G01 X28.193 Y21.402
N2702 G01 X28.194 Y21.267
N2703 G01 Y21.222
N2704 G01 X28.174 Y21.181
N2705 G01 X28.138 Y21.154
N2706 G01 X28.094 Y21.145
N2707 G01 X27.395 Y21.327
N2708 G01 X27.242 Y21.379
N2709 G01 X27.078 Y21.428
N2710 G01 X26.882 Y21.479
N2711 G01 X26.641 Y21.533
N2712 G01 X25.931 Y21.665
N2713 G01 X25.611 Y21.786
N2714 G01 X24.89 Y21.753
N2715 G01 X24.717 Y21.807
N2716 G01 X24.533 Y21.823
N2717 G01 X24.443 Y21.816
N2718 G01 X24.353 Y21.805
N2719 G01 X24.174 Y21.779
N2720 G01 X24.13 Y21.787
N2721 G01 X24.094 Y21.814
N2722 G01 X24.074 Y21.854
N2723 G01 X24.073 Y21.9
N2724 G01 X24.381 Y22.553
N2725 G01 X24.448 Y22.996
N2726 G01 X24.514 Y23.568
N2727 G01 X24.572 Y24.288
N2728 G01 X24.608 Y25.009
N2729 G01 X24.637 Y25.731
N2730 G01 X24.667 Y26.452
N2731 G01 X24.686 Y27.174
N2732 G01 X24.658 Y27.259
N2733 G01 X24.648 Y27.349
N2734 G01 X24.649 Y27.439
N2735 G01 X24.655 Y27.71
N2736 G01 X24.675 Y27.75
N2737 G01 X24.711 Y27.778
N2738 G01 X24.755 Y27.786
N2739 G01 X25.452 Y27.598
N2740 G01 X26.152 Y27.42
N2741 G01 X26.424 Y27.284
N2742 G01 X27.145 Y27.244
N2743 G01 X27.45 Y27.222
N2744 G01 X27.863 Y27.198
N2745 G01 X27.948 Y27.229
N2746 G03 X27.722 Y27.785 I-0.113 J0.278
N2747 G03 X27.535 Y27.518 I0.113 J-0.278
N2748 G01 X27.301 Y20.705
N2749 G03 X27.895 Y20.636 I0.3 J-0.01
N2750 G01 X28.028 Y21.434
N2751 G01 X28.085 Y21.62
N2752 G01 X28.061 Y21.834
N2753 G01 X27.937 Y22.051
N2754 G01 X27.663 Y22.256
N2755 G01 X26.959 Y22.415
N2756 G01 X26.304 Y22.607
N2757 G01 X26.259 Y22.602
N2758 G01 X25.54 Y22.664
N2759 G01 X25.446 Y22.684
N2760 G01 X25.356 Y22.696
N2761 G01 X25.176 Y22.709
N2762 G01 X25.131
N2763 G01 X25.086 Y22.713
N2764 G01 X25.048 Y22.737
N2765 G01 X25.024 Y22.776
N2766 G01 X25.019 Y22.82
N2767 G01 X25.268 Y23.498
N2768 G01 X25.327 Y23.773
N2769 G01 X25.387 Y24.113
N2770 G01 X25.487 Y24.828
N2771 G01 X25.597 Y25.213
N2772 G01 X25.55 Y25.571
N2773 G01 X25.649 Y26.16
N2774 G01 X25.606 Y26.335
N2775 G01 X25.618 Y26.515
N2776 G01 X25.629 Y26.876
N2777 G01 X25.631 Y26.966
N2778 G03 X24.977 Y27.553 I-0.595 J-0.005
N2779 G03 X24.453 Y26.847 I0.06 J-0.592
N2780 G01 X25.482 Y21.569
N2781 G03 X26.641 Y21.533 I0.584 J0.114
N2782 G01 X26.955 Y22.942
N2783 G01 X26.917 Y23.159
N2784 G01 X26.783 Y23.362
N2785 G01 X26.554 Y23.512
N2786 G01 X26.376 Y23.543
N2787 G01 X26.016 Y23.576
N2788 G01 X25.926 Y23.584
N2789 G01 X25.888 Y23.607
N2790 G01 X25.863 Y23.645
N2791 G01 X25.858 Y23.69
N2792 G01 X25.873 Y23.732
N2793 G01 X26.283 Y24.138
N2794 G01 X26.431 Y24.505
N2795 G01 X26.426 Y24.686
N2796 G01 X26.562 Y25.104
N2797 G01 X26.527 Y25.463
N2798 G01 X26.52 Y26.185
N2799 G01 X26.544 Y26.316
N2800 G01 X26.563 Y26.495
N2801 G01 X26.572 Y26.675
N2802 G01 X26.593 Y26.715
N2803 G01 X26.63 Y26.741
N2804 G01 X26.674 Y26.749
N2805 G01 X26.717 Y26.736
N2806 G01 X27.12 Y26.366
N2807 G01 X27.469 Y26.245
N2808 G01 X27.559 Y26.251
N2809 G01 X27.65
N2810 G01 X27.69 Y26.231
N2811 G01 X27.717 Y26.195
N2812 G01 X27.726 Y26.151
N2813 G01 X27.715 Y26.107
N2814 G01 X27.383 Y25.725
N2815 G01 X27.27 Y25.366
N2816 G01 X27.308 Y25.007
N2817 G01 X27.221 Y24.381
N2818 G01 X27.27 Y24.207
N2819 G01 X27.228 Y23.486
N2820 G01 X27.266 Y23.127
N2821 G01 X27.255 Y23.038
N2822 G01 X27.247 Y22.948
N2823 G01 Y22.933 Z9.979
N2824 G01 X27.254 Y22.893 Z9.966
N2825 G01 X27.259 Y22.861 Z9.94
N2826 G01 X27.263 Y22.839 Z9.904
N2827 G01 X27.264 Y22.832 Z9.862
N2828 G00 Z-3.01
N2829 G00 X9.706 Y6.562
N2830 G00 Z14.37
N2831 G01 Z14.67 F1500
N2832 G01 X9.708 Y6.57 Z14.737
N2833 G01 X9.713 Y6.591 Z14.8
N2834 G01 X9.722 Y6.626 Z14.857
N2835 G01 X9.734 Y6.672 Z14.905
N2836 G01 X9.748 Y6.727 Z14.94
N2837 G01 X9.764 Y6.788 Z14.962
N2838 G01 X9.78 Y6.853 Z14.97
N2839 G03 X10.015 Y8.486 I-7.419 J1.9
N2840 G01 Y8.576
N2841 G01 X9.75 Y9.248
N2842 G01 X9.608 Y9.956
N2843 G01 X9.536 Y10.674
N2844 G01 X9.499 Y11.395
N2845 G01 X9.482 Y12.117
N2846 G01 X9.473 Y12.839
N2847 G01 X9.469 Y13.561
N2848 G01 X9.467 Y14.283
N2849 G01 X9.465 Y16.449
N2850 G01 Y38.831
N2851 G01 X9.578 Y39.174
N2852 G01 X9.789 Y39.467
N2853 G01 X10.328 Y39.947
N2854 G01 X10.992 Y40.229
N2855 G01 X11.698 Y40.381
N2856 G01 X12.416 Y40.459
N2857 G01 X13.137 Y40.498
N2858 G01 X13.859 Y40.517
N2859 G01 X14.581 Y40.526
N2860 G01 X15.303 Y40.531
N2861 G01 X16.025 Y40.533
N2862 G01 X18.191 Y40.535
N2863 G01 X29.02
N2864 G01 X38.767
N2865 G01 X39.117 Y40.446
N2866 G01 X39.42 Y40.249
N2867 G01 X39.918 Y39.727
N2868 G01 X40.212 Y39.067
N2869 G01 X40.372 Y38.363
N2870 G01 X40.455 Y37.646
N2871 G01 X40.496 Y36.925
N2872 G01 X40.516 Y36.203
N2873 G01 X40.526 Y35.481
N2874 G01 X40.531 Y34.76
N2875 G01 X40.533 Y34.038
N2876 G01 X40.535 Y31.872
N2877 G01 Y11.295
N2878 G01 X40.504 Y11.117
N2879 G01 X40.373 Y10.78
N2880 G01 X40.152 Y10.495
N2881 G01 X39.6 Y10.029
N2882 G01 X38.931 Y9.758
N2883 G01 X38.224 Y9.612
N2884 G01 X37.506 Y9.538
N2885 G01 X36.785 Y9.5
N2886 G01 X36.063 Y9.482
N2887 G01 X35.341 Y9.473
N2888 G01 X34.619 Y9.469
N2889 G01 X33.897 Y9.467
N2890 G01 X31.731 Y9.465
N2891 G01 X30.287
N2892 G01 X12.237
N2893 G01 X11.893 Y9.573
N2894 G01 X11.592 Y9.772
N2895 G01 X11.088 Y10.29
N2896 G01 X10.848 Y10.433
N2897 G01 X10.562 Y10.47
N2898 G01 X10.382 Y10.467
N2899 G01 X10.292 Y10.466
N2900 G01 X10.251 Y10.486
N2901 G01 X10.223 Y10.521
N2902 G01 X10.214 Y10.565
N2903 G01 X10.301 Y10.916
N2904 G01 X10.343 Y11.358
N2905 G01 X10.386 Y12.079
N2906 G01 X10.403 Y12.801
N2907 G01 X10.41 Y13.523
N2908 G01 X10.413 Y14.245
N2909 G01 X10.415 Y15.689
N2910 G01 Y37.348
N2911 G01 X10.508 Y38.064
N2912 G01 X10.458 Y38.238
N2913 G01 X10.469 Y38.599
N2914 G01 X10.467 Y38.734
N2915 G01 X10.506 Y38.816
N2916 G01 X10.759 Y39.073
N2917 G01 X11.072 Y39.253
N2918 G01 X11.759 Y39.475
N2919 G01 X12.48 Y39.513
N2920 G01 X13.201 Y39.546
N2921 G01 X13.923 Y39.562
N2922 G01 X14.645 Y39.572
N2923 G01 X15.367 Y39.578
N2924 G01 X16.089 Y39.581
N2925 G01 X17.533 Y39.584
N2926 G01 X21.864 Y39.585
N2927 G01 X37.748
N2928 G01 X38.103 Y39.516
N2929 G01 X38.462 Y39.551
N2930 G01 X38.642 Y39.539
N2931 G01 X38.687 Y39.538
N2932 G01 X38.731 Y39.526
N2933 G01 X38.811 Y39.486
N2934 G01 X38.947 Y39.366
N2935 G01 X39.072 Y39.237
N2936 G01 X39.256 Y38.926
N2937 G01 X39.463 Y38.234
N2938 G01 X39.507 Y37.514
N2939 G01 X39.561 Y36.794
N2940 G01 X39.569 Y36.072
N2941 G01 X39.575 Y35.35
N2942 G01 X39.579 Y34.628
N2943 G01 X39.582 Y33.906
N2944 G01 X39.584 Y32.462
N2945 G01 X39.585 Y26.686
N2946 G01 Y16.578
N2947 G01 Y12.246
N2948 G01 X39.516 Y11.892
N2949 G01 X39.551 Y11.532
N2950 G01 X39.539 Y11.352
N2951 G01 X39.531 Y11.308
N2952 G01 X39.494 Y11.225
N2953 G01 X39.38 Y11.086
N2954 G01 X39.103 Y10.854
N2955 G01 X38.435 Y10.58
N2956 G01 X37.715 Y10.521
N2957 G01 X37. Y10.425
N2958 G01 X36.278 Y10.426
N2959 G01 X34.112 Y10.418
N2960 G01 X31.946 Y10.416
N2961 G01 X13.896 Y10.415
N2962 G01 X13.174 Y10.424
N2963 G01 X12.682 Y10.505
N2964 G01 X12.507 Y10.461
N2965 G01 X12.327 Y10.464
N2966 G01 X12.244 Y10.499
N2967 G01 X11.678 Y10.948
N2968 G01 X11.442 Y11.207
N2969 G01 X11.342 Y11.252
N2970 G01 X11.258 Y11.286
N2971 G01 X11.173 Y11.315
N2972 G01 X11.129 Y11.327
N2973 G01 X11.085 Y11.338
N2974 G01 X11.051 Y11.367
N2975 G01 X11.032 Y11.408
N2976 G01 X11.059 Y12.13
N2977 G01 X11.105 Y12.328
N2978 G01 X11.151 Y12.566
N2979 G01 X11.198 Y12.866
N2980 G01 X11.246 Y13.257
N2981 G01 X11.294 Y13.818
N2982 G01 X11.331 Y14.539
N2983 G01 X11.349 Y15.261
N2984 G01 X11.357 Y15.983
N2985 G01 X11.361 Y16.705
N2986 G01 X11.363 Y17.427
N2987 G01 X11.365 Y19.593
N2988 G01 Y27.535
N2989 G01 Y37.643
N2990 G01 X11.474 Y37.987
N2991 G01 X11.452 Y38.166
N2992 G01 X11.432 Y38.254
N2993 G01 X11.424 Y38.344
N2994 G01 X11.423 Y38.389
N2995 G01 X11.441 Y38.43
N2996 G01 X11.476 Y38.459
N2997 G01 X12.179 Y38.626
N2998 G01 X12.901 Y38.615
N2999 G01 X13.622 Y38.616
N3000 G01 X15.066 Y38.625
N3001 G01 X15.788 Y38.631
N3002 G01 X17.954 Y38.635
N3003 G01 X38.17
N3004 G01 X38.26 Y38.622
N3005 G01 X38.304 Y38.617
N3006 G01 X38.343 Y38.593
N3007 G01 X38.39 Y38.516
N3008 G01 X38.589 Y37.822
N3009 G01 X38.603 Y37.1
N3010 G01 X38.613 Y36.378
N3011 G01 X38.631 Y35.656
N3012 G01 X38.63 Y34.934
N3013 G01 X38.634 Y32.768
N3014 G01 X38.635 Y28.436
N3015 G01 Y26.27
N3016 G01 Y11.83
N3017 G01 X38.621 Y11.741
N3018 G01 X38.617 Y11.696
N3019 G01 X38.593 Y11.658
N3020 G01 X38.439 Y11.563
N3021 G01 X37.735 Y11.404
N3022 G01 X37.013 Y11.389
N3023 G01 X36.293 Y11.338
N3024 G01 X35.571 Y11.355
N3025 G01 X34.849 Y11.362
N3026 G01 X34.127 Y11.365
N3027 G01 X32.683 Y11.366
N3028 G01 X13.911 Y11.365
N3029 G01 X13.19 Y11.373
N3030 G01 X12.699 Y11.477
N3031 G01 X12.611 Y11.459
N3032 G01 X12.567 Y11.45
N3033 G01 X12.523 Y11.46
N3034 G01 X12.245 Y11.691
N3035 G01 X12.056 Y11.946
N3036 G01 X11.978 Y11.991
N3037 G01 X11.938 Y12.012
N3038 G01 X11.912 Y12.049
N3039 G01 X11.904 Y12.093
N3040 G01 X11.978 Y12.408
N3041 G01 X12.043 Y12.737
N3042 G01 X12.112 Y13.166
N3043 G01 X12.171 Y13.641
N3044 G01 X12.23 Y14.303
N3045 G01 X12.268 Y15.024
N3046 G01 X12.29 Y15.745
N3047 G01 X12.301 Y16.467
N3048 G01 X12.308 Y17.189
N3049 G01 X12.311 Y17.911
N3050 G01 X12.314 Y19.355
N3051 G01 X12.315 Y20.799
N3052 G01 Y37.405
N3053 G01 X12.343 Y37.583
N3054 G01 X12.368 Y37.67
N3055 G01 X12.387 Y37.758
N3056 G01 X12.393 Y37.803
N3057 G01 X12.418 Y37.841
N3058 G01 X12.457 Y37.863
N3059 G01 X13.178 Y37.91
N3060 G01 X13.42 Y37.866
N3061 G01 X13.727 Y37.822
N3062 G01 X14.13 Y37.779
N3063 G01 X14.745 Y37.734
N3064 G01 X15.466 Y37.707
N3065 G01 X16.188 Y37.694
N3066 G01 X16.91 Y37.689
N3067 G01 X17.632 Y37.687
N3068 G01 X19.798 Y37.685
N3069 G01 X37.803
N3070 G01 X37.843 Y37.665
N3071 G01 X37.871 Y37.63
N3072 G01 X37.88 Y37.585
N3073 G01 X37.702 Y36.886
N3074 G01 X37.691 Y36.164
N3075 G01 X37.686 Y35.442
N3076 G01 X37.684 Y34.72
N3077 G01 Y33.276
N3078 G01 X37.685 Y29.666
N3079 G01 Y12.203
N3080 G01 X37.665 Y12.162
N3081 G01 X37.63 Y12.134
N3082 G01 X37.585 Y12.125
N3083 G01 X36.886 Y12.304
N3084 G01 X36.164 Y12.305
N3085 G01 X35.442 Y12.274
N3086 G01 X34.721 Y12.295
N3087 G01 X33.999 Y12.306
N3088 G01 X33.277 Y12.311
N3089 G01 X32.555 Y12.313
N3090 G01 X31.111 Y12.315
N3091 G01 X13.783
N3092 G01 X13.061 Y12.328
N3093 G01 X13.019 Y12.344
N3094 G01 X12.976 Y12.36
N3095 G01 X12.943 Y12.389
