Fusion 360 CNC opposite Z axis and tool cutting in the air
Results 1 to 13 of 13
Thread: Fusion 360 CNC opposite Z axis and tool cutting in the air
    Dec 2013
    Default Fusion 360 CNC opposite Z axis and tool cutting in the air
    I'm new to the CNC world and I'm currently using Fusion 360 with WINPC NC post processor. I did a simple model in Fusion360 and loaded the gcode (.nc file) onto WINPC NC. I zeroed my XY&Z axis and start the machining process.
    The CNC machine is following the Z & Y axis property, however instead of lowering the spindle to cut into the material, it is lifting it. So, it is doing completely the opposite of what the X-axis is supposed to do. I've set my work coordinate system & tried to flip the Z-axis and still not having any luck.
    Is there any other option/config in Fusion 360 that I need to change to change the direction of the z-axis?
    Note, that when I use Aspire Vectrix, it works fine but not with Fusion 360.
    For your reference, see G-code below:
    (upside)
    (upside)
    (T1 D=3. CR=1. - ZMIN=-19.5 - bullnose end mill)
    N10 G90
    N11 G71
    (2D Adaptive1)
    (CHANGE TOOL)
    N12 T1 M06 (BULLNOSE END MILL D=3. 3MM BULLNOSE ENDMILL)
    N13 S10000 M03
    N14 G54
    N15 G00 X9.706 Y6.562
    N16 G00 Z-7.
    N17 G00 Z-3.01
    N18 G00 Z4.39
    N19 G01 Z4.69 F1500
    N20 G01 X9.708 Y6.57 Z4.757
    N21 G01 X9.713 Y6.591 Z4.82
    N22 G01 X9.722 Y6.626 Z4.877
    N23 G01 X9.734 Y6.672 Z4.925
    N24 G01 X9.748 Y6.727 Z4.96
    N25 G01 X9.764 Y6.788 Z4.982
    N26 G01 X9.78 Y6.853 Z4.99
    N27 G03 X10.015 Y8.486 I-7.419 J1.9
    N28 G01 Y8.576
    N29 G01 X9.75 Y9.248
    N30 G01 X9.608 Y9.956
    N31 G01 X9.536 Y10.674
    N32 G01 X9.499 Y11.395
    N33 G01 X9.482 Y12.117
    N34 G01 X9.473 Y12.839
    N35 G01 X9.469 Y13.561
    N36 G01 X9.467 Y14.283
    N37 G01 X9.465 Y16.449
    N38 G01 Y38.831
    N39 G01 X9.578 Y39.174
    N40 G01 X9.789 Y39.467
    N41 G01 X10.328 Y39.947
    N42 G01 X10.992 Y40.229
    N43 G01 X11.698 Y40.381
    N44 G01 X12.416 Y40.459
    N45 G01 X13.137 Y40.498
    N46 G01 X13.859 Y40.517
    N47 G01 X14.581 Y40.526
    N48 G01 X15.303 Y40.531
    N49 G01 X16.025 Y40.533
    N50 G01 X18.191 Y40.535
    N51 G01 X29.02
    N52 G01 X38.767
    N53 G01 X39.117 Y40.446
    N54 G01 X39.42 Y40.249
    N55 G01 X39.918 Y39.727
    N56 G01 X40.212 Y39.067
    N57 G01 X40.372 Y38.363
    N58 G01 X40.455 Y37.646
    N59 G01 X40.496 Y36.925
    N60 G01 X40.516 Y36.203
    N61 G01 X40.526 Y35.481
    N62 G01 X40.531 Y34.76
    N63 G01 X40.533 Y34.038
    N64 G01 X40.535 Y31.872
    N65 G01 Y11.295
    N66 G01 X40.504 Y11.117
    N67 G01 X40.373 Y10.78
    N68 G01 X40.152 Y10.495
    N69 G01 X39.6 Y10.029
    N70 G01 X38.931 Y9.758
    N71 G01 X38.224 Y9.612
    N72 G01 X37.506 Y9.538
    N73 G01 X36.785 Y9.5
    N74 G01 X36.063 Y9.482
    N75 G01 X35.341 Y9.473
    N76 G01 X34.619 Y9.469
    N77 G01 X33.897 Y9.467
    N78 G01 X31.731 Y9.465
    N79 G01 X30.287
    N80 G01 X12.237
    N81 G01 X11.893 Y9.573
    N82 G01 X11.592 Y9.772
    N83 G01 X11.088 Y10.29
    N84 G01 X10.848 Y10.433
    N85 G01 X10.562 Y10.47
    N86 G01 X10.382 Y10.467
    N87 G01 X10.292 Y10.466
    N88 G01 X10.251 Y10.486
    N89 G01 X10.223 Y10.521
    N90 G01 X10.214 Y10.565
    N91 G01 X10.301 Y10.916
    N92 G01 X10.343 Y11.358
    N93 G01 X10.386 Y12.079
    N94 G01 X10.403 Y12.801
    N95 G01 X10.41 Y13.523
    N96 G01 X10.413 Y14.245
    N97 G01 X10.415 Y15.689
    N98 G01 Y37.348
    N99 G01 X10.508 Y38.064
    N100 G01 X10.458 Y38.238
    N101 G01 X10.469 Y38.599
    N102 G01 X10.467 Y38.734
    N103 G01 X10.506 Y38.816
    N104 G01 X10.759 Y39.073
    N105 G01 X11.072 Y39.253
    N106 G01 X11.759 Y39.475
    N107 G01 X12.48 Y39.513
    N108 G01 X13.201 Y39.546
    N109 G01 X13.923 Y39.562
    N110 G01 X14.645 Y39.572
    N111 G01 X15.367 Y39.578
    N112 G01 X16.089 Y39.581
    N113 G01 X17.533 Y39.584
    N114 G01 X21.864 Y39.585
    N115 G01 X37.748
    N116 G01 X38.103 Y39.516
    N117 G01 X38.462 Y39.551
    N118 G01 X38.642 Y39.539
    N119 G01 X38.687 Y39.538
    N120 G01 X38.731 Y39.526
    N121 G01 X38.811 Y39.486
    N122 G01 X38.947 Y39.366
    N123 G01 X39.072 Y39.237
    N124 G01 X39.256 Y38.926
    N125 G01 X39.463 Y38.234
    N126 G01 X39.507 Y37.514
    N127 G01 X39.561 Y36.794
    N128 G01 X39.569 Y36.072
    N129 G01 X39.575 Y35.35
    N130 G01 X39.579 Y34.628
    N131 G01 X39.582 Y33.906
    N132 G01 X39.584 Y32.462
    N133 G01 X39.585 Y26.686
    N134 G01 Y16.578
    N135 G01 Y12.246
    N136 G01 X39.516 Y11.892
    N137 G01 X39.551 Y11.532
    N138 G01 X39.539 Y11.352
    N139 G01 X39.531 Y11.308
    N140 G01 X39.494 Y11.225
    N141 G01 X39.38 Y11.086
    N142 G01 X39.103 Y10.854
    N143 G01 X38.435 Y10.58
    N144 G01 X37.715 Y10.521
    N145 G01 X37. Y10.425
    N146 G01 X36.278 Y10.426
    N147 G01 X34.112 Y10.418
    N148 G01 X31.946 Y10.416
    N149 G01 X13.896 Y10.415
    N150 G01 X13.174 Y10.424
    N151 G01 X12.682 Y10.505
    N152 G01 X12.507 Y10.461
    N153 G01 X12.327 Y10.464
    N154 G01 X12.244 Y10.499
    N155 G01 X11.678 Y10.948
    N156 G01 X11.442 Y11.207
    N157 G01 X11.342 Y11.252
    N158 G01 X11.258 Y11.286
    N159 G01 X11.173 Y11.315
    N160 G01 X11.129 Y11.327
    N161 G01 X11.085 Y11.338
    N162 G01 X11.051 Y11.367
    N163 G01 X11.032 Y11.408
    N164 G01 X11.059 Y12.13
    N165 G01 X11.105 Y12.328
    N166 G01 X11.151 Y12.566
    N167 G01 X11.198 Y12.866
    N168 G01 X11.246 Y13.257
    N169 G01 X11.294 Y13.818
    N170 G01 X11.331 Y14.539
    N171 G01 X11.349 Y15.261
    N172 G01 X11.357 Y15.983
    N173 G01 X11.361 Y16.705
    N174 G01 X11.363 Y17.427
    N175 G01 X11.365 Y19.593
    N176 G01 Y27.535
    N177 G01 Y37.643
    N178 G01 X11.474 Y37.987
    N179 G01 X11.452 Y38.166
    N180 G01 X11.432 Y38.254
    N181 G01 X11.424 Y38.344
    N182 G01 X11.423 Y38.389
    N183 G01 X11.441 Y38.43
    N184 G01 X11.476 Y38.459
    N185 G01 X12.179 Y38.626
    N186 G01 X12.901 Y38.615
    N187 G01 X13.622 Y38.616
    N188 G01 X15.066 Y38.625
    N189 G01 X15.788 Y38.631
    N190 G01 X17.954 Y38.635
    N191 G01 X38.17
    N192 G01 X38.26 Y38.622
    N193 G01 X38.304 Y38.617
    N194 G01 X38.343 Y38.593
    N195 G01 X38.39 Y38.516
    N196 G01 X38.589 Y37.822
    N197 G01 X38.603 Y37.1
    N198 G01 X38.613 Y36.378
    N199 G01 X38.631 Y35.656
    N200 G01 X38.63 Y34.934
    N201 G01 X38.634 Y32.768
    N202 G01 X38.635 Y28.436
    N203 G01 Y26.27
    N204 G01 Y11.83
    N205 G01 X38.621 Y11.741
    N206 G01 X38.617 Y11.696
    N207 G01 X38.593 Y11.658
    N208 G01 X38.439 Y11.563
    N209 G01 X37.735 Y11.404
    N210 G01 X37.013 Y11.389
    N211 G01 X36.293 Y11.338
    N212 G01 X35.571 Y11.355
    N213 G01 X34.849 Y11.362
    N214 G01 X34.127 Y11.365
    N215 G01 X32.683 Y11.366
    N216 G01 X13.911 Y11.365
    N217 G01 X13.19 Y11.373
    N218 G01 X12.699 Y11.477
    N219 G01 X12.611 Y11.459
    N220 G01 X12.567 Y11.45
    N221 G01 X12.523 Y11.46
    N222 G01 X12.245 Y11.691
    N223 G01 X12.056 Y11.946
    N224 G01 X11.978 Y11.991
    N225 G01 X11.938 Y12.012
    N226 G01 X11.912 Y12.049
    N227 G01 X11.904 Y12.093
    N228 G01 X11.978 Y12.408
    N229 G01 X12.043 Y12.737
    N230 G01 X12.112 Y13.166
    N231 G01 X12.171 Y13.641
    N232 G01 X12.23 Y14.303
    N233 G01 X12.268 Y15.024
    N234 G01 X12.29 Y15.745
    N235 G01 X12.301 Y16.467
    N236 G01 X12.308 Y17.189
    N237 G01 X12.311 Y17.911
    N238 G01 X12.314 Y19.355
    N239 G01 X12.315 Y20.799
    N240 G01 Y37.405
    N241 G01 X12.343 Y37.583
    N242 G01 X12.368 Y37.67
    N243 G01 X12.387 Y37.758
    N244 G01 X12.393 Y37.803
    N245 G01 X12.418 Y37.841
    N246 G01 X12.457 Y37.863
    N247 G01 X13.178 Y37.91
    N248 G01 X13.42 Y37.866
    N249 G01 X13.727 Y37.822
    N250 G01 X14.13 Y37.779
    N251 G01 X14.745 Y37.734
    N252 G01 X15.466 Y37.707
    N253 G01 X16.188 Y37.694
    N254 G01 X16.91 Y37.689
    N255 G01 X17.632 Y37.687
    N256 G01 X19.798 Y37.685
    N257 G01 X37.803
    N258 G01 X37.843 Y37.665
    N259 G01 X37.871 Y37.63
    N260 G01 X37.88 Y37.585
    N261 G01 X37.702 Y36.886
    N262 G01 X37.691 Y36.164
    N263 G01 X37.686 Y35.442
    N264 G01 X37.684 Y34.72
    N265 G01 Y33.276
    N266 G01 X37.685 Y29.666
    N267 G01 Y12.203
    N268 G01 X37.665 Y12.162
    N269 G01 X37.63 Y12.134
    N270 G01 X37.585 Y12.125
    N271 G01 X36.886 Y12.304
    N272 G01 X36.164 Y12.305
    N273 G01 X35.442 Y12.274
    N274 G01 X34.721 Y12.295
    N275 G01 X33.999 Y12.306
    N276 G01 X33.277 Y12.311
    N277 G01 X32.555 Y12.313
    N278 G01 X31.111 Y12.315
    N279 G01 X13.783
    N280 G01 X13.061 Y12.328
    N281 G01 X13.019 Y12.344
    N282 G01 X12.976 Y12.36
    N283 G01 X12.943 Y12.389
    N284 G01 X12.911 Y12.422
    N285 G01 X12.896 Y12.464
    N286 G01 X12.991 Y13.18
    N287 G01 X13.064 Y13.668
    N288 G01 X13.129 Y14.238
    N289 G01 X13.185 Y14.958
    N290 G01 X13.219 Y15.679
    N291 G01 X13.238 Y16.401
    N292 G01 X13.25 Y17.123
    N293 G01 X13.257 Y17.845
    N294 G01 X13.26 Y18.567
    N295 G01 X13.264 Y20.011
    N296 G01 Y20.733
    N297 G01 X13.265 Y31.563
    N298 G01 Y37.158
    N299 G01 X13.266 Y37.203
    N300 G01 X13.286 Y37.244
    N301 G01 X13.322 Y37.271
    N302 G01 X13.366 Y37.28
    N303 G01 X14.064 Y37.093
    N304 G01 X14.258 Y37.043
    N305 G01 X14.479 Y36.994
    N306 G01 X14.755 Y36.944
    N307 G01 X15.094 Y36.894
    N308 G01 X15.549 Y36.843
    N309 G01 X16.207 Y36.793
    N310 G01 X16.929 Y36.764
    N311 G01 X17.651 Y36.749
    N312 G01 X18.373 Y36.742
    N313 G01 X19.095 Y36.738
    N314 G01 X20.539 Y36.736
    N315 G01 X28.48 Y36.735
    N316 G01 X37.054
    N317 G01 X37.095 Y36.715
    N318 G01 X37.122 Y36.68
    N319 G01 X37.132 Y36.635
    N320 G01 X36.953 Y35.936
    N321 G01 X36.907 Y35.656
    N322 G01 X36.86 Y35.292
    N323 G01 X36.813 Y34.783
    N324 G01 X36.771 Y34.062
    N325 G01 X36.752 Y33.34
    N326 G01 X36.743 Y32.618
    N327 G01 X36.739 Y31.896
    N328 G01 X36.737 Y31.174
    N329 G01 X36.735 Y29.008
    N330 G01 Y26.842
    N331 G01 Y12.944
    N332 G01 X36.715 Y12.903
    N333 G01 X36.68 Y12.876
    N334 G01 X36.635 Y12.866
    N335 G01 X35.936 Y13.045
    N336 G01 X35.593 Y13.097
    N337 G01 X35.136 Y13.149
    N338 G01 X34.478 Y13.201
    N339 G01 X33.757 Y13.233
    N340 G01 X33.035 Y13.249
    N341 G01 X32.313 Y13.257
    N342 G01 X31.591 Y13.261
    N343 G01 X30.869 Y13.263
    N344 G01 X28.703 Y13.265
    N345 G01 X13.812
    N346 G01 X13.631 Y13.268
    N347 G01 X13.591 Y13.289
    N348 G01 X13.564 Y13.325
    N349 G01 X13.556 Y13.369
    N350 G01 X13.746 Y14.066
    N351 G01 X13.797 Y14.221
    N352 G01 X13.849 Y14.406
    N353 G01 X13.899 Y14.609
    N354 G01 X13.952 Y14.858
    N355 G01 X14.005 Y15.168
    N356 G01 X14.059 Y15.556
    N357 G01 X14.113 Y16.089
    N358 G01 X14.16 Y16.809
    N359 G01 X14.185 Y17.531
    N360 G01 X14.199 Y18.252
    N361 G01 X14.206 Y18.974
    N362 G01 X14.21 Y19.696
    N363 G01 X14.214 Y21.14
    N364 G01 X14.215 Y24.75
    N365 G01 Y26.194
    N366 G01 Y36.483
    N367 G03 X14.188 Y36.597 I-0.3 J-0.01
    N368 G01 X14.16 Y36.657 Z4.982
    N369 G01 X14.134 Y36.715 Z4.96
    N370 G01 X14.111 Y36.767 Z4.925
    N371 G01 X14.091 Y36.81 Z4.877
    N372 G01 X14.076 Y36.843 Z4.82
    N373 G01 X14.067 Y36.863 Z4.757
    N374 G01 X14.064 Y36.87 Z4.69
    N375 G00 Z-3.01
    N376 G00 X13.464 Y13.548
    N377 G00 Z4.39
    N378 G01 Z4.69 F1500
    N379 G01 X13.457 Y13.55 Z4.757
    N380 G01 X13.436 Y13.557 Z4.82
    N381 G01 X13.401 Y13.567 Z4.877
    N382 G01 X13.356 Y13.581 Z4.925
    N383 G01 X13.301 Y13.597 Z4.96
    N384 G01 X13.241 Y13.615 Z4.982
    N385 G01 X13.177 Y13.635 Z4.99
    N386 G01 X13.064 Y13.668
    N387 G01 X13.813 Y13.556
    N388 G01 X13.98 Y13.473
    N389 G01 X14.189 Y13.462
    N390 G01 X14.41 Y13.543
    N391 G01 X14.617 Y13.74
    N392 G01 X14.72 Y14.149
    N393 G01 X14.809 Y14.568
    N394 G01 X14.891 Y15.026
    N395 G01 X14.97 Y15.585
    N396 G01 X15.04 Y16.239
    N397 G01 X15.091 Y16.959
    N398 G01 X15.121 Y17.68
    N399 G01 X15.14 Y18.402
    N400 G01 X15.15 Y19.124
    N401 G01 X15.157 Y19.846
    N402 G01 X15.16 Y20.568
    N403 G01 X15.164 Y22.012
    N404 G01 X15.165 Y25.622
    N405 G01 Y36.271
    N406 G01 X15.185 Y36.312
    N407 G01 X15.22 Y36.34
    N408 G01 X15.265 Y36.349
    N409 G01 X15.964 Y36.17
    N410 G01 X16.127 Y36.124
    N411 G01 X16.322 Y36.076
    N412 G01 X16.55 Y36.028
    N413 G01 X16.831 Y35.979
    N414 G01 X17.192 Y35.929
    N415 G01 X17.684 Y35.879
    N416 G01 X18.404 Y35.832
    N417 G01 X19.126 Y35.808
    N418 G01 X19.847 Y35.797
    N419 G01 X20.569 Y35.791
    N420 G01 X21.291 Y35.788
    N421 G01 X22.735 Y35.786
    N422 G01 X34.287 Y35.785
    N423 G01 X36.363
    N424 G01 X36.453 Y35.788
    N425 G03 X36.481 Y35.79 I-0.01 J0.3
    N426 G03 X36.404 Y36.386 I-0.038 J0.298
    N427 G03 X36.165 Y35.973 I0.038 J-0.298
    N428 G01 X36.623 Y34.866
    N429 G03 X37.177 Y35.096 I0.277 J0.115
    N430 G03 X36.949 Y35.277 I-0.277 J-0.115
    N431 G01 X36.86 Y35.292
    N432 G01 X36.831 Y35.295
    N433 G01 X36.55 Y35.42
    N434 G01 X36.349 Y35.422
    N435 G01 X36.144 Y35.335
    N436 G01 X36.094 Y35.135
    N437 G01 X36.042 Y34.89
    N438 G01 X35.988 Y34.587
    N439 G01 X35.937 Y34.218
    N440 G01 X35.885 Y33.715
    N441 G01 X35.836 Y32.995
    N442 G01 X35.811 Y32.273
    N443 G01 X35.798 Y31.551
    N444 G01 X35.792 Y30.829
    N445 G01 X35.788 Y30.107
    N446 G01 X35.786 Y28.663
    N447 G01 X35.785 Y21.443
    N448 G01 Y13.682
    N449 G01 X35.765 Y13.641
    N450 G01 X35.73 Y13.614
    N451 G01 X35.685 Y13.605
    N452 G01 X34.986 Y13.783
    N453 G01 X34.842 Y13.829
    N454 G01 X34.674 Y13.876
    N455 G01 X34.472 Y13.925
    N456 G01 X34.231 Y13.975
    N457 G01 X33.939 Y14.024
    N458 G01 X33.558 Y14.075
    N459 G01 X33.038 Y14.125
    N460 G01 X32.317 Y14.17
    N461 G01 X31.596 Y14.192
    N462 G01 X30.874 Y14.203
    N463 G01 X30.152 Y14.209
    N464 G01 X29.43 Y14.212
    N465 G01 X27.986 Y14.214
    N466 G01 X17.156 Y14.215
    N467 G01 X15.306
    N468 G01 X15.282 Y14.214
    N469 G03 X15.287 Y14.054 I0.003 J-0.08
    N470 G03 X15.343 Y14.189 I-0.003 J0.08
    N471 G01 X14.864 Y14.705
    N472 G03 X14.747 Y14.597 I-0.059 J-0.054
    N473 G03 X14.786 Y14.573 I0.059 J0.054
    N474 G01 X14.809 Y14.568
    N475 G01 X14.964 Y14.534
    N476 G01 X15.125 Y14.451
    N477 G01 X15.327 Y14.437
    N478 G01 X15.537 Y14.512
    N479 G01 X15.726 Y14.687
    N480 G01 X15.812 Y15.154
    N481 G01 X15.895 Y15.722
    N482 G01 X15.97 Y16.398
    N483 G01 X16.025 Y17.118
    N484 G01 X16.059 Y17.839
    N485 G01 X16.081 Y18.561
    N486 G01 X16.095 Y19.283
    N487 G01 X16.103 Y20.005
    N488 G01 X16.108 Y20.727
    N489 G01 X16.111 Y21.449
    N490 G01 X16.114 Y22.893
    N491 G01 X16.115 Y27.225
    N492 G01 Y35.528
    N493 G01 X16.112 Y35.618
    N494 G03 X15.512 Y35.597 I-0.3 J-0.01
    N495 G03 X15.927 Y35.33 I0.3 J0.01
    N496 G01 X16.978 Y35.766
    N497 G03 X16.748 Y36.32 I-0.115 J0.277
    N498 G03 X16.579 Y36.142 I0.115 J-0.277
    N499 G03 X16.571 Y36.115 I0.283 J-0.099
    N500 G01 X16.55 Y36.028
    N501 G01 X16.544 Y36.
    N502 G01 X16.399 Y35.729
    N503 G01 X16.382 Y35.531
    N504 G01 X16.453 Y35.321
    N505 G01 X16.631 Y35.265
    N506 G01 X16.848 Y35.206
    N507 G01 X17.11 Y35.144
    N508 G01 X17.386 Y35.089
    N509 G01 X17.745 Y35.031
    N510 G01 X18.177 Y34.976
    N511 G01 X18.784 Y34.921
    N512 G01 X19.505 Y34.881
    N513 G01 X20.227 Y34.859
    N514 G01 X20.949 Y34.848
    N515 G01 X21.671 Y34.842
    N516 G01 X22.393 Y34.839
    N517 G01 X23.837 Y34.836
    N518 G01 X29.613 Y34.835
    N519 G01 X35.479
    N520 G01 X35.503 Y34.836
    N521 G03 X35.497 Y34.996 I-0.003 J0.08
    N522 G03 X35.449 Y34.854 I0.003 J-0.08
    N523 G01 X35.944 Y34.442
    N524 G03 X36.047 Y34.565 I0.051 J0.062
    N525 G03 X36.012 Y34.582 I-0.051 J-0.062
    N526 G01 X35.988 Y34.587
    N527 G01 X35.791 Y34.622
    N528 G01 X35.616 Y34.682
    N529 G01 X35.411 Y34.666
    N530 G01 X35.207 Y34.558
    N531 G01 X35.145 Y34.288
    N532 G01 X35.089 Y34.004
    N533 G01 X35.029 Y33.631
    N534 G01 X34.974 Y33.185
    N535 G01 X34.918 Y32.552
    N536 G01 X34.88 Y31.831
    N537 G01 X34.859 Y31.109
    N538 G01 X34.848 Y30.387
    N539 G01 X34.842 Y29.665
    N540 G01 X34.839 Y28.943
    N541 G01 X34.836 Y27.499
    N542 G01 X34.835 Y21.723
    N543 G01 Y14.413
    N544 G01 X34.838 Y14.323
    N545 G03 X34.84 Y14.295 I0.3 J0.01
    N546 G03 X35.436 Y14.372 I0.298 J0.038
    N547 G03 X35.05 Y14.62 I-0.298 J-0.038
    N548 G01 X33.83 Y14.245
    N549 G03 X34.007 Y13.671 I0.088 J-0.287
    N550 G03 X34.202 Y13.86 I-0.088 J0.287
    N551 G03 X34.21 Y13.887 I-0.284 J0.097
    N552 G01 X34.231 Y13.975
    N553 G01 X34.237 Y14.003
    N554 G01 X34.381 Y14.274
    N555 G01 X34.397 Y14.473
    N556 G01 X34.325 Y14.682
    N557 G01 X34.148 Y14.737
    N558 G01 X33.934 Y14.795
    N559 G01 X33.669 Y14.858
    N560 G01 X33.389 Y14.913
    N561 G01 X33.029 Y14.971
    N562 G01 X32.586 Y15.026
    N563 G01 X31.964 Y15.081
    N564 G01 X31.243 Y15.12
    N565 G01 X30.522 Y15.141
    N566 G01 X29.8 Y15.152
    N567 G01 X29.078 Y15.158
    N568 G01 X28.356 Y15.161
    N569 G01 X26.912 Y15.164
    N570 G01 X21.136 Y15.165
    N571 G01 X16.443
    N572 G01 X16.402 Y15.185
    N573 G01 X16.375 Y15.22
    N574 G01 X16.365 Y15.265
    N575 G01 X16.544 Y15.964
    N576 G01 X16.594 Y16.106
    N577 G01 X16.645 Y16.27
    N578 G01 X16.699 Y16.468
    N579 G01 X16.752 Y16.693
    N580 G01 X16.806 Y16.965
    N581 G01 X16.862 Y17.31
    N582 G01 X16.918 Y17.75
    N583 G01 X16.974 Y18.37
    N584 G01 X17.014 Y19.091
    N585 G01 X17.036 Y19.813
    N586 G01 X17.048 Y20.535
    N587 G01 X17.055 Y21.257
    N588 G01 X17.059 Y21.979
    N589 G01 X17.063 Y23.423
    N590 G01 X17.065 Y26.311
    N591 G01 Y34.614
    N592 G01 X17.062 Y34.704
    N593 G03 X16.462 Y34.683 I-0.3 J-0.01
    N594 G03 X16.884 Y34.419 I0.3 J0.01
    N595 G01 X17.82 Y34.834
    N596 G03 X17.577 Y35.382 I-0.122 J0.274
    N597 G03 X17.406 Y35.177 I0.122 J-0.274
    N598 G01 X17.386 Y35.089
    N599 G01 X17.355 Y34.935
    N600 G01 X17.274 Y34.774
    N601 G01 X17.263 Y34.574
    N602 G01 X17.339 Y34.366
    N603 G01 X17.517 Y34.179
    N604 G01 X17.976 Y34.106
    N605 G01 X18.529 Y34.038
    N606 G01 X19.248 Y33.976
    N607 G01 X19.969 Y33.938
    N608 G01 X20.691 Y33.915
    N609 G01 X21.413 Y33.902
    N610 G01 X22.135 Y33.895
    N611 G01 X22.857 Y33.89
    N612 G01 X23.579 Y33.888
    N613 G01 X25.023 Y33.886
    N614 G01 X32.964 Y33.885
    N615 G01 X34.499
    N616 G01 X34.523 Y33.886
    N617 G03 X34.517 Y34.046 I-0.003 J0.08
    N618 G03 X34.47 Y33.904 I0.003 J-0.08
    N619 G01 X34.987 Y33.485
    N620 G03 X35.087 Y33.61 I0.05 J0.062
    N621 G03 X35.053 Y33.626 I-0.05 J-0.062
    N622 G01 X35.029 Y33.631
    N623 G01 X34.873 Y33.656
    N624 G01 X34.707 Y33.73
    N625 G01 X34.506 Y33.734
    N626 G01 X34.3 Y33.649
    N627 G01 X34.12 Y33.464
    N628 G01 X34.052 Y32.936
    N629 G01 X33.987 Y32.256
    N630 G01 X33.944 Y31.535
    N631 G01 X33.919 Y30.814
    N632 G01 X33.904 Y30.092
    N633 G01 X33.896 Y29.37
    N634 G01 X33.891 Y28.648
    N635 G01 X33.888 Y27.926
    N636 G01 X33.886 Y26.482
    N637 G01 X33.885 Y20.706
    N638 G01 Y15.381