N3096 G01 X12.911 Y12.422
N3097 G01 X12.896 Y12.464
N3098 G01 X12.991 Y13.18
N3099 G01 X13.064 Y13.668
N3100 G01 X13.129 Y14.238
N3101 G01 X13.185 Y14.958
N3102 G01 X13.219 Y15.679
N3103 G01 X13.238 Y16.401
N3104 G01 X13.25 Y17.123
N3105 G01 X13.257 Y17.845
N3106 G01 X13.26 Y18.567
N3107 G01 X13.264 Y20.011
N3108 G01 Y20.733
N3109 G01 X13.265 Y31.563
N3110 G01 Y37.158
N3111 G01 X13.266 Y37.203
N3112 G01 X13.286 Y37.244
N3113 G01 X13.322 Y37.271
N3114 G01 X13.366 Y37.28
N3115 G01 X14.064 Y37.093
N3116 G01 X14.258 Y37.043
N3117 G01 X14.479 Y36.994
N3118 G01 X14.755 Y36.944
N3119 G01 X15.094 Y36.894
N3120 G01 X15.549 Y36.843
N3121 G01 X16.207 Y36.793
N3122 G01 X16.929 Y36.764
N3123 G01 X17.651 Y36.749
N3124 G01 X18.373 Y36.742
N3125 G01 X19.095 Y36.738
N3126 G01 X20.539 Y36.736
N3127 G01 X28.48 Y36.735
N3128 G01 X37.054
N3129 G01 X37.095 Y36.715
N3130 G01 X37.122 Y36.68
N3131 G01 X37.132 Y36.635
N3132 G01 X36.953 Y35.936
N3133 G01 X36.907 Y35.656
N3134 G01 X36.86 Y35.292
N3135 G01 X36.813 Y34.783
N3136 G01 X36.771 Y34.062
N3137 G01 X36.752 Y33.34
N3138 G01 X36.743 Y32.618
N3139 G01 X36.739 Y31.896
N3140 G01 X36.737 Y31.174
N3141 G01 X36.735 Y29.008
N3142 G01 Y26.842
N3143 G01 Y12.944
N3144 G01 X36.715 Y12.903
N3145 G01 X36.68 Y12.876
N3146 G01 X36.635 Y12.866
N3147 G01 X35.936 Y13.045
N3148 G01 X35.593 Y13.097
N3149 G01 X35.136 Y13.149
N3150 G01 X34.478 Y13.201
N3151 G01 X33.757 Y13.233
N3152 G01 X33.035 Y13.249
N3153 G01 X32.313 Y13.257
N3154 G01 X31.591 Y13.261
N3155 G01 X30.869 Y13.263
N3156 G01 X28.703 Y13.265
N3157 G01 X13.812
N3158 G01 X13.631 Y13.268
N3159 G01 X13.591 Y13.289
N3160 G01 X13.564 Y13.325
N3161 G01 X13.556 Y13.369
N3162 G01 X13.746 Y14.066
N3163 G01 X13.797 Y14.221
N3164 G01 X13.849 Y14.406
N3165 G01 X13.899 Y14.609
N3166 G01 X13.952 Y14.858
N3167 G01 X14.005 Y15.168
N3168 G01 X14.059 Y15.556
N3169 G01 X14.113 Y16.089
N3170 G01 X14.16 Y16.809
N3171 G01 X14.185 Y17.531
N3172 G01 X14.199 Y18.252
N3173 G01 X14.206 Y18.974
N3174 G01 X14.21 Y19.696
N3175 G01 X14.214 Y21.14
N3176 G01 X14.215 Y24.75
N3177 G01 Y26.194
N3178 G01 Y36.483
N3179 G03 X14.188 Y36.597 I-0.3 J-0.01
N3180 G01 X14.16 Y36.657 Z14.962
N3181 G01 X14.134 Y36.715 Z14.94
N3182 G01 X14.111 Y36.767 Z14.905
N3183 G01 X14.091 Y36.81 Z14.857
N3184 G01 X14.076 Y36.843 Z14.8
N3185 G01 X14.067 Y36.863 Z14.737
N3186 G01 X14.064 Y36.87 Z14.67
N3187 G00 Z-3.01
N3188 G00 X13.464 Y13.548
N3189 G00 Z14.37
N3190 G01 Z14.67 F1500
N3191 G01 X13.457 Y13.55 Z14.737
N3192 G01 X13.436 Y13.557 Z14.8
N3193 G01 X13.401 Y13.567 Z14.857
N3194 G01 X13.356 Y13.581 Z14.905
N3195 G01 X13.301 Y13.597 Z14.94
N3196 G01 X13.241 Y13.615 Z14.962
N3197 G01 X13.177 Y13.635 Z14.97
N3198 G01 X13.064 Y13.668
N3199 G01 X13.813 Y13.556
N3200 G01 X13.98 Y13.473
N3201 G01 X14.189 Y13.462
N3202 G01 X14.41 Y13.543
N3203 G01 X14.617 Y13.74
N3204 G01 X14.72 Y14.149
N3205 G01 X14.809 Y14.568
N3206 G01 X14.891 Y15.026
N3207 G01 X14.97 Y15.585
N3208 G01 X15.04 Y16.239
N3209 G01 X15.091 Y16.959
N3210 G01 X15.121 Y17.68
N3211 G01 X15.14 Y18.402
N3212 G01 X15.15 Y19.124
N3213 G01 X15.157 Y19.846
N3214 G01 X15.16 Y20.568
N3215 G01 X15.164 Y22.012
N3216 G01 X15.165 Y25.622
N3217 G01 Y36.271
N3218 G01 X15.185 Y36.312
N3219 G01 X15.22 Y36.34
N3220 G01 X15.265 Y36.349
N3221 G01 X15.964 Y36.17
N3222 G01 X16.127 Y36.124
N3223 G01 X16.322 Y36.076
N3224 G01 X16.55 Y36.028
N3225 G01 X16.831 Y35.979
N3226 G01 X17.192 Y35.929
N3227 G01 X17.684 Y35.879
N3228 G01 X18.404 Y35.832
N3229 G01 X19.126 Y35.808
N3230 G01 X19.847 Y35.797
N3231 G01 X20.569 Y35.791
N3232 G01 X21.291 Y35.788
N3233 G01 X22.735 Y35.786
N3234 G01 X34.287 Y35.785
N3235 G01 X36.363
N3236 G01 X36.453 Y35.788
N3237 G03 X36.481 Y35.79 I-0.01 J0.3
N3238 G03 X36.404 Y36.386 I-0.038 J0.298
N3239 G03 X36.165 Y35.973 I0.038 J-0.298
N3240 G01 X36.623 Y34.866
N3241 G03 X37.177 Y35.096 I0.277 J0.115
N3242 G03 X36.949 Y35.277 I-0.277 J-0.115
N3243 G01 X36.86 Y35.292
N3244 G01 X36.831 Y35.295
N3245 G01 X36.55 Y35.42
N3246 G01 X36.349 Y35.422
N3247 G01 X36.144 Y35.335
N3248 G01 X36.094 Y35.135
N3249 G01 X36.042 Y34.89
N3250 G01 X35.988 Y34.587
N3251 G01 X35.937 Y34.218
N3252 G01 X35.885 Y33.715
N3253 G01 X35.836 Y32.995
N3254 G01 X35.811 Y32.273
N3255 G01 X35.798 Y31.551
N3256 G01 X35.792 Y30.829
N3257 G01 X35.788 Y30.107
N3258 G01 X35.786 Y28.663
N3259 G01 X35.785 Y21.443
N3260 G01 Y13.682
N3261 G01 X35.765 Y13.641
N3262 G01 X35.73 Y13.614
N3263 G01 X35.685 Y13.605
N3264 G01 X34.986 Y13.783
N3265 G01 X34.842 Y13.829
N3266 G01 X34.674 Y13.876
N3267 G01 X34.472 Y13.925
N3268 G01 X34.231 Y13.975
N3269 G01 X33.939 Y14.024
N3270 G01 X33.558 Y14.075
N3271 G01 X33.038 Y14.125
N3272 G01 X32.317 Y14.17
N3273 G01 X31.596 Y14.192
N3274 G01 X30.874 Y14.203
N3275 G01 X30.152 Y14.209
N3276 G01 X29.43 Y14.212
N3277 G01 X27.986 Y14.214
N3278 G01 X17.156 Y14.215
N3279 G01 X15.306
N3280 G01 X15.282 Y14.214
N3281 G03 X15.287 Y14.054 I0.003 J-0.08
N3282 G03 X15.343 Y14.189 I-0.003 J0.08
N3283 G01 X14.864 Y14.705
N3284 G03 X14.747 Y14.597 I-0.059 J-0.054
N3285 G03 X14.786 Y14.573 I0.059 J0.054
N3286 G01 X14.809 Y14.568
N3287 G01 X14.964 Y14.534
N3288 G01 X15.125 Y14.451
N3289 G01 X15.327 Y14.437
N3290 G01 X15.537 Y14.512
N3291 G01 X15.726 Y14.687
N3292 G01 X15.812 Y15.154
N3293 G01 X15.895 Y15.722
N3294 G01 X15.97 Y16.398
N3295 G01 X16.025 Y17.118
N3296 G01 X16.059 Y17.839
N3297 G01 X16.081 Y18.561
N3298 G01 X16.095 Y19.283
N3299 G01 X16.103 Y20.005
N3300 G01 X16.108 Y20.727
N3301 G01 X16.111 Y21.449
N3302 G01 X16.114 Y22.893
N3303 G01 X16.115 Y27.225
N3304 G01 Y35.528
N3305 G01 X16.112 Y35.618
N3306 G03 X15.512 Y35.597 I-0.3 J-0.01
N3307 G03 X15.927 Y35.33 I0.3 J0.01
N3308 G01 X16.978 Y35.766
N3309 G03 X16.748 Y36.32 I-0.115 J0.277
N3310 G03 X16.579 Y36.142 I0.115 J-0.277
N3311 G03 X16.571 Y36.115 I0.283 J-0.099
N3312 G01 X16.55 Y36.028
N3313 G01 X16.544 Y36.
N3314 G01 X16.399 Y35.729
N3315 G01 X16.382 Y35.531
N3316 G01 X16.453 Y35.321
N3317 G01 X16.631 Y35.265
N3318 G01 X16.848 Y35.206
N3319 G01 X17.11 Y35.144
N3320 G01 X17.386 Y35.089
N3321 G01 X17.745 Y35.031
N3322 G01 X18.177 Y34.976
N3323 G01 X18.784 Y34.921
N3324 G01 X19.505 Y34.881
N3325 G01 X20.227 Y34.859
N3326 G01 X20.949 Y34.848
N3327 G01 X21.671 Y34.842
N3328 G01 X22.393 Y34.839
N3329 G01 X23.837 Y34.836
N3330 G01 X29.613 Y34.835
N3331 G01 X35.479
N3332 G01 X35.503 Y34.836
N3333 G03 X35.497 Y34.996 I-0.003 J0.08
N3334 G03 X35.449 Y34.854 I0.003 J-0.08
N3335 G01 X35.944 Y34.442
N3336 G03 X36.047 Y34.565 I0.051 J0.062
N3337 G03 X36.012 Y34.582 I-0.051 J-0.062
N3338 G01 X35.988 Y34.587
N3339 G01 X35.791 Y34.622
N3340 G01 X35.616 Y34.682
N3341 G01 X35.411 Y34.666
N3342 G01 X35.207 Y34.558
N3343 G01 X35.145 Y34.288
N3344 G01 X35.089 Y34.004
N3345 G01 X35.029 Y33.631
N3346 G01 X34.974 Y33.185
N3347 G01 X34.918 Y32.552
N3348 G01 X34.88 Y31.831
N3349 G01 X34.859 Y31.109
N3350 G01 X34.848 Y30.387
N3351 G01 X34.842 Y29.665
N3352 G01 X34.839 Y28.943
N3353 G01 X34.836 Y27.499
N3354 G01 X34.835 Y21.723
N3355 G01 Y14.413
N3356 G01 X34.838 Y14.323
N3357 G03 X34.84 Y14.295 I0.3 J0.01
N3358 G03 X35.436 Y14.372 I0.298 J0.038
N3359 G03 X35.05 Y14.62 I-0.298 J-0.038
N3360 G01 X33.83 Y14.245
N3361 G03 X34.007 Y13.671 I0.088 J-0.287
N3362 G03 X34.202 Y13.86 I-0.088 J0.287
N3363 G03 X34.21 Y13.887 I-0.284 J0.097
N3364 G01 X34.231 Y13.975
N3365 G01 X34.237 Y14.003
N3366 G01 X34.381 Y14.274
N3367 G01 X34.397 Y14.473
N3368 G01 X34.325 Y14.682
N3369 G01 X34.148 Y14.737
N3370 G01 X33.934 Y14.795
N3371 G01 X33.669 Y14.858
N3372 G01 X33.389 Y14.913
N3373 G01 X33.029 Y14.971
N3374 G01 X32.586 Y15.026
N3375 G01 X31.964 Y15.081
N3376 G01 X31.243 Y15.12
N3377 G01 X30.522 Y15.141
N3378 G01 X29.8 Y15.152
N3379 G01 X29.078 Y15.158
N3380 G01 X28.356 Y15.161
N3381 G01 X26.912 Y15.164
N3382 G01 X21.136 Y15.165
N3383 G01 X16.443
N3384 G01 X16.402 Y15.185
N3385 G01 X16.375 Y15.22
N3386 G01 X16.365 Y15.265
N3387 G01 X16.544 Y15.964
N3388 G01 X16.594 Y16.106
N3389 G01 X16.645 Y16.27
N3390 G01 X16.699 Y16.468
N3391 G01 X16.752 Y16.693
N3392 G01 X16.806 Y16.965
N3393 G01 X16.862 Y17.31
N3394 G01 X16.918 Y17.75
N3395 G01 X16.974 Y18.37
N3396 G01 X17.014 Y19.091
N3397 G01 X17.036 Y19.813
N3398 G01 X17.048 Y20.535
N3399 G01 X17.055 Y21.257
N3400 G01 X17.059 Y21.979
N3401 G01 X17.063 Y23.423
N3402 G01 X17.065 Y26.311
N3403 G01 Y34.614
N3404 G01 X17.062 Y34.704
N3405 G03 X16.462 Y34.683 I-0.3 J-0.01
N3406 G03 X16.884 Y34.419 I0.3 J0.01
N3407 G01 X17.82 Y34.834
N3408 G03 X17.577 Y35.382 I-0.122 J0.274
N3409 G03 X17.406 Y35.177 I0.122 J-0.274
N3410 G01 X17.386 Y35.089
N3411 G01 X17.355 Y34.935
N3412 G01 X17.274 Y34.774
N3413 G01 X17.263 Y34.574
N3414 G01 X17.339 Y34.366
N3415 G01 X17.517 Y34.179
N3416 G01 X17.976 Y34.106
N3417 G01 X18.529 Y34.038
N3418 G01 X19.248 Y33.976
N3419 G01 X19.969 Y33.938
N3420 G01 X20.691 Y33.915
N3421 G01 X21.413 Y33.902
N3422 G01 X22.135 Y33.895
N3423 G01 X22.857 Y33.89
N3424 G01 X23.579 Y33.888
N3425 G01 X25.023 Y33.886
N3426 G01 X32.964 Y33.885
N3427 G01 X34.499
N3428 G01 X34.523 Y33.886
N3429 G03 X34.517 Y34.046 I-0.003 J0.08
N3430 G03 X34.47 Y33.904 I0.003 J-0.08
N3431 G01 X34.987 Y33.485
N3432 G03 X35.087 Y33.61 I0.05 J0.062
N3433 G03 X35.053 Y33.626 I-0.05 J-0.062
N3434 G01 X35.029 Y33.631
N3435 G01 X34.873 Y33.656
N3436 G01 X34.707 Y33.73
N3437 G01 X34.506 Y33.734
N3438 G01 X34.3 Y33.649
N3439 G01 X34.12 Y33.464
N3440 G01 X34.052 Y32.936
N3441 G01 X33.987 Y32.256
N3442 G01 X33.944 Y31.535
N3443 G01 X33.919 Y30.814
N3444 G01 X33.904 Y30.092
N3445 G01 X33.896 Y29.37
N3446 G01 X33.891 Y28.648
N3447 G01 X33.888 Y27.926
N3448 G01 X33.886 Y26.482
N3449 G01 X33.885 Y20.706
N3450 G01 Y15.381
N3451 G01 X33.886 Y15.357
N3452 G03 X34.046 Y15.363 I0.08 J0.003
N3453 G03 X33.921 Y15.426 I-0.08 J-0.003
N3454 G01 X33.261 Y14.973
N3455 G03 X33.351 Y14.841 I0.045 J-0.066
N3456 G03 X33.384 Y14.889 I-0.045 J0.066
N3457 G01 X33.389 Y14.913
N3458 G01 X33.395 Y14.941
N3459 G01 X33.538 Y15.214
N3460 G01 X33.553 Y15.413
N3461 G01 X33.48 Y15.622
N3462 G01 X33.274 Y15.685
N3463 G01 X33.065 Y15.741
N3464 G01 X32.806 Y15.801
N3465 G01 X32.492 Y15.862
N3466 G01 X32.128 Y15.919
N3467 G01 X31.649 Y15.977
N3468 G01 X30.985 Y16.034
N3469 G01 X30.264 Y16.071
N3470 G01 X29.542 Y16.091
N3471 G01 X28.82 Y16.102
N3472 G01 X28.098 Y16.108
N3473 G01 X27.376 Y16.111
N3474 G01 X25.932 Y16.114
N3475 G01 X20.878 Y16.115
N3476 G01 X17.178
N3477 G01 X17.088 Y16.112
N3478 G03 X17.109 Y15.512 I0.01 J-0.3
N3479 G03 X17.386 Y15.897 I-0.01 J0.3
N3480 G01 X17.032 Y17.092
N3481 G03 X16.457 Y16.921 I-0.288 J-0.085
N3482 G03 X16.639 Y16.725 I0.288 J0.085
N3483 G03 X16.665 Y16.717 I0.105 J0.281
N3484 G01 X16.752 Y16.693
N3485 G01 X16.78 Y16.687
N3486 G01 X17.046 Y16.535
N3487 G01 X17.245 Y16.514
N3488 G01 X17.456 Y16.579
N3489 G01 X17.517 Y16.759
N3490 G01 X17.581 Y16.978
N3491 G01 X17.642 Y17.211
N3492 G01 X17.703 Y17.487
N3493 G01 X17.766 Y17.829
N3494 G01 X17.826 Y18.228
N3495 G01 X17.885 Y18.757
N3496 G01 X17.941 Y19.477
N3497 G01 X17.972 Y20.198
N3498 G01 X17.991 Y20.92
N3499 G01 X18.001 Y21.642
N3500 G01 X18.007 Y22.364
N3501 G01 X18.01 Y23.086
N3502 G01 X18.013 Y24.53
N3503 G01 X18.015 Y28.14
N3504 G01 Y33.465
N3505 G01 X18.035 Y33.505
N3506 G01 X18.07 Y33.533
N3507 G01 X18.115 Y33.542
N3508 G01 X18.814 Y33.364
N3509 G01 X18.975 Y33.315
N3510 G01 X19.167 Y33.265
N3511 G01 X19.4 Y33.213
N3512 G01 X19.67 Y33.162
N3513 G01 X20.021 Y33.109
N3514 G01 X20.475 Y33.057
N3515 G01 X21.144 Y33.004
N3516 G01 X21.866 Y32.972
N3517 G01 X22.587 Y32.955
N3518 G01 X23.309 Y32.946
N3519 G01 X24.031 Y32.941
N3520 G01 X24.753 Y32.938
N3521 G01 X26.197 Y32.936
N3522 G01 X33.417 Y32.935
N3523 G01 X33.458 Y32.915
N3524 G01 X33.485 Y32.88
N3525 G01 X33.495 Y32.835
N3526 G01 X33.316 Y32.136
N3527 G01 X33.268 Y31.956
N3528 G01 X33.219 Y31.744
N3529 G01 X33.168 Y31.483
N3530 G01 X33.117 Y31.162
N3531 G01 X33.065 Y30.736
N3532 G01 X33.013 Y30.138
N3533 G01 X32.976 Y29.417
N3534 G01 X32.957 Y28.695
N3535 G01 X32.946 Y27.973
N3536 G01 X32.941 Y27.251
N3537 G01 X32.938 Y26.529
N3538 G01 X32.936 Y25.085
N3539 G01 X32.935 Y18.587
N3540 G01 Y16.331
N3541 G01 X32.936 Y16.307
N3542 G03 X33.096 Y16.313 I0.08 J0.003
N3543 G03 X32.968 Y16.374 I-0.08 J-0.003
N3544 G01 X32.361 Y15.921
N3545 G03 X32.457 Y15.792 I0.048 J-0.064
N3546 G03 X32.487 Y15.839 I-0.048 J0.064
N3547 G01 X32.492 Y15.862
N3548 G01 X32.498 Y15.89
N3549 G01 X32.64 Y16.164
N3550 G01 X32.654 Y16.363
N3551 G01 X32.58 Y16.572
N3552 G01 X32.375 Y16.634
N3553 G01 X32.154 Y16.693
N3554 G01 X31.897 Y16.752
N3555 G01 X31.574 Y16.814
N3556 G01 X31.206 Y16.871
N3557 G01 X30.712 Y16.929
N3558 G01 X30.024 Y16.987
N3559 G01 X29.302 Y17.021
N3560 G01 X28.581 Y17.041
N3561 G01 X27.859 Y17.052
N3562 G01 X27.137 Y17.058
N3563 G01 X26.415 Y17.061
N3564 G01 X24.971 Y17.064
N3565 G01 X20.639 Y17.065
N3566 G01 X18.202
N3567 G01 X18.112 Y17.062
N3568 G03 X18.133 Y16.462 I0.01 J-0.3
N3569 G03 X18.4 Y16.877 I-0.01 J0.3
N3570 G01 X17.968 Y17.915
N3571 G03 X17.414 Y17.685 I-0.277 J-0.115
N3572 G03 X17.616 Y17.51 I0.277 J0.115
N3573 G01 X17.703 Y17.487
N3574 G01 X17.835 Y17.458
N3575 G01 X17.986 Y17.366
N3576 G01 X18.181 Y17.338
N3577 G01 X18.392 Y17.396
N3578 G01 X18.587 Y17.553
N3579 G01 X18.665 Y17.953
N3580 G01 X18.737 Y18.404
N3581 G01 X18.807 Y18.971
N3582 G01 X18.869 Y19.691
N3583 G01 X18.908 Y20.412
N3584 G01 X18.931 Y21.133
N3585 G01 X18.945 Y21.855
N3586 G01 X18.953 Y22.577
N3587 G01 X18.958 Y23.299
N3588 G01 X18.961 Y24.021
N3589 G01 X18.964 Y25.465
N3590 G01 X18.965 Y29.797
N3591 G01 Y32.775
N3592 G01 X18.964 Y32.799
N3593 G03 X18.804 Y32.794 I-0.08 J-0.003
N3594 G03 X18.93 Y32.731 I0.08 J0.003
N3595 G01 X19.529 Y33.151
N3596 G03 X19.437 Y33.282 I-0.046 J0.066
N3597 G03 X19.406 Y33.236 I0.046 J-0.066
N3598 G01 X19.4 Y33.213
N3599 G01 X19.393 Y33.185
N3600 G01 X19.245 Y32.917
N3601 G01 X19.225 Y32.719
N3602 G01 X19.293 Y32.508
N3603 G01 X19.462 Y32.316
N3604 G01 X19.898 Y32.239
N3605 G01 X20.391 Y32.169
N3606 G01 X21.003 Y32.105
N3607 G01 X21.723 Y32.055
N3608 G01 X22.444 Y32.025
N3609 G01 X23.166 Y32.008
N3610 G01 X23.888 Y31.998
N3611 G01 X24.61 Y31.992
N3612 G01 X25.332 Y31.989
N3613 G01 X26.776 Y31.986
N3614 G01 X31.108 Y31.985
N3615 G01 X32.732
N3616 G01 X32.822 Y31.988
N3617 G03 X32.802 Y32.588 I-0.01 J0.3
N3618 G03 X32.528 Y32.192 I0.01 J-0.3
N3619 G01 X32.903 Y31.075
N3620 G03 X33.472 Y31.266 I0.284 J0.096
N3621 G03 X33.282 Y31.455 I-0.284 J-0.096
N3622 G03 X33.255 Y31.462 I-0.094 J-0.285
N3623 G01 X33.168 Y31.483
N3624 G01 X33.14 Y31.488
N3625 G01 X32.866 Y31.63
N3626 G01 X32.667 Y31.644
N3627 G01 X32.459 Y31.57
N3628 G01 X32.399 Y31.374
N3629 G01 X32.344 Y31.163
N3630 G01 X32.285 Y30.901
N3631 G01 X32.227 Y30.594
N3632 G01 X32.17 Y30.223
N3633 G01 X32.114 Y29.741
N3634 G01 X32.058 Y29.055
N3635 G01 X32.025 Y28.334
N3636 G01 X32.007 Y27.612
N3637 G01 X31.997 Y26.891
N3638 G01 X31.991 Y26.169
N3639 G01 X31.988 Y25.447
N3640 G01 X31.986 Y24.003
N3641 G01 X31.985 Y18.949
N3642 G01 Y17.324
N3643 G01 X31.986 Y17.3
N3644 G03 X32.146 Y17.306 I0.08 J0.003
N3645 G03 X32.014 Y17.364 I-0.08 J-0.003
N3646 G01 X31.438 Y16.869
N3647 G03 X31.543 Y16.747 I0.052 J-0.061
N3648 G03 X31.568 Y16.79 I-0.052 J0.061
N3649 G01 X31.574 Y16.814
N3650 G01 X31.599 Y16.947
N3651 G01 X31.687 Y17.101
N3652 G01 X31.709 Y17.297
N3653 G01 X31.645 Y17.506
N3654 G01 X31.456 Y17.566
N3655 G01 X31.244 Y17.626
N3656 G01 X31.012 Y17.682
N3657 G01 X30.719 Y17.742
N3658 G01 X30.38 Y17.799
N3659 G01 X29.935 Y17.858
N3660 G01 X29.353 Y17.915
N3661 G01 X28.632 Y17.959
N3662 G01 X27.911 Y17.984
N3663 G01 X27.189 Y17.998
N3664 G01 X26.467 Y18.005
N3665 G01 X25.745 Y18.01
N3666 G01 X25.023 Y18.012
N3667 G01 X23.579 Y18.014
N3668 G01 X20.691 Y18.015
N3669 G01 X19.337
N3670 G01 X19.247
N3671 G01 X19.157 Y18.012
N3672 G03 X19.178 Y17.412 I0.01 J-0.3
N3673 G03 X19.44 Y17.837 I-0.01 J0.3
N3674 G01 X18.979 Y18.841
N3675 G03 X18.433 Y18.591 I-0.273 J-0.125
N3676 G03 X18.649 Y18.421 I0.273 J0.125
N3677 G01 X18.737 Y18.404
N3678 G01 X18.872 Y18.383
N3679 G01 X19.03 Y18.3
N3680 G01 X19.228 Y18.285
N3681 G01 X19.437 Y18.357
N3682 G01 X19.493 Y18.544
N3683 G01 X19.549 Y18.762
N3684 G01 X19.609 Y19.034
N3685 G01 X19.666 Y19.342
N3686 G01 X19.727 Y19.746
N3687 G01 X19.784 Y20.257
N3688 G01 X19.84 Y20.977
N3689 G01 X19.872 Y21.699
N3690 G01 X19.89 Y22.42
N3691 G01 X19.9 Y23.142
N3692 G01 X19.906 Y23.864
N3693 G01 X19.91 Y24.586
N3694 G01 X19.913 Y26.03
N3695 G01 X19.915 Y29.64
N3696 G01 Y31.671
N3697 G01 X19.912 Y31.761
N3698 G03 X19.91 Y31.788 I-0.3 J-0.01
N3699 G03 X19.314 Y31.712 I-0.298 J-0.038
N3700 G03 X19.728 Y31.473 I0.298 J0.038
N3701 G01 X20.818 Y31.929
N3702 G03 X20.586 Y32.482 I-0.116 J0.277
N3703 G03 X20.407 Y32.258 I0.116 J-0.277
N3704 G01 X20.391 Y32.169
N3705 G01 X20.387 Y32.141
N3706 G01 X20.259 Y31.861
N3707 G01 X20.255 Y31.66
N3708 G01 X20.339 Y31.453
N3709 G01 X20.549 Y31.398
N3710 G01 X20.792 Y31.342
N3711 G01 X21.1 Y31.283
N3712 G01 X21.458 Y31.228
N3713 G01 X21.943 Y31.17
N3714 G01 X22.626 Y31.113
N3715 G01 X23.347 Y31.079
N3716 G01 X24.069 Y31.06
N3717 G01 X24.791 Y31.049
N3718 G01 X25.513 Y31.043
N3719 G01 X26.235 Y31.039
N3720 G01 X27.679 Y31.036
N3721 G01 X30.567 Y31.035
N3722 G01 X31.74
N3723 G01 X31.83 Y31.038
N3724 G03 X31.809 Y31.638 I-0.01 J0.3
N3725 G03 X31.541 Y31.225 I0.01 J-0.3
N3726 G01 X31.97 Y30.169
N3727 G03 X32.526 Y30.395 I0.278 J0.113
N3728 G03 X32.314 Y30.574 I-0.278 J-0.113
N3729 G01 X32.227 Y30.594
N3730 G01 X32.198 Y30.599
N3731 G01 X31.924 Y30.74
N3732 G01 X31.724 Y30.754
N3733 G01 X31.516 Y30.679
N3734 G01 X31.454 Y30.474
N3735 G01 X31.395 Y30.248
N3736 G01 X31.338 Y29.992
N3737 G01 X31.277 Y29.665
N3738 G01 X31.221 Y29.292
N3739 G01 X31.163 Y28.787
N3740 G01 X31.106 Y28.073
N3741 G01 X31.074 Y27.351
N3742 G01 X31.057 Y26.63
N3743 G01 X31.047 Y25.908
N3744 G01 X31.042 Y25.186
N3745 G01 X31.039 Y24.464
N3746 G01 X31.036 Y23.02
N3747 G01 X31.035 Y18.237
N3748 G01 X31.036 Y18.213
N3749 G03 X31.196 Y18.218 I0.08 J0.003
N3750 G03 X31.059 Y18.272 I-0.08 J-0.003
N3751 G01 X30.579 Y17.794
N3752 G03 X30.692 Y17.681 I0.056 J-0.057
N3753 G03 X30.713 Y17.719 I-0.056 J0.057
N3754 G01 X30.719 Y17.742
N3755 G01 X30.75 Y17.896
N3756 G01 X30.832 Y18.056
N3757 G01 X30.844 Y18.255
N3758 G01 X30.769 Y18.465
N3759 G01 X30.593 Y18.652
N3760 G01 X30.128 Y18.728
N3761 G01 X29.588 Y18.797
N3762 G01 X28.869 Y18.864
N3763 G01 X28.148 Y18.905
N3764 G01 X27.427 Y18.929
N3765 G01 X26.705 Y18.944
N3766 G01 X25.983 Y18.953
N3767 G01 X25.261 Y18.958
N3768 G01 X24.539 Y18.961
N3769 G01 X23.095 Y18.964
N3770 G01 X21.651 Y18.966
N3771 G01 X20.929 Y18.963
N3772 G01 X20.749 Y18.965
N3773 G01 X20.162
N3774 G01 X20.072 Y18.961
N3775 G03 X20.094 Y18.362 I0.011 J-0.3
N3776 G03 X20.357 Y18.783 I-0.011 J0.3
N3777 G01 X19.918 Y19.776
N3778 G03 X19.369 Y19.533 I-0.274 J-0.121
N3779 G03 X19.579 Y19.361 I0.274 J0.121
N3780 G01 X19.666 Y19.342
N3781 G01 X19.8 Y19.317
N3782 G01 X19.956 Y19.23
N3783 G01 X20.153 Y19.21
N3784 G01 X20.361 Y19.276
N3785 G01 X20.551 Y19.44
N3786 G01 X20.621 Y19.86
N3787 G01 X20.691 Y20.383
N3788 G01 X20.755 Y21.052
N3789 G01 X20.8 Y21.773
N3790 G01 X20.826 Y22.495
N3791 G01 X20.842 Y23.216
N3792 G01 X20.851 Y23.938
N3793 G01 X20.857 Y24.66
N3794 G01 X20.86 Y25.382
N3795 G01 X20.863 Y26.826
N3796 G01 X20.865 Y29.714
N3797 G01 Y30.752
N3798 G01 X20.862 Y30.842
N3799 G03 X20.859 Y30.87 I-0.3 J-0.011
N3800 G03 X20.264 Y30.793 I-0.298 J-0.038
N3801 G03 X20.708 Y30.569 I0.298 J0.038
N3802 G01 X21.558 Y31.042
N3803 G03 X21.267 Y31.567 I-0.146 J0.262
N3804 G03 X21.12 Y31.371 I0.146 J-0.262
N3805 G01 X21.1 Y31.283
N3806 G01 X21.062 Y31.087
N3807 G01 X21. Y30.912
N3808 G01 X21.013 Y30.707
N3809 G01 X21.118 Y30.502
N3810 G01 X21.33 Y30.328
N3811 G01 X21.96 Y30.25
N3812 G01 X22.679 Y30.186
N3813 G01 X23.4 Y30.146
N3814 G01 X24.122 Y30.122
N3815 G01 X24.844 Y30.107
N3816 G01 X25.565 Y30.098
N3817 G01 X26.287 Y30.092
N3818 G01 X27.009 Y30.089
N3819 G01 X28.453 Y30.086
N3820 G01 X29.175 Y30.084
N3821 G01 X29.897 Y30.089
N3822 G01 X30.258 Y30.083
N3823 G01 X30.71 Y30.086
N3824 G01 X30.8 Y30.085
N3825 G01 X30.824 Y30.086
N3826 G03 X30.819 Y30.246 I-0.003 J0.08
N3827 G03 X30.758 Y30.117 I0.003 J-0.08
N3828 G01 X31.22 Y29.532
N3829 G03 X31.346 Y29.631 I0.063 J0.05
N3830 G03 X31.3 Y29.66 I-0.063 J-0.05
N3831 G01 X31.277 Y29.665
N3832 G01 X31.249 Y29.67
N3833 G01 X30.974 Y29.811
N3834 G01 X30.774 Y29.823
N3835 G01 X30.566 Y29.748
N3836 G01 X30.505 Y29.544
N3837 G01 X30.444 Y29.31