    N639 G01 X33.886 Y15.357
    N640 G03 X34.046 Y15.363 I0.08 J0.003
    N641 G03 X33.921 Y15.426 I-0.08 J-0.003
    N642 G01 X33.261 Y14.973
    N643 G03 X33.351 Y14.841 I0.045 J-0.066
    N644 G03 X33.384 Y14.889 I-0.045 J0.066
    N645 G01 X33.389 Y14.913
    N646 G01 X33.395 Y14.941
    N647 G01 X33.538 Y15.214
    N648 G01 X33.553 Y15.413
    N649 G01 X33.48 Y15.622
    N650 G01 X33.274 Y15.685
    N651 G01 X33.065 Y15.741
    N652 G01 X32.806 Y15.801
    N653 G01 X32.492 Y15.862
    N654 G01 X32.128 Y15.919
    N655 G01 X31.649 Y15.977
    N656 G01 X30.985 Y16.034
    N657 G01 X30.264 Y16.071
    N658 G01 X29.542 Y16.091
    N659 G01 X28.82 Y16.102
    N660 G01 X28.098 Y16.108
    N661 G01 X27.376 Y16.111
    N662 G01 X25.932 Y16.114
    N663 G01 X20.878 Y16.115
    N664 G01 X17.178
    N665 G01 X17.088 Y16.112
    N666 G03 X17.109 Y15.512 I0.01 J-0.3
    N667 G03 X17.386 Y15.897 I-0.01 J0.3
    N668 G01 X17.032 Y17.092
    N669 G03 X16.457 Y16.921 I-0.288 J-0.085
    N670 G03 X16.639 Y16.725 I0.288 J0.085
    N671 G03 X16.665 Y16.717 I0.105 J0.281
    N672 G01 X16.752 Y16.693
    N673 G01 X16.78 Y16.687
    N674 G01 X17.046 Y16.535
    N675 G01 X17.245 Y16.514
    N676 G01 X17.456 Y16.579
    N677 G01 X17.517 Y16.759
    N678 G01 X17.581 Y16.978
    N679 G01 X17.642 Y17.211
    N680 G01 X17.703 Y17.487
    N681 G01 X17.766 Y17.829
    N682 G01 X17.826 Y18.228
    N683 G01 X17.885 Y18.757
    N684 G01 X17.941 Y19.477
    N685 G01 X17.972 Y20.198
    N686 G01 X17.991 Y20.92
    N687 G01 X18.001 Y21.642
    N688 G01 X18.007 Y22.364
    N689 G01 X18.01 Y23.086
    N690 G01 X18.013 Y24.53
    N691 G01 X18.015 Y28.14
    N692 G01 Y33.465
    N693 G01 X18.035 Y33.505
    N694 G01 X18.07 Y33.533
    N695 G01 X18.115 Y33.542
    N696 G01 X18.814 Y33.364
    N697 G01 X18.975 Y33.315
    N698 G01 X19.167 Y33.265
    N699 G01 X19.4 Y33.213
    N700 G01 X19.67 Y33.162
    N701 G01 X20.021 Y33.109
    N702 G01 X20.475 Y33.057
    N703 G01 X21.144 Y33.004
    N704 G01 X21.866 Y32.972
    N705 G01 X22.587 Y32.955
    N706 G01 X23.309 Y32.946
    N707 G01 X24.031 Y32.941
    N708 G01 X24.753 Y32.938
    N709 G01 X26.197 Y32.936
    N710 G01 X33.417 Y32.935
    N711 G01 X33.458 Y32.915
    N712 G01 X33.485 Y32.88
    N713 G01 X33.495 Y32.835
    N714 G01 X33.316 Y32.136
    N715 G01 X33.268 Y31.956
    N716 G01 X33.219 Y31.744
    N717 G01 X33.168 Y31.483
    N718 G01 X33.117 Y31.162
    N719 G01 X33.065 Y30.736
    N720 G01 X33.013 Y30.138
    N721 G01 X32.976 Y29.417
    N722 G01 X32.957 Y28.695
    N723 G01 X32.946 Y27.973
    N724 G01 X32.941 Y27.251
    N725 G01 X32.938 Y26.529
    N726 G01 X32.936 Y25.085
    N727 G01 X32.935 Y18.587
    N728 G01 Y16.331
    N729 G01 X32.936 Y16.307
    N730 G03 X33.096 Y16.313 I0.08 J0.003
    N731 G03 X32.968 Y16.374 I-0.08 J-0.003
    N732 G01 X32.361 Y15.921
    N733 G03 X32.457 Y15.792 I0.048 J-0.064
    N734 G03 X32.487 Y15.839 I-0.048 J0.064
    N735 G01 X32.492 Y15.862
    N736 G01 X32.498 Y15.89
    N737 G01 X32.64 Y16.164
    N738 G01 X32.654 Y16.363
    N739 G01 X32.58 Y16.572
    N740 G01 X32.375 Y16.634
    N741 G01 X32.154 Y16.693
    N742 G01 X31.897 Y16.752
    N743 G01 X31.574 Y16.814
    N744 G01 X31.206 Y16.871
    N745 G01 X30.712 Y16.929
    N746 G01 X30.024 Y16.987
    N747 G01 X29.302 Y17.021
    N748 G01 X28.581 Y17.041
    N749 G01 X27.859 Y17.052
    N750 G01 X27.137 Y17.058
    N751 G01 X26.415 Y17.061
    N752 G01 X24.971 Y17.064
    N753 G01 X20.639 Y17.065
    N754 G01 X18.202
    N755 G01 X18.112 Y17.062
    N756 G03 X18.133 Y16.462 I0.01 J-0.3
    N757 G03 X18.4 Y16.877 I-0.01 J0.3
    N758 G01 X17.968 Y17.915
    N759 G03 X17.414 Y17.685 I-0.277 J-0.115
    N760 G03 X17.616 Y17.51 I0.277 J0.115
    N761 G01 X17.703 Y17.487
    N762 G01 X17.835 Y17.458
    N763 G01 X17.986 Y17.366
    N764 G01 X18.181 Y17.338
    N765 G01 X18.392 Y17.396
    N766 G01 X18.587 Y17.553
    N767 G01 X18.665 Y17.953
    N768 G01 X18.737 Y18.404
    N769 G01 X18.807 Y18.971
    N770 G01 X18.869 Y19.691
    N771 G01 X18.908 Y20.412
    N772 G01 X18.931 Y21.133
    N773 G01 X18.945 Y21.855
    N774 G01 X18.953 Y22.577
    N775 G01 X18.958 Y23.299
    N776 G01 X18.961 Y24.021
    N777 G01 X18.964 Y25.465
    N778 G01 X18.965 Y29.797
    N779 G01 Y32.775
    N780 G01 X18.964 Y32.799
    N781 G03 X18.804 Y32.794 I-0.08 J-0.003
    N782 G03 X18.93 Y32.731 I0.08 J0.003
    N783 G01 X19.529 Y33.151
    N784 G03 X19.437 Y33.282 I-0.046 J0.066
    N785 G03 X19.406 Y33.236 I0.046 J-0.066
    N786 G01 X19.4 Y33.213
    N787 G01 X19.393 Y33.185
    N788 G01 X19.245 Y32.917
    N789 G01 X19.225 Y32.719
    N790 G01 X19.293 Y32.508
    N791 G01 X19.462 Y32.316
    N792 G01 X19.898 Y32.239
    N793 G01 X20.391 Y32.169
    N794 G01 X21.003 Y32.105
    N795 G01 X21.723 Y32.055
    N796 G01 X22.444 Y32.025
    N797 G01 X23.166 Y32.008
    N798 G01 X23.888 Y31.998
    N799 G01 X24.61 Y31.992
    N800 G01 X25.332 Y31.989
    N801 G01 X26.776 Y31.986
    N802 G01 X31.108 Y31.985
    N803 G01 X32.732
    N804 G01 X32.822 Y31.988
    N805 G03 X32.802 Y32.588 I-0.01 J0.3
    N806 G03 X32.528 Y32.192 I0.01 J-0.3
    N807 G01 X32.903 Y31.075
    N808 G03 X33.472 Y31.266 I0.284 J0.096
    N809 G03 X33.282 Y31.455 I-0.284 J-0.096
    N810 G03 X33.255 Y31.462 I-0.094 J-0.285
    N811 G01 X33.168 Y31.483
    N812 G01 X33.14 Y31.488
    N813 G01 X32.866 Y31.63
    N814 G01 X32.667 Y31.644
    N815 G01 X32.459 Y31.57
    N816 G01 X32.399 Y31.374
    N817 G01 X32.344 Y31.163
    N818 G01 X32.285 Y30.901
    N819 G01 X32.227 Y30.594
    N820 G01 X32.17 Y30.223
    N821 G01 X32.114 Y29.741
    N822 G01 X32.058 Y29.055
    N823 G01 X32.025 Y28.334
    N824 G01 X32.007 Y27.612
    N825 G01 X31.997 Y26.891
    N826 G01 X31.991 Y26.169
    N827 G01 X31.988 Y25.447
    N828 G01 X31.986 Y24.003
    N829 G01 X31.985 Y18.949
    N830 G01 Y17.324
    N831 G01 X31.986 Y17.3
    N832 G03 X32.146 Y17.306 I0.08 J0.003
    N833 G03 X32.014 Y17.364 I-0.08 J-0.003
    N834 G01 X31.438 Y16.869
    N835 G03 X31.543 Y16.747 I0.052 J-0.061
    N836 G03 X31.568 Y16.79 I-0.052 J0.061
    N837 G01 X31.574 Y16.814
    N838 G01 X31.599 Y16.947
    N839 G01 X31.687 Y17.101
    N840 G01 X31.709 Y17.297
    N841 G01 X31.645 Y17.506
    N842 G01 X31.456 Y17.566
    N843 G01 X31.244 Y17.626
    N844 G01 X31.012 Y17.682
    N845 G01 X30.719 Y17.742
    N846 G01 X30.38 Y17.799
    N847 G01 X29.935 Y17.858
    N848 G01 X29.353 Y17.915
    N849 G01 X28.632 Y17.959
    N850 G01 X27.911 Y17.984
    N851 G01 X27.189 Y17.998
    N852 G01 X26.467 Y18.005
    N853 G01 X25.745 Y18.01
    N854 G01 X25.023 Y18.012
    N855 G01 X23.579 Y18.014
    N856 G01 X20.691 Y18.015
    N857 G01 X19.337
    N858 G01 X19.247
    N859 G01 X19.157 Y18.012
    N860 G03 X19.178 Y17.412 I0.01 J-0.3
    N861 G03 X19.44 Y17.837 I-0.01 J0.3
    N862 G01 X18.979 Y18.841
    N863 G03 X18.433 Y18.591 I-0.273 J-0.125
    N864 G03 X18.649 Y18.421 I0.273 J0.125
    N865 G01 X18.737 Y18.404
    N866 G01 X18.872 Y18.383
    N867 G01 X19.03 Y18.3
    N868 G01 X19.228 Y18.285
    N869 G01 X19.437 Y18.357
    N870 G01 X19.493 Y18.544
    N871 G01 X19.549 Y18.762
    N872 G01 X19.609 Y19.034
    N873 G01 X19.666 Y19.342
    N874 G01 X19.727 Y19.746
    N875 G01 X19.784 Y20.257
    N876 G01 X19.84 Y20.977
    N877 G01 X19.872 Y21.699
    N878 G01 X19.89 Y22.42
    N879 G01 X19.9 Y23.142
    N880 G01 X19.906 Y23.864
    N881 G01 X19.91 Y24.586
    N882 G01 X19.913 Y26.03
    N883 G01 X19.915 Y29.64
    N884 G01 Y31.671
    N885 G01 X19.912 Y31.761
    N886 G03 X19.91 Y31.788 I-0.3 J-0.01
    N887 G03 X19.314 Y31.712 I-0.298 J-0.038
    N888 G03 X19.728 Y31.473 I0.298 J0.038
    N889 G01 X20.818 Y31.929
    N890 G03 X20.586 Y32.482 I-0.116 J0.277
    N891 G03 X20.407 Y32.258 I0.116 J-0.277
    N892 G01 X20.391 Y32.169
    N893 G01 X20.387 Y32.141
    N894 G01 X20.259 Y31.861
    N895 G01 X20.255 Y31.66
    N896 G01 X20.339 Y31.453
    N897 G01 X20.549 Y31.398
    N898 G01 X20.792 Y31.342
    N899 G01 X21.1 Y31.283
    N900 G01 X21.458 Y31.228
    N901 G01 X21.943 Y31.17
    N902 G01 X22.626 Y31.113
    N903 G01 X23.347 Y31.079
    N904 G01 X24.069 Y31.06
    N905 G01 X24.791 Y31.049
    N906 G01 X25.513 Y31.043
    N907 G01 X26.235 Y31.039
    N908 G01 X27.679 Y31.036
    N909 G01 X30.567 Y31.035
    N910 G01 X31.74
    N911 G01 X31.83 Y31.038
    N912 G03 X31.809 Y31.638 I-0.01 J0.3
    N913 G03 X31.541 Y31.225 I0.01 J-0.3
    N914 G01 X31.97 Y30.169
    N915 G03 X32.526 Y30.395 I0.278 J0.113
    N916 G03 X32.314 Y30.574 I-0.278 J-0.113
    N917 G01 X32.227 Y30.594
    N918 G01 X32.198 Y30.599
    N919 G01 X31.924 Y30.74
    N920 G01 X31.724 Y30.754
    N921 G01 X31.516 Y30.679
    N922 G01 X31.454 Y30.474
    N923 G01 X31.395 Y30.248
    N924 G01 X31.338 Y29.992
    N925 G01 X31.277 Y29.665
    N926 G01 X31.221 Y29.292
    N927 G01 X31.163 Y28.787
    N928 G01 X31.106 Y28.073
    N929 G01 X31.074 Y27.351
    N930 G01 X31.057 Y26.63
    N931 G01 X31.047 Y25.908
    N932 G01 X31.042 Y25.186
    N933 G01 X31.039 Y24.464
    N934 G01 X31.036 Y23.02
    N935 G01 X31.035 Y18.237
    N936 G01 X31.036 Y18.213
    N937 G03 X31.196 Y18.218 I0.08 J0.003
    N938 G03 X31.059 Y18.272 I-0.08 J-0.003
    N939 G01 X30.579 Y17.794
    N940 G03 X30.692 Y17.681 I0.056 J-0.057
    N941 G03 X30.713 Y17.719 I-0.056 J0.057
    N942 G01 X30.719 Y17.742
    N943 G01 X30.75 Y17.896
    N944 G01 X30.832 Y18.056
    N945 G01 X30.844 Y18.255
    N946 G01 X30.769 Y18.465
    N947 G01 X30.593 Y18.652
    N948 G01 X30.128 Y18.728
    N949 G01 X29.588 Y18.797
    N950 G01 X28.869 Y18.864
    N951 G01 X28.148 Y18.905
    N952 G01 X27.427 Y18.929
    N953 G01 X26.705 Y18.944
    N954 G01 X25.983 Y18.953
    N955 G01 X25.261 Y18.958
    N956 G01 X24.539 Y18.961
    N957 G01 X23.095 Y18.964
    N958 G01 X21.651 Y18.966
    N959 G01 X20.929 Y18.963
    N960 G01 X20.749 Y18.965
    N961 G01 X20.162
    N962 G01 X20.072 Y18.961
    N963 G03 X20.094 Y18.362 I0.011 J-0.3
    N964 G03 X20.357 Y18.783 I-0.011 J0.3
    N965 G01 X19.918 Y19.776
    N966 G03 X19.369 Y19.533 I-0.274 J-0.121
    N967 G03 X19.579 Y19.361 I0.274 J0.121
    N968 G01 X19.666 Y19.342
    N969 G01 X19.8 Y19.317
    N970 G01 X19.956 Y19.23
    N971 G01 X20.153 Y19.21
    N972 G01 X20.361 Y19.276
    N973 G01 X20.551 Y19.44
    N974 G01 X20.621 Y19.86
    N975 G01 X20.691 Y20.383
    N976 G01 X20.755 Y21.052
    N977 G01 X20.8 Y21.773
    N978 G01 X20.826 Y22.495
    N979 G01 X20.842 Y23.216
    N980 G01 X20.851 Y23.938
    N981 G01 X20.857 Y24.66
    N982 G01 X20.86 Y25.382
    N983 G01 X20.863 Y26.826
    N984 G01 X20.865 Y29.714
    N985 G01 Y30.752
    N986 G01 X20.862 Y30.842
    N987 G03 X20.859 Y30.87 I-0.3 J-0.011
    N988 G03 X20.264 Y30.793 I-0.298 J-0.038
    N989 G03 X20.708 Y30.569 I0.298 J0.038
    N990 G01 X21.558 Y31.042
    N991 G03 X21.267 Y31.567 I-0.146 J0.262
    N992 G03 X21.12 Y31.371 I0.146 J-0.262
    N993 G01 X21.1 Y31.283
    N994 G01 X21.062 Y31.087
    N995 G01 X21. Y30.912
    N996 G01 X21.013 Y30.707
    N997 G01 X21.118 Y30.502
    N998 G01 X21.33 Y30.328
    N999 G01 X21.96 Y30.25
    N1000 G01 X22.679 Y30.186
    N1001 G01 X23.4 Y30.146
    N1002 G01 X24.122 Y30.122
    N1003 G01 X24.844 Y30.107
    N1004 G01 X25.565 Y30.098
    N1005 G01 X26.287 Y30.092
    N1006 G01 X27.009 Y30.089
    N1007 G01 X28.453 Y30.086
    N1008 G01 X29.175 Y30.084
    N1009 G01 X29.897 Y30.089
    N1010 G01 X30.258 Y30.083
    N1011 G01 X30.71 Y30.086
    N1012 G01 X30.8 Y30.085
    N1013 G01 X30.824 Y30.086
    N1014 G03 X30.819 Y30.246 I-0.003 J0.08
    N1015 G03 X30.758 Y30.117 I0.003 J-0.08
    N1016 G01 X31.22 Y29.532
    N1017 G03 X31.346 Y29.631 I0.063 J0.05
    N1018 G03 X31.3 Y29.66 I-0.063 J-0.05
    N1019 G01 X31.277 Y29.665
    N1020 G01 X31.249 Y29.67
    N1021 G01 X30.974 Y29.811
    N1022 G01 X30.774 Y29.823
    N1023 G01 X30.566 Y29.748
    N1024 G01 X30.505 Y29.544
    N1025 G01 X30.444 Y29.31
    N1026 G01 X30.387 Y29.054
    N1027 G01 X30.327 Y28.726
    N1028 G01 X30.27 Y28.348
    N1029 G01 X30.212 Y27.834
    N1030 G01 X30.155 Y27.114
    N1031 G01 X30.124 Y26.393
    N1032 G01 X30.107 Y25.671
    N1033 G01 X30.097 Y24.949
    N1034 G01 X30.092 Y24.227
    N1035 G01 X30.089 Y23.505
    N1036 G01 X30.086 Y22.061
    N1037 G01 X30.084 Y20.617
    N1038 G01 X30.087 Y19.896
    N1039 G01 X30.085 Y19.535
    N1040 G01 Y19.354
    N1041 G01 X30.065 Y19.313
    N1042 G01 X30.03 Y19.286
    N1043 G01 X29.985 Y19.277
    N1044 G01 X29.286 Y19.455
    N1045 G01 X29.138 Y19.503
    N1046 G01 X28.962 Y19.553
    N1047 G01 X28.75 Y19.605
    N1048 G01 X28.507 Y19.655
    N1049 G01 X28.202 Y19.708
    N1050 G01 X27.812 Y19.761
    N1051 G01 X27.274 Y19.815
    N1052 G01 X26.554 Y19.861
    N1053 G01 X25.832 Y19.886
    N1054 G01 X25.11 Y19.899
    N1055 G01 X24.389 Y19.906
    N1056 G01 X23.667 Y19.91
    N1057 G01 X22.945 Y19.912
    N1058 G01 X22.223 Y19.918
    N1059 G01 X21.862 Y19.913
    N1060 G01 X21.681 Y19.915
    N1061 G01 X21.275 Y19.914
    N1062 G01 X21.234 Y19.934
    N1063 G01 X21.207 Y19.969
    N1064 G01 X21.197 Y20.014
    N1065 G01 X21.373 Y20.714
    N1066 G01 X21.422 Y20.875
    N1067 G01 X21.473 Y21.069
    N1068 G01 X21.525 Y21.296
    N1069 G01 X21.577 Y21.566
    N1070 G01 X21.631 Y21.914
    N1071 G01 X21.684 Y22.36
    N1072 G01 X21.738 Y23.009
    N1073 G01 X21.773 Y23.73
    N1074 G01 X21.792 Y24.452
    N1075 G01 X21.802 Y25.174
    N1076 G01 X21.808 Y25.895
    N1077 G01 X21.811 Y26.617
    N1078 G01 X21.813 Y27.339
    N1079 G01 X21.817 Y28.061
    N1080 G01 X21.808 Y28.783
    N1081 G01 X21.819 Y29.144
    N1082 G01 X21.816 Y29.325
    N1083 G01 X21.815 Y29.641
    N1084 G01 X21.835 Y29.681
    N1085 G01 X21.871 Y29.709
    N1086 G01 X21.915 Y29.718
    N1087 G01 X22.615 Y29.54
    N1088 G01 X22.791 Y29.49
    N1089 G01 X22.993 Y29.441
    N1090 G01 X23.235 Y29.39
    N1091 G01 X23.542 Y29.338
    N1092 G01 X23.925 Y29.286
    N1093 G01 X24.46 Y29.233
    N1094 G01 X25.18 Y29.187
    N1095 G01 X25.902 Y29.163
    N1096 G01 X26.624 Y29.15
    N1097 G01 X27.345 Y29.144
    N1098 G01 X28.067 Y29.139
    N1099 G01 X28.789 Y29.131
    N1100 G01 X29.15 Y29.137
    N1101 G01 X29.331 Y29.136
    N1102 G01 X29.827 Y29.138
    N1103 G03 X29.941 Y29.165 I-0.011 J0.3
    N1104 G01 X30.002 Y29.192 Z4.982
    N1105 G01 X30.06 Y29.219 Z4.96
    N1106 G01 X30.111 Y29.242 Z4.925
    N1107 G01 X30.154 Y29.262 Z4.877
    N1108 G01 X30.187 Y29.277 Z4.82
    N1109 G01 X30.207 Y29.286 Z4.757
    N1110 G01 X30.214 Y29.289 Z4.69
    N1111 G00 Z-3.01
    N1112 G00 X21.093 Y20.27
    N1113 G00 Z4.39
    N1114 G01 Z4.69 F1500
    N1115 G01 X21.086 Y20.272 Z4.757
    N1116 G01 X21.064 Y20.278 Z4.82
    N1117 G01 X21.03 Y20.288 Z4.877
    N1118 G01 X20.984 Y20.3 Z4.925
    N1119 G01 X20.929 Y20.316 Z4.96
    N1120 G01 X20.868 Y20.333 Z4.982
    N1121 G01 X20.804 Y20.351 Z4.99
    N1122 G01 X20.691 Y20.383
    N1123 G01 X21.333 Y20.298
    N1124 G01 X21.621 Y20.157
    N1125 G01 X21.83 Y20.147
    N1126 G01 X22.049 Y20.23
    N1127 G01 X22.252 Y20.426
    N1128 G01 X22.351 Y20.844
    N1129 G01 X22.438 Y21.28
    N1130 G01 X22.522 Y21.792
    N1131 G01 X22.597 Y22.381
    N1132 G01 X22.664 Y23.1
    N1133 G01 X22.705 Y23.821
    N1134 G01 X22.729 Y24.542
    N1135 G01 X22.744 Y25.264
    N1136 G01 X22.753 Y25.986
    N1137 G01 X22.758 Y26.708
    N1138 G01 X22.77 Y27.43
    N1139 G01 X22.752 Y28.152
    N1140 G01 X22.761 Y28.332
    N1141 G01 X22.76 Y28.512
    N1142 G01 X22.759 Y28.693
    N1143 G01 X22.763 Y28.918
    N1144 G03 X22.163 Y28.912 I-0.3 J-0.003
    N1145 G03 X22.488 Y28.616 I0.3 J0.003
    N1146 G01 X30.51 Y29.272
    N1147 G02 X30.559 Y28.674 I0.024 J-0.299
    N1148 G02 X30.438 Y28.688 I-0.024 J0.299
    N1149 G01 X30.327 Y28.726
    N1150 G01 X30.298 Y28.731
    N1151 G01 X30.023 Y28.872
    N1152 G01 X29.824 Y28.884
    N1153 G01 X29.615 Y28.809
    N1154 G01 X29.555 Y28.605
    N1155 G01 X29.493 Y28.368
    N1156 G01 X29.437 Y28.112
    N1157 G01 X29.376 Y27.784
    N1158 G01 X29.319 Y27.401
    N1159 G01 X29.261 Y26.883
    N1160 G01 X29.205 Y26.163
    N1161 G01 X29.174 Y25.442
    N1162 G01 X29.157 Y24.72
    N1163 G01 X29.147 Y23.998
    N1164 G01 X29.142 Y23.276
    N1165 G01 X29.139 Y22.554
    N1166 G01 X29.131 Y21.832
    N1167 G01 X29.147 Y21.11
    N1168 G01 X29.128 Y20.75
    N1169 G01 X29.134 Y20.569
    N1170 G01 X29.137 Y20.028
    N1171 G01 X29.14 Y19.938
    N1172 G03 X29.74 Y19.96 I0.3 J0.011
    N1173 G03 X29.341 Y20.232 I-0.3 J-0.011
    N1174 G01 X28.339 Y19.883
    N1175 G03 X28.536 Y19.316 I0.099 J-0.283
    N1176 G03 X28.726 Y19.518 I-0.099 J0.283
    N1177 G01 X28.75 Y19.605
    N1178 G01 X28.783 Y19.735
    N1179 G01 X28.877 Y19.884
    N1180 G01 X28.908 Y20.079
    N1181 G01 X28.853 Y20.291
    N1182 G01 X28.699 Y20.489
    N1183 G01 X28.35 Y20.56
    N1184 G01 X27.895 Y20.636
    N1185 G01 X27.4 Y20.7
    N1186 G01 X26.729 Y20.763
    N1187 G01 X26.008 Y20.806
    N1188 G01 X25.287 Y20.831
    N1189 G01 X24.567 Y20.889
    N1190 G01 X24.212 Y20.821
    N1191 G01 X23.687 Y20.901
    N1192 G01 X23.512 Y20.855
    N1193 G01 X23.332 Y20.859
    N1194 G01 X23.061 Y20.862
    N1195 G01 X22.926 Y20.863
    N1196 G03 X22.811 Y20.837 I0.009 J-0.3
    N1197 G01 X22.75 Y20.809 Z4.982
    N1198 G01 X22.693 Y20.783 Z4.96
    N1199 G01 X22.641 Y20.76 Z4.925
    N1200 G01 X22.597 Y20.741 Z4.877
    N1201 G01 X22.565 Y20.726 Z4.82
    N1202 G01 X22.545 Y20.717 Z4.757
    N1203 G01 X22.538 Y20.714 Z4.69
    N1204 G00 Z-3.01
    N1205 G00 X23.378 Y29.783
    N1206 G00 Z4.39
    N1207 G01 Z4.69 F1500
    N1208 G01 X23.375 Y29.776 Z4.757
    N1209 G01 X23.368 Y29.755 Z4.82
    N1210 G01 X23.355 Y29.722 Z4.877
    N1211 G01 X23.339 Y29.677 Z4.925
    N1212 G01 X23.32 Y29.624 Z4.96
    N1213 G01 X23.298 Y29.564 Z4.982
    N1214 G01 X23.276 Y29.501 Z4.99
    N1215 G01 X23.235 Y29.39
    N1216 G01 X23.23 Y29.363
    N1217 G01 X23.085 Y29.091
    N1218 G01 X23.068 Y28.892
    N1219 G01 X23.139 Y28.683
    N1220 G01 X23.32 Y28.626
    N1221 G01 X23.532 Y28.568
    N1222 G01 X23.796 Y28.505
    N1223 G01 X24.081 Y28.448
    N1224 G01 X24.44 Y28.39
    N1225 G01 X24.886 Y28.333
    N1226 G01 X25.505 Y28.276
    N1227 G01 X26.226 Y28.235
    N1228 G01 X26.947 Y28.213
    N1229 G01 X27.667 Y28.158
    N1230 G01 X28.022 Y28.226
    N1231 G01 X28.289 Y28.184
    N1232 G01 X28.469 Y28.183
    N1233 G01 X28.83 Y28.181
    N1234 G01 X28.92 Y28.182
    N1235 G03 X29.034 Y28.212 I-0.017 J0.3
    N1236 G01 X29.094 Y28.241 Z4.982
    N1237 G01 X29.151 Y28.268 Z4.96
    N1238 G01 X29.202 Y28.293 Z4.925
    N1239 G01 X29.245 Y28.313 Z4.877
    N1240 G01 X29.277 Y28.329 Z4.82
    N1241 G01 X29.297 Y28.338 Z4.757
    N1242 G01 X29.304 Y28.342 Z4.69
    N1243 G00 Z-3.01
    N1244 G00 X22.044 Y21.42
    N1245 G00 Z4.39
    N1246 G01 Z4.69 F1500
    N1247 G01 X22.052 Y21.417 Z4.757
    N1248 G01 X22.072 Y21.41 Z4.82
    N1249 G01 X22.106 Y21.398 Z4.877
    N1250 G01 X22.151 Y21.382 Z4.925
    N1251 G01 X22.205 Y21.363 Z4.96
    N1252 G01 X22.264 Y21.342 Z4.982
    N1253 G01 X22.327 Y21.32 Z4.99
    N1254 G01 X22.438 Y21.28
    N1255 G01 X22.467 Y21.275
    N1256 G01 X22.739 Y21.131
    N1257 G01 X22.939 Y21.115
    N1258 G01 X23.15 Y21.187
    N1259 G01 X23.341 Y21.361
    N1260 G01 X23.428 Y21.849
    N1261 G01 X23.508 Y22.409
    N1262 G01 X23.579 Y23.079
    N1263 G01 X23.63 Y23.799