N3838 G01 X30.387 Y29.054
N3839 G01 X30.327 Y28.726
N3840 G01 X30.27 Y28.348
N3841 G01 X30.212 Y27.834
N3842 G01 X30.155 Y27.114
N3843 G01 X30.124 Y26.393
N3844 G01 X30.107 Y25.671
N3845 G01 X30.097 Y24.949
N3846 G01 X30.092 Y24.227
N3847 G01 X30.089 Y23.505
N3848 G01 X30.086 Y22.061
N3849 G01 X30.084 Y20.617
N3850 G01 X30.087 Y19.896
N3851 G01 X30.085 Y19.535
N3852 G01 Y19.354
N3853 G01 X30.065 Y19.313
N3854 G01 X30.03 Y19.286
N3855 G01 X29.985 Y19.277
N3856 G01 X29.286 Y19.455
N3857 G01 X29.138 Y19.503
N3858 G01 X28.962 Y19.553
N3859 G01 X28.75 Y19.605
N3860 G01 X28.507 Y19.655
N3861 G01 X28.202 Y19.708
N3862 G01 X27.812 Y19.761
N3863 G01 X27.274 Y19.815
N3864 G01 X26.554 Y19.861
N3865 G01 X25.832 Y19.886
N3866 G01 X25.11 Y19.899
N3867 G01 X24.389 Y19.906
N3868 G01 X23.667 Y19.91
N3869 G01 X22.945 Y19.912
N3870 G01 X22.223 Y19.918
N3871 G01 X21.862 Y19.913
N3872 G01 X21.681 Y19.915
N3873 G01 X21.275 Y19.914
N3874 G01 X21.234 Y19.934
N3875 G01 X21.207 Y19.969
N3876 G01 X21.197 Y20.014
N3877 G01 X21.373 Y20.714
N3878 G01 X21.422 Y20.875
N3879 G01 X21.473 Y21.069
N3880 G01 X21.525 Y21.296
N3881 G01 X21.577 Y21.566
N3882 G01 X21.631 Y21.914
N3883 G01 X21.684 Y22.36
N3884 G01 X21.738 Y23.009
N3885 G01 X21.773 Y23.73
N3886 G01 X21.792 Y24.452
N3887 G01 X21.802 Y25.174
N3888 G01 X21.808 Y25.895
N3889 G01 X21.811 Y26.617
N3890 G01 X21.813 Y27.339
N3891 G01 X21.817 Y28.061
N3892 G01 X21.808 Y28.783
N3893 G01 X21.819 Y29.144
N3894 G01 X21.816 Y29.325
N3895 G01 X21.815 Y29.641
N3896 G01 X21.835 Y29.681
N3897 G01 X21.871 Y29.709
N3898 G01 X21.915 Y29.718
N3899 G01 X22.615 Y29.54
N3900 G01 X22.791 Y29.49
N3901 G01 X22.993 Y29.441
N3902 G01 X23.235 Y29.39
N3903 G01 X23.542 Y29.338
N3904 G01 X23.925 Y29.286
N3905 G01 X24.46 Y29.233
N3906 G01 X25.18 Y29.187
N3907 G01 X25.902 Y29.163
N3908 G01 X26.624 Y29.15
N3909 G01 X27.345 Y29.144
N3910 G01 X28.067 Y29.139
N3911 G01 X28.789 Y29.131
N3912 G01 X29.15 Y29.137
N3913 G01 X29.331 Y29.136
N3914 G01 X29.827 Y29.138
N3915 G03 X29.941 Y29.165 I-0.011 J0.3
N3916 G01 X30.002 Y29.192 Z14.962
N3917 G01 X30.06 Y29.219 Z14.94
N3918 G01 X30.111 Y29.242 Z14.905
N3919 G01 X30.154 Y29.262 Z14.857
N3920 G01 X30.187 Y29.277 Z14.8
N3921 G01 X30.207 Y29.286 Z14.737
N3922 G01 X30.214 Y29.289 Z14.67
N3923 G00 Z-3.01
N3924 G00 X21.093 Y20.27
N3925 G00 Z14.37
N3926 G01 Z14.67 F1500
N3927 G01 X21.086 Y20.272 Z14.737
N3928 G01 X21.064 Y20.278 Z14.8
N3929 G01 X21.03 Y20.288 Z14.857
N3930 G01 X20.984 Y20.3 Z14.905
N3931 G01 X20.929 Y20.316 Z14.94
N3932 G01 X20.868 Y20.333 Z14.962
N3933 G01 X20.804 Y20.351 Z14.97
N3934 G01 X20.691 Y20.383
N3935 G01 X21.333 Y20.298
N3936 G01 X21.621 Y20.157
N3937 G01 X21.83 Y20.147
N3938 G01 X22.049 Y20.23
N3939 G01 X22.252 Y20.426
N3940 G01 X22.351 Y20.844
N3941 G01 X22.438 Y21.28
N3942 G01 X22.522 Y21.792
N3943 G01 X22.597 Y22.381
N3944 G01 X22.664 Y23.1
N3945 G01 X22.705 Y23.821
N3946 G01 X22.729 Y24.542
N3947 G01 X22.744 Y25.264
N3948 G01 X22.753 Y25.986
N3949 G01 X22.758 Y26.708
N3950 G01 X22.77 Y27.43
N3951 G01 X22.752 Y28.152
N3952 G01 X22.761 Y28.332
N3953 G01 X22.76 Y28.512
N3954 G01 X22.759 Y28.693
N3955 G01 X22.763 Y28.918
N3956 G03 X22.163 Y28.912 I-0.3 J-0.003
N3957 G03 X22.488 Y28.616 I0.3 J0.003
N3958 G01 X30.51 Y29.272
N3959 G02 X30.559 Y28.674 I0.024 J-0.299
N3960 G02 X30.438 Y28.688 I-0.024 J0.299
N3961 G01 X30.327 Y28.726
N3962 G01 X30.298 Y28.731
N3963 G01 X30.023 Y28.872
N3964 G01 X29.824 Y28.884
N3965 G01 X29.615 Y28.809
N3966 G01 X29.555 Y28.605
N3967 G01 X29.493 Y28.368
N3968 G01 X29.437 Y28.112
N3969 G01 X29.376 Y27.784
N3970 G01 X29.319 Y27.401
N3971 G01 X29.261 Y26.883
N3972 G01 X29.205 Y26.163
N3973 G01 X29.174 Y25.442
N3974 G01 X29.157 Y24.72
N3975 G01 X29.147 Y23.998
N3976 G01 X29.142 Y23.276
N3977 G01 X29.139 Y22.554
N3978 G01 X29.131 Y21.832
N3979 G01 X29.147 Y21.11
N3980 G01 X29.128 Y20.75
N3981 G01 X29.134 Y20.569
N3982 G01 X29.137 Y20.028
N3983 G01 X29.14 Y19.938
N3984 G03 X29.74 Y19.96 I0.3 J0.011
N3985 G03 X29.341 Y20.232 I-0.3 J-0.011
N3986 G01 X28.339 Y19.883
N3987 G03 X28.536 Y19.316 I0.099 J-0.283
N3988 G03 X28.726 Y19.518 I-0.099 J0.283
N3989 G01 X28.75 Y19.605
N3990 G01 X28.783 Y19.735
N3991 G01 X28.877 Y19.884
N3992 G01 X28.908 Y20.079
N3993 G01 X28.853 Y20.291
N3994 G01 X28.699 Y20.489
N3995 G01 X28.35 Y20.56
N3996 G01 X27.895 Y20.636
N3997 G01 X27.4 Y20.7
N3998 G01 X26.729 Y20.763
N3999 G01 X26.008 Y20.806
N4000 G01 X25.287 Y20.831
N4001 G01 X24.567 Y20.889
N4002 G01 X24.212 Y20.821
N4003 G01 X23.687 Y20.901
N4004 G01 X23.512 Y20.855
N4005 G01 X23.332 Y20.859
N4006 G01 X23.061 Y20.862
N4007 G01 X22.926 Y20.863
N4008 G03 X22.811 Y20.837 I0.009 J-0.3
N4009 G01 X22.75 Y20.809 Z14.962
N4010 G01 X22.693 Y20.783 Z14.94
N4011 G01 X22.641 Y20.76 Z14.905
N4012 G01 X22.597 Y20.741 Z14.857
N4013 G01 X22.565 Y20.726 Z14.8
N4014 G01 X22.545 Y20.717 Z14.737
N4015 G01 X22.538 Y20.714 Z14.67
N4016 G00 Z-3.01
N4017 G00 X23.378 Y29.783
N4018 G00 Z14.37
N4019 G01 Z14.67 F1500
N4020 G01 X23.375 Y29.776 Z14.737
N4021 G01 X23.368 Y29.755 Z14.8
N4022 G01 X23.355 Y29.722 Z14.857
N4023 G01 X23.339 Y29.677 Z14.905
N4024 G01 X23.32 Y29.624 Z14.94
N4025 G01 X23.298 Y29.564 Z14.962
N4026 G01 X23.276 Y29.501 Z14.97
N4027 G01 X23.235 Y29.39
N4028 G01 X23.23 Y29.363
N4029 G01 X23.085 Y29.091
N4030 G01 X23.068 Y28.892
N4031 G01 X23.139 Y28.683
N4032 G01 X23.32 Y28.626
N4033 G01 X23.532 Y28.568
N4034 G01 X23.796 Y28.505
N4035 G01 X24.081 Y28.448
N4036 G01 X24.44 Y28.39
N4037 G01 X24.886 Y28.333
N4038 G01 X25.505 Y28.276
N4039 G01 X26.226 Y28.235
N4040 G01 X26.947 Y28.213
N4041 G01 X27.667 Y28.158
N4042 G01 X28.022 Y28.226
N4043 G01 X28.289 Y28.184
N4044 G01 X28.469 Y28.183
N4045 G01 X28.83 Y28.181
N4046 G01 X28.92 Y28.182
N4047 G03 X29.034 Y28.212 I-0.017 J0.3
N4048 G01 X29.094 Y28.241 Z14.962
N4049 G01 X29.151 Y28.268 Z14.94
N4050 G01 X29.202 Y28.293 Z14.905
N4051 G01 X29.245 Y28.313 Z14.857
N4052 G01 X29.277 Y28.329 Z14.8
N4053 G01 X29.297 Y28.338 Z14.737
N4054 G01 X29.304 Y28.342 Z14.67
N4055 G00 Z-3.01
N4056 G00 X22.044 Y21.42
N4057 G00 Z14.37
N4058 G01 Z14.67 F1500
N4059 G01 X22.052 Y21.417 Z14.737
N4060 G01 X22.072 Y21.41 Z14.8
N4061 G01 X22.106 Y21.398 Z14.857
N4062 G01 X22.151 Y21.382 Z14.905
N4063 G01 X22.205 Y21.363 Z14.94
N4064 G01 X22.264 Y21.342 Z14.962
N4065 G01 X22.327 Y21.32 Z14.97
N4066 G01 X22.438 Y21.28
N4067 G01 X22.467 Y21.275
N4068 G01 X22.739 Y21.131
N4069 G01 X22.939 Y21.115
N4070 G01 X23.15 Y21.187
N4071 G01 X23.341 Y21.361
N4072 G01 X23.428 Y21.849
N4073 G01 X23.508 Y22.409
N4074 G01 X23.579 Y23.079
N4075 G01 X23.63 Y23.799
N4076 G01 X23.663 Y24.52
N4077 G01 X23.683 Y25.242
N4078 G01 X23.696 Y25.964
N4079 G01 X23.723 Y26.686
N4080 G01 X23.679 Y27.406
N4081 G01 X23.692 Y27.496
N4082 G01 X23.7 Y27.585
N4083 G01 X23.708 Y27.766
N4084 G01 X23.706 Y27.946
N4085 G03 X23.107 Y27.917 I-0.3 J-0.015
N4086 G03 X23.44 Y27.634 I0.3 J0.015
N4087 G01 X29.55 Y28.329
N4088 G02 X29.618 Y27.732 I0.034 J-0.298
N4089 G02 X29.488 Y27.746 I-0.034 J0.298
N4090 G01 X29.376 Y27.784
N4091 G01 X29.242 Y27.809
N4092 G01 X29.087 Y27.896
N4093 G01 X28.891 Y27.916
N4094 G01 X28.682 Y27.85
N4095 G01 X28.493 Y27.686
N4096 G01 X28.423 Y27.272
N4097 G01 X28.355 Y26.753
N4098 G01 X28.291 Y26.092
N4099 G01 X28.247 Y25.371
N4100 G01 X28.221 Y24.649
N4101 G01 X28.206 Y23.928
N4102 G01 X28.197 Y23.206
N4103 G01 X28.177 Y22.484
N4104 G01 X28.209 Y21.763
N4105 G01 X28.201 Y21.673
N4106 G01 X28.197 Y21.583
N4107 G01 X28.193 Y21.402
N4108 G01 X28.194 Y21.267
N4109 G01 Y21.222
N4110 G01 X28.174 Y21.181
N4111 G01 X28.138 Y21.154
N4112 G01 X28.094 Y21.145
N4113 G01 X27.395 Y21.327
N4114 G01 X27.242 Y21.379
N4115 G01 X27.078 Y21.428
N4116 G01 X26.882 Y21.479
N4117 G01 X26.641 Y21.533
N4118 G01 X25.931 Y21.665
N4119 G01 X25.611 Y21.786
N4120 G01 X24.89 Y21.753
N4121 G01 X24.717 Y21.807
N4122 G01 X24.533 Y21.823
N4123 G01 X24.443 Y21.816
N4124 G01 X24.353 Y21.805
N4125 G01 X24.174 Y21.779
N4126 G01 X24.13 Y21.787
N4127 G01 X24.094 Y21.814
N4128 G01 X24.074 Y21.854
N4129 G01 X24.073 Y21.9
N4130 G01 X24.381 Y22.553
N4131 G01 X24.448 Y22.996
N4132 G01 X24.514 Y23.568
N4133 G01 X24.572 Y24.288
N4134 G01 X24.608 Y25.009
N4135 G01 X24.637 Y25.731
N4136 G01 X24.667 Y26.452
N4137 G01 X24.686 Y27.174
N4138 G01 X24.658 Y27.259
N4139 G01 X24.648 Y27.349
N4140 G01 X24.649 Y27.439
N4141 G01 X24.655 Y27.71
N4142 G01 X24.675 Y27.75
N4143 G01 X24.711 Y27.778
N4144 G01 X24.755 Y27.786
N4145 G01 X25.452 Y27.598
N4146 G01 X26.152 Y27.42
N4147 G01 X26.424 Y27.284
N4148 G01 X27.145 Y27.244
N4149 G01 X27.45 Y27.222
N4150 G01 X27.863 Y27.198
N4151 G01 X27.948 Y27.229
N4152 G03 X27.722 Y27.785 I-0.113 J0.278
N4153 G03 X27.535 Y27.518 I0.113 J-0.278
N4154 G01 X27.301 Y20.705
N4155 G03 X27.895 Y20.636 I0.3 J-0.01
N4156 G01 X28.028 Y21.434
N4157 G01 X28.085 Y21.62
N4158 G01 X28.061 Y21.834
N4159 G01 X27.937 Y22.051
N4160 G01 X27.663 Y22.256
N4161 G01 X26.959 Y22.415
N4162 G01 X26.304 Y22.607
N4163 G01 X26.259 Y22.602
N4164 G01 X25.54 Y22.664
N4165 G01 X25.446 Y22.684
N4166 G01 X25.356 Y22.696
N4167 G01 X25.176 Y22.709
N4168 G01 X25.131
N4169 G01 X25.086 Y22.713
N4170 G01 X25.048 Y22.737
N4171 G01 X25.024 Y22.776
N4172 G01 X25.019 Y22.82
N4173 G01 X25.268 Y23.498
N4174 G01 X25.327 Y23.773
N4175 G01 X25.387 Y24.113
N4176 G01 X25.487 Y24.828
N4177 G01 X25.597 Y25.213
N4178 G01 X25.55 Y25.571
N4179 G01 X25.649 Y26.16
N4180 G01 X25.606 Y26.335
N4181 G01 X25.618 Y26.515
N4182 G01 X25.629 Y26.876
N4183 G01 X25.631 Y26.966
N4184 G03 X24.977 Y27.553 I-0.595 J-0.005
N4185 G03 X24.453 Y26.847 I0.06 J-0.592
N4186 G01 X25.482 Y21.569
N4187 G03 X26.641 Y21.533 I0.584 J0.114
N4188 G01 X26.955 Y22.942
N4189 G01 X26.917 Y23.159
N4190 G01 X26.783 Y23.362
N4191 G01 X26.554 Y23.512
N4192 G01 X26.376 Y23.543
N4193 G01 X26.016 Y23.576
N4194 G01 X25.926 Y23.584
N4195 G01 X25.888 Y23.607
N4196 G01 X25.863 Y23.645
N4197 G01 X25.858 Y23.69
N4198 G01 X25.873 Y23.732
N4199 G01 X26.283 Y24.138
N4200 G01 X26.431 Y24.505
N4201 G01 X26.426 Y24.686
N4202 G01 X26.562 Y25.104
N4203 G01 X26.527 Y25.463
N4204 G01 X26.52 Y26.185
N4205 G01 X26.544 Y26.316
N4206 G01 X26.563 Y26.495
N4207 G01 X26.572 Y26.675
N4208 G01 X26.593 Y26.715
N4209 G01 X26.63 Y26.741
N4210 G01 X26.674 Y26.749
N4211 G01 X26.717 Y26.736
N4212 G01 X27.12 Y26.366
N4213 G01 X27.469 Y26.245
N4214 G01 X27.559 Y26.251
N4215 G01 X27.65
N4216 G01 X27.69 Y26.231
N4217 G01 X27.717 Y26.195
N4218 G01 X27.726 Y26.151
N4219 G01 X27.715 Y26.107
N4220 G01 X27.383 Y25.725
N4221 G01 X27.27 Y25.366
N4222 G01 X27.308 Y25.007
N4223 G01 X27.221 Y24.381
N4224 G01 X27.27 Y24.207
N4225 G01 X27.228 Y23.486
N4226 G01 X27.266 Y23.127
N4227 G01 X27.255 Y23.038
N4228 G01 X27.247 Y22.948
N4229 G01 Y22.933 Z14.969
N4230 G01 X27.254 Y22.893 Z14.956
N4231 G01 X27.259 Y22.861 Z14.93
N4232 G01 X27.263 Y22.839 Z14.894
N4233 G01 X27.264 Y22.832 Z14.852
N4234 G00 Z-3.01
N4235 G00 X9.706 Y6.562
N4236 G00 Z18.9
N4237 G01 Z19.2 F1500
N4238 G01 X9.708 Y6.57 Z19.267
N4239 G01 X9.713 Y6.591 Z19.33
N4240 G01 X9.722 Y6.626 Z19.387
N4241 G01 X9.734 Y6.672 Z19.435
N4242 G01 X9.748 Y6.727 Z19.47
N4243 G01 X9.764 Y6.788 Z19.492
N4244 G01 X9.78 Y6.853 Z19.5
N4245 G03 X10.015 Y8.486 I-7.419 J1.9
N4246 G01 Y8.576
N4247 G01 X9.75 Y9.248
N4248 G01 X9.608 Y9.956
N4249 G01 X9.536 Y10.674
N4250 G01 X9.499 Y11.395
N4251 G01 X9.482 Y12.117
N4252 G01 X9.473 Y12.839
N4253 G01 X9.469 Y13.561
N4254 G01 X9.467 Y14.283
N4255 G01 X9.465 Y16.449
N4256 G01 Y38.831
N4257 G01 X9.578 Y39.174
N4258 G01 X9.789 Y39.467
N4259 G01 X10.328 Y39.947
N4260 G01 X10.992 Y40.229
N4261 G01 X11.698 Y40.381
N4262 G01 X12.416 Y40.459
N4263 G01 X13.137 Y40.498
N4264 G01 X13.859 Y40.517
N4265 G01 X14.581 Y40.526
N4266 G01 X15.303 Y40.531
N4267 G01 X16.025 Y40.533
N4268 G01 X18.191 Y40.535
N4269 G01 X29.02
N4270 G01 X38.767
N4271 G01 X39.117 Y40.446
N4272 G01 X39.42 Y40.249
N4273 G01 X39.918 Y39.727
N4274 G01 X40.212 Y39.067
N4275 G01 X40.372 Y38.363
N4276 G01 X40.455 Y37.646
N4277 G01 X40.496 Y36.925
N4278 G01 X40.516 Y36.203
N4279 G01 X40.526 Y35.481
N4280 G01 X40.531 Y34.76
N4281 G01 X40.533 Y34.038
N4282 G01 X40.535 Y31.872
N4283 G01 Y11.295
N4284 G01 X40.504 Y11.117
N4285 G01 X40.373 Y10.78
N4286 G01 X40.152 Y10.495
N4287 G01 X39.6 Y10.029
N4288 G01 X38.931 Y9.758
N4289 G01 X38.224 Y9.612
N4290 G01 X37.506 Y9.538
N4291 G01 X36.785 Y9.5
N4292 G01 X36.063 Y9.482
N4293 G01 X35.341 Y9.473
N4294 G01 X34.619 Y9.469
N4295 G01 X33.897 Y9.467
N4296 G01 X31.731 Y9.465
N4297 G01 X30.287
N4298 G01 X12.237
N4299 G01 X11.893 Y9.573
N4300 G01 X11.592 Y9.772
N4301 G01 X11.088 Y10.29
N4302 G01 X10.848 Y10.433
N4303 G01 X10.562 Y10.47
N4304 G01 X10.382 Y10.467
N4305 G01 X10.292 Y10.466
N4306 G01 X10.251 Y10.486
N4307 G01 X10.223 Y10.521
N4308 G01 X10.214 Y10.565
N4309 G01 X10.301 Y10.916
N4310 G01 X10.343 Y11.358
N4311 G01 X10.386 Y12.079
N4312 G01 X10.403 Y12.801
N4313 G01 X10.41 Y13.523
N4314 G01 X10.413 Y14.245
N4315 G01 X10.415 Y15.689
N4316 G01 Y37.348
N4317 G01 X10.508 Y38.064
N4318 G01 X10.458 Y38.238
N4319 G01 X10.469 Y38.599
N4320 G01 X10.467 Y38.734
N4321 G01 X10.506 Y38.816
N4322 G01 X10.759 Y39.073
N4323 G01 X11.072 Y39.253
N4324 G01 X11.759 Y39.475
N4325 G01 X12.48 Y39.513
N4326 G01 X13.201 Y39.546
N4327 G01 X13.923 Y39.562
N4328 G01 X14.645 Y39.572
N4329 G01 X15.367 Y39.578
N4330 G01 X16.089 Y39.581
N4331 G01 X17.533 Y39.584
N4332 G01 X21.864 Y39.585
N4333 G01 X37.748
N4334 G01 X38.103 Y39.516
N4335 G01 X38.462 Y39.551
N4336 G01 X38.642 Y39.539
N4337 G01 X38.687 Y39.538
N4338 G01 X38.731 Y39.526
N4339 G01 X38.811 Y39.486
N4340 G01 X38.947 Y39.366
N4341 G01 X39.072 Y39.237
N4342 G01 X39.256 Y38.926
N4343 G01 X39.463 Y38.234
N4344 G01 X39.507 Y37.514
N4345 G01 X39.561 Y36.794
N4346 G01 X39.569 Y36.072
N4347 G01 X39.575 Y35.35
N4348 G01 X39.579 Y34.628
N4349 G01 X39.582 Y33.906
N4350 G01 X39.584 Y32.462
N4351 G01 X39.585 Y26.686
N4352 G01 Y16.578
N4353 G01 Y12.246
N4354 G01 X39.516 Y11.892
N4355 G01 X39.551 Y11.532
N4356 G01 X39.539 Y11.352
N4357 G01 X39.531 Y11.308
N4358 G01 X39.494 Y11.225
N4359 G01 X39.38 Y11.086
N4360 G01 X39.103 Y10.854
N4361 G01 X38.435 Y10.58
N4362 G01 X37.715 Y10.521
N4363 G01 X37. Y10.425
N4364 G01 X36.278 Y10.426
N4365 G01 X34.112 Y10.418
N4366 G01 X31.946 Y10.416
N4367 G01 X13.896 Y10.415
N4368 G01 X13.174 Y10.424
N4369 G01 X12.682 Y10.505
N4370 G01 X12.507 Y10.461
N4371 G01 X12.327 Y10.464
N4372 G01 X12.244 Y10.499
N4373 G01 X11.678 Y10.948
N4374 G01 X11.442 Y11.207
N4375 G01 X11.342 Y11.252
N4376 G01 X11.258 Y11.286
N4377 G01 X11.173 Y11.315
N4378 G01 X11.129 Y11.327
N4379 G01 X11.085 Y11.338
N4380 G01 X11.051 Y11.367
N4381 G01 X11.032 Y11.408
N4382 G01 X11.059 Y12.13
N4383 G01 X11.105 Y12.328
N4384 G01 X11.151 Y12.566
N4385 G01 X11.198 Y12.866
N4386 G01 X11.246 Y13.257
N4387 G01 X11.294 Y13.818
N4388 G01 X11.331 Y14.539
N4389 G01 X11.349 Y15.261
N4390 G01 X11.357 Y15.983
N4391 G01 X11.361 Y16.705
N4392 G01 X11.363 Y17.427
N4393 G01 X11.365 Y19.593
N4394 G01 Y27.535
N4395 G01 Y37.643
N4396 G01 X11.474 Y37.987
N4397 G01 X11.452 Y38.166
N4398 G01 X11.432 Y38.254
N4399 G01 X11.424 Y38.344
N4400 G01 X11.423 Y38.389
N4401 G01 X11.441 Y38.43
N4402 G01 X11.476 Y38.459
N4403 G01 X12.179 Y38.626
N4404 G01 X12.901 Y38.615
N4405 G01 X13.622 Y38.616
N4406 G01 X15.066 Y38.625
N4407 G01 X15.788 Y38.631
N4408 G01 X17.954 Y38.635
N4409 G01 X38.17
N4410 G01 X38.26 Y38.622
N4411 G01 X38.304 Y38.617
N4412 G01 X38.343 Y38.593
N4413 G01 X38.39 Y38.516
N4414 G01 X38.589 Y37.822
N4415 G01 X38.603 Y37.1
N4416 G01 X38.613 Y36.378
N4417 G01 X38.631 Y35.656
N4418 G01 X38.63 Y34.934
N4419 G01 X38.634 Y32.768
N4420 G01 X38.635 Y28.436
N4421 G01 Y26.27
N4422 G01 Y11.83
N4423 G01 X38.621 Y11.741
N4424 G01 X38.617 Y11.696
N4425 G01 X38.593 Y11.658
N4426 G01 X38.439 Y11.563
N4427 G01 X37.735 Y11.404
N4428 G01 X37.013 Y11.389
N4429 G01 X36.293 Y11.338
N4430 G01 X35.571 Y11.355
N4431 G01 X34.849 Y11.362
N4432 G01 X34.127 Y11.365
N4433 G01 X32.683 Y11.366
N4434 G01 X13.911 Y11.365
N4435 G01 X13.19 Y11.373
N4436 G01 X12.699 Y11.477
N4437 G01 X12.611 Y11.459
N4438 G01 X12.567 Y11.45
N4439 G01 X12.523 Y11.46
N4440 G01 X12.245 Y11.691
N4441 G01 X12.056 Y11.946
N4442 G01 X11.978 Y11.991
N4443 G01 X11.938 Y12.012
N4444 G01 X11.912 Y12.049
N4445 G01 X11.904 Y12.093
N4446 G01 X11.978 Y12.408
N4447 G01 X12.043 Y12.737
N4448 G01 X12.112 Y13.166
N4449 G01 X12.171 Y13.641
N4450 G01 X12.23 Y14.303
N4451 G01 X12.268 Y15.024
N4452 G01 X12.29 Y15.745
N4453 G01 X12.301 Y16.467
N4454 G01 X12.308 Y17.189
N4455 G01 X12.311 Y17.911
N4456 G01 X12.314 Y19.355
N4457 G01 X12.315 Y20.799
N4458 G01 Y37.405
N4459 G01 X12.343 Y37.583
N4460 G01 X12.368 Y37.67
N4461 G01 X12.387 Y37.758
N4462 G01 X12.393 Y37.803
N4463 G01 X12.418 Y37.841
N4464 G01 X12.457 Y37.863
N4465 G01 X13.178 Y37.91
N4466 G01 X13.42 Y37.866
N4467 G01 X13.727 Y37.822
N4468 G01 X14.13 Y37.779
N4469 G01 X14.745 Y37.734
N4470 G01 X15.466 Y37.707
N4471 G01 X16.188 Y37.694
N4472 G01 X16.91 Y37.689
N4473 G01 X17.632 Y37.687
N4474 G01 X19.798 Y37.685
N4475 G01 X37.803
N4476 G01 X37.843 Y37.665
N4477 G01 X37.871 Y37.63
N4478 G01 X37.88 Y37.585
N4479 G01 X37.702 Y36.886
N4480 G01 X37.691 Y36.164
N4481 G01 X37.686 Y35.442
N4482 G01 X37.684 Y34.72
N4483 G01 Y33.276
N4484 G01 X37.685 Y29.666
N4485 G01 Y12.203
N4486 G01 X37.665 Y12.162
N4487 G01 X37.63 Y12.134
N4488 G01 X37.585 Y12.125
N4489 G01 X36.886 Y12.304
N4490 G01 X36.164 Y12.305
N4491 G01 X35.442 Y12.274
N4492 G01 X34.721 Y12.295
N4493 G01 X33.999 Y12.306
N4494 G01 X33.277 Y12.311
N4495 G01 X32.555 Y12.313
N4496 G01 X31.111 Y12.315
N4497 G01 X13.783
N4498 G01 X13.061 Y12.328
N4499 G01 X13.019 Y12.344
N4500 G01 X12.976 Y12.36
N4501 G01 X12.943 Y12.389
N4502 G01 X12.911 Y12.422
N4503 G01 X12.896 Y12.464
N4504 G01 X12.991 Y13.18
N4505 G01 X13.064 Y13.668
N4506 G01 X13.129 Y14.238
N4507 G01 X13.185 Y14.958
N4508 G01 X13.219 Y15.679
N4509 G01 X13.238 Y16.401
N4510 G01 X13.25 Y17.123
N4511 G01 X13.257 Y17.845
N4512 G01 X13.26 Y18.567
N4513 G01 X13.264 Y20.011
N4514 G01 Y20.733
N4515 G01 X13.265 Y31.563
N4516 G01 Y37.158
N4517 G01 X13.266 Y37.203
N4518 G01 X13.286 Y37.244
N4519 G01 X13.322 Y37.271
N4520 G01 X13.366 Y37.28
N4521 G01 X14.064 Y37.093
N4522 G01 X14.258 Y37.043
N4523 G01 X14.479 Y36.994
N4524 G01 X14.755 Y36.944
N4525 G01 X15.094 Y36.894
N4526 G01 X15.549 Y36.843
N4527 G01 X16.207 Y36.793
N4528 G01 X16.929 Y36.764
N4529 G01 X17.651 Y36.749
N4530 G01 X18.373 Y36.742
N4531 G01 X19.095 Y36.738
N4532 G01 X20.539 Y36.736
N4533 G01 X28.48 Y36.735
N4534 G01 X37.054
N4535 G01 X37.095 Y36.715
N4536 G01 X37.122 Y36.68
N4537 G01 X37.132 Y36.635
N4538 G01 X36.953 Y35.936
N4539 G01 X36.907 Y35.656
N4540 G01 X36.86 Y35.292
N4541 G01 X36.813 Y34.783
N4542 G01 X36.771 Y34.062
N4543 G01 X36.752 Y33.34
N4544 G01 X36.743 Y32.618
N4545 G01 X36.739 Y31.896
N4546 G01 X36.737 Y31.174
N4547 G01 X36.735 Y29.008
N4548 G01 Y26.842
N4549 G01 Y12.944
N4550 G01 X36.715 Y12.903
N4551 G01 X36.68 Y12.876
N4552 G01 X36.635 Y12.866
N4553 G01 X35.936 Y13.045
N4554 G01 X35.593 Y13.097
N4555 G01 X35.136 Y13.149
N4556 G01 X34.478 Y13.201
N4557 G01 X33.757 Y13.233
N4558 G01 X33.035 Y13.249
N4559 G01 X32.313 Y13.257
N4560 G01 X31.591 Y13.261
N4561 G01 X30.869 Y13.263
N4562 G01 X28.703 Y13.265
N4563 G01 X13.812
N4564 G01 X13.631 Y13.268
N4565 G01 X13.591 Y13.289
N4566 G01 X13.564 Y13.325
N4567 G01 X13.556 Y13.369
N4568 G01 X13.746 Y14.066
N4569 G01 X13.797 Y14.221
N4570 G01 X13.849 Y14.406
N4571 G01 X13.899 Y14.609
N4572 G01 X13.952 Y14.858
N4573 G01 X14.005 Y15.168
N4574 G01 X14.059 Y15.556
N4575 G01 X14.113 Y16.089
N4576 G01 X14.16 Y16.809
N4577 G01 X14.185 Y17.531
N4578 G01 X14.199 Y18.252
N4579 G01 X14.206 Y18.974
N4580 G01 X14.21 Y19.696
N4581 G01 X14.214 Y21.14
N4582 G01 X14.215 Y24.75
N4583 G01 Y26.194
N4584 G01 Y36.483
N4585 G03 X14.188 Y36.597 I-0.3 J-0.01
N4586 G01 X14.16 Y36.657 Z19.492
N4587 G01 X14.134 Y36.715 Z19.47
N4588 G01 X14.111 Y36.767 Z19.435
N4589 G01 X14.091 Y36.81 Z19.387
N4590 G01 X14.076 Y36.843 Z19.33
N4591 G01 X14.067 Y36.863 Z19.267
N4592 G01 X14.064 Y36.87 Z19.2
N4593 G00 Z-3.01
N4594 G00 X13.464 Y13.548
N4595 G00 Z18.9
N4596 G01 Z19.2 F1500
N4597 G01 X13.457 Y13.55 Z19.267
N4598 G01 X13.436 Y13.557 Z19.33
N4599 G01 X13.401 Y13.567 Z19.387
N4600 G01 X13.356 Y13.581 Z19.435
N4601 G01 X13.301 Y13.597 Z19.47
N4602 G01 X13.241 Y13.615 Z19.492
N4603 G01 X13.177 Y13.635 Z19.5
N4604 G01 X13.064 Y13.668
N4605 G01 X13.813 Y13.556
N4606 G01 X13.98 Y13.473