    N1264 G01 X23.663 Y24.52
    N1265 G01 X23.683 Y25.242
    N1266 G01 X23.696 Y25.964
    N1267 G01 X23.723 Y26.686
    N1268 G01 X23.679 Y27.406
    N1269 G01 X23.692 Y27.496
    N1270 G01 X23.7 Y27.585
    N1271 G01 X23.708 Y27.766
    N1272 G01 X23.706 Y27.946
    N1273 G03 X23.107 Y27.917 I-0.3 J-0.015
    N1274 G03 X23.44 Y27.634 I0.3 J0.015
    N1275 G01 X29.55 Y28.329
    N1276 G02 X29.618 Y27.732 I0.034 J-0.298
    N1277 G02 X29.488 Y27.746 I-0.034 J0.298
    N1278 G01 X29.376 Y27.784
    N1279 G01 X29.242 Y27.809
    N1280 G01 X29.087 Y27.896
    N1281 G01 X28.891 Y27.916
    N1282 G01 X28.682 Y27.85
    N1283 G01 X28.493 Y27.686
    N1284 G01 X28.423 Y27.272
    N1285 G01 X28.355 Y26.753
    N1286 G01 X28.291 Y26.092
    N1287 G01 X28.247 Y25.371
    N1288 G01 X28.221 Y24.649
    N1289 G01 X28.206 Y23.928
    N1290 G01 X28.197 Y23.206
    N1291 G01 X28.177 Y22.484
    N1292 G01 X28.209 Y21.763
    N1293 G01 X28.201 Y21.673
    N1294 G01 X28.197 Y21.583
    N1295 G01 X28.193 Y21.402
    N1296 G01 X28.194 Y21.267
    N1297 G01 Y21.222
    N1298 G01 X28.174 Y21.181
    N1299 G01 X28.138 Y21.154
    N1300 G01 X28.094 Y21.145
    N1301 G01 X27.395 Y21.327
    N1302 G01 X27.242 Y21.379
    N1303 G01 X27.078 Y21.428
    N1304 G01 X26.882 Y21.479
    N1305 G01 X26.641 Y21.533
    N1306 G01 X25.931 Y21.665
    N1307 G01 X25.611 Y21.786
    N1308 G01 X24.89 Y21.753
    N1309 G01 X24.717 Y21.807
    N1310 G01 X24.533 Y21.823
    N1311 G01 X24.443 Y21.816
    N1312 G01 X24.353 Y21.805
    N1313 G01 X24.174 Y21.779
    N1314 G01 X24.13 Y21.787
    N1315 G01 X24.094 Y21.814
    N1316 G01 X24.074 Y21.854
    N1317 G01 X24.073 Y21.9
    N1318 G01 X24.381 Y22.553
    N1319 G01 X24.448 Y22.996
    N1320 G01 X24.514 Y23.568
    N1321 G01 X24.572 Y24.288
    N1322 G01 X24.608 Y25.009
    N1323 G01 X24.637 Y25.731
    N1324 G01 X24.667 Y26.452
    N1325 G01 X24.686 Y27.174
    N1326 G01 X24.658 Y27.259
    N1327 G01 X24.648 Y27.349
    N1328 G01 X24.649 Y27.439
    N1329 G01 X24.655 Y27.71
    N1330 G01 X24.675 Y27.75
    N1331 G01 X24.711 Y27.778
    N1332 G01 X24.755 Y27.786
    N1333 G01 X25.452 Y27.598
    N1334 G01 X26.152 Y27.42
    N1335 G01 X26.424 Y27.284
    N1336 G01 X27.145 Y27.244
    N1337 G01 X27.45 Y27.222
    N1338 G01 X27.863 Y27.198
    N1339 G01 X27.948 Y27.229
    N1340 G03 X27.722 Y27.785 I-0.113 J0.278
    N1341 G03 X27.535 Y27.518 I0.113 J-0.278
    N1342 G01 X27.301 Y20.705
    N1343 G03 X27.895 Y20.636 I0.3 J-0.01
    N1344 G01 X28.028 Y21.434
    N1345 G01 X28.085 Y21.62
    N1346 G01 X28.061 Y21.834
    N1347 G01 X27.937 Y22.051
    N1348 G01 X27.663 Y22.256
    N1349 G01 X26.959 Y22.415
    N1350 G01 X26.304 Y22.607
    N1351 G01 X26.259 Y22.602
    N1352 G01 X25.54 Y22.664
    N1353 G01 X25.446 Y22.684
    N1354 G01 X25.356 Y22.696
    N1355 G01 X25.176 Y22.709
    N1356 G01 X25.131
    N1357 G01 X25.086 Y22.713
    N1358 G01 X25.048 Y22.737
    N1359 G01 X25.024 Y22.776
    N1360 G01 X25.019 Y22.82
    N1361 G01 X25.268 Y23.498
    N1362 G01 X25.327 Y23.773
    N1363 G01 X25.387 Y24.113
    N1364 G01 X25.487 Y24.828
    N1365 G01 X25.597 Y25.213
    N1366 G01 X25.55 Y25.571
    N1367 G01 X25.649 Y26.16
    N1368 G01 X25.606 Y26.335
    N1369 G01 X25.618 Y26.515
    N1370 G01 X25.629 Y26.876
    N1371 G01 X25.631 Y26.966
    N1372 G03 X24.977 Y27.553 I-0.595 J-0.005
    N1373 G03 X24.453 Y26.847 I0.06 J-0.592
    N1374 G01 X25.482 Y21.569
    N1375 G03 X26.641 Y21.533 I0.584 J0.114
    N1376 G01 X26.955 Y22.942
    N1377 G01 X26.917 Y23.159
    N1378 G01 X26.783 Y23.362
    N1379 G01 X26.554 Y23.512
    N1380 G01 X26.376 Y23.543
    N1381 G01 X26.016 Y23.576
    N1382 G01 X25.926 Y23.584
    N1383 G01 X25.888 Y23.607
    N1384 G01 X25.863 Y23.645
    N1385 G01 X25.858 Y23.69
    N1386 G01 X25.873 Y23.732
    N1387 G01 X26.283 Y24.138
    N1388 G01 X26.431 Y24.505
    N1389 G01 X26.426 Y24.686
    N1390 G01 X26.562 Y25.104
    N1391 G01 X26.527 Y25.463
    N1392 G01 X26.52 Y26.185
    N1393 G01 X26.544 Y26.316
    N1394 G01 X26.563 Y26.495
    N1395 G01 X26.572 Y26.675
    N1396 G01 X26.593 Y26.715
    N1397 G01 X26.63 Y26.741
    N1398 G01 X26.674 Y26.749
    N1399 G01 X26.717 Y26.736
    N1400 G01 X27.12 Y26.366
    N1401 G01 X27.469 Y26.245
    N1402 G01 X27.559 Y26.251
    N1403 G01 X27.65
    N1404 G01 X27.69 Y26.231
    N1405 G01 X27.717 Y26.195
    N1406 G01 X27.726 Y26.151
    N1407 G01 X27.715 Y26.107
    N1408 G01 X27.383 Y25.725
    N1409 G01 X27.27 Y25.366
    N1410 G01 X27.308 Y25.007
    N1411 G01 X27.221 Y24.381
    N1412 G01 X27.27 Y24.207
    N1413 G01 X27.228 Y23.486
    N1414 G01 X27.266 Y23.127
    N1415 G01 X27.255 Y23.038
    N1416 G01 X27.247 Y22.948
    N1417 G01 Y22.933 Z4.989
    N1418 G01 X27.254 Y22.893 Z4.976
    N1419 G01 X27.259 Y22.861 Z4.95
    N1420 G01 X27.263 Y22.839 Z4.914
    N1421 G01 X27.264 Y22.832 Z4.872
    N1422 G00 Z-3.01
    N1423 G00 X9.706 Y6.562
    N1424 G00 Z9.38
    N1425 G01 Z9.68 F1500
    N1426 G01 X9.708 Y6.57 Z9.747
    N1427 G01 X9.713 Y6.591 Z9.81
    N1428 G01 X9.722 Y6.626 Z9.867
    N1429 G01 X9.734 Y6.672 Z9.915
    N1430 G01 X9.748 Y6.727 Z9.95
    N1431 G01 X9.764 Y6.788 Z9.972
    N1432 G01 X9.78 Y6.853 Z9.98
    N1433 G03 X10.015 Y8.486 I-7.419 J1.9
    N1434 G01 Y8.576
    N1435 G01 X9.75 Y9.248
    N1436 G01 X9.608 Y9.956
    N1437 G01 X9.536 Y10.674
    N1438 G01 X9.499 Y11.395
    N1439 G01 X9.482 Y12.117
    N1440 G01 X9.473 Y12.839
    N1441 G01 X9.469 Y13.561
    N1442 G01 X9.467 Y14.283
    N1443 G01 X9.465 Y16.449
    N1444 G01 Y38.831
    N1445 G01 X9.578 Y39.174
    N1446 G01 X9.789 Y39.467
    N1447 G01 X10.328 Y39.947
    N1448 G01 X10.992 Y40.229
    N1449 G01 X11.698 Y40.381
    N1450 G01 X12.416 Y40.459
    N1451 G01 X13.137 Y40.498
    N1452 G01 X13.859 Y40.517
    N1453 G01 X14.581 Y40.526
    N1454 G01 X15.303 Y40.531
    N1455 G01 X16.025 Y40.533
    N1456 G01 X18.191 Y40.535
    N1457 G01 X29.02
    N1458 G01 X38.767
    N1459 G01 X39.117 Y40.446
    N1460 G01 X39.42 Y40.249
    N1461 G01 X39.918 Y39.727
    N1462 G01 X40.212 Y39.067
    N1463 G01 X40.372 Y38.363
    N1464 G01 X40.455 Y37.646
    N1465 G01 X40.496 Y36.925
    N1466 G01 X40.516 Y36.203
    N1467 G01 X40.526 Y35.481
    N1468 G01 X40.531 Y34.76
    N1469 G01 X40.533 Y34.038
    N1470 G01 X40.535 Y31.872
    N1471 G01 Y11.295
    N1472 G01 X40.504 Y11.117
    N1473 G01 X40.373 Y10.78
    N1474 G01 X40.152 Y10.495
    N1475 G01 X39.6 Y10.029
    N1476 G01 X38.931 Y9.758
    N1477 G01 X38.224 Y9.612
    N1478 G01 X37.506 Y9.538
    N1479 G01 X36.785 Y9.5
    N1480 G01 X36.063 Y9.482
    N1481 G01 X35.341 Y9.473
    N1482 G01 X34.619 Y9.469
    N1483 G01 X33.897 Y9.467
    N1484 G01 X31.731 Y9.465
    N1485 G01 X30.287
    N1486 G01 X12.237
    N1487 G01 X11.893 Y9.573
    N1488 G01 X11.592 Y9.772
    N1489 G01 X11.088 Y10.29
    N1490 G01 X10.848 Y10.433
    N1491 G01 X10.562 Y10.47
    N1492 G01 X10.382 Y10.467
    N1493 G01 X10.292 Y10.466
    N1494 G01 X10.251 Y10.486
    N1495 G01 X10.223 Y10.521
    N1496 G01 X10.214 Y10.565
    N1497 G01 X10.301 Y10.916
    N1498 G01 X10.343 Y11.358
    N1499 G01 X10.386 Y12.079
    N1500 G01 X10.403 Y12.801
    N1501 G01 X10.41 Y13.523
    N1502 G01 X10.413 Y14.245
    N1503 G01 X10.415 Y15.689
    N1504 G01 Y37.348
    N1505 G01 X10.508 Y38.064
    N1506 G01 X10.458 Y38.238
    N1507 G01 X10.469 Y38.599
    N1508 G01 X10.467 Y38.734
    N1509 G01 X10.506 Y38.816
    N1510 G01 X10.759 Y39.073
    N1511 G01 X11.072 Y39.253
    N1512 G01 X11.759 Y39.475
    N1513 G01 X12.48 Y39.513
    N1514 G01 X13.201 Y39.546
    N1515 G01 X13.923 Y39.562
    N1516 G01 X14.645 Y39.572
    N1517 G01 X15.367 Y39.578
    N1518 G01 X16.089 Y39.581
    N1519 G01 X17.533 Y39.584
    N1520 G01 X21.864 Y39.585
    N1521 G01 X37.748
    N1522 G01 X38.103 Y39.516
    N1523 G01 X38.462 Y39.551
    N1524 G01 X38.642 Y39.539
    N1525 G01 X38.687 Y39.538
    N1526 G01 X38.731 Y39.526
    N1527 G01 X38.811 Y39.486
    N1528 G01 X38.947 Y39.366
    N1529 G01 X39.072 Y39.237
    N1530 G01 X39.256 Y38.926
    N1531 G01 X39.463 Y38.234
    N1532 G01 X39.507 Y37.514
    N1533 G01 X39.561 Y36.794
    N1534 G01 X39.569 Y36.072
    N1535 G01 X39.575 Y35.35
    N1536 G01 X39.579 Y34.628
    N1537 G01 X39.582 Y33.906
    N1538 G01 X39.584 Y32.462
    N1539 G01 X39.585 Y26.686
    N1540 G01 Y16.578
    N1541 G01 Y12.246
    N1542 G01 X39.516 Y11.892
    N1543 G01 X39.551 Y11.532
    N1544 G01 X39.539 Y11.352
    N1545 G01 X39.531 Y11.308
    N1546 G01 X39.494 Y11.225
    N1547 G01 X39.38 Y11.086
    N1548 G01 X39.103 Y10.854
    N1549 G01 X38.435 Y10.58
    N1550 G01 X37.715 Y10.521
    N1551 G01 X37. Y10.425
    N1552 G01 X36.278 Y10.426
    N1553 G01 X34.112 Y10.418
    N1554 G01 X31.946 Y10.416
    N1555 G01 X13.896 Y10.415
    N1556 G01 X13.174 Y10.424
    N1557 G01 X12.682 Y10.505
    N1558 G01 X12.507 Y10.461
    N1559 G01 X12.327 Y10.464
    N1560 G01 X12.244 Y10.499
    N1561 G01 X11.678 Y10.948
    N1562 G01 X11.442 Y11.207
    N1563 G01 X11.342 Y11.252
    N1564 G01 X11.258 Y11.286
    N1565 G01 X11.173 Y11.315
    N1566 G01 X11.129 Y11.327
    N1567 G01 X11.085 Y11.338
    N1568 G01 X11.051 Y11.367
    N1569 G01 X11.032 Y11.408
    N1570 G01 X11.059 Y12.13
    N1571 G01 X11.105 Y12.328
    N1572 G01 X11.151 Y12.566
    N1573 G01 X11.198 Y12.866
    N1574 G01 X11.246 Y13.257
    N1575 G01 X11.294 Y13.818
    N1576 G01 X11.331 Y14.539
    N1577 G01 X11.349 Y15.261
    N1578 G01 X11.357 Y15.983
    N1579 G01 X11.361 Y16.705
    N1580 G01 X11.363 Y17.427
    N1581 G01 X11.365 Y19.593
    N1582 G01 Y27.535
    N1583 G01 Y37.643
    N1584 G01 X11.474 Y37.987
    N1585 G01 X11.452 Y38.166
    N1586 G01 X11.432 Y38.254
    N1587 G01 X11.424 Y38.344
    N1588 G01 X11.423 Y38.389
    N1589 G01 X11.441 Y38.43
    N1590 G01 X11.476 Y38.459
    N1591 G01 X12.179 Y38.626
    N1592 G01 X12.901 Y38.615
    N1593 G01 X13.622 Y38.616
    N1594 G01 X15.066 Y38.625
    N1595 G01 X15.788 Y38.631
    N1596 G01 X17.954 Y38.635
    N1597 G01 X38.17
    N1598 G01 X38.26 Y38.622
    N1599 G01 X38.304 Y38.617
    N1600 G01 X38.343 Y38.593
    N1601 G01 X38.39 Y38.516
    N1602 G01 X38.589 Y37.822
    N1603 G01 X38.603 Y37.1
    N1604 G01 X38.613 Y36.378
    N1605 G01 X38.631 Y35.656
    N1606 G01 X38.63 Y34.934
    N1607 G01 X38.634 Y32.768
    N1608 G01 X38.635 Y28.436
    N1609 G01 Y26.27
    N1610 G01 Y11.83
    N1611 G01 X38.621 Y11.741
    N1612 G01 X38.617 Y11.696
    N1613 G01 X38.593 Y11.658
    N1614 G01 X38.439 Y11.563
    N1615 G01 X37.735 Y11.404
    N1616 G01 X37.013 Y11.389
    N1617 G01 X36.293 Y11.338
    N1618 G01 X35.571 Y11.355
    N1619 G01 X34.849 Y11.362
    N1620 G01 X34.127 Y11.365
    N1621 G01 X32.683 Y11.366
    N1622 G01 X13.911 Y11.365
    N1623 G01 X13.19 Y11.373
    N1624 G01 X12.699 Y11.477
    N1625 G01 X12.611 Y11.459
    N1626 G01 X12.567 Y11.45
    N1627 G01 X12.523 Y11.46
    N1628 G01 X12.245 Y11.691
    N1629 G01 X12.056 Y11.946
    N1630 G01 X11.978 Y11.991
    N1631 G01 X11.938 Y12.012
    N1632 G01 X11.912 Y12.049
    N1633 G01 X11.904 Y12.093
    N1634 G01 X11.978 Y12.408
    N1635 G01 X12.043 Y12.737
    N1636 G01 X12.112 Y13.166
    N1637 G01 X12.171 Y13.641
    N1638 G01 X12.23 Y14.303
    N1639 G01 X12.268 Y15.024
    N1640 G01 X12.29 Y15.745
    N1641 G01 X12.301 Y16.467
    N1642 G01 X12.308 Y17.189
    N1643 G01 X12.311 Y17.911
    N1644 G01 X12.314 Y19.355
    N1645 G01 X12.315 Y20.799
    N1646 G01 Y37.405
    N1647 G01 X12.343 Y37.583
    N1648 G01 X12.368 Y37.67
    N1649 G01 X12.387 Y37.758
    N1650 G01 X12.393 Y37.803
    N1651 G01 X12.418 Y37.841
    N1652 G01 X12.457 Y37.863
    N1653 G01 X13.178 Y37.91
    N1654 G01 X13.42 Y37.866
    N1655 G01 X13.727 Y37.822
    N1656 G01 X14.13 Y37.779
    N1657 G01 X14.745 Y37.734
    N1658 G01 X15.466 Y37.707
    N1659 G01 X16.188 Y37.694
    N1660 G01 X16.91 Y37.689
    N1661 G01 X17.632 Y37.687
    N1662 G01 X19.798 Y37.685
    N1663 G01 X37.803
    N1664 G01 X37.843 Y37.665
    N1665 G01 X37.871 Y37.63
    N1666 G01 X37.88 Y37.585
    N1667 G01 X37.702 Y36.886
    N1668 G01 X37.691 Y36.164
    N1669 G01 X37.686 Y35.442
    N1670 G01 X37.684 Y34.72
    N1671 G01 Y33.276
    N1672 G01 X37.685 Y29.666
    N1673 G01 Y12.203
    N1674 G01 X37.665 Y12.162
    N1675 G01 X37.63 Y12.134
    N1676 G01 X37.585 Y12.125
    N1677 G01 X36.886 Y12.304
    N1678 G01 X36.164 Y12.305
    N1679 G01 X35.442 Y12.274
    N1680 G01 X34.721 Y12.295
    N1681 G01 X33.999 Y12.306
    N1682 G01 X33.277 Y12.311
    N1683 G01 X32.555 Y12.313
    N1684 G01 X31.111 Y12.315
    N1685 G01 X13.783
    N1686 G01 X13.061 Y12.328
    N1687 G01 X13.019 Y12.344
    N1688 G01 X12.976 Y12.36
    N1689 G01 X12.943 Y12.389
    N1690 G01 X12.911 Y12.422
    N1691 G01 X12.896 Y12.464
    N1692 G01 X12.991 Y13.18
    N1693 G01 X13.064 Y13.668
    N1694 G01 X13.129 Y14.238
    N1695 G01 X13.185 Y14.958
    N1696 G01 X13.219 Y15.679
    N1697 G01 X13.238 Y16.401
    N1698 G01 X13.25 Y17.123
    N1699 G01 X13.257 Y17.845
    N1700 G01 X13.26 Y18.567
    N1701 G01 X13.264 Y20.011
    N1702 G01 Y20.733
    N1703 G01 X13.265 Y31.563
    N1704 G01 Y37.158
    N1705 G01 X13.266 Y37.203
    N1706 G01 X13.286 Y37.244
    N1707 G01 X13.322 Y37.271
    N1708 G01 X13.366 Y37.28
    N1709 G01 X14.064 Y37.093
    N1710 G01 X14.258 Y37.043
    N1711 G01 X14.479 Y36.994
    N1712 G01 X14.755 Y36.944
    N1713 G01 X15.094 Y36.894
    N1714 G01 X15.549 Y36.843
    N1715 G01 X16.207 Y36.793
    N1716 G01 X16.929 Y36.764
    N1717 G01 X17.651 Y36.749
    N1718 G01 X18.373 Y36.742
    N1719 G01 X19.095 Y36.738
    N1720 G01 X20.539 Y36.736
    N1721 G01 X28.48 Y36.735
    N1722 G01 X37.054
    N1723 G01 X37.095 Y36.715
    N1724 G01 X37.122 Y36.68
    N1725 G01 X37.132 Y36.635
    N1726 G01 X36.953 Y35.936
    N1727 G01 X36.907 Y35.656
    N1728 G01 X36.86 Y35.292
    N1729 G01 X36.813 Y34.783
    N1730 G01 X36.771 Y34.062
    N1731 G01 X36.752 Y33.34
    N1732 G01 X36.743 Y32.618
    N1733 G01 X36.739 Y31.896
    N1734 G01 X36.737 Y31.174
    N1735 G01 X36.735 Y29.008
    N1736 G01 Y26.842
    N1737 G01 Y12.944
    N1738 G01 X36.715 Y12.903
    N1739 G01 X36.68 Y12.876
    N1740 G01 X36.635 Y12.866
    N1741 G01 X35.936 Y13.045
    N1742 G01 X35.593 Y13.097
    N1743 G01 X35.136 Y13.149
    N1744 G01 X34.478 Y13.201
    N1745 G01 X33.757 Y13.233
    N1746 G01 X33.035 Y13.249
    N1747 G01 X32.313 Y13.257
    N1748 G01 X31.591 Y13.261
    N1749 G01 X30.869 Y13.263
    N1750 G01 X28.703 Y13.265
    N1751 G01 X13.812
    N1752 G01 X13.631 Y13.268
    N1753 G01 X13.591 Y13.289
    N1754 G01 X13.564 Y13.325
    N1755 G01 X13.556 Y13.369
    N1756 G01 X13.746 Y14.066
    N1757 G01 X13.797 Y14.221
    N1758 G01 X13.849 Y14.406
    N1759 G01 X13.899 Y14.609
    N1760 G01 X13.952 Y14.858
    N1761 G01 X14.005 Y15.168
    N1762 G01 X14.059 Y15.556
    N1763 G01 X14.113 Y16.089
    N1764 G01 X14.16 Y16.809
    N1765 G01 X14.185 Y17.531
    N1766 G01 X14.199 Y18.252
    N1767 G01 X14.206 Y18.974
    N1768 G01 X14.21 Y19.696
    N1769 G01 X14.214 Y21.14
    N1770 G01 X14.215 Y24.75
    N1771 G01 Y26.194
    N1772 G01 Y36.483
    N1773 G03 X14.188 Y36.597 I-0.3 J-0.01
    N1774 G01 X14.16 Y36.657 Z9.972
    N1775 G01 X14.134 Y36.715 Z9.95
    N1776 G01 X14.111 Y36.767 Z9.915
    N1777 G01 X14.091 Y36.81 Z9.867
    N1778 G01 X14.076 Y36.843 Z9.81
    N1779 G01 X14.067 Y36.863 Z9.747
    N1780 G01 X14.064 Y36.87 Z9.68
    N1781 G00 Z-3.01
    N1782 G00 X13.464 Y13.548
    N1783 G00 Z9.38
    N1784 G01 Z9.68 F1500
    N1785 G01 X13.457 Y13.55 Z9.747
    N1786 G01 X13.436 Y13.557 Z9.81
    N1787 G01 X13.401 Y13.567 Z9.867
    N1788 G01 X13.356 Y13.581 Z9.915
    N1789 G01 X13.301 Y13.597 Z9.95
    N1790 G01 X13.241 Y13.615 Z9.972
    N1791 G01 X13.177 Y13.635 Z9.98
    N1792 G01 X13.064 Y13.668
    N1793 G01 X13.813 Y13.556
    N1794 G01 X13.98 Y13.473
    N1795 G01 X14.189 Y13.462
    N1796 G01 X14.41 Y13.543
    N1797 G01 X14.617 Y13.74
    N1798 G01 X14.72 Y14.149
    N1799 G01 X14.809 Y14.568
    N1800 G01 X14.891 Y15.026
    N1801 G01 X14.97 Y15.585
    N1802 G01 X15.04 Y16.239
    N1803 G01 X15.091 Y16.959
    N1804 G01 X15.121 Y17.68
    N1805 G01 X15.14 Y18.402
    N1806 G01 X15.15 Y19.124
    N1807 G01 X15.157 Y19.846
    N1808 G01 X15.16 Y20.568
    N1809 G01 X15.164 Y22.012
    N1810 G01 X15.165 Y25.622
    N1811 G01 Y36.271
    N1812 G01 X15.185 Y36.312
    N1813 G01 X15.22 Y36.34
    N1814 G01 X15.265 Y36.349
    N1815 G01 X15.964 Y36.17
    N1816 G01 X16.127 Y36.124
    N1817 G01 X16.322 Y36.076
    N1818 G01 X16.55 Y36.028
    N1819 G01 X16.831 Y35.979
    N1820 G01 X17.192 Y35.929
    N1821 G01 X17.684 Y35.879
    N1822 G01 X18.404 Y35.832
    N1823 G01 X19.126 Y35.808
    N1824 G01 X19.847 Y35.797
    N1825 G01 X20.569 Y35.791
    N1826 G01 X21.291 Y35.788
    N1827 G01 X22.735 Y35.786
    N1828 G01 X34.287 Y35.785
    N1829 G01 X36.363
    N1830 G01 X36.453 Y35.788
    N1831 G03 X36.481 Y35.79 I-0.01 J0.3
    N1832 G03 X36.404 Y36.386 I-0.038 J0.298
    N1833 G03 X36.165 Y35.973 I0.038 J-0.298
    N1834 G01 X36.623 Y34.866
    N1835 G03 X37.177 Y35.096 I0.277 J0.115
    N1836 G03 X36.949 Y35.277 I-0.277 J-0.115
    N1837 G01 X36.86 Y35.292
    N1838 G01 X36.831 Y35.295
    N1839 G01 X36.55 Y35.42
    N1840 G01 X36.349 Y35.422
    N1841 G01 X36.144 Y35.335
    N1842 G01 X36.094 Y35.135
    N1843 G01 X36.042 Y34.89
    N1844 G01 X35.988 Y34.587
    N1845 G01 X35.937 Y34.218
    N1846 G01 X35.885 Y33.715
    N1847 G01 X35.836 Y32.995
    N1848 G01 X35.811 Y32.273
    N1849 G01 X35.798 Y31.551
    N1850 G01 X35.792 Y30.829
    N1851 G01 X35.788 Y30.107
    N1852 G01 X35.786 Y28.663
    N1853 G01 X35.785 Y21.443
    N1854 G01 Y13.682
    N1855 G01 X35.765 Y13.641
    N1856 G01 X35.73 Y13.614
    N1857 G01 X35.685 Y13.605
    N1858 G01 X34.986 Y13.783
    N1859 G01 X34.842 Y13.829
    N1860 G01 X34.674 Y13.876
    N1861 G01 X34.472 Y13.925
    N1862 G01 X34.231 Y13.975
    N1863 G01 X33.939 Y14.024
    N1864 G01 X33.558 Y14.075
    N1865 G01 X33.038 Y14.125
    N1866 G01 X32.317 Y14.17
    N1867 G01 X31.596 Y14.192
    N1868 G01 X30.874 Y14.203
    N1869 G01 X30.152 Y14.209
    N1870 G01 X29.43 Y14.212
    N1871 G01 X27.986 Y14.214
    N1872 G01 X17.156 Y14.215
    N1873 G01 X15.306
    N1874 G01 X15.282 Y14.214
    N1875 G03 X15.287 Y14.054 I0.003 J-0.08
    N1876 G03 X15.343 Y14.189 I-0.003 J0.08
    N1877 G01 X14.864 Y14.705
    N1878 G03 X14.747 Y14.597 I-0.059 J-0.054
    N1879 G03 X14.786 Y14.573 I0.059 J0.054
    N1880 G01 X14.809 Y14.568
    N1881 G01 X14.964 Y14.534
    N1882 G01 X15.125 Y14.451
    N1883 G01 X15.327 Y14.437
    N1884 G01 X15.537 Y14.512
    N1885 G01 X15.726 Y14.687
    N1886 G01 X15.812 Y15.154
    N1887 G01 X15.895 Y15.722
    N1888 G01 X15.97 Y16.398
    N1889 G01 X16.025 Y17.118
    N1890 G01 X16.059 Y17.839
    N1891 G01 X16.081 Y18.561
    N1892 G01 X16.095 Y19.283
    N1893 G01 X16.103 Y20.005
    N1894 G01 X16.108 Y20.727
    N1895 G01 X16.111 Y21.449
    N1896 G01 X16.114 Y22.893
    N1897 G01 X16.115 Y27.225
    N1898 G01 Y35.528
    N1899 G01 X16.112 Y35.618
    N1900 G03 X15.512 Y35.597 I-0.3 J-0.01
    N1901 G03 X15.927 Y35.33 I0.3 J0.01
    N1902 G01 X16.978 Y35.766
    N1903 G03 X16.748 Y36.32 I-0.115 J0.277
    N1904 G03 X16.579 Y36.142 I0.115 J-0.277
    N1905 G03 X16.571 Y36.115 I0.283 J-0.099
    N1906 G01 X16.55 Y36.028
    N1907 G01 X16.544 Y36.
    N1908 G01 X16.399 Y35.729
    N1909 G01 X16.382 Y35.531
    N1910 G01 X16.453 Y35.321
    N1911 G01 X16.631 Y35.265
    N1912 G01 X16.848 Y35.206
    N1913 G01 X17.11 Y35.144
    N1914 G01 X17.386 Y35.089
    N1915 G01 X17.745 Y35.031
    N1916 G01 X18.177 Y34.976
    N1917 G01 X18.784 Y34.921
    N1918 G01 X19.505 Y34.881
    N1919 G01 X20.227 Y34.859
    N1920 G01 X20.949 Y34.848
    N1921 G01 X21.671 Y34.842
    N1922 G01 X22.393 Y34.839
    N1923 G01 X23.837 Y34.836
    N1924 G01 X29.613 Y34.835
    N1925 G01 X35.479
    N1926 G01 X35.503 Y34.836
    N1927 G03 X35.497 Y34.996 I-0.003 J0.08
    N1928 G03 X35.449 Y34.854 I0.003 J-0.08
    N1929 G01 X35.944 Y34.442
    N1930 G03 X36.047 Y34.565 I0.051 J0.062
    N1931 G03 X36.012 Y34.582 I-0.051 J-0.062
    N1932 G01 X35.988 Y34.587
    N1933 G01 X35.791 Y34.622
    N1934 G01 X35.616 Y34.682
    N1935 G01 X35.411 Y34.666
    N1936 G01 X35.207 Y34.558
    N1937 G01 X35.145 Y34.288
    N1938 G01 X35.089 Y34.004
    N1939 G01 X35.029 Y33.631
    N1940 G01 X34.974 Y33.185
    N1941 G01 X34.918 Y32.552
    N1942 G01 X34.88 Y31.831
    N1943 G01 X34.859 Y31.109
    N1944 G01 X34.848 Y30.387
    N1945 G01 X34.842 Y29.665
    N1946 G01 X34.839 Y28.943
    N1947 G01 X34.836 Y27.499
    N1948 G01 X34.835 Y21.723
    N1949 G01 Y14.413
    N1950 G01 X34.838 Y14.323
    N1951 G03 X34.84 Y14.295 I0.3 J0.01
    N1952 G03 X35.436 Y14.372 I0.298 J0.038
    N1953 G03 X35.05 Y14.62 I-0.298 J-0.038
    N1954 G01 X33.83 Y14.245
    N1955 G03 X34.007 Y13.671 I0.088 J-0.287
    N1956 G03 X34.202 Y13.86 I-0.088 J0.287
    N1957 G03 X34.21 Y13.887 I-0.284 J0.097
    N1958 G01 X34.231 Y13.975
    N1959 G01 X34.237 Y14.003
    N1960 G01 X34.381 Y14.274
    N1961 G01 X34.397 Y14.473
    N1962 G01 X34.325 Y14.682
    N1963 G01 X34.148 Y14.737
    N1964 G01 X33.934 Y14.795
    N1965 G01 X33.669 Y14.858
    N1966 G01 X33.389 Y14.913
    N1967 G01 X33.029 Y14.971
    N1968 G01 X32.586 Y15.026
    N1969 G01 X31.964 Y15.081
    N1970 G01 X31.243 Y15.12
    N1971 G01 X30.522 Y15.141
    N1972 G01 X29.8 Y15.152
    N1973 G01 X29.078 Y15.158
    N1974 G01 X28.356 Y15.161
    N1975 G01 X26.912 Y15.164
    N1976 G01 X21.136 Y15.165
    N1977 G01 X16.443
    N1978 G01 X16.402 Y15.185
    N1979 G01 X16.375 Y15.22
    N1980 G01 X16.365 Y15.265
    N1981 G01 X16.544 Y15.964
    N1982 G01 X16.594 Y16.106
    N1983 G01 X16.645 Y16.27
    N1984 G01 X16.699 Y16.468
    N1985 G01 X16.752 Y16.693
    N1986 G01 X16.806 Y16.965
    N1987 G01 X16.862 Y17.31
    N1988 G01 X16.918 Y17.75
    N1989 G01 X16.974 Y18.37
    N1990 G01 X17.014 Y19.091
    N1991 G01 X17.036 Y19.813
    N1992 G01 X17.048 Y20.535
    N1993 G01 X17.055 Y21.257
    N1994 G01 X17.059 Y21.979
    N1995 G01 X17.063 Y23.423
    N1996 G01 X17.065 Y26.311
    N1997 G01 Y34.614
    N1998 G01 X17.062 Y34.704
    N1999 G03 X16.462 Y34.683 I-0.3 J-0.01
    N2000 G03 X16.884 Y34.419 I0.3 J0.01
    N2001 G01 X17.82 Y34.834
    N2002 G03 X17.577 Y35.382 I-0.122 J0.274
    N2003 G03 X17.406 Y35.177 I0.122 J-0.274
    N2004 G01 X17.386 Y35.089
    N2005 G01 X17.355 Y34.935
    N2006 G01 X17.274 Y34.774
    N2007 G01 X17.263 Y34.574
    N2008 G01 X17.339 Y34.366
    N2009 G01 X17.517 Y34.179
    N2010 G01 X17.976 Y34.106
    N2011 G01 X18.529 Y34.038
    N2012 G01 X19.248 Y33.976
    N2013 G01 X19.969 Y33.938
    N2014 G01 X20.691 Y33.915
    N2015 G01 X21.413 Y33.902
    N2016 G01 X22.135 Y33.895
    N2017 G01 X22.857 Y33.89
    N2018 G01 X23.579 Y33.888
    N2019 G01 X25.023 Y33.886
    N2020 G01 X32.964 Y33.885
    N2021 G01 X34.499
    N2022 G01 X34.523 Y33.886
    N2023 G03 X34.517 Y34.046 I-0.003 J0.08
    N2024 G03 X34.47 Y33.904 I0.003 J-0.08
    N2025 G01 X34.987 Y33.485
    N2026 G03 X35.087 Y33.61 I0.05 J0.062
    N2027 G03 X35.053 Y33.626 I-0.05 J-0.062
    N2028 G01 X35.029 Y33.631
    N2029 G01 X34.873 Y33.656
    N2030 G01 X34.707 Y33.73
    N2031 G01 X34.506 Y33.734
    N2032 G01 X34.3 Y33.649
    N2033 G01 X34.12 Y33.464
    N2034 G01 X34.052 Y32.936
    N2035 G01 X33.987 Y32.256
    N2036 G01 X33.944 Y31.535
    N2037 G01 X33.919 Y30.814
    N2038 G01 X33.904 Y30.092
    N2039 G01 X33.896 Y29.37
    N2040 G01 X33.891 Y28.648
    N2041 G01 X33.888 Y27.926
    N2042 G01 X33.886 Y26.482
    N2043 G01 X33.885 Y20.706
    N2044 G01 Y15.381
    N2045 G01 X33.886 Y15.357
    N2046 G03 X34.046 Y15.363 I0.08 J0.003
    N2047 G03 X33.921 Y15.426 I-0.08 J-0.003
    N2048 G01 X33.261 Y14.973
    N2049 G03 X33.351 Y14.841 I0.045 J-0.066
    N2050 G03 X33.384 Y14.889 I-0.045 J0.066
    N2051 G01 X33.389 Y14.913
    N2052 G01 X33.395 Y14.941
    N2053 G01 X33.538 Y15.214
    N2054 G01 X33.553 Y15.413
    N2055 G01 X33.48 Y15.622
    N2056 G01 X33.274 Y15.685
    N2057 G01 X33.065 Y15.741
    N2058 G01 X32.806 Y15.801
    N2059 G01 X32.492 Y15.862
    N2060 G01 X32.128 Y15.919
    N2061 G01 X31.649 Y15.977
    N2062 G01 X30.985 Y16.034
    N2063 G01 X30.264 Y16.071
    N2064 G01 X29.542 Y16.091
    N2065 G01 X28.82 Y16.102
    N2066 G01 X28.098 Y16.108
    N2067 G01 X27.376 Y16.111
    N2068 G01 X25.932 Y16.114
    N2069 G01 X20.878 Y16.115
    N2070 G01 X17.178
    N2071 G01 X17.088 Y16.112
    N2072 G03 X17.109 Y15.512 I0.01 J-0.3
    N2073 G03 X17.386 Y15.897 I-0.01 J0.3
    N2074 G01 X17.032 Y17.092
    N2075 G03 X16.457 Y16.921 I-0.288 J-0.085
    N2076 G03 X16.639 Y16.725 I0.288 J0.085
    N2077 G03 X16.665 Y16.717 I0.105 J0.281
    N2078 G01 X16.752 Y16.693
    N2079 G01 X16.78 Y16.687
    N2080 G01 X17.046 Y16.535
    N2081 G01 X17.245 Y16.514
    N2082 G01 X17.456 Y16.579
    N2083 G01 X17.517 Y16.759
    N2084 G01 X17.581 Y16.978
    N2085 G01 X17.642 Y17.211
    N2086 G01 X17.703 Y17.487
    N2087 G01 X17.766 Y17.829
    N2088 G01 X17.826 Y18.228
    N2089 G01 X17.885 Y18.757
    N2090 G01 X17.941 Y19.477
    N2091 G01 X17.972 Y20.198
    N2092 G01 X17.991 Y20.92
    N2093 G01 X18.001 Y21.642
    N2094 G01 X18.007 Y22.364
    N2095 G01 X18.01 Y23.086
    N2096 G01 X18.013 Y24.53
    N2097 G01 X18.015 Y28.14
    N2098 G01 Y33.465
    N2099 G01 X18.035 Y33.505
    N2100 G01 X18.07 Y33.533
    N2101 G01 X18.115 Y33.542
    N2102 G01 X18.814 Y33.364
    N2103 G01 X18.975 Y33.315
    N2104 G01 X19.167 Y33.265
    N2105 G01 X19.4 Y33.213
    N2106 G01 X19.67 Y33.162
    N2107 G01 X20.021 Y33.109
    N2108 G01 X20.475 Y33.057
    N2109 G01 X21.144 Y33.004
    N2110 G01 X21.866 Y32.972
    N2111 G01 X22.587 Y32.955
    N2112 G01 X23.309 Y32.946
    N2113 G01 X24.031 Y32.941
    N2114 G01 X24.753 Y32.938
    N2115 G01 X26.197 Y32.936
    N2116 G01 X33.417 Y32.935
    N2117 G01 X33.458 Y32.915
    N2118 G01 X33.485 Y32.88
    N2119 G01 X33.495 Y32.835
    N2120 G01 X33.316 Y32.136
    N2121 G01 X33.268 Y31.956
    N2122 G01 X33.219 Y31.744
    N2123 G01 X33.168 Y31.483
    N2124 G01 X33.117 Y31.162
    N2125 G01 X33.065 Y30.736
    N2126 G01 X33.013 Y30.138
    N2127 G01 X32.976 Y29.417
    N2128 G01 X32.957 Y28.695
    N2129 G01 X32.946 Y27.973
    N2130 G01 X32.941 Y27.251
    N2131 G01 X32.938 Y26.529
    N2132 G01 X32.936 Y25.085
    N2133 G01 X32.935 Y18.587
    N2134 G01 Y16.331
    N2135 G01 X32.936 Y16.307
    N2136 G03 X33.096 Y16.313 I0.08 J0.003
    N2137 G03 X32.968 Y16.374 I-0.08 J-0.003
    N2138 G01 X32.361 Y15.921
    N2139 G03 X32.457 Y15.792 I0.048 J-0.064
    N2140 G03 X32.487 Y15.839 I-0.048 J0.064
    N2141 G01 X32.492 Y15.862
    N2142 G01 X32.498 Y15.89
    N2143 G01 X32.64 Y16.164
    N2144 G01 X32.654 Y16.363
    N2145 G01 X32.58 Y16.572
    N2146 G01 X32.375 Y16.634
    N2147 G01 X32.154 Y16.693
    N2148 G01 X31.897 Y16.752
    N2149 G01 X31.574 Y16.814
    N2150 G01 X31.206 Y16.871
    N2151 G01 X30.712 Y16.929
    N2152 G01 X30.024 Y16.987
    N2153 G01 X29.302 Y17.021
    N2154 G01 X28.581 Y17.041
    N2155 G01 X27.859 Y17.052
    N2156 G01 X27.137 Y17.058
    N2157 G01 X26.415 Y17.061
    N2158 G01 X24.971 Y17.064
    N2159 G01 X20.639 Y17.065
    N2160 G01 X18.202
    N2161 G01 X18.112 Y17.062
    N2162 G03 X18.133 Y16.462 I0.01 J-0.3
    N2163 G03 X18.4 Y16.877 I-0.01 J0.3
    N2164 G01 X17.968 Y17.915
    N2165 G03 X17.414 Y17.685 I-0.277 J-0.115
    N2166 G03 X17.616 Y17.51 I0.277 J0.115
    N2167 G01 X17.703 Y17.487
    N2168 G01 X17.835 Y17.458
    N2169 G01 X17.986 Y17.366
    N2170 G01 X18.181 Y17.338
    N2171 G01 X18.392 Y17.396
    N2172 G01 X18.587 Y17.553
    N2173 G01 X18.665 Y17.953
    N2174 G01 X18.737 Y18.404
    N2175 G01 X18.807 Y18.971
    N2176 G01 X18.869 Y19.691
    N2177 G01 X18.908 Y20.412
    N2178 G01 X18.931 Y21.133
    N2179 G01 X18.945 Y21.855
    N2180 G01 X18.953 Y22.577
    N2181 G01 X18.958 Y23.299
    N2182 G01 X18.961 Y24.021
    N2183 G01 X18.964 Y25.465
    N2184 G01 X18.965 Y29.797
    N2185 G01 Y32.775
    N2186 G01 X18.964 Y32.799
    N2187 G03 X18.804 Y32.794 I-0.08 J-0.003
    N2188 G03 X18.93 Y32.731 I0.08 J0.003
    N2189 G01 X19.529 Y33.151
    N2190 G03 X19.437 Y33.282 I-0.046 J0.066
    N2191 G03 X19.406 Y33.236 I0.046 J-0.066
    N2192 G01 X19.4 Y33.213
    N2193 G01 X19.393 Y33.185
    N2194 G01 X19.245 Y32.917
    N2195 G01 X19.225 Y32.719
    N2196 G01 X19.293 Y32.508
    N2197 G01 X19.462 Y32.316
    N2198 G01 X19.898 Y32.239
    N2199 G01 X20.391 Y32.169
    N2200 G01 X21.003 Y32.105
    N2201 G01 X21.723 Y32.055
    N2202 G01 X22.444 Y32.025
    N2203 G01 X23.166 Y32.008
    N2204 G01 X23.888 Y31.998
    N2205 G01 X24.61 Y31.992
    N2206 G01 X25.332 Y31.989
    N2207 G01 X26.776 Y31.986
    N2208 G01 X31.108 Y31.985
    N2209 G01 X32.732
    N2210 G01 X32.822 Y31.988
    N2211 G03 X32.802 Y32.588 I-0.01 J0.3
    N2212 G03 X32.528 Y32.192 I0.01 J-0.3
    N2213 G01 X32.903 Y31.075
    N2214 G03 X33.472 Y31.266 I0.284 J0.096
    N2215 G03 X33.282 Y31.455 I-0.284 J-0.096
    N2216 G03 X33.255 Y31.462 I-0.094 J-0.285
    N2217 G01 X33.168 Y31.483
    N2218 G01 X33.14 Y31.488
    N2219 G01 X32.866 Y31.63
    N2220 G01 X32.667 Y31.644
    N2221 G01 X32.459 Y31.57
    N2222 G01 X32.399 Y31.374
    N2223 G01 X32.344 Y31.163
    N2224 G01 X32.285 Y30.901
    N2225 G01 X32.227 Y30.594
    N2226 G01 X32.17 Y30.223
    N2227 G01 X32.114 Y29.741
    N2228 G01 X32.058 Y29.055
    N2229 G01 X32.025 Y28.334
    N2230 G01 X32.007 Y27.612
    N2231 G01 X31.997 Y26.891
    N2232 G01 X31.991 Y26.169
    N2233 G01 X31.988 Y25.447
    N2234 G01 X31.986 Y24.003
    N2235 G01 X31.985 Y18.949
    N2236 G01 Y17.324
    N2237 G01 X31.986 Y17.3
    N2238 G03 X32.146 Y17.306 I0.08 J0.003
    N2239 G03 X32.014 Y17.364 I-0.08 J-0.003
    N2240 G01 X31.438 Y16.869
    N2241 G03 X31.543 Y16.747 I0.052 J-0.061
    N2242 G03 X31.568 Y16.79 I-0.052 J0.061
    N2243 G01 X31.574 Y16.814
    N2244 G01 X31.599 Y16.947
    N2245 G01 X31.687 Y17.101
    N2246 G01 X31.709 Y17.297
    N2247 G01 X31.645 Y17.506
    N2248 G01 X31.456 Y17.566
    N2249 G01 X31.244 Y17.626
    N2250 G01 X31.012 Y17.682
    N2251 G01 X30.719 Y17.742
    N2252 G01 X30.38 Y17.799
    N2253 G01 X29.935 Y17.858
    N2254 G01 X29.353 Y17.915
    N2255 G01 X28.632 Y17.959
    N2256 G01 X27.911 Y17.984
    N2257 G01 X27.189 Y17.998
    N2258 G01 X26.467 Y18.005
    N2259 G01 X25.745 Y18.01
    N2260 G01 X25.023 Y18.012
    N2261 G01 X23.579 Y18.014
    N2262 G01 X20.691 Y18.015
    N2263 G01 X19.337
    N2264 G01 X19.247
    N2265 G01 X19.157 Y18.012
    N2266 G03 X19.178 Y17.412 I0.01 J-0.3
    N2267 G03 X19.44 Y17.837 I-0.01 J0.3
    N2268 G01 X18.979 Y18.841
    N2269 G03 X18.433 Y18.591 I-0.273 J-0.125
    N2270 G03 X18.649 Y18.421 I0.273 J0.125
    N2271 G01 X18.737 Y18.404
    N2272 G01 X18.872 Y18.383
    N2273 G01 X19.03 Y18.3
    N2274 G01 X19.228 Y18.285
    N2275 G01 X19.437 Y18.357
    N2276 G01 X19.493 Y18.544
    N2277 G01 X19.549 Y18.762
    N2278 G01 X19.609 Y19.034
    N2279 G01 X19.666 Y19.342
    N2280 G01 X19.727 Y19.746
    N2281 G01 X19.784 Y20.257
    N2282 G01 X19.84 Y20.977
    N2283 G01 X19.872 Y21.699
    N2284 G01 X19.89 Y22.42
    N2285 G01 X19.9 Y23.142
    N2286 G01 X19.906 Y23.864
    N2287 G01 X19.91 Y24.586
    N2288 G01 X19.913 Y26.03
    N2289 G01 X19.915 Y29.64
    N2290 G01 Y31.671
    N2291 G01 X19.912 Y31.761
    N2292 G03 X19.91 Y31.788 I-0.3 J-0.01
    N2293 G03 X19.314 Y31.712 I-0.298 J-0.038
    N2294 G03 X19.728 Y31.473 I0.298 J0.038
    N2295 G01 X20.818 Y31.929
    N2296 G03 X20.586 Y32.482 I-0.116 J0.277
    N2297 G03 X20.407 Y32.258 I0.116 J-0.277
    N2298 G01 X20.391 Y32.169
    N2299 G01 X20.387 Y32.141
    N2300 G01 X20.259 Y31.861
    N2301 G01 X20.255 Y31.66
    N2302 G01 X20.339 Y31.453
    N2303 G01 X20.549 Y31.398
    N2304 G01 X20.792 Y31.342
    N2305 G01 X21.1 Y31.283
    N2306 G01 X21.458 Y31.228
    N2307 G01 X21.943 Y31.17
    N2308 G01 X22.626 Y31.113
    N2309 G01 X23.347 Y31.079
    N2310 G01 X24.069 Y31.06
    N2311 G01 X24.791 Y31.049
    N2312 G01 X25.513 Y31.043
    N2313 G01 X26.235 Y31.039
    N2314 G01 X27.679 Y31.036
    N2315 G01 X30.567 Y31.035
    N2316 G01 X31.74
    N2317 G01 X31.83 Y31.038
    N2318 G03 X31.809 Y31.638 I-0.01 J0.3
    N2319 G03 X31.541 Y31.225 I0.01 J-0.3
    N2320 G01 X31.97 Y30.169
    N2321 G03 X32.526 Y30.395 I0.278 J0.113
    N2322 G03 X32.314 Y30.574 I-0.278 J-0.113
    N2323 G01 X32.227 Y30.594
    N2324 G01 X32.198 Y30.599
    N2325 G01 X31.924 Y30.74
    N2326 G01 X31.724 Y30.754
    N2327 G01 X31.516 Y30.679
    N2328 G01 X31.454 Y30.474
    N2329 G01 X31.395 Y30.248
    N2330 G01 X31.338 Y29.992
    N2331 G01 X31.277 Y29.665
    N2332 G01 X31.221 Y29.292
    N2333 G01 X31.163 Y28.787
    N2334 G01 X31.106 Y28.073
    N2335 G01 X31.074 Y27.351
    N2336 G01 X31.057 Y26.63
    N2337 G01 X31.047 Y25.908
    N2338 G01 X31.042 Y25.186
    N2339 G01 X31.039 Y24.464
    N2340 G01 X31.036 Y23.02
    N2341 G01 X31.035 Y18.237
    N2342 G01 X31.036 Y18.213
    N2343 G03 X31.196 Y18.218 I0.08 J0.003
    N2344 G03 X31.059 Y18.272 I-0.08 J-0.003
    N2345 G01 X30.579 Y17.794
    N2346 G03 X30.692 Y17.681 I0.056 J-0.057
    N2347 G03 X30.713 Y17.719 I-0.056 J0.057
    N2348 G01 X30.719 Y17.742
    N2349 G01 X30.75 Y17.896
    N2350 G01 X30.832 Y18.056
    N2351 G01 X30.844 Y18.255
    N2352 G01 X30.769 Y18.465
    N2353 G01 X30.593 Y18.652
    N2354 G01 X30.128 Y18.728
    N2355 G01 X29.588 Y18.797
    N2356 G01 X28.869 Y18.864
    N2357 G01 X28.148 Y18.905
    N2358 G01 X27.427 Y18.929
    N2359 G01 X26.705 Y18.944
    N2360 G01 X25.983 Y18.953
    N2361 G01 X25.261 Y18.958
    N2362 G01 X24.539 Y18.961
    N2363 G01 X23.095 Y18.964
    N2364 G01 X21.651 Y18.966
    N2365 G01 X20.929 Y18.963
    N2366 G01 X20.749 Y18.965
    N2367 G01 X20.162
    N2368 G01 X20.072 Y18.961
    N2369 G03 X20.094 Y18.362 I0.011 J-0.3
    N2370 G03 X20.357 Y18.783 I-0.011 J0.3
    N2371 G01 X19.918 Y19.776
    N2372 G03 X19.369 Y19.533 I-0.274 J-0.121
    N2373 G03 X19.579 Y19.361 I0.274 J0.121
    N2374 G01 X19.666 Y19.342
    N2375 G01 X19.8 Y19.317
    N2376 G01 X19.956 Y19.23
    N2377 G01 X20.153 Y19.21
    N2378 G01 X20.361 Y19.276
    N2379 G01 X20.551 Y19.44
    N2380 G01 X20.621 Y19.86
    N2381 G01 X20.691 Y20.383
    N2382 G01 X20.755 Y21.052
    N2383 G01 X20.8 Y21.773
    N2384 G01 X20.826 Y22.495
    N2385 G01 X20.842 Y23.216
    N2386 G01 X20.851 Y23.938
    N2387 G01 X20.857 Y24.66
    N2388 G01 X20.86 Y25.382
    N2389 G01 X20.863 Y26.826
    N2390 G01 X20.865 Y29.714
    N2391 G01 Y30.752
    N2392 G01 X20.862 Y30.842
    N2393 G03 X20.859 Y30.87 I-0.3 J-0.011
    N2394 G03 X20.264 Y30.793 I-0.298 J-0.038
    N2395 G03 X20.708 Y30.569 I0.298 J0.038
    N2396 G01 X21.558 Y31.042
    N2397 G03 X21.267 Y31.567 I-0.146 J0.262
    N2398 G03 X21.12 Y31.371 I0.146 J-0.262
    N2399 G01 X21.1 Y31.283
    N2400 G01 X21.062 Y31.087
    N2401 G01 X21. Y30.912
    N2402 G01 X21.013 Y30.707
    N2403 G01 X21.118 Y30.502
    N2404 G01 X21.33 Y30.328
    N2405 G01 X21.96 Y30.25
    N2406 G01 X22.679 Y30.186
    N2407 G01 X23.4 Y30.146
    N2408 G01 X24.122 Y30.122
    N2409 G01 X24.844 Y30.107
    N2410 G01 X25.565 Y30.098
    N2411 G01 X26.287 Y30.092
    N2412 G01 X27.009 Y30.089
    N2413 G01 X28.453 Y30.086
    N2414 G01 X29.175 Y30.084
    N2415 G01 X29.897 Y30.089
    N2416 G01 X30.258 Y30.083
    N2417 G01 X30.71 Y30.086
    N2418 G01 X30.8 Y30.085
    N2419 G01 X30.824 Y30.086
    N2420 G03 X30.819 Y30.246 I-0.003 J0.08
    N2421 G03 X30.758 Y30.117 I0.003 J-0.08
    N2422 G01 X31.22 Y29.532
    N2423 G03 X31.346 Y29.631 I0.063 J0.05
    N2424 G03 X31.3 Y29.66 I-0.063 J-0.05
    N2425 G01 X31.277 Y29.665
    N2426 G01 X31.249 Y29.67
    N2427 G01 X30.974 Y29.811
    N2428 G01 X30.774 Y29.823
    N2429 G01 X30.566 Y29.748
    N2430 G01 X30.505 Y29.544
    N2431 G01 X30.444 Y29.31
    N2432 G01 X30.387 Y29.054
    N2433 G01 X30.327 Y28.726
    N2434 G01 X30.27 Y28.348
    N2435 G01 X30.212 Y27.834
    N2436 G01 X30.155 Y27.114
    N2437 G01 X30.124 Y26.393
    N2438 G01 X30.107 Y25.671
    N2439 G01 X30.097 Y24.949
    N2440 G01 X30.092 Y24.227
    N2441 G01 X30.089 Y23.505
    N2442 G01 X30.086 Y22.061
    N2443 G01 X30.084 Y20.617
    N2444 G01 X30.087 Y19.896
    N2445 G01 X30.085 Y19.535
    N2446 G01 Y19.354
    N2447 G01 X30.065 Y19.313
    N2448 G01 X30.03 Y19.286
    N2449 G01 X29.985 Y19.277
    N2450 G01 X29.286 Y19.455
    N2451 G01 X29.138 Y19.503
    N2452 G01 X28.962 Y19.553
    N2453 G01 X28.75 Y19.605
    N2454 G01 X28.507 Y19.655
    N2455 G01 X28.202 Y19.708
    N2456 G01 X27.812 Y19.761
    N2457 G01 X27.274 Y19.815
    N2458 G01 X26.554 Y19.861
    N2459 G01 X25.832 Y19.886
    N2460 G01 X25.11 Y19.899
    N2461 G01 X24.389 Y19.906
    N2462 G01 X23.667 Y19.91
    N2463 G01 X22.945 Y19.912
    N2464 G01 X22.223 Y19.918
    N2465 G01 X21.862 Y19.913
    N2466 G01 X21.681 Y19.915
    N2467 G01 X21.275 Y19.914
    N2468 G01 X21.234 Y19.934
    N2469 G01 X21.207 Y19.969
    N2470 G01 X21.197 Y20.014
    N2471 G01 X21.373 Y20.714
    N2472 G01 X21.422 Y20.875
    N2473 G01 X21.473 Y21.069
    N2474 G01 X21.525 Y21.296
    N2475 G01 X21.577 Y21.566
    N2476 G01 X21.631 Y21.914
    N2477 G01 X21.684 Y22.36
    N2478 G01 X21.738 Y23.009
    N2479 G01 X21.773 Y23.73
    N2480 G01 X21.792 Y24.452
    N2481 G01 X21.802 Y25.174
    N2482 G01 X21.808 Y25.895
    N2483 G01 X21.811 Y26.617
    N2484 G01 X21.813 Y27.339
    N2485 G01 X21.817 Y28.061
    N2486 G01 X21.808 Y28.783
    N2487 G01 X21.819 Y29.144
    N2488 G01 X21.816 Y29.325
    N2489 G01 X21.815 Y29.641
    N2490 G01 X21.835 Y29.681
    N2491 G01 X21.871 Y29.709
    N2492 G01 X21.915 Y29.718
    N2493 G01 X22.615 Y29.54
    N2494 G01 X22.791 Y29.49
    N2495 G01 X22.993 Y29.441
    N2496 G01 X23.235 Y29.39
    N2497 G01 X23.542 Y29.338
    N2498 G01 X23.925 Y29.286
    N2499 G01 X24.46 Y29.233
    N2500 G01 X25.18 Y29.187
    N2501 G01 X25.902 Y29.163
    N2502 G01 X26.624 Y29.15
    N2503 G01 X27.345 Y29.144
    N2504 G01 X28.067 Y29.139
    N2505 G01 X28.789 Y29.131
    N2506 G01 X29.15 Y29.137
    N2507 G01 X29.331 Y29.136
    N2508 G01 X29.827 Y29.138
    N2509 G03 X29.941 Y29.165 I-0.011 J0.3
    N2510 G01 X30.002 Y29.192 Z9.972
    N2511 G01 X30.06 Y29.219 Z9.95
    N2512 G01 X30.111 Y29.242 Z9.915
    N2513 G01 X30.154 Y29.262 Z9.867
    N2514 G01 X30.187 Y29.277 Z9.81
    N2515 G01 X30.207 Y29.286 Z9.747
    N2516 G01 X30.214 Y29.289 Z9.68
    N2517 G00 Z-3.01
    N2518 G00 X21.093 Y20.27
    N2519 G00 Z9.38
    N2520 G01 Z9.68 F1500
    N2521 G01 X21.086 Y20.272 Z9.747
    N2522 G01 X21.064 Y20.278 Z9.81
    N2523 G01 X21.03 Y20.288 Z9.867
    N2524 G01 X20.984 Y20.3 Z9.915
    N2525 G01 X20.929 Y20.316 Z9.95
    N2526 G01 X20.868 Y20.333 Z9.972
    N2527 G01 X20.804 Y20.351 Z9.98
    N2528 G01 X20.691 Y20.383
    N2529 G01 X21.333 Y20.298
    N2530 G01 X21.621 Y20.157
    N2531 G01 X21.83 Y20.147
    N2532 G01 X22.049 Y20.23
    N2533 G01 X22.252 Y20.426
    N2534 G01 X22.351 Y20.844
    N2535 G01 X22.438 Y21.28
    N2536 G01 X22.522 Y21.792
    N2537 G01 X22.597 Y22.381
    N2538 G01 X22.664 Y23.1
    N2539 G01 X22.705 Y23.821
    N2540 G01 X22.729 Y24.542
    N2541 G01 X22.744 Y25.264
    N2542 G01 X22.753 Y25.986
    N2543 G01 X22.758 Y26.708
    N2544 G01 X22.77 Y27.43
    N2545 G01 X22.752 Y28.152
    N2546 G01 X22.761 Y28.332
    N2547 G01 X22.76 Y28.512
    N2548 G01 X22.759 Y28.693
    N2549 G01 X22.763 Y28.918
    N2550 G03 X22.163 Y28.912 I-0.3 J-0.003
    N2551 G03 X22.488 Y28.616 I0.3 J0.003
    N2552 G01 X30.51 Y29.272
    N2553 G02 X30.559 Y28.674 I0.024 J-0.299
    N2554 G02 X30.438 Y28.688 I-0.024 J0.299
    N2555 G01 X30.327 Y28.726
    N2556 G01 X30.298 Y28.731
    N2557 G01 X30.023 Y28.872
    N2558 G01 X29.824 Y28.884
    N2559 G01 X29.615 Y28.809
    N2560 G01 X29.555 Y28.605
    N2561 G01 X29.493 Y28.368
    N2562 G01 X29.437 Y28.112
    N2563 G01 X29.376 Y27.784
    N2564 G01 X29.319 Y27.401
    N2565 G01 X29.261 Y26.883
    N2566 G01 X29.205 Y26.163
    N2567 G01 X29.174 Y25.442
    N2568 G01 X29.157 Y24.72
    N2569 G01 X29.147 Y23.998
    N2570 G01 X29.142 Y23.276
    N2571 G01 X29.139 Y22.554
    N2572 G01 X29.131 Y21.832
    N2573 G01 X29.147 Y21.11
    N2574 G01 X29.128 Y20.75
    N2575 G01 X29.134 Y20.569
    N2576 G01 X29.137 Y20.028
    N2577 G01 X29.14 Y19.938
    N2578 G03 X29.74 Y19.96 I0.3 J0.011
    N2579 G03 X29.341 Y20.232 I-0.3 J-0.011
    N2580 G01 X28.339 Y19.883
    N2581 G03 X28.536 Y19.316 I0.099 J-0.283
    N2582 G03 X28.726 Y19.518 I-0.099 J0.283
    N2583 G01 X28.75 Y19.605
    N2584 G01 X28.783 Y19.735
    N2585 G01 X28.877 Y19.884
    N2586 G01 X28.908 Y20.079
    N2587 G01 X28.853 Y20.291
    N2588 G01 X28.699 Y20.489
    N2589 G01 X28.35 Y20.56
    N2590 G01 X27.895 Y20.636
    N2591 G01 X27.4 Y20.7
    N2592 G01 X26.729 Y20.763
    N2593 G01 X26.008 Y20.806
    N2594 G01 X25.287 Y20.831
    N2595 G01 X24.567 Y20.889
    N2596 G01 X24.212 Y20.821
    N2597 G01 X23.687 Y20.901