N4607 G01 X14.189 Y13.462
N4608 G01 X14.41 Y13.543
N4609 G01 X14.617 Y13.74
N4610 G01 X14.72 Y14.149
N4611 G01 X14.809 Y14.568
N4612 G01 X14.891 Y15.026
N4613 G01 X14.97 Y15.585
N4614 G01 X15.04 Y16.239
N4615 G01 X15.091 Y16.959
N4616 G01 X15.121 Y17.68
N4617 G01 X15.14 Y18.402
N4618 G01 X15.15 Y19.124
N4619 G01 X15.157 Y19.846
N4620 G01 X15.16 Y20.568
N4621 G01 X15.164 Y22.012
N4622 G01 X15.165 Y25.622
N4623 G01 Y36.271
N4624 G01 X15.185 Y36.312
N4625 G01 X15.22 Y36.34
N4626 G01 X15.265 Y36.349
N4627 G01 X15.964 Y36.17
N4628 G01 X16.127 Y36.124
N4629 G01 X16.322 Y36.076
N4630 G01 X16.55 Y36.028
N4631 G01 X16.831 Y35.979
N4632 G01 X17.192 Y35.929
N4633 G01 X17.684 Y35.879
N4634 G01 X18.404 Y35.832
N4635 G01 X19.126 Y35.808
N4636 G01 X19.847 Y35.797
N4637 G01 X20.569 Y35.791
N4638 G01 X21.291 Y35.788
N4639 G01 X22.735 Y35.786
N4640 G01 X34.287 Y35.785
N4641 G01 X36.363
N4642 G01 X36.453 Y35.788
N4643 G03 X36.481 Y35.79 I-0.01 J0.3
N4644 G03 X36.404 Y36.386 I-0.038 J0.298
N4645 G03 X36.165 Y35.973 I0.038 J-0.298
N4646 G01 X36.623 Y34.866
N4647 G03 X37.177 Y35.096 I0.277 J0.115
N4648 G03 X36.949 Y35.277 I-0.277 J-0.115
N4649 G01 X36.86 Y35.292
N4650 G01 X36.831 Y35.295
N4651 G01 X36.55 Y35.42
N4652 G01 X36.349 Y35.422
N4653 G01 X36.144 Y35.335
N4654 G01 X36.094 Y35.135
N4655 G01 X36.042 Y34.89
N4656 G01 X35.988 Y34.587
N4657 G01 X35.937 Y34.218
N4658 G01 X35.885 Y33.715
N4659 G01 X35.836 Y32.995
N4660 G01 X35.811 Y32.273
N4661 G01 X35.798 Y31.551
N4662 G01 X35.792 Y30.829
N4663 G01 X35.788 Y30.107
N4664 G01 X35.786 Y28.663
N4665 G01 X35.785 Y21.443
N4666 G01 Y13.682
N4667 G01 X35.765 Y13.641
N4668 G01 X35.73 Y13.614
N4669 G01 X35.685 Y13.605
N4670 G01 X34.986 Y13.783
N4671 G01 X34.842 Y13.829
N4672 G01 X34.674 Y13.876
N4673 G01 X34.472 Y13.925
N4674 G01 X34.231 Y13.975
N4675 G01 X33.939 Y14.024
N4676 G01 X33.558 Y14.075
N4677 G01 X33.038 Y14.125
N4678 G01 X32.317 Y14.17
N4679 G01 X31.596 Y14.192
N4680 G01 X30.874 Y14.203
N4681 G01 X30.152 Y14.209
N4682 G01 X29.43 Y14.212
N4683 G01 X27.986 Y14.214
N4684 G01 X17.156 Y14.215
N4685 G01 X15.306
N4686 G01 X15.282 Y14.214
N4687 G03 X15.287 Y14.054 I0.003 J-0.08
N4688 G03 X15.343 Y14.189 I-0.003 J0.08
N4689 G01 X14.864 Y14.705
N4690 G03 X14.747 Y14.597 I-0.059 J-0.054
N4691 G03 X14.786 Y14.573 I0.059 J0.054
N4692 G01 X14.809 Y14.568
N4693 G01 X14.964 Y14.534
N4694 G01 X15.125 Y14.451
N4695 G01 X15.327 Y14.437
N4696 G01 X15.537 Y14.512
N4697 G01 X15.726 Y14.687
N4698 G01 X15.812 Y15.154
N4699 G01 X15.895 Y15.722
N4700 G01 X15.97 Y16.398
N4701 G01 X16.025 Y17.118
N4702 G01 X16.059 Y17.839
N4703 G01 X16.081 Y18.561
N4704 G01 X16.095 Y19.283
N4705 G01 X16.103 Y20.005
N4706 G01 X16.108 Y20.727
N4707 G01 X16.111 Y21.449
N4708 G01 X16.114 Y22.893
N4709 G01 X16.115 Y27.225
N4710 G01 Y35.528
N4711 G01 X16.112 Y35.618
N4712 G03 X15.512 Y35.597 I-0.3 J-0.01
N4713 G03 X15.927 Y35.33 I0.3 J0.01
N4714 G01 X16.978 Y35.766
N4715 G03 X16.748 Y36.32 I-0.115 J0.277
N4716 G03 X16.579 Y36.142 I0.115 J-0.277
N4717 G03 X16.571 Y36.115 I0.283 J-0.099
N4718 G01 X16.55 Y36.028
N4719 G01 X16.544 Y36.
N4720 G01 X16.399 Y35.729
N4721 G01 X16.382 Y35.531
N4722 G01 X16.453 Y35.321
N4723 G01 X16.631 Y35.265
N4724 G01 X16.848 Y35.206
N4725 G01 X17.11 Y35.144
N4726 G01 X17.386 Y35.089
N4727 G01 X17.745 Y35.031
N4728 G01 X18.177 Y34.976
N4729 G01 X18.784 Y34.921
N4730 G01 X19.505 Y34.881
N4731 G01 X20.227 Y34.859
N4732 G01 X20.949 Y34.848
N4733 G01 X21.671 Y34.842
N4734 G01 X22.393 Y34.839
N4735 G01 X23.837 Y34.836
N4736 G01 X29.613 Y34.835
N4737 G01 X35.479
N4738 G01 X35.503 Y34.836
N4739 G03 X35.497 Y34.996 I-0.003 J0.08
N4740 G03 X35.449 Y34.854 I0.003 J-0.08
N4741 G01 X35.944 Y34.442
N4742 G03 X36.047 Y34.565 I0.051 J0.062
N4743 G03 X36.012 Y34.582 I-0.051 J-0.062
N4744 G01 X35.988 Y34.587
N4745 G01 X35.791 Y34.622
N4746 G01 X35.616 Y34.682
N4747 G01 X35.411 Y34.666
N4748 G01 X35.207 Y34.558
N4749 G01 X35.145 Y34.288
N4750 G01 X35.089 Y34.004
N4751 G01 X35.029 Y33.631
N4752 G01 X34.974 Y33.185
N4753 G01 X34.918 Y32.552
N4754 G01 X34.88 Y31.831
N4755 G01 X34.859 Y31.109
N4756 G01 X34.848 Y30.387
N4757 G01 X34.842 Y29.665
N4758 G01 X34.839 Y28.943
N4759 G01 X34.836 Y27.499
N4760 G01 X34.835 Y21.723
N4761 G01 Y14.413
N4762 G01 X34.838 Y14.323
N4763 G03 X34.84 Y14.295 I0.3 J0.01
N4764 G03 X35.436 Y14.372 I0.298 J0.038
N4765 G03 X35.05 Y14.62 I-0.298 J-0.038
N4766 G01 X33.83 Y14.245
N4767 G03 X34.007 Y13.671 I0.088 J-0.287
N4768 G03 X34.202 Y13.86 I-0.088 J0.287
N4769 G03 X34.21 Y13.887 I-0.284 J0.097
N4770 G01 X34.231 Y13.975
N4771 G01 X34.237 Y14.003
N4772 G01 X34.381 Y14.274
N4773 G01 X34.397 Y14.473
N4774 G01 X34.325 Y14.682
N4775 G01 X34.148 Y14.737
N4776 G01 X33.934 Y14.795
N4777 G01 X33.669 Y14.858
N4778 G01 X33.389 Y14.913
N4779 G01 X33.029 Y14.971
N4780 G01 X32.586 Y15.026
N4781 G01 X31.964 Y15.081
N4782 G01 X31.243 Y15.12
N4783 G01 X30.522 Y15.141
N4784 G01 X29.8 Y15.152
N4785 G01 X29.078 Y15.158
N4786 G01 X28.356 Y15.161
N4787 G01 X26.912 Y15.164
N4788 G01 X21.136 Y15.165
N4789 G01 X16.443
N4790 G01 X16.402 Y15.185
N4791 G01 X16.375 Y15.22
N4792 G01 X16.365 Y15.265
N4793 G01 X16.544 Y15.964
N4794 G01 X16.594 Y16.106
N4795 G01 X16.645 Y16.27
N4796 G01 X16.699 Y16.468
N4797 G01 X16.752 Y16.693
N4798 G01 X16.806 Y16.965
N4799 G01 X16.862 Y17.31
N4800 G01 X16.918 Y17.75
N4801 G01 X16.974 Y18.37
N4802 G01 X17.014 Y19.091
N4803 G01 X17.036 Y19.813
N4804 G01 X17.048 Y20.535
N4805 G01 X17.055 Y21.257
N4806 G01 X17.059 Y21.979
N4807 G01 X17.063 Y23.423
N4808 G01 X17.065 Y26.311
N4809 G01 Y34.614
N4810 G01 X17.062 Y34.704
N4811 G03 X16.462 Y34.683 I-0.3 J-0.01
N4812 G03 X16.884 Y34.419 I0.3 J0.01
N4813 G01 X17.82 Y34.834
N4814 G03 X17.577 Y35.382 I-0.122 J0.274
N4815 G03 X17.406 Y35.177 I0.122 J-0.274
N4816 G01 X17.386 Y35.089
N4817 G01 X17.355 Y34.935
N4818 G01 X17.274 Y34.774
N4819 G01 X17.263 Y34.574
N4820 G01 X17.339 Y34.366
N4821 G01 X17.517 Y34.179
N4822 G01 X17.976 Y34.106
N4823 G01 X18.529 Y34.038
N4824 G01 X19.248 Y33.976
N4825 G01 X19.969 Y33.938
N4826 G01 X20.691 Y33.915
N4827 G01 X21.413 Y33.902
N4828 G01 X22.135 Y33.895
N4829 G01 X22.857 Y33.89
N4830 G01 X23.579 Y33.888
N4831 G01 X25.023 Y33.886
N4832 G01 X32.964 Y33.885
N4833 G01 X34.499
N4834 G01 X34.523 Y33.886
N4835 G03 X34.517 Y34.046 I-0.003 J0.08
N4836 G03 X34.47 Y33.904 I0.003 J-0.08
N4837 G01 X34.987 Y33.485
N4838 G03 X35.087 Y33.61 I0.05 J0.062
N4839 G03 X35.053 Y33.626 I-0.05 J-0.062
N4840 G01 X35.029 Y33.631
N4841 G01 X34.873 Y33.656
N4842 G01 X34.707 Y33.73
N4843 G01 X34.506 Y33.734
N4844 G01 X34.3 Y33.649
N4845 G01 X34.12 Y33.464
N4846 G01 X34.052 Y32.936
N4847 G01 X33.987 Y32.256
N4848 G01 X33.944 Y31.535
N4849 G01 X33.919 Y30.814
N4850 G01 X33.904 Y30.092
N4851 G01 X33.896 Y29.37
N4852 G01 X33.891 Y28.648
N4853 G01 X33.888 Y27.926
N4854 G01 X33.886 Y26.482
N4855 G01 X33.885 Y20.706
N4856 G01 Y15.381
N4857 G01 X33.886 Y15.357
N4858 G03 X34.046 Y15.363 I0.08 J0.003
N4859 G03 X33.921 Y15.426 I-0.08 J-0.003
N4860 G01 X33.261 Y14.973
N4861 G03 X33.351 Y14.841 I0.045 J-0.066
N4862 G03 X33.384 Y14.889 I-0.045 J0.066
N4863 G01 X33.389 Y14.913
N4864 G01 X33.395 Y14.941
N4865 G01 X33.538 Y15.214
N4866 G01 X33.553 Y15.413
N4867 G01 X33.48 Y15.622
N4868 G01 X33.274 Y15.685
N4869 G01 X33.065 Y15.741
N4870 G01 X32.806 Y15.801
N4871 G01 X32.492 Y15.862
N4872 G01 X32.128 Y15.919
N4873 G01 X31.649 Y15.977
N4874 G01 X30.985 Y16.034
N4875 G01 X30.264 Y16.071
N4876 G01 X29.542 Y16.091
N4877 G01 X28.82 Y16.102
N4878 G01 X28.098 Y16.108
N4879 G01 X27.376 Y16.111
N4880 G01 X25.932 Y16.114
N4881 G01 X20.878 Y16.115
N4882 G01 X17.178
N4883 G01 X17.088 Y16.112
N4884 G03 X17.109 Y15.512 I0.01 J-0.3
N4885 G03 X17.386 Y15.897 I-0.01 J0.3
N4886 G01 X17.032 Y17.092
N4887 G03 X16.457 Y16.921 I-0.288 J-0.085
N4888 G03 X16.639 Y16.725 I0.288 J0.085
N4889 G03 X16.665 Y16.717 I0.105 J0.281
N4890 G01 X16.752 Y16.693
N4891 G01 X16.78 Y16.687
N4892 G01 X17.046 Y16.535
N4893 G01 X17.245 Y16.514
N4894 G01 X17.456 Y16.579
N4895 G01 X17.517 Y16.759
N4896 G01 X17.581 Y16.978
N4897 G01 X17.642 Y17.211
N4898 G01 X17.703 Y17.487
N4899 G01 X17.766 Y17.829
N4900 G01 X17.826 Y18.228
N4901 G01 X17.885 Y18.757
N4902 G01 X17.941 Y19.477
N4903 G01 X17.972 Y20.198
N4904 G01 X17.991 Y20.92
N4905 G01 X18.001 Y21.642
N4906 G01 X18.007 Y22.364
N4907 G01 X18.01 Y23.086
N4908 G01 X18.013 Y24.53
N4909 G01 X18.015 Y28.14
N4910 G01 Y33.465
N4911 G01 X18.035 Y33.505
N4912 G01 X18.07 Y33.533
N4913 G01 X18.115 Y33.542
N4914 G01 X18.814 Y33.364
N4915 G01 X18.975 Y33.315
N4916 G01 X19.167 Y33.265
N4917 G01 X19.4 Y33.213
N4918 G01 X19.67 Y33.162
N4919 G01 X20.021 Y33.109
N4920 G01 X20.475 Y33.057
N4921 G01 X21.144 Y33.004
N4922 G01 X21.866 Y32.972
N4923 G01 X22.587 Y32.955
N4924 G01 X23.309 Y32.946
N4925 G01 X24.031 Y32.941
N4926 G01 X24.753 Y32.938
N4927 G01 X26.197 Y32.936
N4928 G01 X33.417 Y32.935
N4929 G01 X33.458 Y32.915
N4930 G01 X33.485 Y32.88
N4931 G01 X33.495 Y32.835
N4932 G01 X33.316 Y32.136
N4933 G01 X33.268 Y31.956
N4934 G01 X33.219 Y31.744
N4935 G01 X33.168 Y31.483
N4936 G01 X33.117 Y31.162
N4937 G01 X33.065 Y30.736
N4938 G01 X33.013 Y30.138
N4939 G01 X32.976 Y29.417
N4940 G01 X32.957 Y28.695
N4941 G01 X32.946 Y27.973
N4942 G01 X32.941 Y27.251
N4943 G01 X32.938 Y26.529
N4944 G01 X32.936 Y25.085
N4945 G01 X32.935 Y18.587
N4946 G01 Y16.331
N4947 G01 X32.936 Y16.307
N4948 G03 X33.096 Y16.313 I0.08 J0.003
N4949 G03 X32.968 Y16.374 I-0.08 J-0.003
N4950 G01 X32.361 Y15.921
N4951 G03 X32.457 Y15.792 I0.048 J-0.064
N4952 G03 X32.487 Y15.839 I-0.048 J0.064
N4953 G01 X32.492 Y15.862
N4954 G01 X32.498 Y15.89
N4955 G01 X32.64 Y16.164
N4956 G01 X32.654 Y16.363
N4957 G01 X32.58 Y16.572
N4958 G01 X32.375 Y16.634
N4959 G01 X32.154 Y16.693
N4960 G01 X31.897 Y16.752
N4961 G01 X31.574 Y16.814
N4962 G01 X31.206 Y16.871
N4963 G01 X30.712 Y16.929
N4964 G01 X30.024 Y16.987
N4965 G01 X29.302 Y17.021
N4966 G01 X28.581 Y17.041
N4967 G01 X27.859 Y17.052
N4968 G01 X27.137 Y17.058
N4969 G01 X26.415 Y17.061
N4970 G01 X24.971 Y17.064
N4971 G01 X20.639 Y17.065
N4972 G01 X18.202
N4973 G01 X18.112 Y17.062
N4974 G03 X18.133 Y16.462 I0.01 J-0.3
N4975 G03 X18.4 Y16.877 I-0.01 J0.3
N4976 G01 X17.968 Y17.915
N4977 G03 X17.414 Y17.685 I-0.277 J-0.115