    N2598 G01 X23.512 Y20.855
    N2599 G01 X23.332 Y20.859
    N2600 G01 X23.061 Y20.862
    N2601 G01 X22.926 Y20.863
    N2602 G03 X22.811 Y20.837 I0.009 J-0.3
    N2603 G01 X22.75 Y20.809 Z9.972
    N2604 G01 X22.693 Y20.783 Z9.95
    N2605 G01 X22.641 Y20.76 Z9.915
    N2606 G01 X22.597 Y20.741 Z9.867
    N2607 G01 X22.565 Y20.726 Z9.81
    N2608 G01 X22.545 Y20.717 Z9.747
    N2609 G01 X22.538 Y20.714 Z9.68
    N2610 G00 Z-3.01
    N2611 G00 X23.378 Y29.783
    N2612 G00 Z9.38
    N2613 G01 Z9.68 F1500
    N2614 G01 X23.375 Y29.776 Z9.747
    N2615 G01 X23.368 Y29.755 Z9.81
    N2616 G01 X23.355 Y29.722 Z9.867
    N2617 G01 X23.339 Y29.677 Z9.915
    N2618 G01 X23.32 Y29.624 Z9.95
    N2619 G01 X23.298 Y29.564 Z9.972
    N2620 G01 X23.276 Y29.501 Z9.98
    N2621 G01 X23.235 Y29.39
    N2622 G01 X23.23 Y29.363
    N2623 G01 X23.085 Y29.091
    N2624 G01 X23.068 Y28.892
    N2625 G01 X23.139 Y28.683
    N2626 G01 X23.32 Y28.626
    N2627 G01 X23.532 Y28.568
    N2628 G01 X23.796 Y28.505
    N2629 G01 X24.081 Y28.448
    N2630 G01 X24.44 Y28.39
    N2631 G01 X24.886 Y28.333
    N2632 G01 X25.505 Y28.276
    N2633 G01 X26.226 Y28.235
    N2634 G01 X26.947 Y28.213
    N2635 G01 X27.667 Y28.158
    N2636 G01 X28.022 Y28.226
    N2637 G01 X28.289 Y28.184
    N2638 G01 X28.469 Y28.183
    N2639 G01 X28.83 Y28.181
    N2640 G01 X28.92 Y28.182
    N2641 G03 X29.034 Y28.212 I-0.017 J0.3
    N2642 G01 X29.094 Y28.241 Z9.972
    N2643 G01 X29.151 Y28.268 Z9.95
    N2644 G01 X29.202 Y28.293 Z9.915
    N2645 G01 X29.245 Y28.313 Z9.867
    N2646 G01 X29.277 Y28.329 Z9.81
    N2647 G01 X29.297 Y28.338 Z9.747
    N2648 G01 X29.304 Y28.342 Z9.68
    N2649 G00 Z-3.01
    N2650 G00 X22.044 Y21.42
    N2651 G00 Z9.38
    N2652 G01 Z9.68 F1500
    N2653 G01 X22.052 Y21.417 Z9.747
    N2654 G01 X22.072 Y21.41 Z9.81
    N2655 G01 X22.106 Y21.398 Z9.867
    N2656 G01 X22.151 Y21.382 Z9.915
    N2657 G01 X22.205 Y21.363 Z9.95
    N2658 G01 X22.264 Y21.342 Z9.972
    N2659 G01 X22.327 Y21.32 Z9.98
    N2660 G01 X22.438 Y21.28
    N2661 G01 X22.467 Y21.275
    N2662 G01 X22.739 Y21.131
    N2663 G01 X22.939 Y21.115
    N2664 G01 X23.15 Y21.187
    N2665 G01 X23.341 Y21.361
    N2666 G01 X23.428 Y21.849
    N2667 G01 X23.508 Y22.409
    N2668 G01 X23.579 Y23.079
    N2669 G01 X23.63 Y23.799
    N2670 G01 X23.663 Y24.52
    N2671 G01 X23.683 Y25.242
    N2672 G01 X23.696 Y25.964
    N2673 G01 X23.723 Y26.686
    N2674 G01 X23.679 Y27.406
    N2675 G01 X23.692 Y27.496
    N2676 G01 X23.7 Y27.585
    N2677 G01 X23.708 Y27.766
    N2678 G01 X23.706 Y27.946
    N2679 G03 X23.107 Y27.917 I-0.3 J-0.015
    N2680 G03 X23.44 Y27.634 I0.3 J0.015
    N2681 G01 X29.55 Y28.329
    N2682 G02 X29.618 Y27.732 I0.034 J-0.298
    N2683 G02 X29.488 Y27.746 I-0.034 J0.298
    N2684 G01 X29.376 Y27.784
    N2685 G01 X29.242 Y27.809
    N2686 G01 X29.087 Y27.896
    N2687 G01 X28.891 Y27.916
    N2688 G01 X28.682 Y27.85
    N2689 G01 X28.493 Y27.686
    N2690 G01 X28.423 Y27.272
    N2691 G01 X28.355 Y26.753
    N2692 G01 X28.291 Y26.092
    N2693 G01 X28.247 Y25.371
    N2694 G01 X28.221 Y24.649
    N2695 G01 X28.206 Y23.928
    N2696 G01 X28.197 Y23.206
    N2697 G01 X28.177 Y22.484
    N2698 G01 X28.209 Y21.763
    N2699 G01 X28.201 Y21.673
    N2700 G01 X28.197 Y21.583
    N2701 G01 X28.193 Y21.402
    N2702 G01 X28.194 Y21.267
    N2703 G01 Y21.222
    N2704 G01 X28.174 Y21.181
    N2705 G01 X28.138 Y21.154
    N2706 G01 X28.094 Y21.145
    N2707 G01 X27.395 Y21.327
    N2708 G01 X27.242 Y21.379
    N2709 G01 X27.078 Y21.428
    N2710 G01 X26.882 Y21.479
    N2711 G01 X26.641 Y21.533
    N2712 G01 X25.931 Y21.665
    N2713 G01 X25.611 Y21.786
    N2714 G01 X24.89 Y21.753
    N2715 G01 X24.717 Y21.807
    N2716 G01 X24.533 Y21.823
    N2717 G01 X24.443 Y21.816
    N2718 G01 X24.353 Y21.805
    N2719 G01 X24.174 Y21.779
    N2720 G01 X24.13 Y21.787
    N2721 G01 X24.094 Y21.814
    N2722 G01 X24.074 Y21.854
    N2723 G01 X24.073 Y21.9
    N2724 G01 X24.381 Y22.553
    N2725 G01 X24.448 Y22.996
    N2726 G01 X24.514 Y23.568
    N2727 G01 X24.572 Y24.288
    N2728 G01 X24.608 Y25.009
    N2729 G01 X24.637 Y25.731
    N2730 G01 X24.667 Y26.452
    N2731 G01 X24.686 Y27.174
    N2732 G01 X24.658 Y27.259
    N2733 G01 X24.648 Y27.349
    N2734 G01 X24.649 Y27.439
    N2735 G01 X24.655 Y27.71
    N2736 G01 X24.675 Y27.75
    N2737 G01 X24.711 Y27.778
    N2738 G01 X24.755 Y27.786
    N2739 G01 X25.452 Y27.598
    N2740 G01 X26.152 Y27.42
    N2741 G01 X26.424 Y27.284
    N2742 G01 X27.145 Y27.244
    N2743 G01 X27.45 Y27.222
    N2744 G01 X27.863 Y27.198
    N2745 G01 X27.948 Y27.229
    N2746 G03 X27.722 Y27.785 I-0.113 J0.278
    N2747 G03 X27.535 Y27.518 I0.113 J-0.278
    N2748 G01 X27.301 Y20.705
    N2749 G03 X27.895 Y20.636 I0.3 J-0.01
    N2750 G01 X28.028 Y21.434
    N2751 G01 X28.085 Y21.62
    N2752 G01 X28.061 Y21.834
    N2753 G01 X27.937 Y22.051
    N2754 G01 X27.663 Y22.256
    N2755 G01 X26.959 Y22.415
    N2756 G01 X26.304 Y22.607
    N2757 G01 X26.259 Y22.602
    N2758 G01 X25.54 Y22.664
    N2759 G01 X25.446 Y22.684
    N2760 G01 X25.356 Y22.696
    N2761 G01 X25.176 Y22.709
    N2762 G01 X25.131
    N2763 G01 X25.086 Y22.713
    N2764 G01 X25.048 Y22.737
    N2765 G01 X25.024 Y22.776
    N2766 G01 X25.019 Y22.82
    N2767 G01 X25.268 Y23.498
    N2768 G01 X25.327 Y23.773
    N2769 G01 X25.387 Y24.113
    N2770 G01 X25.487 Y24.828
    N2771 G01 X25.597 Y25.213
    N2772 G01 X25.55 Y25.571
    N2773 G01 X25.649 Y26.16
    N2774 G01 X25.606 Y26.335
    N2775 G01 X25.618 Y26.515
    N2776 G01 X25.629 Y26.876
    N2777 G01 X25.631 Y26.966
    N2778 G03 X24.977 Y27.553 I-0.595 J-0.005
    N2779 G03 X24.453 Y26.847 I0.06 J-0.592
    N2780 G01 X25.482 Y21.569
    N2781 G03 X26.641 Y21.533 I0.584 J0.114
    N2782 G01 X26.955 Y22.942
    N2783 G01 X26.917 Y23.159
    N2784 G01 X26.783 Y23.362
    N2785 G01 X26.554 Y23.512
    N2786 G01 X26.376 Y23.543
    N2787 G01 X26.016 Y23.576
    N2788 G01 X25.926 Y23.584
    N2789 G01 X25.888 Y23.607
    N2790 G01 X25.863 Y23.645
    N2791 G01 X25.858 Y23.69
    N2792 G01 X25.873 Y23.732
    N2793 G01 X26.283 Y24.138
    N2794 G01 X26.431 Y24.505
    N2795 G01 X26.426 Y24.686
    N2796 G01 X26.562 Y25.104
    N2797 G01 X26.527 Y25.463
    N2798 G01 X26.52 Y26.185
    N2799 G01 X26.544 Y26.316
    N2800 G01 X26.563 Y26.495
    N2801 G01 X26.572 Y26.675
    N2802 G01 X26.593 Y26.715
    N2803 G01 X26.63 Y26.741
    N2804 G01 X26.674 Y26.749
    N2805 G01 X26.717 Y26.736
    N2806 G01 X27.12 Y26.366
    N2807 G01 X27.469 Y26.245
    N2808 G01 X27.559 Y26.251
    N2809 G01 X27.65
    N2810 G01 X27.69 Y26.231
    N2811 G01 X27.717 Y26.195
    N2812 G01 X27.726 Y26.151
    N2813 G01 X27.715 Y26.107
    N2814 G01 X27.383 Y25.725
    N2815 G01 X27.27 Y25.366
    N2816 G01 X27.308 Y25.007
    N2817 G01 X27.221 Y24.381
    N2818 G01 X27.27 Y24.207
    N2819 G01 X27.228 Y23.486
    N2820 G01 X27.266 Y23.127
    N2821 G01 X27.255 Y23.038
    N2822 G01 X27.247 Y22.948
    N2823 G01 Y22.933 Z9.979
    N2824 G01 X27.254 Y22.893 Z9.966
    N2825 G01 X27.259 Y22.861 Z9.94
    N2826 G01 X27.263 Y22.839 Z9.904
    N2827 G01 X27.264 Y22.832 Z9.862
    N2828 G00 Z-3.01
    N2829 G00 X9.706 Y6.562
    N2830 G00 Z14.37
    N2831 G01 Z14.67 F1500
    N2832 G01 X9.708 Y6.57 Z14.737
    N2833 G01 X9.713 Y6.591 Z14.8
    N2834 G01 X9.722 Y6.626 Z14.857
    N2835 G01 X9.734 Y6.672 Z14.905
    N2836 G01 X9.748 Y6.727 Z14.94
    N2837 G01 X9.764 Y6.788 Z14.962
    N2838 G01 X9.78 Y6.853 Z14.97
    N2839 G03 X10.015 Y8.486 I-7.419 J1.9
    N2840 G01 Y8.576
    N2841 G01 X9.75 Y9.248
    N2842 G01 X9.608 Y9.956
    N2843 G01 X9.536 Y10.674
    N2844 G01 X9.499 Y11.395
    N2845 G01 X9.482 Y12.117
    N2846 G01 X9.473 Y12.839
    N2847 G01 X9.469 Y13.561
    N2848 G01 X9.467 Y14.283
    N2849 G01 X9.465 Y16.449
    N2850 G01 Y38.831
    N2851 G01 X9.578 Y39.174
    N2852 G01 X9.789 Y39.467
    N2853 G01 X10.328 Y39.947
    N2854 G01 X10.992 Y40.229
    N2855 G01 X11.698 Y40.381
    N2856 G01 X12.416 Y40.459
    N2857 G01 X13.137 Y40.498
    N2858 G01 X13.859 Y40.517
    N2859 G01 X14.581 Y40.526
    N2860 G01 X15.303 Y40.531
    N2861 G01 X16.025 Y40.533
    N2862 G01 X18.191 Y40.535
    N2863 G01 X29.02
    N2864 G01 X38.767
    N2865 G01 X39.117 Y40.446
    N2866 G01 X39.42 Y40.249
    N2867 G01 X39.918 Y39.727
    N2868 G01 X40.212 Y39.067
    N2869 G01 X40.372 Y38.363
    N2870 G01 X40.455 Y37.646
    N2871 G01 X40.496 Y36.925
    N2872 G01 X40.516 Y36.203
    N2873 G01 X40.526 Y35.481
    N2874 G01 X40.531 Y34.76
    N2875 G01 X40.533 Y34.038
    N2876 G01 X40.535 Y31.872
    N2877 G01 Y11.295
    N2878 G01 X40.504 Y11.117
    N2879 G01 X40.373 Y10.78
    N2880 G01 X40.152 Y10.495
    N2881 G01 X39.6 Y10.029
    N2882 G01 X38.931 Y9.758
    N2883 G01 X38.224 Y9.612
    N2884 G01 X37.506 Y9.538
    N2885 G01 X36.785 Y9.5
    N2886 G01 X36.063 Y9.482
    N2887 G01 X35.341 Y9.473
    N2888 G01 X34.619 Y9.469
    N2889 G01 X33.897 Y9.467
    N2890 G01 X31.731 Y9.465
    N2891 G01 X30.287
    N2892 G01 X12.237
    N2893 G01 X11.893 Y9.573
    N2894 G01 X11.592 Y9.772
    N2895 G01 X11.088 Y10.29
    N2896 G01 X10.848 Y10.433
    N2897 G01 X10.562 Y10.47
    N2898 G01 X10.382 Y10.467
    N2899 G01 X10.292 Y10.466
    N2900 G01 X10.251 Y10.486
    N2901 G01 X10.223 Y10.521
    N2902 G01 X10.214 Y10.565
    N2903 G01 X10.301 Y10.916
    N2904 G01 X10.343 Y11.358
    N2905 G01 X10.386 Y12.079
    N2906 G01 X10.403 Y12.801
    N2907 G01 X10.41 Y13.523
    N2908 G01 X10.413 Y14.245
    N2909 G01 X10.415 Y15.689
    N2910 G01 Y37.348
    N2911 G01 X10.508 Y38.064
    N2912 G01 X10.458 Y38.238
    N2913 G01 X10.469 Y38.599
    N2914 G01 X10.467 Y38.734
    N2915 G01 X10.506 Y38.816
    N2916 G01 X10.759 Y39.073
    N2917 G01 X11.072 Y39.253
    N2918 G01 X11.759 Y39.475
    N2919 G01 X12.48 Y39.513
    N2920 G01 X13.201 Y39.546
    N2921 G01 X13.923 Y39.562
    N2922 G01 X14.645 Y39.572
    N2923 G01 X15.367 Y39.578
    N2924 G01 X16.089 Y39.581
    N2925 G01 X17.533 Y39.584
    N2926 G01 X21.864 Y39.585
    N2927 G01 X37.748
    N2928 G01 X38.103 Y39.516
    N2929 G01 X38.462 Y39.551
    N2930 G01 X38.642 Y39.539
    N2931 G01 X38.687 Y39.538
    N2932 G01 X38.731 Y39.526
    N2933 G01 X38.811 Y39.486
    N2934 G01 X38.947 Y39.366
    N2935 G01 X39.072 Y39.237
    N2936 G01 X39.256 Y38.926
    N2937 G01 X39.463 Y38.234
    N2938 G01 X39.507 Y37.514
    N2939 G01 X39.561 Y36.794
    N2940 G01 X39.569 Y36.072
    N2941 G01 X39.575 Y35.35
    N2942 G01 X39.579 Y34.628
    N2943 G01 X39.582 Y33.906
    N2944 G01 X39.584 Y32.462
    N2945 G01 X39.585 Y26.686
    N2946 G01 Y16.578
    N2947 G01 Y12.246
    N2948 G01 X39.516 Y11.892
    N2949 G01 X39.551 Y11.532
    N2950 G01 X39.539 Y11.352
    N2951 G01 X39.531 Y11.308
    N2952 G01 X39.494 Y11.225
    N2953 G01 X39.38 Y11.086
    N2954 G01 X39.103 Y10.854
    N2955 G01 X38.435 Y10.58
    N2956 G01 X37.715 Y10.521
    N2957 G01 X37. Y10.425
    N2958 G01 X36.278 Y10.426
    N2959 G01 X34.112 Y10.418
    N2960 G01 X31.946 Y10.416
    N2961 G01 X13.896 Y10.415
    N2962 G01 X13.174 Y10.424
    N2963 G01 X12.682 Y10.505
    N2964 G01 X12.507 Y10.461
    N2965 G01 X12.327 Y10.464
    N2966 G01 X12.244 Y10.499
    N2967 G01 X11.678 Y10.948
    N2968 G01 X11.442 Y11.207
    N2969 G01 X11.342 Y11.252
    N2970 G01 X11.258 Y11.286
    N2971 G01 X11.173 Y11.315
    N2972 G01 X11.129 Y11.327
    N2973 G01 X11.085 Y11.338
    N2974 G01 X11.051 Y11.367
    N2975 G01 X11.032 Y11.408
    N2976 G01 X11.059 Y12.13
    N2977 G01 X11.105 Y12.328
    N2978 G01 X11.151 Y12.566
    N2979 G01 X11.198 Y12.866
    N2980 G01 X11.246 Y13.257
    N2981 G01 X11.294 Y13.818
    N2982 G01 X11.331 Y14.539
    N2983 G01 X11.349 Y15.261
    N2984 G01 X11.357 Y15.983
    N2985 G01 X11.361 Y16.705
    N2986 G01 X11.363 Y17.427
    N2987 G01 X11.365 Y19.593
    N2988 G01 Y27.535
    N2989 G01 Y37.643
    N2990 G01 X11.474 Y37.987
    N2991 G01 X11.452 Y38.166
    N2992 G01 X11.432 Y38.254
    N2993 G01 X11.424 Y38.344
    N2994 G01 X11.423 Y38.389
    N2995 G01 X11.441 Y38.43
    N2996 G01 X11.476 Y38.459
    N2997 G01 X12.179 Y38.626
    N2998 G01 X12.901 Y38.615
    N2999 G01 X13.622 Y38.616
    N3000 G01 X15.066 Y38.625
    N3001 G01 X15.788 Y38.631
    N3002 G01 X17.954 Y38.635
    N3003 G01 X38.17
    N3004 G01 X38.26 Y38.622
    N3005 G01 X38.304 Y38.617
    N3006 G01 X38.343 Y38.593
    N3007 G01 X38.39 Y38.516
    N3008 G01 X38.589 Y37.822
    N3009 G01 X38.603 Y37.1
    N3010 G01 X38.613 Y36.378
    N3011 G01 X38.631 Y35.656
    N3012 G01 X38.63 Y34.934
    N3013 G01 X38.634 Y32.768
    N3014 G01 X38.635 Y28.436
    N3015 G01 Y26.27
    N3016 G01 Y11.83
    N3017 G01 X38.621 Y11.741
    N3018 G01 X38.617 Y11.696
    N3019 G01 X38.593 Y11.658
    N3020 G01 X38.439 Y11.563
    N3021 G01 X37.735 Y11.404
    N3022 G01 X37.013 Y11.389
    N3023 G01 X36.293 Y11.338
    N3024 G01 X35.571 Y11.355
    N3025 G01 X34.849 Y11.362
    N3026 G01 X34.127 Y11.365
    N3027 G01 X32.683 Y11.366
    N3028 G01 X13.911 Y11.365
    N3029 G01 X13.19 Y11.373
    N3030 G01 X12.699 Y11.477
    N3031 G01 X12.611 Y11.459
    N3032 G01 X12.567 Y11.45
    N3033 G01 X12.523 Y11.46
    N3034 G01 X12.245 Y11.691
    N3035 G01 X12.056 Y11.946
    N3036 G01 X11.978 Y11.991
    N3037 G01 X11.938 Y12.012
    N3038 G01 X11.912 Y12.049
    N3039 G01 X11.904 Y12.093
    N3040 G01 X11.978 Y12.408
    N3041 G01 X12.043 Y12.737
    N3042 G01 X12.112 Y13.166
    N3043 G01 X12.171 Y13.641
    N3044 G01 X12.23 Y14.303
    N3045 G01 X12.268 Y15.024
    N3046 G01 X12.29 Y15.745
    N3047 G01 X12.301 Y16.467
    N3048 G01 X12.308 Y17.189
    N3049 G01 X12.311 Y17.911
    N3050 G01 X12.314 Y19.355
    N3051 G01 X12.315 Y20.799
    N3052 G01 Y37.405
    N3053 G01 X12.343 Y37.583
    N3054 G01 X12.368 Y37.67
    N3055 G01 X12.387 Y37.758
    N3056 G01 X12.393 Y37.803
    N3057 G01 X12.418 Y37.841
    N3058 G01 X12.457 Y37.863
    N3059 G01 X13.178 Y37.91
    N3060 G01 X13.42 Y37.866
    N3061 G01 X13.727 Y37.822
    N3062 G01 X14.13 Y37.779
    N3063 G01 X14.745 Y37.734
    N3064 G01 X15.466 Y37.707
    N3065 G01 X16.188 Y37.694
    N3066 G01 X16.91 Y37.689
    N3067 G01 X17.632 Y37.687
    N3068 G01 X19.798 Y37.685
    N3069 G01 X37.803
    N3070 G01 X37.843 Y37.665
    N3071 G01 X37.871 Y37.63
    N3072 G01 X37.88 Y37.585
    N3073 G01 X37.702 Y36.886
    N3074 G01 X37.691 Y36.164
    N3075 G01 X37.686 Y35.442
    N3076 G01 X37.684 Y34.72
    N3077 G01 Y33.276
    N3078 G01 X37.685 Y29.666
    N3079 G01 Y12.203
    N3080 G01 X37.665 Y12.162
    N3081 G01 X37.63 Y12.134
    N3082 G01 X37.585 Y12.125
    N3083 G01 X36.886 Y12.304
    N3084 G01 X36.164 Y12.305
    N3085 G01 X35.442 Y12.274
    N3086 G01 X34.721 Y12.295
    N3087 G01 X33.999 Y12.306
    N3088 G01 X33.277 Y12.311
    N3089 G01 X32.555 Y12.313
    N3090 G01 X31.111 Y12.315
    N3091 G01 X13.783
    N3092 G01 X13.061 Y12.328
    N3093 G01 X13.019 Y12.344
    N3094 G01 X12.976 Y12.36
    N3095 G01 X12.943 Y12.389
    N3096 G01 X12.911 Y12.422
    N3097 G01 X12.896 Y12.464
    N3098 G01 X12.991 Y13.18
    N3099 G01 X13.064 Y13.668
    N3100 G01 X13.129 Y14.238
    N3101 G01 X13.185 Y14.958
    N3102 G01 X13.219 Y15.679
    N3103 G01 X13.238 Y16.401
    N3104 G01 X13.25 Y17.123
    N3105 G01 X13.257 Y17.845
    N3106 G01 X13.26 Y18.567
    N3107 G01 X13.264 Y20.011
    N3108 G01 Y20.733
    N3109 G01 X13.265 Y31.563
    N3110 G01 Y37.158
    N3111 G01 X13.266 Y37.203
    N3112 G01 X13.286 Y37.244
    N3113 G01 X13.322 Y37.271
    N3114 G01 X13.366 Y37.28
    N3115 G01 X14.064 Y37.093
    N3116 G01 X14.258 Y37.043
    N3117 G01 X14.479 Y36.994
    N3118 G01 X14.755 Y36.944
    N3119 G01 X15.094 Y36.894
    N3120 G01 X15.549 Y36.843
    N3121 G01 X16.207 Y36.793
    N3122 G01 X16.929 Y36.764
    N3123 G01 X17.651 Y36.749
    N3124 G01 X18.373 Y36.742
    N3125 G01 X19.095 Y36.738
    N3126 G01 X20.539 Y36.736
    N3127 G01 X28.48 Y36.735
    N3128 G01 X37.054
    N3129 G01 X37.095 Y36.715
    N3130 G01 X37.122 Y36.68
    N3131 G01 X37.132 Y36.635
    N3132 G01 X36.953 Y35.936
    N3133 G01 X36.907 Y35.656
    N3134 G01 X36.86 Y35.292
    N3135 G01 X36.813 Y34.783
    N3136 G01 X36.771 Y34.062
    N3137 G01 X36.752 Y33.34
    N3138 G01 X36.743 Y32.618
    N3139 G01 X36.739 Y31.896
    N3140 G01 X36.737 Y31.174
    N3141 G01 X36.735 Y29.008
    N3142 G01 Y26.842
    N3143 G01 Y12.944
    N3144 G01 X36.715 Y12.903
    N3145 G01 X36.68 Y12.876
    N3146 G01 X36.635 Y12.866
    N3147 G01 X35.936 Y13.045
    N3148 G01 X35.593 Y13.097
    N3149 G01 X35.136 Y13.149
    N3150 G01 X34.478 Y13.201
    N3151 G01 X33.757 Y13.233
    N3152 G01 X33.035 Y13.249
    N3153 G01 X32.313 Y13.257
    N3154 G01 X31.591 Y13.261
    N3155 G01 X30.869 Y13.263
    N3156 G01 X28.703 Y13.265
    N3157 G01 X13.812
    N3158 G01 X13.631 Y13.268
    N3159 G01 X13.591 Y13.289
    N3160 G01 X13.564 Y13.325
    N3161 G01 X13.556 Y13.369
    N3162 G01 X13.746 Y14.066
    N3163 G01 X13.797 Y14.221
    N3164 G01 X13.849 Y14.406
    N3165 G01 X13.899 Y14.609
    N3166 G01 X13.952 Y14.858
    N3167 G01 X14.005 Y15.168
    N3168 G01 X14.059 Y15.556
    N3169 G01 X14.113 Y16.089
    N3170 G01 X14.16 Y16.809
    N3171 G01 X14.185 Y17.531
    N3172 G01 X14.199 Y18.252
    N3173 G01 X14.206 Y18.974
    N3174 G01 X14.21 Y19.696
    N3175 G01 X14.214 Y21.14
    N3176 G01 X14.215 Y24.75
    N3177 G01 Y26.194
    N3178 G01 Y36.483
    N3179 G03 X14.188 Y36.597 I-0.3 J-0.01
    N3180 G01 X14.16 Y36.657 Z14.962
    N3181 G01 X14.134 Y36.715 Z14.94
    N3182 G01 X14.111 Y36.767 Z14.905
    N3183 G01 X14.091 Y36.81 Z14.857
    N3184 G01 X14.076 Y36.843 Z14.8
    N3185 G01 X14.067 Y36.863 Z14.737
    N3186 G01 X14.064 Y36.87 Z14.67
    N3187 G00 Z-3.01
    N3188 G00 X13.464 Y13.548
    N3189 G00 Z14.37
    N3190 G01 Z14.67 F1500
    N3191 G01 X13.457 Y13.55 Z14.737
    N3192 G01 X13.436 Y13.557 Z14.8
    N3193 G01 X13.401 Y13.567 Z14.857
    N3194 G01 X13.356 Y13.581 Z14.905
    N3195 G01 X13.301 Y13.597 Z14.94
    N3196 G01 X13.241 Y13.615 Z14.962
    N3197 G01 X13.177 Y13.635 Z14.97
    N3198 G01 X13.064 Y13.668
    N3199 G01 X13.813 Y13.556
    N3200 G01 X13.98 Y13.473
    N3201 G01 X14.189 Y13.462
    N3202 G01 X14.41 Y13.543
    N3203 G01 X14.617 Y13.74
    N3204 G01 X14.72 Y14.149
    N3205 G01 X14.809 Y14.568
    N3206 G01 X14.891 Y15.026
    N3207 G01 X14.97 Y15.585
    N3208 G01 X15.04 Y16.239
    N3209 G01 X15.091 Y16.959
    N3210 G01 X15.121 Y17.68
    N3211 G01 X15.14 Y18.402
    N3212 G01 X15.15 Y19.124
    N3213 G01 X15.157 Y19.846
    N3214 G01 X15.16 Y20.568
    N3215 G01 X15.164 Y22.012
    N3216 G01 X15.165 Y25.622
    N3217 G01 Y36.271
    N3218 G01 X15.185 Y36.312
    N3219 G01 X15.22 Y36.34
    N3220 G01 X15.265 Y36.349
    N3221 G01 X15.964 Y36.17
    N3222 G01 X16.127 Y36.124
    N3223 G01 X16.322 Y36.076
    N3224 G01 X16.55 Y36.028
    N3225 G01 X16.831 Y35.979
    N3226 G01 X17.192 Y35.929
    N3227 G01 X17.684 Y35.879
    N3228 G01 X18.404 Y35.832
    N3229 G01 X19.126 Y35.808
    N3230 G01 X19.847 Y35.797
    N3231 G01 X20.569 Y35.791
    N3232 G01 X21.291 Y35.788
    N3233 G01 X22.735 Y35.786
    N3234 G01 X34.287 Y35.785
    N3235 G01 X36.363
    N3236 G01 X36.453 Y35.788
    N3237 G03 X36.481 Y35.79 I-0.01 J0.3
    N3238 G03 X36.404 Y36.386 I-0.038 J0.298
    N3239 G03 X36.165 Y35.973 I0.038 J-0.298
    N3240 G01 X36.623 Y34.866
    N3241 G03 X37.177 Y35.096 I0.277 J0.115
    N3242 G03 X36.949 Y35.277 I-0.277 J-0.115
    N3243 G01 X36.86 Y35.292
    N3244 G01 X36.831 Y35.295
    N3245 G01 X36.55 Y35.42
    N3246 G01 X36.349 Y35.422
    N3247 G01 X36.144 Y35.335
    N3248 G01 X36.094 Y35.135
    N3249 G01 X36.042 Y34.89
    N3250 G01 X35.988 Y34.587
    N3251 G01 X35.937 Y34.218
    N3252 G01 X35.885 Y33.715
    N3253 G01 X35.836 Y32.995
    N3254 G01 X35.811 Y32.273
    N3255 G01 X35.798 Y31.551
    N3256 G01 X35.792 Y30.829
    N3257 G01 X35.788 Y30.107
    N3258 G01 X35.786 Y28.663
    N3259 G01 X35.785 Y21.443
    N3260 G01 Y13.682
    N3261 G01 X35.765 Y13.641
    N3262 G01 X35.73 Y13.614
    N3263 G01 X35.685 Y13.605
    N3264 G01 X34.986 Y13.783
    N3265 G01 X34.842 Y13.829
    N3266 G01 X34.674 Y13.876
    N3267 G01 X34.472 Y13.925
    N3268 G01 X34.231 Y13.975
    N3269 G01 X33.939 Y14.024
    N3270 G01 X33.558 Y14.075
    N3271 G01 X33.038 Y14.125
    N3272 G01 X32.317 Y14.17
    N3273 G01 X31.596 Y14.192
    N3274 G01 X30.874 Y14.203
    N3275 G01 X30.152 Y14.209
    N3276 G01 X29.43 Y14.212
    N3277 G01 X27.986 Y14.214
    N3278 G01 X17.156 Y14.215
    N3279 G01 X15.306
    N3280 G01 X15.282 Y14.214
    N3281 G03 X15.287 Y14.054 I0.003 J-0.08
    N3282 G03 X15.343 Y14.189 I-0.003 J0.08
    N3283 G01 X14.864 Y14.705
    N3284 G03 X14.747 Y14.597 I-0.059 J-0.054
    N3285 G03 X14.786 Y14.573 I0.059 J0.054
    N3286 G01 X14.809 Y14.568
    N3287 G01 X14.964 Y14.534
    N3288 G01 X15.125 Y14.451
    N3289 G01 X15.327 Y14.437
    N3290 G01 X15.537 Y14.512
    N3291 G01 X15.726 Y14.687
    N3292 G01 X15.812 Y15.154
    N3293 G01 X15.895 Y15.722
    N3294 G01 X15.97 Y16.398
    N3295 G01 X16.025 Y17.118
    N3296 G01 X16.059 Y17.839
    N3297 G01 X16.081 Y18.561
    N3298 G01 X16.095 Y19.283
    N3299 G01 X16.103 Y20.005
    N3300 G01 X16.108 Y20.727
    N3301 G01 X16.111 Y21.449
    N3302 G01 X16.114 Y22.893
    N3303 G01 X16.115 Y27.225
    N3304 G01 Y35.528
    N3305 G01 X16.112 Y35.618
    N3306 G03 X15.512 Y35.597 I-0.3 J-0.01
    N3307 G03 X15.927 Y35.33 I0.3 J0.01
    N3308 G01 X16.978 Y35.766
    N3309 G03 X16.748 Y36.32 I-0.115 J0.277
    N3310 G03 X16.579 Y36.142 I0.115 J-0.277
    N3311 G03 X16.571 Y36.115 I0.283 J-0.099
    N3312 G01 X16.55 Y36.028
    N3313 G01 X16.544 Y36.