N4978 G03 X17.616 Y17.51 I0.277 J0.115
N4979 G01 X17.703 Y17.487
N4980 G01 X17.835 Y17.458
N4981 G01 X17.986 Y17.366
N4982 G01 X18.181 Y17.338
N4983 G01 X18.392 Y17.396
N4984 G01 X18.587 Y17.553
N4985 G01 X18.665 Y17.953
N4986 G01 X18.737 Y18.404
N4987 G01 X18.807 Y18.971
N4988 G01 X18.869 Y19.691
N4989 G01 X18.908 Y20.412
N4990 G01 X18.931 Y21.133
N4991 G01 X18.945 Y21.855
N4992 G01 X18.953 Y22.577
N4993 G01 X18.958 Y23.299
N4994 G01 X18.961 Y24.021
N4995 G01 X18.964 Y25.465
N4996 G01 X18.965 Y29.797
N4997 G01 Y32.775
N4998 G01 X18.964 Y32.799
N4999 G03 X18.804 Y32.794 I-0.08 J-0.003
N5000 G03 X18.93 Y32.731 I0.08 J0.003
N5001 G01 X19.529 Y33.151
N5002 G03 X19.437 Y33.282 I-0.046 J0.066
N5003 G03 X19.406 Y33.236 I0.046 J-0.066
N5004 G01 X19.4 Y33.213
N5005 G01 X19.393 Y33.185
N5006 G01 X19.245 Y32.917
N5007 G01 X19.225 Y32.719
N5008 G01 X19.293 Y32.508
N5009 G01 X19.462 Y32.316
N5010 G01 X19.898 Y32.239
N5011 G01 X20.391 Y32.169
N5012 G01 X21.003 Y32.105
N5013 G01 X21.723 Y32.055
N5014 G01 X22.444 Y32.025
N5015 G01 X23.166 Y32.008
N5016 G01 X23.888 Y31.998
N5017 G01 X24.61 Y31.992
N5018 G01 X25.332 Y31.989
N5019 G01 X26.776 Y31.986
N5020 G01 X31.108 Y31.985
N5021 G01 X32.732
N5022 G01 X32.822 Y31.988
N5023 G03 X32.802 Y32.588 I-0.01 J0.3
N5024 G03 X32.528 Y32.192 I0.01 J-0.3
N5025 G01 X32.903 Y31.075
N5026 G03 X33.472 Y31.266 I0.284 J0.096
N5027 G03 X33.282 Y31.455 I-0.284 J-0.096
N5028 G03 X33.255 Y31.462 I-0.094 J-0.285
N5029 G01 X33.168 Y31.483
N5030 G01 X33.14 Y31.488
N5031 G01 X32.866 Y31.63
N5032 G01 X32.667 Y31.644
N5033 G01 X32.459 Y31.57
N5034 G01 X32.399 Y31.374
N5035 G01 X32.344 Y31.163
N5036 G01 X32.285 Y30.901
N5037 G01 X32.227 Y30.594
N5038 G01 X32.17 Y30.223
N5039 G01 X32.114 Y29.741
N5040 G01 X32.058 Y29.055
N5041 G01 X32.025 Y28.334
N5042 G01 X32.007 Y27.612
N5043 G01 X31.997 Y26.891
N5044 G01 X31.991 Y26.169
N5045 G01 X31.988 Y25.447
N5046 G01 X31.986 Y24.003
N5047 G01 X31.985 Y18.949
N5048 G01 Y17.324
N5049 G01 X31.986 Y17.3
N5050 G03 X32.146 Y17.306 I0.08 J0.003
N5051 G03 X32.014 Y17.364 I-0.08 J-0.003
N5052 G01 X31.438 Y16.869
N5053 G03 X31.543 Y16.747 I0.052 J-0.061
N5054 G03 X31.568 Y16.79 I-0.052 J0.061
N5055 G01 X31.574 Y16.814
N5056 G01 X31.599 Y16.947
N5057 G01 X31.687 Y17.101
N5058 G01 X31.709 Y17.297
N5059 G01 X31.645 Y17.506
N5060 G01 X31.456 Y17.566
N5061 G01 X31.244 Y17.626
N5062 G01 X31.012 Y17.682
N5063 G01 X30.719 Y17.742
N5064 G01 X30.38 Y17.799
N5065 G01 X29.935 Y17.858
N5066 G01 X29.353 Y17.915
N5067 G01 X28.632 Y17.959
N5068 G01 X27.911 Y17.984
N5069 G01 X27.189 Y17.998
N5070 G01 X26.467 Y18.005
N5071 G01 X25.745 Y18.01
N5072 G01 X25.023 Y18.012
N5073 G01 X23.579 Y18.014
N5074 G01 X20.691 Y18.015
N5075 G01 X19.337
N5076 G01 X19.247
N5077 G01 X19.157 Y18.012
N5078 G03 X19.178 Y17.412 I0.01 J-0.3
N5079 G03 X19.44 Y17.837 I-0.01 J0.3
N5080 G01 X18.979 Y18.841
N5081 G03 X18.433 Y18.591 I-0.273 J-0.125
N5082 G03 X18.649 Y18.421 I0.273 J0.125
N5083 G01 X18.737 Y18.404
N5084 G01 X18.872 Y18.383
N5085 G01 X19.03 Y18.3
N5086 G01 X19.228 Y18.285
N5087 G01 X19.437 Y18.357
N5088 G01 X19.493 Y18.544
N5089 G01 X19.549 Y18.762
N5090 G01 X19.609 Y19.034
N5091 G01 X19.666 Y19.342
N5092 G01 X19.727 Y19.746
N5093 G01 X19.784 Y20.257
N5094 G01 X19.84 Y20.977
N5095 G01 X19.872 Y21.699
N5096 G01 X19.89 Y22.42
N5097 G01 X19.9 Y23.142
N5098 G01 X19.906 Y23.864
N5099 G01 X19.91 Y24.586
N5100 G01 X19.913 Y26.03
N5101 G01 X19.915 Y29.64
N5102 G01 Y31.671
N5103 G01 X19.912 Y31.761
N5104 G03 X19.91 Y31.788 I-0.3 J-0.01
N5105 G03 X19.314 Y31.712 I-0.298 J-0.038
N5106 G03 X19.728 Y31.473 I0.298 J0.038
N5107 G01 X20.818 Y31.929
N5108 G03 X20.586 Y32.482 I-0.116 J0.277
N5109 G03 X20.407 Y32.258 I0.116 J-0.277
N5110 G01 X20.391 Y32.169
N5111 G01 X20.387 Y32.141
N5112 G01 X20.259 Y31.861
N5113 G01 X20.255 Y31.66
N5114 G01 X20.339 Y31.453
N5115 G01 X20.549 Y31.398
N5116 G01 X20.792 Y31.342
N5117 G01 X21.1 Y31.283
N5118 G01 X21.458 Y31.228
N5119 G01 X21.943 Y31.17
N5120 G01 X22.626 Y31.113
N5121 G01 X23.347 Y31.079
N5122 G01 X24.069 Y31.06
N5123 G01 X24.791 Y31.049
N5124 G01 X25.513 Y31.043
N5125 G01 X26.235 Y31.039
N5126 G01 X27.679 Y31.036
N5127 G01 X30.567 Y31.035
N5128 G01 X31.74
N5129 G01 X31.83 Y31.038
N5130 G03 X31.809 Y31.638 I-0.01 J0.3
N5131 G03 X31.541 Y31.225 I0.01 J-0.3
N5132 G01 X31.97 Y30.169
N5133 G03 X32.526 Y30.395 I0.278 J0.113
N5134 G03 X32.314 Y30.574 I-0.278 J-0.113
N5135 G01 X32.227 Y30.594
N5136 G01 X32.198 Y30.599
N5137 G01 X31.924 Y30.74
N5138 G01 X31.724 Y30.754
N5139 G01 X31.516 Y30.679
N5140 G01 X31.454 Y30.474
N5141 G01 X31.395 Y30.248
N5142 G01 X31.338 Y29.992
N5143 G01 X31.277 Y29.665
N5144 G01 X31.221 Y29.292
N5145 G01 X31.163 Y28.787
N5146 G01 X31.106 Y28.073
N5147 G01 X31.074 Y27.351
N5148 G01 X31.057 Y26.63
N5149 G01 X31.047 Y25.908
N5150 G01 X31.042 Y25.186
N5151 G01 X31.039 Y24.464
N5152 G01 X31.036 Y23.02
N5153 G01 X31.035 Y18.237
N5154 G01 X31.036 Y18.213
N5155 G03 X31.196 Y18.218 I0.08 J0.003
N5156 G03 X31.059 Y18.272 I-0.08 J-0.003
N5157 G01 X30.579 Y17.794
N5158 G03 X30.692 Y17.681 I0.056 J-0.057
N5159 G03 X30.713 Y17.719 I-0.056 J0.057
N5160 G01 X30.719 Y17.742
N5161 G01 X30.75 Y17.896
N5162 G01 X30.832 Y18.056
N5163 G01 X30.844 Y18.255
N5164 G01 X30.769 Y18.465
N5165 G01 X30.593 Y18.652
N5166 G01 X30.128 Y18.728
N5167 G01 X29.588 Y18.797
N5168 G01 X28.869 Y18.864
N5169 G01 X28.148 Y18.905
N5170 G01 X27.427 Y18.929
N5171 G01 X26.705 Y18.944
N5172 G01 X25.983 Y18.953
N5173 G01 X25.261 Y18.958
N5174 G01 X24.539 Y18.961
N5175 G01 X23.095 Y18.964
N5176 G01 X21.651 Y18.966
N5177 G01 X20.929 Y18.963
N5178 G01 X20.749 Y18.965
N5179 G01 X20.162
N5180 G01 X20.072 Y18.961
N5181 G03 X20.094 Y18.362 I0.011 J-0.3
N5182 G03 X20.357 Y18.783 I-0.011 J0.3
N5183 G01 X19.918 Y19.776
N5184 G03 X19.369 Y19.533 I-0.274 J-0.121
N5185 G03 X19.579 Y19.361 I0.274 J0.121
N5186 G01 X19.666 Y19.342
N5187 G01 X19.8 Y19.317
N5188 G01 X19.956 Y19.23
N5189 G01 X20.153 Y19.21
N5190 G01 X20.361 Y19.276
N5191 G01 X20.551 Y19.44
N5192 G01 X20.621 Y19.86
N5193 G01 X20.691 Y20.383
N5194 G01 X20.755 Y21.052
N5195 G01 X20.8 Y21.773
N5196 G01 X20.826 Y22.495
N5197 G01 X20.842 Y23.216
N5198 G01 X20.851 Y23.938
N5199 G01 X20.857 Y24.66
N5200 G01 X20.86 Y25.382
N5201 G01 X20.863 Y26.826
N5202 G01 X20.865 Y29.714
N5203 G01 Y30.752
N5204 G01 X20.862 Y30.842
N5205 G03 X20.859 Y30.87 I-0.3 J-0.011
N5206 G03 X20.264 Y30.793 I-0.298 J-0.038
N5207 G03 X20.708 Y30.569 I0.298 J0.038
N5208 G01 X21.558 Y31.042
N5209 G03 X21.267 Y31.567 I-0.146 J0.262
N5210 G03 X21.12 Y31.371 I0.146 J-0.262
N5211 G01 X21.1 Y31.283
N5212 G01 X21.062 Y31.087
N5213 G01 X21. Y30.912
N5214 G01 X21.013 Y30.707
N5215 G01 X21.118 Y30.502
N5216 G01 X21.33 Y30.328
N5217 G01 X21.96 Y30.25
N5218 G01 X22.679 Y30.186
N5219 G01 X23.4 Y30.146
N5220 G01 X24.122 Y30.122
N5221 G01 X24.844 Y30.107
N5222 G01 X25.565 Y30.098
N5223 G01 X26.287 Y30.092
N5224 G01 X27.009 Y30.089
N5225 G01 X28.453 Y30.086
N5226 G01 X29.175 Y30.084
N5227 G01 X29.897 Y30.089
N5228 G01 X30.258 Y30.083
N5229 G01 X30.71 Y30.086
N5230 G01 X30.8 Y30.085
N5231 G01 X30.824 Y30.086
N5232 G03 X30.819 Y30.246 I-0.003 J0.08
N5233 G03 X30.758 Y30.117 I0.003 J-0.08
N5234 G01 X31.22 Y29.532
N5235 G03 X31.346 Y29.631 I0.063 J0.05
N5236 G03 X31.3 Y29.66 I-0.063 J-0.05
N5237 G01 X31.277 Y29.665
N5238 G01 X31.249 Y29.67
N5239 G01 X30.974 Y29.811
N5240 G01 X30.774 Y29.823
N5241 G01 X30.566 Y29.748
N5242 G01 X30.505 Y29.544
N5243 G01 X30.444 Y29.31
N5244 G01 X30.387 Y29.054
N5245 G01 X30.327 Y28.726
N5246 G01 X30.27 Y28.348
N5247 G01 X30.212 Y27.834
N5248 G01 X30.155 Y27.114
N5249 G01 X30.124 Y26.393
N5250 G01 X30.107 Y25.671
N5251 G01 X30.097 Y24.949
N5252 G01 X30.092 Y24.227
N5253 G01 X30.089 Y23.505
N5254 G01 X30.086 Y22.061
N5255 G01 X30.084 Y20.617
N5256 G01 X30.087 Y19.896
N5257 G01 X30.085 Y19.535
N5258 G01 Y19.354
N5259 G01 X30.065 Y19.313
N5260 G01 X30.03 Y19.286
N5261 G01 X29.985 Y19.277
N5262 G01 X29.286 Y19.455
N5263 G01 X29.138 Y19.503
N5264 G01 X28.962 Y19.553
N5265 G01 X28.75 Y19.605
N5266 G01 X28.507 Y19.655
N5267 G01 X28.202 Y19.708
N5268 G01 X27.812 Y19.761
N5269 G01 X27.274 Y19.815
N5270 G01 X26.554 Y19.861
N5271 G01 X25.832 Y19.886
N5272 G01 X25.11 Y19.899
N5273 G01 X24.389 Y19.906
N5274 G01 X23.667 Y19.91
N5275 G01 X22.945 Y19.912
N5276 G01 X22.223 Y19.918
N5277 G01 X21.862 Y19.913
N5278 G01 X21.681 Y19.915
N5279 G01 X21.275 Y19.914
N5280 G01 X21.234 Y19.934
N5281 G01 X21.207 Y19.969
N5282 G01 X21.197 Y20.014
N5283 G01 X21.373 Y20.714
N5284 G01 X21.422 Y20.875
N5285 G01 X21.473 Y21.069
N5286 G01 X21.525 Y21.296
N5287 G01 X21.577 Y21.566
N5288 G01 X21.631 Y21.914
N5289 G01 X21.684 Y22.36
N5290 G01 X21.738 Y23.009
N5291 G01 X21.773 Y23.73
N5292 G01 X21.792 Y24.452
N5293 G01 X21.802 Y25.174
N5294 G01 X21.808 Y25.895
N5295 G01 X21.811 Y26.617
N5296 G01 X21.813 Y27.339
N5297 G01 X21.817 Y28.061
N5298 G01 X21.808 Y28.783
N5299 G01 X21.819 Y29.144
N5300 G01 X21.816 Y29.325
N5301 G01 X21.815 Y29.641
N5302 G01 X21.835 Y29.681
N5303 G01 X21.871 Y29.709
N5304 G01 X21.915 Y29.718
N5305 G01 X22.615 Y29.54
N5306 G01 X22.791 Y29.49
N5307 G01 X22.993 Y29.441
N5308 G01 X23.235 Y29.39
N5309 G01 X23.542 Y29.338
N5310 G01 X23.925 Y29.286
N5311 G01 X24.46 Y29.233
N5312 G01 X25.18 Y29.187
N5313 G01 X25.902 Y29.163
N5314 G01 X26.624 Y29.15
N5315 G01 X27.345 Y29.144
N5316 G01 X28.067 Y29.139
N5317 G01 X28.789 Y29.131
N5318 G01 X29.15 Y29.137
N5319 G01 X29.331 Y29.136
N5320 G01 X29.827 Y29.138
N5321 G03 X29.941 Y29.165 I-0.011 J0.3
N5322 G01 X30.002 Y29.192 Z19.492
N5323 G01 X30.06 Y29.219 Z19.47
N5324 G01 X30.111 Y29.242 Z19.435
N5325 G01 X30.154 Y29.262 Z19.387
N5326 G01 X30.187 Y29.277 Z19.33
N5327 G01 X30.207 Y29.286 Z19.267
N5328 G01 X30.214 Y29.289 Z19.2
N5329 G00 Z-3.01
N5330 G00 X21.093 Y20.27
N5331 G00 Z18.9
N5332 G01 Z19.2 F1500
N5333 G01 X21.086 Y20.272 Z19.267
N5334 G01 X21.064 Y20.278 Z19.33
N5335 G01 X21.03 Y20.288 Z19.387
N5336 G01 X20.984 Y20.3 Z19.435
N5337 G01 X20.929 Y20.316 Z19.47
N5338 G01 X20.868 Y20.333 Z19.492
N5339 G01 X20.804 Y20.351 Z19.5
N5340 G01 X20.691 Y20.383
N5341 G01 X21.333 Y20.298
N5342 G01 X21.621 Y20.157
N5343 G01 X21.83 Y20.147
N5344 G01 X22.049 Y20.23
N5345 G01 X22.252 Y20.426
N5346 G01 X22.351 Y20.844
N5347 G01 X22.438 Y21.28
N5348 G01 X22.522 Y21.792
N5349 G01 X22.597 Y22.381
N5350 G01 X22.664 Y23.1
N5351 G01 X22.705 Y23.821
N5352 G01 X22.729 Y24.542
N5353 G01 X22.744 Y25.264
N5354 G01 X22.753 Y25.986
N5355 G01 X22.758 Y26.708
N5356 G01 X22.77 Y27.43
N5357 G01 X22.752 Y28.152
N5358 G01 X22.761 Y28.332
N5359 G01 X22.76 Y28.512
N5360 G01 X22.759 Y28.693
N5361 G01 X22.763 Y28.918
N5362 G03 X22.163 Y28.912 I-0.3 J-0.003
N5363 G03 X22.488 Y28.616 I0.3 J0.003
N5364 G01 X30.51 Y29.272
N5365 G02 X30.559 Y28.674 I0.024 J-0.299
N5366 G02 X30.438 Y28.688 I-0.024 J0.299
N5367 G01 X30.327 Y28.726
N5368 G01 X30.298 Y28.731
N5369 G01 X30.023 Y28.872
N5370 G01 X29.824 Y28.884
N5371 G01 X29.615 Y28.809
N5372 G01 X29.555 Y28.605
N5373 G01 X29.493 Y28.368
N5374 G01 X29.437 Y28.112
N5375 G01 X29.376 Y27.784
N5376 G01 X29.319 Y27.401
N5377 G01 X29.261 Y26.883
N5378 G01 X29.205 Y26.163
N5379 G01 X29.174 Y25.442
N5380 G01 X29.157 Y24.72
N5381 G01 X29.147 Y23.998
N5382 G01 X29.142 Y23.276
N5383 G01 X29.139 Y22.554
N5384 G01 X29.131 Y21.832
N5385 G01 X29.147 Y21.11
N5386 G01 X29.128 Y20.75
N5387 G01 X29.134 Y20.569
N5388 G01 X29.137 Y20.028
N5389 G01 X29.14 Y19.938
N5390 G03 X29.74 Y19.96 I0.3 J0.011
N5391 G03 X29.341 Y20.232 I-0.3 J-0.011
N5392 G01 X28.339 Y19.883
N5393 G03 X28.536 Y19.316 I0.099 J-0.283
N5394 G03 X28.726 Y19.518 I-0.099 J0.283
N5395 G01 X28.75 Y19.605
N5396 G01 X28.783 Y19.735
N5397 G01 X28.877 Y19.884
N5398 G01 X28.908 Y20.079
N5399 G01 X28.853 Y20.291
N5400 G01 X28.699 Y20.489
N5401 G01 X28.35 Y20.56
N5402 G01 X27.895 Y20.636
N5403 G01 X27.4 Y20.7
N5404 G01 X26.729 Y20.763
N5405 G01 X26.008 Y20.806
N5406 G01 X25.287 Y20.831
N5407 G01 X24.567 Y20.889
N5408 G01 X24.212 Y20.821
N5409 G01 X23.687 Y20.901
N5410 G01 X23.512 Y20.855
N5411 G01 X23.332 Y20.859
N5412 G01 X23.061 Y20.862
N5413 G01 X22.926 Y20.863
N5414 G03 X22.811 Y20.837 I0.009 J-0.3
N5415 G01 X22.75 Y20.809 Z19.492
N5416 G01 X22.693 Y20.783 Z19.47
N5417 G01 X22.641 Y20.76 Z19.435
N5418 G01 X22.597 Y20.741 Z19.387
N5419 G01 X22.565 Y20.726 Z19.33
N5420 G01 X22.545 Y20.717 Z19.267
N5421 G01 X22.538 Y20.714 Z19.2
N5422 G00 Z-3.01
N5423 G00 X23.378 Y29.783
N5424 G00 Z18.9
N5425 G01 Z19.2 F1500
N5426 G01 X23.375 Y29.776 Z19.267
N5427 G01 X23.368 Y29.755 Z19.33
N5428 G01 X23.355 Y29.722 Z19.387
N5429 G01 X23.339 Y29.677 Z19.435
N5430 G01 X23.32 Y29.624 Z19.47
N5431 G01 X23.298 Y29.564 Z19.492
N5432 G01 X23.276 Y29.501 Z19.5
N5433 G01 X23.235 Y29.39
N5434 G01 X23.23 Y29.363
N5435 G01 X23.085 Y29.091
N5436 G01 X23.068 Y28.892
N5437 G01 X23.139 Y28.683
N5438 G01 X23.32 Y28.626
N5439 G01 X23.532 Y28.568
N5440 G01 X23.796 Y28.505
N5441 G01 X24.081 Y28.448
N5442 G01 X24.44 Y28.39
N5443 G01 X24.886 Y28.333
N5444 G01 X25.505 Y28.276
N5445 G01 X26.226 Y28.235
N5446 G01 X26.947 Y28.213
N5447 G01 X27.667 Y28.158
N5448 G01 X28.022 Y28.226
N5449 G01 X28.289 Y28.184
N5450 G01 X28.469 Y28.183
N5451 G01 X28.83 Y28.181
N5452 G01 X28.92 Y28.182
N5453 G03 X29.034 Y28.212 I-0.017 J0.3
N5454 G01 X29.094 Y28.241 Z19.492
N5455 G01 X29.151 Y28.268 Z19.47
N5456 G01 X29.202 Y28.293 Z19.435
N5457 G01 X29.245 Y28.313 Z19.387
N5458 G01 X29.277 Y28.329 Z19.33
N5459 G01 X29.297 Y28.338 Z19.267
N5460 G01 X29.304 Y28.342 Z19.2
N5461 G00 Z-3.01
N5462 G00 X22.044 Y21.42
N5463 G00 Z18.9
N5464 G01 Z19.2 F1500
N5465 G01 X22.052 Y21.417 Z19.267
N5466 G01 X22.072 Y21.41 Z19.33
N5467 G01 X22.106 Y21.398 Z19.387
N5468 G01 X22.151 Y21.382 Z19.435
N5469 G01 X22.205 Y21.363 Z19.47
N5470 G01 X22.264 Y21.342 Z19.492
N5471 G01 X22.327 Y21.32 Z19.5
N5472 G01 X22.438 Y21.28
N5473 G01 X22.467 Y21.275
N5474 G01 X22.739 Y21.131
N5475 G01 X22.939 Y21.115
N5476 G01 X23.15 Y21.187
N5477 G01 X23.341 Y21.361
N5478 G01 X23.428 Y21.849
N5479 G01 X23.508 Y22.409
N5480 G01 X23.579 Y23.079
N5481 G01 X23.63 Y23.799
N5482 G01 X23.663 Y24.52
N5483 G01 X23.683 Y25.242
N5484 G01 X23.696 Y25.964
N5485 G01 X23.723 Y26.686
N5486 G01 X23.679 Y27.406
N5487 G01 X23.692 Y27.496
N5488 G01 X23.7 Y27.585
N5489 G01 X23.708 Y27.766
N5490 G01 X23.706 Y27.946
N5491 G03 X23.107 Y27.917 I-0.3 J-0.015
N5492 G03 X23.44 Y27.634 I0.3 J0.015
N5493 G01 X29.55 Y28.329
N5494 G02 X29.618 Y27.732 I0.034 J-0.298
N5495 G02 X29.488 Y27.746 I-0.034 J0.298
N5496 G01 X29.376 Y27.784
N5497 G01 X29.242 Y27.809
N5498 G01 X29.087 Y27.896
N5499 G01 X28.891 Y27.916
N5500 G01 X28.682 Y27.85
N5501 G01 X28.493 Y27.686
N5502 G01 X28.423 Y27.272
N5503 G01 X28.355 Y26.753
N5504 G01 X28.291 Y26.092
N5505 G01 X28.247 Y25.371
N5506 G01 X28.221 Y24.649
N5507 G01 X28.206 Y23.928
N5508 G01 X28.197 Y23.206
N5509 G01 X28.177 Y22.484
N5510 G01 X28.209 Y21.763
N5511 G01 X28.201 Y21.673
N5512 G01 X28.197 Y21.583
N5513 G01 X28.193 Y21.402
N5514 G01 X28.194 Y21.267
N5515 G01 Y21.222
N5516 G01 X28.174 Y21.181
N5517 G01 X28.138 Y21.154
N5518 G01 X28.094 Y21.145
N5519 G01 X27.395 Y21.327
N5520 G01 X27.242 Y21.379
N5521 G01 X27.078 Y21.428
N5522 G01 X26.882 Y21.479
N5523 G01 X26.641 Y21.533
N5524 G01 X25.931 Y21.665
N5525 G01 X25.611 Y21.786
N5526 G01 X24.89 Y21.753
N5527 G01 X24.717 Y21.807
N5528 G01 X24.533 Y21.823
N5529 G01 X24.443 Y21.816
N5530 G01 X24.353 Y21.805
N5531 G01 X24.174 Y21.779
N5532 G01 X24.13 Y21.787
N5533 G01 X24.094 Y21.814
N5534 G01 X24.074 Y21.854
N5535 G01 X24.073 Y21.9
N5536 G01 X24.381 Y22.553
N5537 G01 X24.448 Y22.996
N5538 G01 X24.514 Y23.568
N5539 G01 X24.572 Y24.288
N5540 G01 X24.608 Y25.009
N5541 G01 X24.637 Y25.731
N5542 G01 X24.667 Y26.452
N5543 G01 X24.686 Y27.174
N5544 G01 X24.658 Y27.259
N5545 G01 X24.648 Y27.349
N5546 G01 X24.649 Y27.439
N5547 G01 X24.655 Y27.71
N5548 G01 X24.675 Y27.75
N5549 G01 X24.711 Y27.778
N5550 G01 X24.755 Y27.786
N5551 G01 X25.452 Y27.598
N5552 G01 X26.152 Y27.42
N5553 G01 X26.424 Y27.284
N5554 G01 X27.145 Y27.244
N5555 G01 X27.45 Y27.222
N5556 G01 X27.863 Y27.198
N5557 G01 X27.948 Y27.229
N5558 G03 X27.722 Y27.785 I-0.113 J0.278
N5559 G03 X27.535 Y27.518 I0.113 J-0.278
N5560 G01 X27.301 Y20.705
N5561 G03 X27.895 Y20.636 I0.3 J-0.01
N5562 G01 X28.028 Y21.434
N5563 G01 X28.085 Y21.62
N5564 G01 X28.061 Y21.834
N5565 G01 X27.937 Y22.051
N5566 G01 X27.663 Y22.256
N5567 G01 X26.959 Y22.415
N5568 G01 X26.304 Y22.607
N5569 G01 X26.259 Y22.602
N5570 G01 X25.54 Y22.664
N5571 G01 X25.446 Y22.684
N5572 G01 X25.356 Y22.696
N5573 G01 X25.176 Y22.709
N5574 G01 X25.131
N5575 G01 X25.086 Y22.713
N5576 G01 X25.048 Y22.737
N5577 G01 X25.024 Y22.776
N5578 G01 X25.019 Y22.82
N5579 G01 X25.268 Y23.498
N5580 G01 X25.327 Y23.773
N5581 G01 X25.387 Y24.113
N5582 G01 X25.487 Y24.828
N5583 G01 X25.597 Y25.213
N5584 G01 X25.55 Y25.571
N5585 G01 X25.649 Y26.16
N5586 G01 X25.606 Y26.335
N5587 G01 X25.618 Y26.515
N5588 G01 X25.629 Y26.876
N5589 G01 X25.631 Y26.966
N5590 G03 X24.977 Y27.553 I-0.595 J-0.005
N5591 G03 X24.453 Y26.847 I0.06 J-0.592
N5592 G01 X25.482 Y21.569
N5593 G03 X26.641 Y21.533 I0.584 J0.114
N5594 G01 X26.955 Y22.942
N5595 G01 X26.917 Y23.159
N5596 G01 X26.783 Y23.362
N5597 G01 X26.554 Y23.512
N5598 G01 X26.376 Y23.543
N5599 G01 X26.016 Y23.576
N5600 G01 X25.926 Y23.584
N5601 G01 X25.888 Y23.607
N5602 G01 X25.863 Y23.645
N5603 G01 X25.858 Y23.69
N5604 G01 X25.873 Y23.732
N5605 G01 X26.283 Y24.138
N5606 G01 X26.431 Y24.505
N5607 G01 X26.426 Y24.686
N5608 G01 X26.562 Y25.104
N5609 G01 X26.527 Y25.463
N5610 G01 X26.52 Y26.185
N5611 G01 X26.544 Y26.316
N5612 G01 X26.563 Y26.495
N5613 G01 X26.572 Y26.675
N5614 G01 X26.593 Y26.715
N5615 G01 X26.63 Y26.741
N5616 G01 X26.674 Y26.749
N5617 G01 X26.717 Y26.736
N5618 G01 X27.12 Y26.366
N5619 G01 X27.469 Y26.245
N5620 G01 X27.559 Y26.251
N5621 G01 X27.65
N5622 G01 X27.69 Y26.231
N5623 G01 X27.717 Y26.195
N5624 G01 X27.726 Y26.151
N5625 G01 X27.715 Y26.107
N5626 G01 X27.383 Y25.725
N5627 G01 X27.27 Y25.366
N5628 G01 X27.308 Y25.007
N5629 G01 X27.221 Y24.381
N5630 G01 X27.27 Y24.207
N5631 G01 X27.228 Y23.486
N5632 G01 X27.266 Y23.127
N5633 G01 X27.255 Y23.038
N5634 G01 X27.247 Y22.948
N5635 G03 X27.264 Y22.832 I0.3 J-0.015
N5636 G01 X27.287 Y22.769 Z19.492
N5637 G01 X27.308 Y22.709 Z19.47
N5638 G01 X27.327 Y22.656 Z19.435
N5639 G01 X27.343 Y22.611 Z19.387
N5640 G01 X27.355 Y22.577 Z19.33
N5641 G01 X27.363 Y22.557 Z19.267
N5642 G01 X27.365 Y22.549 Z19.2
N5643 G00 Z-7.
N5644 M05
N5645 M30
Thanks!
- Will Fusion 360 replace GMax and th CNC tool kit for 5 axis trunnion tables?
- y axis, Dual Stepper, opposite shaft rotation set up.
- Multipurpose tool holder (Rhombic insert) for both face and z-axis cutting
- Need Help!- 4 Axis - Opposite sides machining
- Need Help!- Z Axis doing the opposite but only in X-????
The Z moves look to be inverted. What we really need to see is your design file from Fusion. It's likely you have something setup wrong.
C|
Did you select the bottom of the part as the Zero position in the CAM?
Also, you can post a .txt file rather that the whole g-code in the thread.
Hi Cygnus,
I've attached the 3 files that I tried. I've also tried all sort of different setup with different WCS origin, etc.. Could you please have a look at the attached files and let me know what I'm doing wrong as they are all cutting in the air.
Will do next time, sorry about that.
Could you please explain where is the job setup orientation configured please?
Thanks!
If you go through the learn section of the fusion forum it would help you a lot Help
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
the first file in your attached files was fine, you would be better of asking this on the fusion forum. it could be a post problem as well
If you go back to setup and select the z axis arrow does it reverse it?
No,
I tried reversing the Z-axis in the setup and still won't fix the issue.
So, the fix is to untick "Invert Z-coordinates" in WinPC NC. By default its tick and works fine with Aspire Vectric. For Fusion 360, you need to untick it and it should work. I tried cutting in the air and it seems to work. Tomorrow I'll try cutting some wood and I'll confirm.
Thanks!
I've replied on the Autodesk Fusion forums. The issue is in the Post Processor. The Z is being scaled to -1, which will reverse the Z axis. Suggest changing it and saving it to an area that is NOT the generic post folder.
https://forums.autodesk.com/t5/compu...t/false#M24531