    N3314 G01 X16.399 Y35.729
    N3315 G01 X16.382 Y35.531
    N3316 G01 X16.453 Y35.321
    N3317 G01 X16.631 Y35.265
    N3318 G01 X16.848 Y35.206
    N3319 G01 X17.11 Y35.144
    N3320 G01 X17.386 Y35.089
    N3321 G01 X17.745 Y35.031
    N3322 G01 X18.177 Y34.976
    N3323 G01 X18.784 Y34.921
    N3324 G01 X19.505 Y34.881
    N3325 G01 X20.227 Y34.859
    N3326 G01 X20.949 Y34.848
    N3327 G01 X21.671 Y34.842
    N3328 G01 X22.393 Y34.839
    N3329 G01 X23.837 Y34.836
    N3330 G01 X29.613 Y34.835
    N3331 G01 X35.479
    N3332 G01 X35.503 Y34.836
    N3333 G03 X35.497 Y34.996 I-0.003 J0.08
    N3334 G03 X35.449 Y34.854 I0.003 J-0.08
    N3335 G01 X35.944 Y34.442
    N3336 G03 X36.047 Y34.565 I0.051 J0.062
    N3337 G03 X36.012 Y34.582 I-0.051 J-0.062
    N3338 G01 X35.988 Y34.587
    N3339 G01 X35.791 Y34.622
    N3340 G01 X35.616 Y34.682
    N3341 G01 X35.411 Y34.666
    N3342 G01 X35.207 Y34.558
    N3343 G01 X35.145 Y34.288
    N3344 G01 X35.089 Y34.004
    N3345 G01 X35.029 Y33.631
    N3346 G01 X34.974 Y33.185
    N3347 G01 X34.918 Y32.552
    N3348 G01 X34.88 Y31.831
    N3349 G01 X34.859 Y31.109
    N3350 G01 X34.848 Y30.387
    N3351 G01 X34.842 Y29.665
    N3352 G01 X34.839 Y28.943
    N3353 G01 X34.836 Y27.499
    N3354 G01 X34.835 Y21.723
    N3355 G01 Y14.413
    N3356 G01 X34.838 Y14.323
    N3357 G03 X34.84 Y14.295 I0.3 J0.01
    N3358 G03 X35.436 Y14.372 I0.298 J0.038
    N3359 G03 X35.05 Y14.62 I-0.298 J-0.038
    N3360 G01 X33.83 Y14.245
    N3361 G03 X34.007 Y13.671 I0.088 J-0.287
    N3362 G03 X34.202 Y13.86 I-0.088 J0.287
    N3363 G03 X34.21 Y13.887 I-0.284 J0.097
    N3364 G01 X34.231 Y13.975
    N3365 G01 X34.237 Y14.003
    N3366 G01 X34.381 Y14.274
    N3367 G01 X34.397 Y14.473
    N3368 G01 X34.325 Y14.682
    N3369 G01 X34.148 Y14.737
    N3370 G01 X33.934 Y14.795
    N3371 G01 X33.669 Y14.858
    N3372 G01 X33.389 Y14.913
    N3373 G01 X33.029 Y14.971
    N3374 G01 X32.586 Y15.026
    N3375 G01 X31.964 Y15.081
    N3376 G01 X31.243 Y15.12
    N3377 G01 X30.522 Y15.141
    N3378 G01 X29.8 Y15.152
    N3379 G01 X29.078 Y15.158
    N3380 G01 X28.356 Y15.161
    N3381 G01 X26.912 Y15.164
    N3382 G01 X21.136 Y15.165
    N3383 G01 X16.443
    N3384 G01 X16.402 Y15.185
    N3385 G01 X16.375 Y15.22
    N3386 G01 X16.365 Y15.265
    N3387 G01 X16.544 Y15.964
    N3388 G01 X16.594 Y16.106
    N3389 G01 X16.645 Y16.27
    N3390 G01 X16.699 Y16.468
    N3391 G01 X16.752 Y16.693
    N3392 G01 X16.806 Y16.965
    N3393 G01 X16.862 Y17.31
    N3394 G01 X16.918 Y17.75
    N3395 G01 X16.974 Y18.37
    N3396 G01 X17.014 Y19.091
    N3397 G01 X17.036 Y19.813
    N3398 G01 X17.048 Y20.535
    N3399 G01 X17.055 Y21.257
    N3400 G01 X17.059 Y21.979
    N3401 G01 X17.063 Y23.423
    N3402 G01 X17.065 Y26.311
    N3403 G01 Y34.614
    N3404 G01 X17.062 Y34.704
    N3405 G03 X16.462 Y34.683 I-0.3 J-0.01
    N3406 G03 X16.884 Y34.419 I0.3 J0.01
    N3407 G01 X17.82 Y34.834
    N3408 G03 X17.577 Y35.382 I-0.122 J0.274
    N3409 G03 X17.406 Y35.177 I0.122 J-0.274
    N3410 G01 X17.386 Y35.089
    N3411 G01 X17.355 Y34.935
    N3412 G01 X17.274 Y34.774
    N3413 G01 X17.263 Y34.574
    N3414 G01 X17.339 Y34.366
    N3415 G01 X17.517 Y34.179
    N3416 G01 X17.976 Y34.106
    N3417 G01 X18.529 Y34.038
    N3418 G01 X19.248 Y33.976
    N3419 G01 X19.969 Y33.938
    N3420 G01 X20.691 Y33.915
    N3421 G01 X21.413 Y33.902
    N3422 G01 X22.135 Y33.895
    N3423 G01 X22.857 Y33.89
    N3424 G01 X23.579 Y33.888
    N3425 G01 X25.023 Y33.886
    N3426 G01 X32.964 Y33.885
    N3427 G01 X34.499
    N3428 G01 X34.523 Y33.886
    N3429 G03 X34.517 Y34.046 I-0.003 J0.08
    N3430 G03 X34.47 Y33.904 I0.003 J-0.08
    N3431 G01 X34.987 Y33.485
    N3432 G03 X35.087 Y33.61 I0.05 J0.062
    N3433 G03 X35.053 Y33.626 I-0.05 J-0.062
    N3434 G01 X35.029 Y33.631
    N3435 G01 X34.873 Y33.656
    N3436 G01 X34.707 Y33.73
    N3437 G01 X34.506 Y33.734
    N3438 G01 X34.3 Y33.649
    N3439 G01 X34.12 Y33.464
    N3440 G01 X34.052 Y32.936
    N3441 G01 X33.987 Y32.256
    N3442 G01 X33.944 Y31.535
    N3443 G01 X33.919 Y30.814
    N3444 G01 X33.904 Y30.092
    N3445 G01 X33.896 Y29.37
    N3446 G01 X33.891 Y28.648
    N3447 G01 X33.888 Y27.926
    N3448 G01 X33.886 Y26.482
    N3449 G01 X33.885 Y20.706
    N3450 G01 Y15.381
    N3451 G01 X33.886 Y15.357
    N3452 G03 X34.046 Y15.363 I0.08 J0.003
    N3453 G03 X33.921 Y15.426 I-0.08 J-0.003
    N3454 G01 X33.261 Y14.973
    N3455 G03 X33.351 Y14.841 I0.045 J-0.066
    N3456 G03 X33.384 Y14.889 I-0.045 J0.066
    N3457 G01 X33.389 Y14.913
    N3458 G01 X33.395 Y14.941
    N3459 G01 X33.538 Y15.214
    N3460 G01 X33.553 Y15.413
    N3461 G01 X33.48 Y15.622
    N3462 G01 X33.274 Y15.685
    N3463 G01 X33.065 Y15.741
    N3464 G01 X32.806 Y15.801
    N3465 G01 X32.492 Y15.862
    N3466 G01 X32.128 Y15.919
    N3467 G01 X31.649 Y15.977
    N3468 G01 X30.985 Y16.034
    N3469 G01 X30.264 Y16.071
    N3470 G01 X29.542 Y16.091
    N3471 G01 X28.82 Y16.102
    N3472 G01 X28.098 Y16.108
    N3473 G01 X27.376 Y16.111
    N3474 G01 X25.932 Y16.114
    N3475 G01 X20.878 Y16.115
    N3476 G01 X17.178
    N3477 G01 X17.088 Y16.112
    N3478 G03 X17.109 Y15.512 I0.01 J-0.3
    N3479 G03 X17.386 Y15.897 I-0.01 J0.3
    N3480 G01 X17.032 Y17.092
    N3481 G03 X16.457 Y16.921 I-0.288 J-0.085
    N3482 G03 X16.639 Y16.725 I0.288 J0.085
    N3483 G03 X16.665 Y16.717 I0.105 J0.281
    N3484 G01 X16.752 Y16.693
    N3485 G01 X16.78 Y16.687
    N3486 G01 X17.046 Y16.535
    N3487 G01 X17.245 Y16.514
    N3488 G01 X17.456 Y16.579
    N3489 G01 X17.517 Y16.759
    N3490 G01 X17.581 Y16.978
    N3491 G01 X17.642 Y17.211
    N3492 G01 X17.703 Y17.487
    N3493 G01 X17.766 Y17.829
    N3494 G01 X17.826 Y18.228
    N3495 G01 X17.885 Y18.757
    N3496 G01 X17.941 Y19.477
    N3497 G01 X17.972 Y20.198
    N3498 G01 X17.991 Y20.92
    N3499 G01 X18.001 Y21.642
    N3500 G01 X18.007 Y22.364
    N3501 G01 X18.01 Y23.086
    N3502 G01 X18.013 Y24.53
    N3503 G01 X18.015 Y28.14
    N3504 G01 Y33.465
    N3505 G01 X18.035 Y33.505
    N3506 G01 X18.07 Y33.533
    N3507 G01 X18.115 Y33.542
    N3508 G01 X18.814 Y33.364
    N3509 G01 X18.975 Y33.315
    N3510 G01 X19.167 Y33.265
    N3511 G01 X19.4 Y33.213
    N3512 G01 X19.67 Y33.162
    N3513 G01 X20.021 Y33.109
    N3514 G01 X20.475 Y33.057
    N3515 G01 X21.144 Y33.004
    N3516 G01 X21.866 Y32.972
    N3517 G01 X22.587 Y32.955
    N3518 G01 X23.309 Y32.946
    N3519 G01 X24.031 Y32.941
    N3520 G01 X24.753 Y32.938
    N3521 G01 X26.197 Y32.936
    N3522 G01 X33.417 Y32.935
    N3523 G01 X33.458 Y32.915
    N3524 G01 X33.485 Y32.88
    N3525 G01 X33.495 Y32.835
    N3526 G01 X33.316 Y32.136
    N3527 G01 X33.268 Y31.956
    N3528 G01 X33.219 Y31.744
    N3529 G01 X33.168 Y31.483
    N3530 G01 X33.117 Y31.162
    N3531 G01 X33.065 Y30.736
    N3532 G01 X33.013 Y30.138
    N3533 G01 X32.976 Y29.417
    N3534 G01 X32.957 Y28.695
    N3535 G01 X32.946 Y27.973
    N3536 G01 X32.941 Y27.251
    N3537 G01 X32.938 Y26.529
    N3538 G01 X32.936 Y25.085
    N3539 G01 X32.935 Y18.587
    N3540 G01 Y16.331
    N3541 G01 X32.936 Y16.307
    N3542 G03 X33.096 Y16.313 I0.08 J0.003
    N3543 G03 X32.968 Y16.374 I-0.08 J-0.003
    N3544 G01 X32.361 Y15.921
    N3545 G03 X32.457 Y15.792 I0.048 J-0.064
    N3546 G03 X32.487 Y15.839 I-0.048 J0.064
    N3547 G01 X32.492 Y15.862
    N3548 G01 X32.498 Y15.89
    N3549 G01 X32.64 Y16.164
    N3550 G01 X32.654 Y16.363
    N3551 G01 X32.58 Y16.572
    N3552 G01 X32.375 Y16.634
    N3553 G01 X32.154 Y16.693
    N3554 G01 X31.897 Y16.752
    N3555 G01 X31.574 Y16.814
    N3556 G01 X31.206 Y16.871
    N3557 G01 X30.712 Y16.929
    N3558 G01 X30.024 Y16.987
    N3559 G01 X29.302 Y17.021
    N3560 G01 X28.581 Y17.041
    N3561 G01 X27.859 Y17.052
    N3562 G01 X27.137 Y17.058
    N3563 G01 X26.415 Y17.061
    N3564 G01 X24.971 Y17.064
    N3565 G01 X20.639 Y17.065
    N3566 G01 X18.202
    N3567 G01 X18.112 Y17.062
    N3568 G03 X18.133 Y16.462 I0.01 J-0.3
    N3569 G03 X18.4 Y16.877 I-0.01 J0.3
    N3570 G01 X17.968 Y17.915
    N3571 G03 X17.414 Y17.685 I-0.277 J-0.115
    N3572 G03 X17.616 Y17.51 I0.277 J0.115
    N3573 G01 X17.703 Y17.487
    N3574 G01 X17.835 Y17.458
    N3575 G01 X17.986 Y17.366
    N3576 G01 X18.181 Y17.338
    N3577 G01 X18.392 Y17.396
    N3578 G01 X18.587 Y17.553
    N3579 G01 X18.665 Y17.953
    N3580 G01 X18.737 Y18.404
    N3581 G01 X18.807 Y18.971
    N3582 G01 X18.869 Y19.691
    N3583 G01 X18.908 Y20.412
    N3584 G01 X18.931 Y21.133
    N3585 G01 X18.945 Y21.855
    N3586 G01 X18.953 Y22.577
    N3587 G01 X18.958 Y23.299
    N3588 G01 X18.961 Y24.021
    N3589 G01 X18.964 Y25.465
    N3590 G01 X18.965 Y29.797
    N3591 G01 Y32.775
    N3592 G01 X18.964 Y32.799
    N3593 G03 X18.804 Y32.794 I-0.08 J-0.003
    N3594 G03 X18.93 Y32.731 I0.08 J0.003
    N3595 G01 X19.529 Y33.151
    N3596 G03 X19.437 Y33.282 I-0.046 J0.066
    N3597 G03 X19.406 Y33.236 I0.046 J-0.066
    N3598 G01 X19.4 Y33.213
    N3599 G01 X19.393 Y33.185
    N3600 G01 X19.245 Y32.917
    N3601 G01 X19.225 Y32.719
    N3602 G01 X19.293 Y32.508
    N3603 G01 X19.462 Y32.316
    N3604 G01 X19.898 Y32.239
    N3605 G01 X20.391 Y32.169
    N3606 G01 X21.003 Y32.105
    N3607 G01 X21.723 Y32.055
    N3608 G01 X22.444 Y32.025
    N3609 G01 X23.166 Y32.008
    N3610 G01 X23.888 Y31.998
    N3611 G01 X24.61 Y31.992
    N3612 G01 X25.332 Y31.989
    N3613 G01 X26.776 Y31.986
    N3614 G01 X31.108 Y31.985
    N3615 G01 X32.732
    N3616 G01 X32.822 Y31.988
    N3617 G03 X32.802 Y32.588 I-0.01 J0.3
    N3618 G03 X32.528 Y32.192 I0.01 J-0.3
    N3619 G01 X32.903 Y31.075
    N3620 G03 X33.472 Y31.266 I0.284 J0.096
    N3621 G03 X33.282 Y31.455 I-0.284 J-0.096
    N3622 G03 X33.255 Y31.462 I-0.094 J-0.285
    N3623 G01 X33.168 Y31.483
    N3624 G01 X33.14 Y31.488
    N3625 G01 X32.866 Y31.63
    N3626 G01 X32.667 Y31.644
    N3627 G01 X32.459 Y31.57
    N3628 G01 X32.399 Y31.374
    N3629 G01 X32.344 Y31.163
    N3630 G01 X32.285 Y30.901
    N3631 G01 X32.227 Y30.594
    N3632 G01 X32.17 Y30.223
    N3633 G01 X32.114 Y29.741
    N3634 G01 X32.058 Y29.055
    N3635 G01 X32.025 Y28.334
    N3636 G01 X32.007 Y27.612
    N3637 G01 X31.997 Y26.891
    N3638 G01 X31.991 Y26.169
    N3639 G01 X31.988 Y25.447
    N3640 G01 X31.986 Y24.003
    N3641 G01 X31.985 Y18.949
    N3642 G01 Y17.324
    N3643 G01 X31.986 Y17.3
    N3644 G03 X32.146 Y17.306 I0.08 J0.003
    N3645 G03 X32.014 Y17.364 I-0.08 J-0.003
    N3646 G01 X31.438 Y16.869
    N3647 G03 X31.543 Y16.747 I0.052 J-0.061
    N3648 G03 X31.568 Y16.79 I-0.052 J0.061
    N3649 G01 X31.574 Y16.814
    N3650 G01 X31.599 Y16.947
    N3651 G01 X31.687 Y17.101
    N3652 G01 X31.709 Y17.297
    N3653 G01 X31.645 Y17.506
    N3654 G01 X31.456 Y17.566
    N3655 G01 X31.244 Y17.626
    N3656 G01 X31.012 Y17.682
    N3657 G01 X30.719 Y17.742
    N3658 G01 X30.38 Y17.799
    N3659 G01 X29.935 Y17.858
    N3660 G01 X29.353 Y17.915
    N3661 G01 X28.632 Y17.959
    N3662 G01 X27.911 Y17.984
    N3663 G01 X27.189 Y17.998
    N3664 G01 X26.467 Y18.005
    N3665 G01 X25.745 Y18.01
    N3666 G01 X25.023 Y18.012
    N3667 G01 X23.579 Y18.014
    N3668 G01 X20.691 Y18.015
    N3669 G01 X19.337
    N3670 G01 X19.247
    N3671 G01 X19.157 Y18.012
    N3672 G03 X19.178 Y17.412 I0.01 J-0.3
    N3673 G03 X19.44 Y17.837 I-0.01 J0.3
    N3674 G01 X18.979 Y18.841
    N3675 G03 X18.433 Y18.591 I-0.273 J-0.125
    N3676 G03 X18.649 Y18.421 I0.273 J0.125
    N3677 G01 X18.737 Y18.404
    N3678 G01 X18.872 Y18.383
    N3679 G01 X19.03 Y18.3
    N3680 G01 X19.228 Y18.285
    N3681 G01 X19.437 Y18.357
    N3682 G01 X19.493 Y18.544
    N3683 G01 X19.549 Y18.762
    N3684 G01 X19.609 Y19.034
    N3685 G01 X19.666 Y19.342
    N3686 G01 X19.727 Y19.746
    N3687 G01 X19.784 Y20.257
    N3688 G01 X19.84 Y20.977
    N3689 G01 X19.872 Y21.699
    N3690 G01 X19.89 Y22.42
    N3691 G01 X19.9 Y23.142
    N3692 G01 X19.906 Y23.864
    N3693 G01 X19.91 Y24.586
    N3694 G01 X19.913 Y26.03
    N3695 G01 X19.915 Y29.64
    N3696 G01 Y31.671
    N3697 G01 X19.912 Y31.761
    N3698 G03 X19.91 Y31.788 I-0.3 J-0.01
    N3699 G03 X19.314 Y31.712 I-0.298 J-0.038
    N3700 G03 X19.728 Y31.473 I0.298 J0.038
    N3701 G01 X20.818 Y31.929
    N3702 G03 X20.586 Y32.482 I-0.116 J0.277
    N3703 G03 X20.407 Y32.258 I0.116 J-0.277
    N3704 G01 X20.391 Y32.169
    N3705 G01 X20.387 Y32.141
    N3706 G01 X20.259 Y31.861
    N3707 G01 X20.255 Y31.66
    N3708 G01 X20.339 Y31.453
    N3709 G01 X20.549 Y31.398
    N3710 G01 X20.792 Y31.342
    N3711 G01 X21.1 Y31.283
    N3712 G01 X21.458 Y31.228
    N3713 G01 X21.943 Y31.17
    N3714 G01 X22.626 Y31.113
    N3715 G01 X23.347 Y31.079
    N3716 G01 X24.069 Y31.06
    N3717 G01 X24.791 Y31.049
    N3718 G01 X25.513 Y31.043
    N3719 G01 X26.235 Y31.039
    N3720 G01 X27.679 Y31.036
    N3721 G01 X30.567 Y31.035
    N3722 G01 X31.74
    N3723 G01 X31.83 Y31.038
    N3724 G03 X31.809 Y31.638 I-0.01 J0.3
    N3725 G03 X31.541 Y31.225 I0.01 J-0.3
    N3726 G01 X31.97 Y30.169
    N3727 G03 X32.526 Y30.395 I0.278 J0.113
    N3728 G03 X32.314 Y30.574 I-0.278 J-0.113
    N3729 G01 X32.227 Y30.594
    N3730 G01 X32.198 Y30.599
    N3731 G01 X31.924 Y30.74
    N3732 G01 X31.724 Y30.754
    N3733 G01 X31.516 Y30.679
    N3734 G01 X31.454 Y30.474
    N3735 G01 X31.395 Y30.248
    N3736 G01 X31.338 Y29.992
    N3737 G01 X31.277 Y29.665
    N3738 G01 X31.221 Y29.292
    N3739 G01 X31.163 Y28.787
    N3740 G01 X31.106 Y28.073
    N3741 G01 X31.074 Y27.351
    N3742 G01 X31.057 Y26.63
    N3743 G01 X31.047 Y25.908
    N3744 G01 X31.042 Y25.186
    N3745 G01 X31.039 Y24.464
    N3746 G01 X31.036 Y23.02
    N3747 G01 X31.035 Y18.237
    N3748 G01 X31.036 Y18.213
    N3749 G03 X31.196 Y18.218 I0.08 J0.003
    N3750 G03 X31.059 Y18.272 I-0.08 J-0.003
    N3751 G01 X30.579 Y17.794
    N3752 G03 X30.692 Y17.681 I0.056 J-0.057
    N3753 G03 X30.713 Y17.719 I-0.056 J0.057
    N3754 G01 X30.719 Y17.742
    N3755 G01 X30.75 Y17.896
    N3756 G01 X30.832 Y18.056
    N3757 G01 X30.844 Y18.255
    N3758 G01 X30.769 Y18.465
    N3759 G01 X30.593 Y18.652
    N3760 G01 X30.128 Y18.728
    N3761 G01 X29.588 Y18.797
    N3762 G01 X28.869 Y18.864
    N3763 G01 X28.148 Y18.905
    N3764 G01 X27.427 Y18.929
    N3765 G01 X26.705 Y18.944
    N3766 G01 X25.983 Y18.953
    N3767 G01 X25.261 Y18.958
    N3768 G01 X24.539 Y18.961
    N3769 G01 X23.095 Y18.964
    N3770 G01 X21.651 Y18.966
    N3771 G01 X20.929 Y18.963
    N3772 G01 X20.749 Y18.965
    N3773 G01 X20.162
    N3774 G01 X20.072 Y18.961
    N3775 G03 X20.094 Y18.362 I0.011 J-0.3
    N3776 G03 X20.357 Y18.783 I-0.011 J0.3
    N3777 G01 X19.918 Y19.776
    N3778 G03 X19.369 Y19.533 I-0.274 J-0.121
    N3779 G03 X19.579 Y19.361 I0.274 J0.121
    N3780 G01 X19.666 Y19.342
    N3781 G01 X19.8 Y19.317
    N3782 G01 X19.956 Y19.23
    N3783 G01 X20.153 Y19.21
    N3784 G01 X20.361 Y19.276
    N3785 G01 X20.551 Y19.44
    N3786 G01 X20.621 Y19.86
    N3787 G01 X20.691 Y20.383
    N3788 G01 X20.755 Y21.052
    N3789 G01 X20.8 Y21.773
    N3790 G01 X20.826 Y22.495
    N3791 G01 X20.842 Y23.216
    N3792 G01 X20.851 Y23.938
    N3793 G01 X20.857 Y24.66
    N3794 G01 X20.86 Y25.382
    N3795 G01 X20.863 Y26.826
    N3796 G01 X20.865 Y29.714
    N3797 G01 Y30.752
    N3798 G01 X20.862 Y30.842
    N3799 G03 X20.859 Y30.87 I-0.3 J-0.011
    N3800 G03 X20.264 Y30.793 I-0.298 J-0.038
    N3801 G03 X20.708 Y30.569 I0.298 J0.038
    N3802 G01 X21.558 Y31.042
    N3803 G03 X21.267 Y31.567 I-0.146 J0.262
    N3804 G03 X21.12 Y31.371 I0.146 J-0.262
    N3805 G01 X21.1 Y31.283
    N3806 G01 X21.062 Y31.087
    N3807 G01 X21. Y30.912
    N3808 G01 X21.013 Y30.707
    N3809 G01 X21.118 Y30.502
    N3810 G01 X21.33 Y30.328
    N3811 G01 X21.96 Y30.25
    N3812 G01 X22.679 Y30.186
    N3813 G01 X23.4 Y30.146
    N3814 G01 X24.122 Y30.122
    N3815 G01 X24.844 Y30.107
    N3816 G01 X25.565 Y30.098
    N3817 G01 X26.287 Y30.092
    N3818 G01 X27.009 Y30.089
    N3819 G01 X28.453 Y30.086
    N3820 G01 X29.175 Y30.084
    N3821 G01 X29.897 Y30.089
    N3822 G01 X30.258 Y30.083
    N3823 G01 X30.71 Y30.086
    N3824 G01 X30.8 Y30.085
    N3825 G01 X30.824 Y30.086
    N3826 G03 X30.819 Y30.246 I-0.003 J0.08
    N3827 G03 X30.758 Y30.117 I0.003 J-0.08
    N3828 G01 X31.22 Y29.532
    N3829 G03 X31.346 Y29.631 I0.063 J0.05
    N3830 G03 X31.3 Y29.66 I-0.063 J-0.05
    N3831 G01 X31.277 Y29.665
    N3832 G01 X31.249 Y29.67
    N3833 G01 X30.974 Y29.811
    N3834 G01 X30.774 Y29.823
    N3835 G01 X30.566 Y29.748
    N3836 G01 X30.505 Y29.544
    N3837 G01 X30.444 Y29.31
    N3838 G01 X30.387 Y29.054
    N3839 G01 X30.327 Y28.726
    N3840 G01 X30.27 Y28.348
    N3841 G01 X30.212 Y27.834
    N3842 G01 X30.155 Y27.114
    N3843 G01 X30.124 Y26.393
    N3844 G01 X30.107 Y25.671
    N3845 G01 X30.097 Y24.949
    N3846 G01 X30.092 Y24.227
    N3847 G01 X30.089 Y23.505
    N3848 G01 X30.086 Y22.061
    N3849 G01 X30.084 Y20.617
    N3850 G01 X30.087 Y19.896
    N3851 G01 X30.085 Y19.535
    N3852 G01 Y19.354
    N3853 G01 X30.065 Y19.313
    N3854 G01 X30.03 Y19.286
    N3855 G01 X29.985 Y19.277
    N3856 G01 X29.286 Y19.455
    N3857 G01 X29.138 Y19.503
    N3858 G01 X28.962 Y19.553
    N3859 G01 X28.75 Y19.605
    N3860 G01 X28.507 Y19.655
    N3861 G01 X28.202 Y19.708
    N3862 G01 X27.812 Y19.761
    N3863 G01 X27.274 Y19.815
    N3864 G01 X26.554 Y19.861
    N3865 G01 X25.832 Y19.886
    N3866 G01 X25.11 Y19.899
    N3867 G01 X24.389 Y19.906
    N3868 G01 X23.667 Y19.91
    N3869 G01 X22.945 Y19.912
    N3870 G01 X22.223 Y19.918
    N3871 G01 X21.862 Y19.913
    N3872 G01 X21.681 Y19.915
    N3873 G01 X21.275 Y19.914
    N3874 G01 X21.234 Y19.934
    N3875 G01 X21.207 Y19.969
    N3876 G01 X21.197 Y20.014
    N3877 G01 X21.373 Y20.714
    N3878 G01 X21.422 Y20.875
    N3879 G01 X21.473 Y21.069
    N3880 G01 X21.525 Y21.296
    N3881 G01 X21.577 Y21.566
    N3882 G01 X21.631 Y21.914
    N3883 G01 X21.684 Y22.36
    N3884 G01 X21.738 Y23.009
    N3885 G01 X21.773 Y23.73
    N3886 G01 X21.792 Y24.452
    N3887 G01 X21.802 Y25.174
    N3888 G01 X21.808 Y25.895
    N3889 G01 X21.811 Y26.617
    N3890 G01 X21.813 Y27.339
    N3891 G01 X21.817 Y28.061
    N3892 G01 X21.808 Y28.783
    N3893 G01 X21.819 Y29.144
    N3894 G01 X21.816 Y29.325
    N3895 G01 X21.815 Y29.641
    N3896 G01 X21.835 Y29.681
    N3897 G01 X21.871 Y29.709
    N3898 G01 X21.915 Y29.718
    N3899 G01 X22.615 Y29.54
    N3900 G01 X22.791 Y29.49
    N3901 G01 X22.993 Y29.441
    N3902 G01 X23.235 Y29.39
    N3903 G01 X23.542 Y29.338
    N3904 G01 X23.925 Y29.286
    N3905 G01 X24.46 Y29.233
    N3906 G01 X25.18 Y29.187
    N3907 G01 X25.902 Y29.163
    N3908 G01 X26.624 Y29.15
    N3909 G01 X27.345 Y29.144
    N3910 G01 X28.067 Y29.139
    N3911 G01 X28.789 Y29.131
    N3912 G01 X29.15 Y29.137
    N3913 G01 X29.331 Y29.136
    N3914 G01 X29.827 Y29.138
    N3915 G03 X29.941 Y29.165 I-0.011 J0.3
    N3916 G01 X30.002 Y29.192 Z14.962
    N3917 G01 X30.06 Y29.219 Z14.94
    N3918 G01 X30.111 Y29.242 Z14.905
    N3919 G01 X30.154 Y29.262 Z14.857
    N3920 G01 X30.187 Y29.277 Z14.8
    N3921 G01 X30.207 Y29.286 Z14.737
    N3922 G01 X30.214 Y29.289 Z14.67
    N3923 G00 Z-3.01
    N3924 G00 X21.093 Y20.27
    N3925 G00 Z14.37
    N3926 G01 Z14.67 F1500
    N3927 G01 X21.086 Y20.272 Z14.737
    N3928 G01 X21.064 Y20.278 Z14.8
    N3929 G01 X21.03 Y20.288 Z14.857
    N3930 G01 X20.984 Y20.3 Z14.905
    N3931 G01 X20.929 Y20.316 Z14.94
    N3932 G01 X20.868 Y20.333 Z14.962
    N3933 G01 X20.804 Y20.351 Z14.97
    N3934 G01 X20.691 Y20.383
    N3935 G01 X21.333 Y20.298
    N3936 G01 X21.621 Y20.157
    N3937 G01 X21.83 Y20.147
    N3938 G01 X22.049 Y20.23
    N3939 G01 X22.252 Y20.426
    N3940 G01 X22.351 Y20.844
    N3941 G01 X22.438 Y21.28
    N3942 G01 X22.522 Y21.792
    N3943 G01 X22.597 Y22.381
    N3944 G01 X22.664 Y23.1
    N3945 G01 X22.705 Y23.821
    N3946 G01 X22.729 Y24.542
    N3947 G01 X22.744 Y25.264
    N3948 G01 X22.753 Y25.986
    N3949 G01 X22.758 Y26.708
    N3950 G01 X22.77 Y27.43
    N3951 G01 X22.752 Y28.152
    N3952 G01 X22.761 Y28.332
    N3953 G01 X22.76 Y28.512
    N3954 G01 X22.759 Y28.693
    N3955 G01 X22.763 Y28.918
    N3956 G03 X22.163 Y28.912 I-0.3 J-0.003
    N3957 G03 X22.488 Y28.616 I0.3 J0.003
    N3958 G01 X30.51 Y29.272
    N3959 G02 X30.559 Y28.674 I0.024 J-0.299
    N3960 G02 X30.438 Y28.688 I-0.024 J0.299
    N3961 G01 X30.327 Y28.726
    N3962 G01 X30.298 Y28.731
    N3963 G01 X30.023 Y28.872
    N3964 G01 X29.824 Y28.884
    N3965 G01 X29.615 Y28.809
    N3966 G01 X29.555 Y28.605
    N3967 G01 X29.493 Y28.368
    N3968 G01 X29.437 Y28.112
    N3969 G01 X29.376 Y27.784
    N3970 G01 X29.319 Y27.401
    N3971 G01 X29.261 Y26.883
    N3972 G01 X29.205 Y26.163
    N3973 G01 X29.174 Y25.442
    N3974 G01 X29.157 Y24.72
    N3975 G01 X29.147 Y23.998
    N3976 G01 X29.142 Y23.276
    N3977 G01 X29.139 Y22.554
    N3978 G01 X29.131 Y21.832
    N3979 G01 X29.147 Y21.11
    N3980 G01 X29.128 Y20.75
    N3981 G01 X29.134 Y20.569
    N3982 G01 X29.137 Y20.028
    N3983 G01 X29.14 Y19.938
    N3984 G03 X29.74 Y19.96 I0.3 J0.011
    N3985 G03 X29.341 Y20.232 I-0.3 J-0.011
    N3986 G01 X28.339 Y19.883
    N3987 G03 X28.536 Y19.316 I0.099 J-0.283
    N3988 G03 X28.726 Y19.518 I-0.099 J0.283
    N3989 G01 X28.75 Y19.605
    N3990 G01 X28.783 Y19.735
    N3991 G01 X28.877 Y19.884
    N3992 G01 X28.908 Y20.079
    N3993 G01 X28.853 Y20.291
    N3994 G01 X28.699 Y20.489
    N3995 G01 X28.35 Y20.56
    N3996 G01 X27.895 Y20.636
    N3997 G01 X27.4 Y20.7
    N3998 G01 X26.729 Y20.763
    N3999 G01 X26.008 Y20.806
    N4000 G01 X25.287 Y20.831
    N4001 G01 X24.567 Y20.889
    N4002 G01 X24.212 Y20.821
    N4003 G01 X23.687 Y20.901
    N4004 G01 X23.512 Y20.855
    N4005 G01 X23.332 Y20.859
    N4006 G01 X23.061 Y20.862
    N4007 G01 X22.926 Y20.863
    N4008 G03 X22.811 Y20.837 I0.009 J-0.3
    N4009 G01 X22.75 Y20.809 Z14.962
    N4010 G01 X22.693 Y20.783 Z14.94
    N4011 G01 X22.641 Y20.76 Z14.905
    N4012 G01 X22.597 Y20.741 Z14.857
    N4013 G01 X22.565 Y20.726 Z14.8
    N4014 G01 X22.545 Y20.717 Z14.737
    N4015 G01 X22.538 Y20.714 Z14.67
    N4016 G00 Z-3.01
    N4017 G00 X23.378 Y29.783
    N4018 G00 Z14.37
    N4019 G01 Z14.67 F1500
    N4020 G01 X23.375 Y29.776 Z14.737
    N4021 G01 X23.368 Y29.755 Z14.8
    N4022 G01 X23.355 Y29.722 Z14.857
    N4023 G01 X23.339 Y29.677 Z14.905
    N4024 G01 X23.32 Y29.624 Z14.94
    N4025 G01 X23.298 Y29.564 Z14.962
    N4026 G01 X23.276 Y29.501 Z14.97
    N4027 G01 X23.235 Y29.39
    N4028 G01 X23.23 Y29.363
    N4029 G01 X23.085 Y29.091
    N4030 G01 X23.068 Y28.892
    N4031 G01 X23.139 Y28.683
    N4032 G01 X23.32 Y28.626
    N4033 G01 X23.532 Y28.568
    N4034 G01 X23.796 Y28.505
    N4035 G01 X24.081 Y28.448
    N4036 G01 X24.44 Y28.39
    N4037 G01 X24.886 Y28.333
    N4038 G01 X25.505 Y28.276
    N4039 G01 X26.226 Y28.235
    N4040 G01 X26.947 Y28.213
    N4041 G01 X27.667 Y28.158
    N4042 G01 X28.022 Y28.226
    N4043 G01 X28.289 Y28.184
    N4044 G01 X28.469 Y28.183
    N4045 G01 X28.83 Y28.181
    N4046 G01 X28.92 Y28.182
    N4047 G03 X29.034 Y28.212 I-0.017 J0.3
    N4048 G01 X29.094 Y28.241 Z14.962
    N4049 G01 X29.151 Y28.268 Z14.94
    N4050 G01 X29.202 Y28.293 Z14.905
    N4051 G01 X29.245 Y28.313 Z14.857
    N4052 G01 X29.277 Y28.329 Z14.8
    N4053 G01 X29.297 Y28.338 Z14.737
    N4054 G01 X29.304 Y28.342 Z14.67
    N4055 G00 Z-3.01
    N4056 G00 X22.044 Y21.42
    N4057 G00 Z14.37
    N4058 G01 Z14.67 F1500
    N4059 G01 X22.052 Y21.417 Z14.737
    N4060 G01 X22.072 Y21.41 Z14.8
    N4061 G01 X22.106 Y21.398 Z14.857
    N4062 G01 X22.151 Y21.382 Z14.905
    N4063 G01 X22.205 Y21.363 Z14.94
    N4064 G01 X22.264 Y21.342 Z14.962
    N4065 G01 X22.327 Y21.32 Z14.97
    N4066 G01 X22.438 Y21.28
    N4067 G01 X22.467 Y21.275
    N4068 G01 X22.739 Y21.131
    N4069 G01 X22.939 Y21.115
    N4070 G01 X23.15 Y21.187
    N4071 G01 X23.341 Y21.361
    N4072 G01 X23.428 Y21.849
    N4073 G01 X23.508 Y22.409
    N4074 G01 X23.579 Y23.079
    N4075 G01 X23.63 Y23.799
    N4076 G01 X23.663 Y24.52
    N4077 G01 X23.683 Y25.242
    N4078 G01 X23.696 Y25.964
    N4079 G01 X23.723 Y26.686
    N4080 G01 X23.679 Y27.406
    N4081 G01 X23.692 Y27.496
    N4082 G01 X23.7 Y27.585
    N4083 G01 X23.708 Y27.766
    N4084 G01 X23.706 Y27.946
    N4085 G03 X23.107 Y27.917 I-0.3 J-0.015
    N4086 G03 X23.44 Y27.634 I0.3 J0.015
    N4087 G01 X29.55 Y28.329
    N4088 G02 X29.618 Y27.732 I0.034 J-0.298
    N4089 G02 X29.488 Y27.746 I-0.034 J0.298
    N4090 G01 X29.376 Y27.784
    N4091 G01 X29.242 Y27.809
    N4092 G01 X29.087 Y27.896
    N4093 G01 X28.891 Y27.916
    N4094 G01 X28.682 Y27.85
    N4095 G01 X28.493 Y27.686
    N4096 G01 X28.423 Y27.272
    N4097 G01 X28.355 Y26.753
    N4098 G01 X28.291 Y26.092
    N4099 G01 X28.247 Y25.371
    N4100 G01 X28.221 Y24.649
    N4101 G01 X28.206 Y23.928
    N4102 G01 X28.197 Y23.206
    N4103 G01 X28.177 Y22.484
    N4104 G01 X28.209 Y21.763
    N4105 G01 X28.201 Y21.673
    N4106 G01 X28.197 Y21.583
    N4107 G01 X28.193 Y21.402
    N4108 G01 X28.194 Y21.267
    N4109 G01 Y21.222
    N4110 G01 X28.174 Y21.181
    N4111 G01 X28.138 Y21.154
    N4112 G01 X28.094 Y21.145
    N4113 G01 X27.395 Y21.327
    N4114 G01 X27.242 Y21.379
    N4115 G01 X27.078 Y21.428
    N4116 G01 X26.882 Y21.479
    N4117 G01 X26.641 Y21.533
    N4118 G01 X25.931 Y21.665
    N4119 G01 X25.611 Y21.786
    N4120 G01 X24.89 Y21.753
    N4121 G01 X24.717 Y21.807
    N4122 G01 X24.533 Y21.823
    N4123 G01 X24.443 Y21.816
    N4124 G01 X24.353 Y21.805
    N4125 G01 X24.174 Y21.779
    N4126 G01 X24.13 Y21.787
    N4127 G01 X24.094 Y21.814
    N4128 G01 X24.074 Y21.854
    N4129 G01 X24.073 Y21.9
    N4130 G01 X24.381 Y22.553
    N4131 G01 X24.448 Y22.996
    N4132 G01 X24.514 Y23.568
    N4133 G01 X24.572 Y24.288
    N4134 G01 X24.608 Y25.009
    N4135 G01 X24.637 Y25.731
    N4136 G01 X24.667 Y26.452
    N4137 G01 X24.686 Y27.174
    N4138 G01 X24.658 Y27.259
    N4139 G01 X24.648 Y27.349
    N4140 G01 X24.649 Y27.439
    N4141 G01 X24.655 Y27.71
    N4142 G01 X24.675 Y27.75
    N4143 G01 X24.711 Y27.778
    N4144 G01 X24.755 Y27.786
    N4145 G01 X25.452 Y27.598
    N4146 G01 X26.152 Y27.42
    N4147 G01 X26.424 Y27.284
    N4148 G01 X27.145 Y27.244
    N4149 G01 X27.45 Y27.222
    N4150 G01 X27.863 Y27.198
    N4151 G01 X27.948 Y27.229
    N4152 G03 X27.722 Y27.785 I-0.113 J0.278
    N4153 G03 X27.535 Y27.518 I0.113 J-0.278
    N4154 G01 X27.301 Y20.705
    N4155 G03 X27.895 Y20.636 I0.3 J-0.01
    N4156 G01 X28.028 Y21.434
    N4157 G01 X28.085 Y21.62
    N4158 G01 X28.061 Y21.834
    N4159 G01 X27.937 Y22.051
    N4160 G01 X27.663 Y22.256
    N4161 G01 X26.959 Y22.415
    N4162 G01 X26.304 Y22.607
    N4163 G01 X26.259 Y22.602
    N4164 G01 X25.54 Y22.664
    N4165 G01 X25.446 Y22.684
    N4166 G01 X25.356 Y22.696
    N4167 G01 X25.176 Y22.709
    N4168 G01 X25.131
    N4169 G01 X25.086 Y22.713
    N4170 G01 X25.048 Y22.737
    N4171 G01 X25.024 Y22.776
    N4172 G01 X25.019 Y22.82
    N4173 G01 X25.268 Y23.498
    N4174 G01 X25.327 Y23.773
    N4175 G01 X25.387 Y24.113
    N4176 G01 X25.487 Y24.828
    N4177 G01 X25.597 Y25.213
    N4178 G01 X25.55 Y25.571
    N4179 G01 X25.649 Y26.16
    N4180 G01 X25.606 Y26.335
    N4181 G01 X25.618 Y26.515
    N4182 G01 X25.629 Y26.876
    N4183 G01 X25.631 Y26.966
    N4184 G03 X24.977 Y27.553 I-0.595 J-0.005
    N4185 G03 X24.453 Y26.847 I0.06 J-0.592
    N4186 G01 X25.482 Y21.569
    N4187 G03 X26.641 Y21.533 I0.584 J0.114
    N4188 G01 X26.955 Y22.942
    N4189 G01 X26.917 Y23.159
    N4190 G01 X26.783 Y23.362
    N4191 G01 X26.554 Y23.512
    N4192 G01 X26.376 Y23.543
    N4193 G01 X26.016 Y23.576
    N4194 G01 X25.926 Y23.584
    N4195 G01 X25.888 Y23.607
    N4196 G01 X25.863 Y23.645
    N4197 G01 X25.858 Y23.69
    N4198 G01 X25.873 Y23.732
    N4199 G01 X26.283 Y24.138
    N4200 G01 X26.431 Y24.505
    N4201 G01 X26.426 Y24.686
    N4202 G01 X26.562 Y25.104
    N4203 G01 X26.527 Y25.463
    N4204 G01 X26.52 Y26.185
    N4205 G01 X26.544 Y26.316
    N4206 G01 X26.563 Y26.495
    N4207 G01 X26.572 Y26.675
    N4208 G01 X26.593 Y26.715
    N4209 G01 X26.63 Y26.741
    N4210 G01 X26.674 Y26.749
    N4211 G01 X26.717 Y26.736
    N4212 G01 X27.12 Y26.366
    N4213 G01 X27.469 Y26.245
    N4214 G01 X27.559 Y26.251
    N4215 G01 X27.65
    N4216 G01 X27.69 Y26.231
    N4217 G01 X27.717 Y26.195
    N4218 G01 X27.726 Y26.151
    N4219 G01 X27.715 Y26.107
    N4220 G01 X27.383 Y25.725
    N4221 G01 X27.27 Y25.366
    N4222 G01 X27.308 Y25.007
    N4223 G01 X27.221 Y24.381
    N4224 G01 X27.27 Y24.207
    N4225 G01 X27.228 Y23.486
    N4226 G01 X27.266 Y23.127
    N4227 G01 X27.255 Y23.038
    N4228 G01 X27.247 Y22.948
    N4229 G01 Y22.933 Z14.969
    N4230 G01 X27.254 Y22.893 Z14.956
    N4231 G01 X27.259 Y22.861 Z14.93
    N4232 G01 X27.263 Y22.839 Z14.894
    N4233 G01 X27.264 Y22.832 Z14.852
    N4234 G00 Z-3.01
    N4235 G00 X9.706 Y6.562
    N4236 G00 Z18.9
    N4237 G01 Z19.2 F1500
    N4238 G01 X9.708 Y6.57 Z19.267
    N4239 G01 X9.713 Y6.591 Z19.33
    N4240 G01 X9.722 Y6.626 Z19.387
    N4241 G01 X9.734 Y6.672 Z19.435
    N4242 G01 X9.748 Y6.727 Z19.47
    N4243 G01 X9.764 Y6.788 Z19.492
    N4244 G01 X9.78 Y6.853 Z19.5
    N4245 G03 X10.015 Y8.486 I-7.419 J1.9
    N4246 G01 Y8.576
    N4247 G01 X9.75 Y9.248
    N4248 G01 X9.608 Y9.956
    N4249 G01 X9.536 Y10.674
    N4250 G01 X9.499 Y11.395
    N4251 G01 X9.482 Y12.117
    N4252 G01 X9.473 Y12.839
    N4253 G01 X9.469 Y13.561
    N4254 G01 X9.467 Y14.283
    N4255 G01 X9.465 Y16.449
    N4256 G01 Y38.831
    N4257 G01 X9.578 Y39.174
    N4258 G01 X9.789 Y39.467
    N4259 G01 X10.328 Y39.947
    N4260 G01 X10.992 Y40.229
    N4261 G01 X11.698 Y40.381
    N4262 G01 X12.416 Y40.459
    N4263 G01 X13.137 Y40.498
    N4264 G01 X13.859 Y40.517
    N4265 G01 X14.581 Y40.526
    N4266 G01 X15.303 Y40.531
    N4267 G01 X16.025 Y40.533
    N4268 G01 X18.191 Y40.535
    N4269 G01 X29.02
    N4270 G01 X38.767
    N4271 G01 X39.117 Y40.446
    N4272 G01 X39.42 Y40.249
    N4273 G01 X39.918 Y39.727
    N4274 G01 X40.212 Y39.067
    N4275 G01 X40.372 Y38.363
    N4276 G01 X40.455 Y37.646
    N4277 G01 X40.496 Y36.925
    N4278 G01 X40.516 Y36.203
    N4279 G01 X40.526 Y35.481
    N4280 G01 X40.531 Y34.76
    N4281 G01 X40.533 Y34.038
    N4282 G01 X40.535 Y31.872
    N4283 G01 Y11.295
    N4284 G01 X40.504 Y11.117
    N4285 G01 X40.373 Y10.78
    N4286 G01 X40.152 Y10.495
    N4287 G01 X39.6 Y10.029
    N4288 G01 X38.931 Y9.758
    N4289 G01 X38.224 Y9.612
    N4290 G01 X37.506 Y9.538
    N4291 G01 X36.785 Y9.5
    N4292 G01 X36.063 Y9.482
    N4293 G01 X35.341 Y9.473
    N4294 G01 X34.619 Y9.469
    N4295 G01 X33.897 Y9.467
    N4296 G01 X31.731 Y9.465
    N4297 G01 X30.287
    N4298 G01 X12.237
    N4299 G01 X11.893 Y9.573
    N4300 G01 X11.592 Y9.772
    N4301 G01 X11.088 Y10.29
    N4302 G01 X10.848 Y10.433
    N4303 G01 X10.562 Y10.47
    N4304 G01 X10.382 Y10.467
    N4305 G01 X10.292 Y10.466
    N4306 G01 X10.251 Y10.486
    N4307 G01 X10.223 Y10.521
    N4308 G01 X10.214 Y10.565
    N4309 G01 X10.301 Y10.916
    N4310 G01 X10.343 Y11.358
    N4311 G01 X10.386 Y12.079
    N4312 G01 X10.403 Y12.801
    N4313 G01 X10.41 Y13.523
    N4314 G01 X10.413 Y14.245
    N4315 G01 X10.415 Y15.689
    N4316 G01 Y37.348
    N4317 G01 X10.508 Y38.064
    N4318 G01 X10.458 Y38.238
    N4319 G01 X10.469 Y38.599
    N4320 G01 X10.467 Y38.734
    N4321 G01 X10.506 Y38.816
    N4322 G01 X10.759 Y39.073
    N4323 G01 X11.072 Y39.253
    N4324 G01 X11.759 Y39.475
    N4325 G01 X12.48 Y39.513
    N4326 G01 X13.201 Y39.546
    N4327 G01 X13.923 Y39.562
    N4328 G01 X14.645 Y39.572
    N4329 G01 X15.367 Y39.578
    N4330 G01 X16.089 Y39.581
    N4331 G01 X17.533 Y39.584
    N4332 G01 X21.864 Y39.585
    N4333 G01 X37.748
    N4334 G01 X38.103 Y39.516
    N4335 G01 X38.462 Y39.551
    N4336 G01 X38.642 Y39.539
    N4337 G01 X38.687 Y39.538
    N4338 G01 X38.731 Y39.526
    N4339 G01 X38.811 Y39.486
    N4340 G01 X38.947 Y39.366
    N4341 G01 X39.072 Y39.237
    N4342 G01 X39.256 Y38.926
    N4343 G01 X39.463 Y38.234
    N4344 G01 X39.507 Y37.514
    N4345 G01 X39.561 Y36.794
    N4346 G01 X39.569 Y36.072
    N4347 G01 X39.575 Y35.35
    N4348 G01 X39.579 Y34.628
    N4349 G01 X39.582 Y33.906
    N4350 G01 X39.584 Y32.462
    N4351 G01 X39.585 Y26.686
    N4352 G01 Y16.578
    N4353 G01 Y12.246
    N4354 G01 X39.516 Y11.892
    N4355 G01 X39.551 Y11.532
    N4356 G01 X39.539 Y11.352
    N4357 G01 X39.531 Y11.308
    N4358 G01 X39.494 Y11.225
    N4359 G01 X39.38 Y11.086
    N4360 G01 X39.103 Y10.854
    N4361 G01 X38.435 Y10.58
    N4362 G01 X37.715 Y10.521
    N4363 G01 X37. Y10.425
    N4364 G01 X36.278 Y10.426
    N4365 G01 X34.112 Y10.418
    N4366 G01 X31.946 Y10.416
    N4367 G01 X13.896 Y10.415
    N4368 G01 X13.174 Y10.424
    N4369 G01 X12.682 Y10.505
    N4370 G01 X12.507 Y10.461
    N4371 G01 X12.327 Y10.464
    N4372 G01 X12.244 Y10.499
    N4373 G01 X11.678 Y10.948
    N4374 G01 X11.442 Y11.207
    N4375 G01 X11.342 Y11.252
    N4376 G01 X11.258 Y11.286
    N4377 G01 X11.173 Y11.315
    N4378 G01 X11.129 Y11.327
    N4379 G01 X11.085 Y11.338
    N4380 G01 X11.051 Y11.367
    N4381 G01 X11.032 Y11.408
    N4382 G01 X11.059 Y12.13
    N4383 G01 X11.105 Y12.328
    N4384 G01 X11.151 Y12.566
    N4385 G01 X11.198 Y12.866
    N4386 G01 X11.246 Y13.257
    N4387 G01 X11.294 Y13.818
    N4388 G01 X11.331 Y14.539
    N4389 G01 X11.349 Y15.261
    N4390 G01 X11.357 Y15.983
    N4391 G01 X11.361 Y16.705
    N4392 G01 X11.363 Y17.427
    N4393 G01 X11.365 Y19.593
    N4394 G01 Y27.535
    N4395 G01 Y37.643
    N4396 G01 X11.474 Y37.987
    N4397 G01 X11.452 Y38.166
    N4398 G01 X11.432 Y38.254
    N4399 G01 X11.424 Y38.344
    N4400 G01 X11.423 Y38.389
    N4401 G01 X11.441 Y38.43
    N4402 G01 X11.476 Y38.459
    N4403 G01 X12.179 Y38.626
    N4404 G01 X12.901 Y38.615
    N4405 G01 X13.622 Y38.616
    N4406 G01 X15.066 Y38.625
    N4407 G01 X15.788 Y38.631
    N4408 G01 X17.954 Y38.635
    N4409 G01 X38.17
    N4410 G01 X38.26 Y38.622
    N4411 G01 X38.304 Y38.617
    N4412 G01 X38.343 Y38.593
    N4413 G01 X38.39 Y38.516
    N4414 G01 X38.589 Y37.822
    N4415 G01 X38.603 Y37.1
    N4416 G01 X38.613 Y36.378
    N4417 G01 X38.631 Y35.656
    N4418 G01 X38.63 Y34.934
    N4419 G01 X38.634 Y32.768
    N4420 G01 X38.635 Y28.436
    N4421 G01 Y26.27
    N4422 G01 Y11.83
    N4423 G01 X38.621 Y11.741
    N4424 G01 X38.617 Y11.696
    N4425 G01 X38.593 Y11.658
    N4426 G01 X38.439 Y11.563
    N4427 G01 X37.735 Y11.404
    N4428 G01 X37.013 Y11.389
    N4429 G01 X36.293 Y11.338
    N4430 G01 X35.571 Y11.355
    N4431 G01 X34.849 Y11.362
    N4432 G01 X34.127 Y11.365
    N4433 G01 X32.683 Y11.366
    N4434 G01 X13.911 Y11.365
    N4435 G01 X13.19 Y11.373
    N4436 G01 X12.699 Y11.477
    N4437 G01 X12.611 Y11.459
    N4438 G01 X12.567 Y11.45
    N4439 G01 X12.523 Y11.46
    N4440 G01 X12.245 Y11.691
    N4441 G01 X12.056 Y11.946
    N4442 G01 X11.978 Y11.991
    N4443 G01 X11.938 Y12.012
    N4444 G01 X11.912 Y12.049
    N4445 G01 X11.904 Y12.093
    N4446 G01 X11.978 Y12.408
    N4447 G01 X12.043 Y12.737
    N4448 G01 X12.112 Y13.166
    N4449 G01 X12.171 Y13.641
    N4450 G01 X12.23 Y14.303
    N4451 G01 X12.268 Y15.024
    N4452 G01 X12.29 Y15.745
    N4453 G01 X12.301 Y16.467
    N4454 G01 X12.308 Y17.189
    N4455 G01 X12.311 Y17.911
    N4456 G01 X12.314 Y19.355
    N4457 G01 X12.315 Y20.799
    N4458 G01 Y37.405
    N4459 G01 X12.343 Y37.583
    N4460 G01 X12.368 Y37.67
    N4461 G01 X12.387 Y37.758
    N4462 G01 X12.393 Y37.803
    N4463 G01 X12.418 Y37.841
    N4464 G01 X12.457 Y37.863
    N4465 G01 X13.178 Y37.91
    N4466 G01 X13.42 Y37.866
    N4467 G01 X13.727 Y37.822
    N4468 G01 X14.13 Y37.779
    N4469 G01 X14.745 Y37.734
    N4470 G01 X15.466 Y37.707
    N4471 G01 X16.188 Y37.694
    N4472 G01 X16.91 Y37.689
    N4473 G01 X17.632 Y37.687
    N4474 G01 X19.798 Y37.685
    N4475 G01 X37.803
    N4476 G01 X37.843 Y37.665
    N4477 G01 X37.871 Y37.63
    N4478 G01 X37.88 Y37.585
    N4479 G01 X37.702 Y36.886
    N4480 G01 X37.691 Y36.164
    N4481 G01 X37.686 Y35.442
    N4482 G01 X37.684 Y34.72
    N4483 G01 Y33.276
    N4484 G01 X37.685 Y29.666
    N4485 G01 Y12.203
    N4486 G01 X37.665 Y12.162
    N4487 G01 X37.63 Y12.134
    N4488 G01 X37.585 Y12.125
    N4489 G01 X36.886 Y12.304
    N4490 G01 X36.164 Y12.305
    N4491 G01 X35.442 Y12.274
    N4492 G01 X34.721 Y12.295
    N4493 G01 X33.999 Y12.306
    N4494 G01 X33.277 Y12.311
    N4495 G01 X32.555 Y12.313
    N4496 G01 X31.111 Y12.315
    N4497 G01 X13.783
    N4498 G01 X13.061 Y12.328
    N4499 G01 X13.019 Y12.344
    N4500 G01 X12.976 Y12.36
    N4501 G01 X12.943 Y12.389
    N4502 G01 X12.911 Y12.422
    N4503 G01 X12.896 Y12.464
    N4504 G01 X12.991 Y13.18
    N4505 G01 X13.064 Y13.668
    N4506 G01 X13.129 Y14.238
    N4507 G01 X13.185 Y14.958
    N4508 G01 X13.219 Y15.679
    N4509 G01 X13.238 Y16.401
    N4510 G01 X13.25 Y17.123
    N4511 G01 X13.257 Y17.845
    N4512 G01 X13.26 Y18.567
    N4513 G01 X13.264 Y20.011
    N4514 G01 Y20.733
    N4515 G01 X13.265 Y31.563
    N4516 G01 Y37.158
    N4517 G01 X13.266 Y37.203
    N4518 G01 X13.286 Y37.244
    N4519 G01 X13.322 Y37.271
    N4520 G01 X13.366 Y37.28
    N4521 G01 X14.064 Y37.093
    N4522 G01 X14.258 Y37.043
    N4523 G01 X14.479 Y36.994
    N4524 G01 X14.755 Y36.944
    N4525 G01 X15.094 Y36.894
    N4526 G01 X15.549 Y36.843
    N4527 G01 X16.207 Y36.793
    N4528 G01 X16.929 Y36.764
    N4529 G01 X17.651 Y36.749
    N4530 G01 X18.373 Y36.742
    N4531 G01 X19.095 Y36.738
    N4532 G01 X20.539 Y36.736
    N4533 G01 X28.48 Y36.735
    N4534 G01 X37.054
    N4535 G01 X37.095 Y36.715
    N4536 G01 X37.122 Y36.68
    N4537 G01 X37.132 Y36.635
    N4538 G01 X36.953 Y35.936
    N4539 G01 X36.907 Y35.656
    N4540 G01 X36.86 Y35.292
    N4541 G01 X36.813 Y34.783
    N4542 G01 X36.771 Y34.062
    N4543 G01 X36.752 Y33.34
    N4544 G01 X36.743 Y32.618
    N4545 G01 X36.739 Y31.896
    N4546 G01 X36.737 Y31.174
    N4547 G01 X36.735 Y29.008
    N4548 G01 Y26.842
    N4549 G01 Y12.944
    N4550 G01 X36.715 Y12.903
    N4551 G01 X36.68 Y12.876
    N4552 G01 X36.635 Y12.866
    N4553 G01 X35.936 Y13.045
    N4554 G01 X35.593 Y13.097
    N4555 G01 X35.136 Y13.149
    N4556 G01 X34.478 Y13.201
    N4557 G01 X33.757 Y13.233
    N4558 G01 X33.035 Y13.249
    N4559 G01 X32.313 Y13.257
    N4560 G01 X31.591 Y13.261
    N4561 G01 X30.869 Y13.263
    N4562 G01 X28.703 Y13.265
    N4563 G01 X13.812
    N4564 G01 X13.631 Y13.268
    N4565 G01 X13.591 Y13.289
    N4566 G01 X13.564 Y13.325
    N4567 G01 X13.556 Y13.369
    N4568 G01 X13.746 Y14.066
    N4569 G01 X13.797 Y14.221
    N4570 G01 X13.849 Y14.406
    N4571 G01 X13.899 Y14.609
    N4572 G01 X13.952 Y14.858
    N4573 G01 X14.005 Y15.168
    N4574 G01 X14.059 Y15.556
    N4575 G01 X14.113 Y16.089
    N4576 G01 X14.16 Y16.809
    N4577 G01 X14.185 Y17.531
    N4578 G01 X14.199 Y18.252
    N4579 G01 X14.206 Y18.974
    N4580 G01 X14.21 Y19.696
    N4581 G01 X14.214 Y21.14
    N4582 G01 X14.215 Y24.75
    N4583 G01 Y26.194
    N4584 G01 Y36.483
    N4585 G03 X14.188 Y36.597 I-0.3 J-0.01
    N4586 G01 X14.16 Y36.657 Z19.492
    N4587 G01 X14.134 Y36.715 Z19.47
    N4588 G01 X14.111 Y36.767 Z19.435
    N4589 G01 X14.091 Y36.81 Z19.387
    N4590 G01 X14.076 Y36.843 Z19.33
    N4591 G01 X14.067 Y36.863 Z19.267
    N4592 G01 X14.064 Y36.87 Z19.2
    N4593 G00 Z-3.01
    N4594 G00 X13.464 Y13.548
    N4595 G00 Z18.9
    N4596 G01 Z19.2 F1500
    N4597 G01 X13.457 Y13.55 Z19.267
    N4598 G01 X13.436 Y13.557 Z19.33
    N4599 G01 X13.401 Y13.567 Z19.387
    N4600 G01 X13.356 Y13.581 Z19.435
    N4601 G01 X13.301 Y13.597 Z19.47
    N4602 G01 X13.241 Y13.615 Z19.492
    N4603 G01 X13.177 Y13.635 Z19.5
    N4604 G01 X13.064 Y13.668
    N4605 G01 X13.813 Y13.556
    N4606 G01 X13.98 Y13.473
    N4607 G01 X14.189 Y13.462
    N4608 G01 X14.41 Y13.543
    N4609 G01 X14.617 Y13.74
    N4610 G01 X14.72 Y14.149
    N4611 G01 X14.809 Y14.568
    N4612 G01 X14.891 Y15.026
    N4613 G01 X14.97 Y15.585
    N4614 G01 X15.04 Y16.239
    N4615 G01 X15.091 Y16.959
    N4616 G01 X15.121 Y17.68
    N4617 G01 X15.14 Y18.402
    N4618 G01 X15.15 Y19.124
    N4619 G01 X15.157 Y19.846
    N4620 G01 X15.16 Y20.568
    N4621 G01 X15.164 Y22.012
    N4622 G01 X15.165 Y25.622
    N4623 G01 Y36.271
    N4624 G01 X15.185 Y36.312
    N4625 G01 X15.22 Y36.34
    N4626 G01 X15.265 Y36.349
    N4627 G01 X15.964 Y36.17
    N4628 G01 X16.127 Y36.124
    N4629 G01 X16.322 Y36.076
    N4630 G01 X16.55 Y36.028
    N4631 G01 X16.831 Y35.979
    N4632 G01 X17.192 Y35.929
    N4633 G01 X17.684 Y35.879
    N4634 G01 X18.404 Y35.832
    N4635 G01 X19.126 Y35.808
    N4636 G01 X19.847 Y35.797
    N4637 G01 X20.569 Y35.791
    N4638 G01 X21.291 Y35.788
    N4639 G01 X22.735 Y35.786
    N4640 G01 X34.287 Y35.785
    N4641 G01 X36.363
    N4642 G01 X36.453 Y35.788
    N4643 G03 X36.481 Y35.79 I-0.01 J0.3
    N4644 G03 X36.404 Y36.386 I-0.038 J0.298
    N4645 G03 X36.165 Y35.973 I0.038 J-0.298
    N4646 G01 X36.623 Y34.866
    N4647 G03 X37.177 Y35.096 I0.277 J0.115
    N4648 G03 X36.949 Y35.277 I-0.277 J-0.115
    N4649 G01 X36.86 Y35.292
    N4650 G01 X36.831 Y35.295
    N4651 G01 X36.55 Y35.42
    N4652 G01 X36.349 Y35.422
    N4653 G01 X36.144 Y35.335
    N4654 G01 X36.094 Y35.135
    N4655 G01 X36.042 Y34.89
    N4656 G01 X35.988 Y34.587
    N4657 G01 X35.937 Y34.218
    N4658 G01 X35.885 Y33.715
    N4659 G01 X35.836 Y32.995
    N4660 G01 X35.811 Y32.273
    N4661 G01 X35.798 Y31.551
    N4662 G01 X35.792 Y30.829
    N4663 G01 X35.788 Y30.107
    N4664 G01 X35.786 Y28.663
    N4665 G01 X35.785 Y21.443
    N4666 G01 Y13.682
    N4667 G01 X35.765 Y13.641
    N4668 G01 X35.73 Y13.614
    N4669 G01 X35.685 Y13.605
    N4670 G01 X34.986 Y13.783
    N4671 G01 X34.842 Y13.829
    N4672 G01 X34.674 Y13.876
    N4673 G01 X34.472 Y13.925
    N4674 G01 X34.231 Y13.975
    N4675 G01 X33.939 Y14.024
    N4676 G01 X33.558 Y14.075
    N4677 G01 X33.038 Y14.125
    N4678 G01 X32.317 Y14.17
    N4679 G01 X31.596 Y14.192
    N4680 G01 X30.874 Y14.203
    N4681 G01 X30.152 Y14.209
    N4682 G01 X29.43 Y14.212
    N4683 G01 X27.986 Y14.214
    N4684 G01 X17.156 Y14.215
    N4685 G01 X15.306
    N4686 G01 X15.282 Y14.214
    N4687 G03 X15.287 Y14.054 I0.003 J-0.08
    N4688 G03 X15.343 Y14.189 I-0.003 J0.08
    N4689 G01 X14.864 Y14.705
    N4690 G03 X14.747 Y14.597 I-0.059 J-0.054
    N4691 G03 X14.786 Y14.573 I0.059 J0.054
    N4692 G01 X14.809 Y14.568
    N4693 G01 X14.964 Y14.534
    N4694 G01 X15.125 Y14.451
    N4695 G01 X15.327 Y14.437
    N4696 G01 X15.537 Y14.512
    N4697 G01 X15.726 Y14.687
    N4698 G01 X15.812 Y15.154
    N4699 G01 X15.895 Y15.722
    N4700 G01 X15.97 Y16.398
    N4701 G01 X16.025 Y17.118
    N4702 G01 X16.059 Y17.839
    N4703 G01 X16.081 Y18.561
    N4704 G01 X16.095 Y19.283
    N4705 G01 X16.103 Y20.005
    N4706 G01 X16.108 Y20.727
    N4707 G01 X16.111 Y21.449
    N4708 G01 X16.114 Y22.893
    N4709 G01 X16.115 Y27.225
    N4710 G01 Y35.528
    N4711 G01 X16.112 Y35.618
    N4712 G03 X15.512 Y35.597 I-0.3 J-0.01
    N4713 G03 X15.927 Y35.33 I0.3 J0.01
    N4714 G01 X16.978 Y35.766
    N4715 G03 X16.748 Y36.32 I-0.115 J0.277
    N4716 G03 X16.579 Y36.142 I0.115 J-0.277
    N4717 G03 X16.571 Y36.115 I0.283 J-0.099
    N4718 G01 X16.55 Y36.028
    N4719 G01 X16.544 Y36.
    N4720 G01 X16.399 Y35.729
    N4721 G01 X16.382 Y35.531
    N4722 G01 X16.453 Y35.321
    N4723 G01 X16.631 Y35.265
    N4724 G01 X16.848 Y35.206
    N4725 G01 X17.11 Y35.144
    N4726 G01 X17.386 Y35.089
    N4727 G01 X17.745 Y35.031
    N4728 G01 X18.177 Y34.976
    N4729 G01 X18.784 Y34.921
    N4730 G01 X19.505 Y34.881
    N4731 G01 X20.227 Y34.859
    N4732 G01 X20.949 Y34.848
    N4733 G01 X21.671 Y34.842
    N4734 G01 X22.393 Y34.839
    N4735 G01 X23.837 Y34.836
    N4736 G01 X29.613 Y34.835
    N4737 G01 X35.479
    N4738 G01 X35.503 Y34.836
    N4739 G03 X35.497 Y34.996 I-0.003 J0.08
    N4740 G03 X35.449 Y34.854 I0.003 J-0.08
    N4741 G01 X35.944 Y34.442
    N4742 G03 X36.047 Y34.565 I0.051 J0.062
    N4743 G03 X36.012 Y34.582 I-0.051 J-0.062
    N4744 G01 X35.988 Y34.587
    N4745 G01 X35.791 Y34.622
    N4746 G01 X35.616 Y34.682
    N4747 G01 X35.411 Y34.666
    N4748 G01 X35.207 Y34.558
    N4749 G01 X35.145 Y34.288
    N4750 G01 X35.089 Y34.004
    N4751 G01 X35.029 Y33.631
    N4752 G01 X34.974 Y33.185
    N4753 G01 X34.918 Y32.552
    N4754 G01 X34.88 Y31.831
    N4755 G01 X34.859 Y31.109
    N4756 G01 X34.848 Y30.387
    N4757 G01 X34.842 Y29.665
    N4758 G01 X34.839 Y28.943
    N4759 G01 X34.836 Y27.499
    N4760 G01 X34.835 Y21.723
    N4761 G01 Y14.413
    N4762 G01 X34.838 Y14.323
    N4763 G03 X34.84 Y14.295 I0.3 J0.01
    N4764 G03 X35.436 Y14.372 I0.298 J0.038
    N4765 G03 X35.05 Y14.62 I-0.298 J-0.038
    N4766 G01 X33.83 Y14.245
    N4767 G03 X34.007 Y13.671 I0.088 J-0.287
    N4768 G03 X34.202 Y13.86 I-0.088 J0.287
    N4769 G03 X34.21 Y13.887 I-0.284 J0.097
    N4770 G01 X34.231 Y13.975
    N4771 G01 X34.237 Y14.003
    N4772 G01 X34.381 Y14.274
    N4773 G01 X34.397 Y14.473
    N4774 G01 X34.325 Y14.682
    N4775 G01 X34.148 Y14.737
    N4776 G01 X33.934 Y14.795
    N4777 G01 X33.669 Y14.858
    N4778 G01 X33.389 Y14.913
    N4779 G01 X33.029 Y14.971
    N4780 G01 X32.586 Y15.026
    N4781 G01 X31.964 Y15.081
    N4782 G01 X31.243 Y15.12
    N4783 G01 X30.522 Y15.141
    N4784 G01 X29.8 Y15.152
    N4785 G01 X29.078 Y15.158
    N4786 G01 X28.356 Y15.161
    N4787 G01 X26.912 Y15.164
    N4788 G01 X21.136 Y15.165
    N4789 G01 X16.443
    N4790 G01 X16.402 Y15.185
    N4791 G01 X16.375 Y15.22
    N4792 G01 X16.365 Y15.265
    N4793 G01 X16.544 Y15.964
    N4794 G01 X16.594 Y16.106
    N4795 G01 X16.645 Y16.27
    N4796 G01 X16.699 Y16.468
    N4797 G01 X16.752 Y16.693
    N4798 G01 X16.806 Y16.965
    N4799 G01 X16.862 Y17.31
    N4800 G01 X16.918 Y17.75
    N4801 G01 X16.974 Y18.37
    N4802 G01 X17.014 Y19.091
    N4803 G01 X17.036 Y19.813
    N4804 G01 X17.048 Y20.535
    N4805 G01 X17.055 Y21.257
    N4806 G01 X17.059 Y21.979
    N4807 G01 X17.063 Y23.423
    N4808 G01 X17.065 Y26.311
    N4809 G01 Y34.614
    N4810 G01 X17.062 Y34.704
    N4811 G03 X16.462 Y34.683 I-0.3 J-0.01
    N4812 G03 X16.884 Y34.419 I0.3 J0.01
    N4813 G01 X17.82 Y34.834
    N4814 G03 X17.577 Y35.382 I-0.122 J0.274
    N4815 G03 X17.406 Y35.177 I0.122 J-0.274
    N4816 G01 X17.386 Y35.089
    N4817 G01 X17.355 Y34.935
    N4818 G01 X17.274 Y34.774
    N4819 G01 X17.263 Y34.574
    N4820 G01 X17.339 Y34.366
    N4821 G01 X17.517 Y34.179
    N4822 G01 X17.976 Y34.106
    N4823 G01 X18.529 Y34.038
    N4824 G01 X19.248 Y33.976
    N4825 G01 X19.969 Y33.938
    N4826 G01 X20.691 Y33.915
    N4827 G01 X21.413 Y33.902
    N4828 G01 X22.135 Y33.895
    N4829 G01 X22.857 Y33.89
    N4830 G01 X23.579 Y33.888
    N4831 G01 X25.023 Y33.886
    N4832 G01 X32.964 Y33.885
    N4833 G01 X34.499
    N4834 G01 X34.523 Y33.886
    N4835 G03 X34.517 Y34.046 I-0.003 J0.08
    N4836 G03 X34.47 Y33.904 I0.003 J-0.08
    N4837 G01 X34.987 Y33.485
    N4838 G03 X35.087 Y33.61 I0.05 J0.062
    N4839 G03 X35.053 Y33.626 I-0.05 J-0.062
    N4840 G01 X35.029 Y33.631
    N4841 G01 X34.873 Y33.656
    N4842 G01 X34.707 Y33.73
    N4843 G01 X34.506 Y33.734
    N4844 G01 X34.3 Y33.649
    N4845 G01 X34.12 Y33.464
    N4846 G01 X34.052 Y32.936
    N4847 G01 X33.987 Y32.256
    N4848 G01 X33.944 Y31.535
    N4849 G01 X33.919 Y30.814
    N4850 G01 X33.904 Y30.092
    N4851 G01 X33.896 Y29.37
    N4852 G01 X33.891 Y28.648
    N4853 G01 X33.888 Y27.926
    N4854 G01 X33.886 Y26.482
    N4855 G01 X33.885 Y20.706
    N4856 G01 Y15.381
    N4857 G01 X33.886 Y15.357
    N4858 G03 X34.046 Y15.363 I0.08 J0.003
    N4859 G03 X33.921 Y15.426 I-0.08 J-0.003
    N4860 G01 X33.261 Y14.973
    N4861 G03 X33.351 Y14.841 I0.045 J-0.066
    N4862 G03 X33.384 Y14.889 I-0.045 J0.066
    N4863 G01 X33.389 Y14.913
    N4864 G01 X33.395 Y14.941
    N4865 G01 X33.538 Y15.214
    N4866 G01 X33.553 Y15.413
    N4867 G01 X33.48 Y15.622
    N4868 G01 X33.274 Y15.685
    N4869 G01 X33.065 Y15.741
    N4870 G01 X32.806 Y15.801
    N4871 G01 X32.492 Y15.862
    N4872 G01 X32.128 Y15.919
    N4873 G01 X31.649 Y15.977
    N4874 G01 X30.985 Y16.034
    N4875 G01 X30.264 Y16.071
    N4876 G01 X29.542 Y16.091
    N4877 G01 X28.82 Y16.102
    N4878 G01 X28.098 Y16.108
    N4879 G01 X27.376 Y16.111
    N4880 G01 X25.932 Y16.114
    N4881 G01 X20.878 Y16.115
    N4882 G01 X17.178
    N4883 G01 X17.088 Y16.112
    N4884 G03 X17.109 Y15.512 I0.01 J-0.3
    N4885 G03 X17.386 Y15.897 I-0.01 J0.3
    N4886 G01 X17.032 Y17.092
    N4887 G03 X16.457 Y16.921 I-0.288 J-0.085
    N4888 G03 X16.639 Y16.725 I0.288 J0.085
    N4889 G03 X16.665 Y16.717 I0.105 J0.281
    N4890 G01 X16.752 Y16.693
    N4891 G01 X16.78 Y16.687
    N4892 G01 X17.046 Y16.535
    N4893 G01 X17.245 Y16.514
    N4894 G01 X17.456 Y16.579
    N4895 G01 X17.517 Y16.759
    N4896 G01 X17.581 Y16.978
    N4897 G01 X17.642 Y17.211
    N4898 G01 X17.703 Y17.487
    N4899 G01 X17.766 Y17.829
    N4900 G01 X17.826 Y18.228
    N4901 G01 X17.885 Y18.757
    N4902 G01 X17.941 Y19.477
    N4903 G01 X17.972 Y20.198
    N4904 G01 X17.991 Y20.92
    N4905 G01 X18.001 Y21.642
    N4906 G01 X18.007 Y22.364
    N4907 G01 X18.01 Y23.086
    N4908 G01 X18.013 Y24.53
    N4909 G01 X18.015 Y28.14
    N4910 G01 Y33.465
    N4911 G01 X18.035 Y33.505
    N4912 G01 X18.07 Y33.533
    N4913 G01 X18.115 Y33.542
    N4914 G01 X18.814 Y33.364
    N4915 G01 X18.975 Y33.315
    N4916 G01 X19.167 Y33.265
    N4917 G01 X19.4 Y33.213
    N4918 G01 X19.67 Y33.162
    N4919 G01 X20.021 Y33.109
    N4920 G01 X20.475 Y33.057
    N4921 G01 X21.144 Y33.004
    N4922 G01 X21.866 Y32.972
    N4923 G01 X22.587 Y32.955
    N4924 G01 X23.309 Y32.946
    N4925 G01 X24.031 Y32.941
    N4926 G01 X24.753 Y32.938
    N4927 G01 X26.197 Y32.936
    N4928 G01 X33.417 Y32.935
    N4929 G01 X33.458 Y32.915
    N4930 G01 X33.485 Y32.88
    N4931 G01 X33.495 Y32.835
    N4932 G01 X33.316 Y32.136
    N4933 G01 X33.268 Y31.956
    N4934 G01 X33.219 Y31.744
    N4935 G01 X33.168 Y31.483
    N4936 G01 X33.117 Y31.162
    N4937 G01 X33.065 Y30.736
    N4938 G01 X33.013 Y30.138
    N4939 G01 X32.976 Y29.417
    N4940 G01 X32.957 Y28.695
    N4941 G01 X32.946 Y27.973
    N4942 G01 X32.941 Y27.251
    N4943 G01 X32.938 Y26.529
    N4944 G01 X32.936 Y25.085
    N4945 G01 X32.935 Y18.587
    N4946 G01 Y16.331
    N4947 G01 X32.936 Y16.307
    N4948 G03 X33.096 Y16.313 I0.08 J0.003
    N4949 G03 X32.968 Y16.374 I-0.08 J-0.003
    N4950 G01 X32.361 Y15.921
    N4951 G03 X32.457 Y15.792 I0.048 J-0.064
    N4952 G03 X32.487 Y15.839 I-0.048 J0.064
    N4953 G01 X32.492 Y15.862
    N4954 G01 X32.498 Y15.89
    N4955 G01 X32.64 Y16.164
    N4956 G01 X32.654 Y16.363
    N4957 G01 X32.58 Y16.572
    N4958 G01 X32.375 Y16.634
    N4959 G01 X32.154 Y16.693
    N4960 G01 X31.897 Y16.752
    N4961 G01 X31.574 Y16.814
    N4962 G01 X31.206 Y16.871
    N4963 G01 X30.712 Y16.929
    N4964 G01 X30.024 Y16.987
    N4965 G01 X29.302 Y17.021
    N4966 G01 X28.581 Y17.041
    N4967 G01 X27.859 Y17.052
    N4968 G01 X27.137 Y17.058
    N4969 G01 X26.415 Y17.061
    N4970 G01 X24.971 Y17.064
    N4971 G01 X20.639 Y17.065
    N4972 G01 X18.202
    N4973 G01 X18.112 Y17.062
    N4974 G03 X18.133 Y16.462 I0.01 J-0.3
    N4975 G03 X18.4 Y16.877 I-0.01 J0.3
    N4976 G01 X17.968 Y17.915
    N4977 G03 X17.414 Y17.685 I-0.277 J-0.115
    N4978 G03 X17.616 Y17.51 I0.277 J0.115
    N4979 G01 X17.703 Y17.487
    N4980 G01 X17.835 Y17.458
    N4981 G01 X17.986 Y17.366
    N4982 G01 X18.181 Y17.338
    N4983 G01 X18.392 Y17.396
    N4984 G01 X18.587 Y17.553
    N4985 G01 X18.665 Y17.953
    N4986 G01 X18.737 Y18.404
    N4987 G01 X18.807 Y18.971
    N4988 G01 X18.869 Y19.691
    N4989 G01 X18.908 Y20.412
    N4990 G01 X18.931 Y21.133
    N4991 G01 X18.945 Y21.855
    N4992 G01 X18.953 Y22.577
    N4993 G01 X18.958 Y23.299
    N4994 G01 X18.961 Y24.021
    N4995 G01 X18.964 Y25.465
    N4996 G01 X18.965 Y29.797
    N4997 G01 Y32.775
    N4998 G01 X18.964 Y32.799
    N4999 G03 X18.804 Y32.794 I-0.08 J-0.003
    N5000 G03 X18.93 Y32.731 I0.08 J0.003
    N5001 G01 X19.529 Y33.151
    N5002 G03 X19.437 Y33.282 I-0.046 J0.066
    N5003 G03 X19.406 Y33.236 I0.046 J-0.066
    N5004 G01 X19.4 Y33.213
    N5005 G01 X19.393 Y33.185
    N5006 G01 X19.245 Y32.917
    N5007 G01 X19.225 Y32.719
    N5008 G01 X19.293 Y32.508
    N5009 G01 X19.462 Y32.316
    N5010 G01 X19.898 Y32.239
    N5011 G01 X20.391 Y32.169
    N5012 G01 X21.003 Y32.105
    N5013 G01 X21.723 Y32.055
    N5014 G01 X22.444 Y32.025
    N5015 G01 X23.166 Y32.008
    N5016 G01 X23.888 Y31.998
    N5017 G01 X24.61 Y31.992
    N5018 G01 X25.332 Y31.989
    N5019 G01 X26.776 Y31.986
    N5020 G01 X31.108 Y31.985
    N5021 G01 X32.732
    N5022 G01 X32.822 Y31.988
    N5023 G03 X32.802 Y32.588 I-0.01 J0.3
    N5024 G03 X32.528 Y32.192 I0.01 J-0.3
    N5025 G01 X32.903 Y31.075
    N5026 G03 X33.472 Y31.266 I0.284 J0.096
    N5027 G03 X33.282 Y31.455 I-0.284 J-0.096
    N5028 G03 X33.255 Y31.462 I-0.094 J-0.285
    N5029 G01 X33.168 Y31.483
    N5030 G01 X33.14 Y31.488
    N5031 G01 X32.866 Y31.63
    N5032 G01 X32.667 Y31.644
    N5033 G01 X32.459 Y31.57
    N5034 G01 X32.399 Y31.374
    N5035 G01 X32.344 Y31.163
    N5036 G01 X32.285 Y30.901
    N5037 G01 X32.227 Y30.594
    N5038 G01 X32.17 Y30.223
    N5039 G01 X32.114 Y29.741
    N5040 G01 X32.058 Y29.055
    N5041 G01 X32.025 Y28.334
    N5042 G01 X32.007 Y27.612
    N5043 G01 X31.997 Y26.891
    N5044 G01 X31.991 Y26.169
    N5045 G01 X31.988 Y25.447
    N5046 G01 X31.986 Y24.003
    N5047 G01 X31.985 Y18.949
    N5048 G01 Y17.324
    N5049 G01 X31.986 Y17.3
    N5050 G03 X32.146 Y17.306 I0.08 J0.003
    N5051 G03 X32.014 Y17.364 I-0.08 J-0.003
    N5052 G01 X31.438 Y16.869
    N5053 G03 X31.543 Y16.747 I0.052 J-0.061
    N5054 G03 X31.568 Y16.79 I-0.052 J0.061
    N5055 G01 X31.574 Y16.814
    N5056 G01 X31.599 Y16.947
    N5057 G01 X31.687 Y17.101
    N5058 G01 X31.709 Y17.297
    N5059 G01 X31.645 Y17.506
    N5060 G01 X31.456 Y17.566
    N5061 G01 X31.244 Y17.626
    N5062 G01 X31.012 Y17.682
    N5063 G01 X30.719 Y17.742
    N5064 G01 X30.38 Y17.799
    N5065 G01 X29.935 Y17.858
    N5066 G01 X29.353 Y17.915
    N5067 G01 X28.632 Y17.959
    N5068 G01 X27.911 Y17.984
    N5069 G01 X27.189 Y17.998
    N5070 G01 X26.467 Y18.005
    N5071 G01 X25.745 Y18.01
    N5072 G01 X25.023 Y18.012
    N5073 G01 X23.579 Y18.014
    N5074 G01 X20.691 Y18.015
    N5075 G01 X19.337
    N5076 G01 X19.247
    N5077 G01 X19.157 Y18.012
    N5078 G03 X19.178 Y17.412 I0.01 J-0.3
    N5079 G03 X19.44 Y17.837 I-0.01 J0.3
    N5080 G01 X18.979 Y18.841
    N5081 G03 X18.433 Y18.591 I-0.273 J-0.125
    N5082 G03 X18.649 Y18.421 I0.273 J0.125
    N5083 G01 X18.737 Y18.404
    N5084 G01 X18.872 Y18.383
    N5085 G01 X19.03 Y18.3
    N5086 G01 X19.228 Y18.285
    N5087 G01 X19.437 Y18.357
    N5088 G01 X19.493 Y18.544
    N5089 G01 X19.549 Y18.762
    N5090 G01 X19.609 Y19.034
    N5091 G01 X19.666 Y19.342
    N5092 G01 X19.727 Y19.746
    N5093 G01 X19.784 Y20.257
    N5094 G01 X19.84 Y20.977
    N5095 G01 X19.872 Y21.699
    N5096 G01 X19.89 Y22.42
    N5097 G01 X19.9 Y23.142
    N5098 G01 X19.906 Y23.864
    N5099 G01 X19.91 Y24.586
    N5100 G01 X19.913 Y26.03
    N5101 G01 X19.915 Y29.64
    N5102 G01 Y31.671
    N5103 G01 X19.912 Y31.761
    N5104 G03 X19.91 Y31.788 I-0.3 J-0.01
    N5105 G03 X19.314 Y31.712 I-0.298 J-0.038
    N5106 G03 X19.728 Y31.473 I0.298 J0.038
    N5107 G01 X20.818 Y31.929
    N5108 G03 X20.586 Y32.482 I-0.116 J0.277
    N5109 G03 X20.407 Y32.258 I0.116 J-0.277
    N5110 G01 X20.391 Y32.169
    N5111 G01 X20.387 Y32.141
    N5112 G01 X20.259 Y31.861
    N5113 G01 X20.255 Y31.66
    N5114 G01 X20.339 Y31.453
    N5115 G01 X20.549 Y31.398
    N5116 G01 X20.792 Y31.342
    N5117 G01 X21.1 Y31.283
    N5118 G01 X21.458 Y31.228
    N5119 G01 X21.943 Y31.17
    N5120 G01 X22.626 Y31.113
    N5121 G01 X23.347 Y31.079
    N5122 G01 X24.069 Y31.06
    N5123 G01 X24.791 Y31.049
    N5124 G01 X25.513 Y31.043
    N5125 G01 X26.235 Y31.039
    N5126 G01 X27.679 Y31.036
    N5127 G01 X30.567 Y31.035
    N5128 G01 X31.74
    N5129 G01 X31.83 Y31.038
    N5130 G03 X31.809 Y31.638 I-0.01 J0.3
    N5131 G03 X31.541 Y31.225 I0.01 J-0.3
    N5132 G01 X31.97 Y30.169
    N5133 G03 X32.526 Y30.395 I0.278 J0.113
    N5134 G03 X32.314 Y30.574 I-0.278 J-0.113
    N5135 G01 X32.227 Y30.594
    N5136 G01 X32.198 Y30.599
    N5137 G01 X31.924 Y30.74
    N5138 G01 X31.724 Y30.754
    N5139 G01 X31.516 Y30.679
    N5140 G01 X31.454 Y30.474
    N5141 G01 X31.395 Y30.248
    N5142 G01 X31.338 Y29.992
    N5143 G01 X31.277 Y29.665
    N5144 G01 X31.221 Y29.292
    N5145 G01 X31.163 Y28.787
    N5146 G01 X31.106 Y28.073
    N5147 G01 X31.074 Y27.351
    N5148 G01 X31.057 Y26.63
    N5149 G01 X31.047 Y25.908
    N5150 G01 X31.042 Y25.186
    N5151 G01 X31.039 Y24.464
    N5152 G01 X31.036 Y23.02
    N5153 G01 X31.035 Y18.237
    N5154 G01 X31.036 Y18.213
    N5155 G03 X31.196 Y18.218 I0.08 J0.003
    N5156 G03 X31.059 Y18.272 I-0.08 J-0.003
    N5157 G01 X30.579 Y17.794
    N5158 G03 X30.692 Y17.681 I0.056 J-0.057
    N5159 G03 X30.713 Y17.719 I-0.056 J0.057
    N5160 G01 X30.719 Y17.742
    N5161 G01 X30.75 Y17.896
    N5162 G01 X30.832 Y18.056
    N5163 G01 X30.844 Y18.255
    N5164 G01 X30.769 Y18.465
    N5165 G01 X30.593 Y18.652
    N5166 G01 X30.128 Y18.728
    N5167 G01 X29.588 Y18.797
    N5168 G01 X28.869 Y18.864
    N5169 G01 X28.148 Y18.905
    N5170 G01 X27.427 Y18.929
    N5171 G01 X26.705 Y18.944
    N5172 G01 X25.983 Y18.953
    N5173 G01 X25.261 Y18.958
    N5174 G01 X24.539 Y18.961
    N5175 G01 X23.095 Y18.964
    N5176 G01 X21.651 Y18.966
    N5177 G01 X20.929 Y18.963
    N5178 G01 X20.749 Y18.965
    N5179 G01 X20.162
    N5180 G01 X20.072 Y18.961
    N5181 G03 X20.094 Y18.362 I0.011 J-0.3
    N5182 G03 X20.357 Y18.783 I-0.011 J0.3
    N5183 G01 X19.918 Y19.776
    N5184 G03 X19.369 Y19.533 I-0.274 J-0.121
    N5185 G03 X19.579 Y19.361 I0.274 J0.121
    N5186 G01 X19.666 Y19.342
    N5187 G01 X19.8 Y19.317
    N5188 G01 X19.956 Y19.23
    N5189 G01 X20.153 Y19.21
    N5190 G01 X20.361 Y19.276
    N5191 G01 X20.551 Y19.44
    N5192 G01 X20.621 Y19.86
    N5193 G01 X20.691 Y20.383
    N5194 G01 X20.755 Y21.052
    N5195 G01 X20.8 Y21.773
    N5196 G01 X20.826 Y22.495
    N5197 G01 X20.842 Y23.216
    N5198 G01 X20.851 Y23.938
    N5199 G01 X20.857 Y24.66
    N5200 G01 X20.86 Y25.382
    N5201 G01 X20.863 Y26.826
    N5202 G01 X20.865 Y29.714
    N5203 G01 Y30.752
    N5204 G01 X20.862 Y30.842
    N5205 G03 X20.859 Y30.87 I-0.3 J-0.011
    N5206 G03 X20.264 Y30.793 I-0.298 J-0.038
    N5207 G03 X20.708 Y30.569 I0.298 J0.038
    N5208 G01 X21.558 Y31.042
    N5209 G03 X21.267 Y31.567 I-0.146 J0.262
    N5210 G03 X21.12 Y31.371 I0.146 J-0.262
    N5211 G01 X21.1 Y31.283
    N5212 G01 X21.062 Y31.087
    N5213 G01 X21. Y30.912
    N5214 G01 X21.013 Y30.707
    N5215 G01 X21.118 Y30.502
    N5216 G01 X21.33 Y30.328
    N5217 G01 X21.96 Y30.25
    N5218 G01 X22.679 Y30.186
    N5219 G01 X23.4 Y30.146
    N5220 G01 X24.122 Y30.122
    N5221 G01 X24.844 Y30.107
    N5222 G01 X25.565 Y30.098
    N5223 G01 X26.287 Y30.092
    N5224 G01 X27.009 Y30.089
    N5225 G01 X28.453 Y30.086
    N5226 G01 X29.175 Y30.084
    N5227 G01 X29.897 Y30.089
    N5228 G01 X30.258 Y30.083
    N5229 G01 X30.71 Y30.086
    N5230 G01 X30.8 Y30.085
    N5231 G01 X30.824 Y30.086
    N5232 G03 X30.819 Y30.246 I-0.003 J0.08
    N5233 G03 X30.758 Y30.117 I0.003 J-0.08
    N5234 G01 X31.22 Y29.532
    N5235 G03 X31.346 Y29.631 I0.063 J0.05
    N5236 G03 X31.3 Y29.66 I-0.063 J-0.05
    N5237 G01 X31.277 Y29.665
    N5238 G01 X31.249 Y29.67
    N5239 G01 X30.974 Y29.811
    N5240 G01 X30.774 Y29.823
    N5241 G01 X30.566 Y29.748
    N5242 G01 X30.505 Y29.544
    N5243 G01 X30.444 Y29.31
    N5244 G01 X30.387 Y29.054
    N5245 G01 X30.327 Y28.726
    N5246 G01 X30.27 Y28.348
    N5247 G01 X30.212 Y27.834
    N5248 G01 X30.155 Y27.114
    N5249 G01 X30.124 Y26.393
    N5250 G01 X30.107 Y25.671
    N5251 G01 X30.097 Y24.949
    N5252 G01 X30.092 Y24.227
    N5253 G01 X30.089 Y23.505
    N5254 G01 X30.086 Y22.061
    N5255 G01 X30.084 Y20.617
    N5256 G01 X30.087 Y19.896
    N5257 G01 X30.085 Y19.535
    N5258 G01 Y19.354
    N5259 G01 X30.065 Y19.313
    N5260 G01 X30.03 Y19.286
    N5261 G01 X29.985 Y19.277
    N5262 G01 X29.286 Y19.455
    N5263 G01 X29.138 Y19.503
    N5264 G01 X28.962 Y19.553
    N5265 G01 X28.75 Y19.605
    N5266 G01 X28.507 Y19.655
    N5267 G01 X28.202 Y19.708
    N5268 G01 X27.812 Y19.761
    N5269 G01 X27.274 Y19.815
    N5270 G01 X26.554 Y19.861
    N5271 G01 X25.832 Y19.886
    N5272 G01 X25.11 Y19.899
    N5273 G01 X24.389 Y19.906
    N5274 G01 X23.667 Y19.91
    N5275 G01 X22.945 Y19.912
    N5276 G01 X22.223 Y19.918
    N5277 G01 X21.862 Y19.913
    N5278 G01 X21.681 Y19.915
    N5279 G01 X21.275 Y19.914
    N5280 G01 X21.234 Y19.934
    N5281 G01 X21.207 Y19.969
    N5282 G01 X21.197 Y20.014
    N5283 G01 X21.373 Y20.714
    N5284 G01 X21.422 Y20.875
    N5285 G01 X21.473 Y21.069
    N5286 G01 X21.525 Y21.296
    N5287 G01 X21.577 Y21.566
    N5288 G01 X21.631 Y21.914
    N5289 G01 X21.684 Y22.36
    N5290 G01 X21.738 Y23.009
    N5291 G01 X21.773 Y23.73
    N5292 G01 X21.792 Y24.452
    N5293 G01 X21.802 Y25.174
    N5294 G01 X21.808 Y25.895
    N5295 G01 X21.811 Y26.617
    N5296 G01 X21.813 Y27.339
    N5297 G01 X21.817 Y28.061
    N5298 G01 X21.808 Y28.783
    N5299 G01 X21.819 Y29.144
    N5300 G01 X21.816 Y29.325
    N5301 G01 X21.815 Y29.641
    N5302 G01 X21.835 Y29.681
    N5303 G01 X21.871 Y29.709
    N5304 G01 X21.915 Y29.718
    N5305 G01 X22.615 Y29.54
    N5306 G01 X22.791 Y29.49
    N5307 G01 X22.993 Y29.441
    N5308 G01 X23.235 Y29.39
    N5309 G01 X23.542 Y29.338
    N5310 G01 X23.925 Y29.286
    N5311 G01 X24.46 Y29.233
    N5312 G01 X25.18 Y29.187
    N5313 G01 X25.902 Y29.163
    N5314 G01 X26.624 Y29.15
    N5315 G01 X27.345 Y29.144
    N5316 G01 X28.067 Y29.139
    N5317 G01 X28.789 Y29.131
    N5318 G01 X29.15 Y29.137
    N5319 G01 X29.331 Y29.136
    N5320 G01 X29.827 Y29.138
    N5321 G03 X29.941 Y29.165 I-0.011 J0.3
    N5322 G01 X30.002 Y29.192 Z19.492
    N5323 G01 X30.06 Y29.219 Z19.47
    N5324 G01 X30.111 Y29.242 Z19.435
    N5325 G01 X30.154 Y29.262 Z19.387
    N5326 G01 X30.187 Y29.277 Z19.33
    N5327 G01 X30.207 Y29.286 Z19.267
    N5328 G01 X30.214 Y29.289 Z19.2
    N5329 G00 Z-3.01
    N5330 G00 X21.093 Y20.27
    N5331 G00 Z18.9
    N5332 G01 Z19.2 F1500
    N5333 G01 X21.086 Y20.272 Z19.267
    N5334 G01 X21.064 Y20.278 Z19.33
    N5335 G01 X21.03 Y20.288 Z19.387
    N5336 G01 X20.984 Y20.3 Z19.435
    N5337 G01 X20.929 Y20.316 Z19.47
    N5338 G01 X20.868 Y20.333 Z19.492
    N5339 G01 X20.804 Y20.351 Z19.5
    N5340 G01 X20.691 Y20.383
    N5341 G01 X21.333 Y20.298
    N5342 G01 X21.621 Y20.157
    N5343 G01 X21.83 Y20.147
    N5344 G01 X22.049 Y20.23
    N5345 G01 X22.252 Y20.426
    N5346 G01 X22.351 Y20.844
    N5347 G01 X22.438 Y21.28
    N5348 G01 X22.522 Y21.792
    N5349 G01 X22.597 Y22.381
    N5350 G01 X22.664 Y23.1
    N5351 G01 X22.705 Y23.821
    N5352 G01 X22.729 Y24.542
    N5353 G01 X22.744 Y25.264
    N5354 G01 X22.753 Y25.986
    N5355 G01 X22.758 Y26.708
    N5356 G01 X22.77 Y27.43
    N5357 G01 X22.752 Y28.152
    N5358 G01 X22.761 Y28.332
    N5359 G01 X22.76 Y28.512
    N5360 G01 X22.759 Y28.693
    N5361 G01 X22.763 Y28.918
    N5362 G03 X22.163 Y28.912 I-0.3 J-0.003
    N5363 G03 X22.488 Y28.616 I0.3 J0.003
    N5364 G01 X30.51 Y29.272
    N5365 G02 X30.559 Y28.674 I0.024 J-0.299
    N5366 G02 X30.438 Y28.688 I-0.024 J0.299
    N5367 G01 X30.327 Y28.726
    N5368 G01 X30.298 Y28.731
    N5369 G01 X30.023 Y28.872
    N5370 G01 X29.824 Y28.884
    N5371 G01 X29.615 Y28.809
    N5372 G01 X29.555 Y28.605
    N5373 G01 X29.493 Y28.368
    N5374 G01 X29.437 Y28.112
    N5375 G01 X29.376 Y27.784
    N5376 G01 X29.319 Y27.401
    N5377 G01 X29.261 Y26.883
    N5378 G01 X29.205 Y26.163
    N5379 G01 X29.174 Y25.442
    N5380 G01 X29.157 Y24.72
    N5381 G01 X29.147 Y23.998
    N5382 G01 X29.142 Y23.276
    N5383 G01 X29.139 Y22.554
    N5384 G01 X29.131 Y21.832
    N5385 G01 X29.147 Y21.11
    N5386 G01 X29.128 Y20.75
    N5387 G01 X29.134 Y20.569
    N5388 G01 X29.137 Y20.028
    N5389 G01 X29.14 Y19.938
    N5390 G03 X29.74 Y19.96 I0.3 J0.011
    N5391 G03 X29.341 Y20.232 I-0.3 J-0.011
    N5392 G01 X28.339 Y19.883
    N5393 G03 X28.536 Y19.316 I0.099 J-0.283
    N5394 G03 X28.726 Y19.518 I-0.099 J0.283
    N5395 G01 X28.75 Y19.605
    N5396 G01 X28.783 Y19.735
    N5397 G01 X28.877 Y19.884
    N5398 G01 X28.908 Y20.079
    N5399 G01 X28.853 Y20.291
    N5400 G01 X28.699 Y20.489
    N5401 G01 X28.35 Y20.56
    N5402 G01 X27.895 Y20.636
    N5403 G01 X27.4 Y20.7
    N5404 G01 X26.729 Y20.763
    N5405 G01 X26.008 Y20.806
    N5406 G01 X25.287 Y20.831
    N5407 G01 X24.567 Y20.889
    N5408 G01 X24.212 Y20.821
    N5409 G01 X23.687 Y20.901
    N5410 G01 X23.512 Y20.855
    N5411 G01 X23.332 Y20.859
    N5412 G01 X23.061 Y20.862
    N5413 G01 X22.926 Y20.863
    N5414 G03 X22.811 Y20.837 I0.009 J-0.3
    N5415 G01 X22.75 Y20.809 Z19.492
    N5416 G01 X22.693 Y20.783 Z19.47
    N5417 G01 X22.641 Y20.76 Z19.435
    N5418 G01 X22.597 Y20.741 Z19.387
    N5419 G01 X22.565 Y20.726 Z19.33
    N5420 G01 X22.545 Y20.717 Z19.267
    N5421 G01 X22.538 Y20.714 Z19.2
    N5422 G00 Z-3.01
    N5423 G00 X23.378 Y29.783
    N5424 G00 Z18.9
    N5425 G01 Z19.2 F1500
    N5426 G01 X23.375 Y29.776 Z19.267
    N5427 G01 X23.368 Y29.755 Z19.33
    N5428 G01 X23.355 Y29.722 Z19.387
    N5429 G01 X23.339 Y29.677 Z19.435
    N5430 G01 X23.32 Y29.624 Z19.47
    N5431 G01 X23.298 Y29.564 Z19.492
    N5432 G01 X23.276 Y29.501 Z19.5
    N5433 G01 X23.235 Y29.39
    N5434 G01 X23.23 Y29.363
    N5435 G01 X23.085 Y29.091
    N5436 G01 X23.068 Y28.892
    N5437 G01 X23.139 Y28.683
    N5438 G01 X23.32 Y28.626
    N5439 G01 X23.532 Y28.568
    N5440 G01 X23.796 Y28.505
    N5441 G01 X24.081 Y28.448
    N5442 G01 X24.44 Y28.39
    N5443 G01 X24.886 Y28.333
    N5444 G01 X25.505 Y28.276
    N5445 G01 X26.226 Y28.235
    N5446 G01 X26.947 Y28.213
    N5447 G01 X27.667 Y28.158
    N5448 G01 X28.022 Y28.226
    N5449 G01 X28.289 Y28.184
    N5450 G01 X28.469 Y28.183
    N5451 G01 X28.83 Y28.181
    N5452 G01 X28.92 Y28.182
    N5453 G03 X29.034 Y28.212 I-0.017 J0.3
    N5454 G01 X29.094 Y28.241 Z19.492
    N5455 G01 X29.151 Y28.268 Z19.47
    N5456 G01 X29.202 Y28.293 Z19.435
    N5457 G01 X29.245 Y28.313 Z19.387
    N5458 G01 X29.277 Y28.329 Z19.33
    N5459 G01 X29.297 Y28.338 Z19.267
    N5460 G01 X29.304 Y28.342 Z19.2
    N5461 G00 Z-3.01
    N5462 G00 X22.044 Y21.42
    N5463 G00 Z18.9
    N5464 G01 Z19.2 F1500
    N5465 G01 X22.052 Y21.417 Z19.267
    N5466 G01 X22.072 Y21.41 Z19.33
    N5467 G01 X22.106 Y21.398 Z19.387
    N5468 G01 X22.151 Y21.382 Z19.435
    N5469 G01 X22.205 Y21.363 Z19.47
    N5470 G01 X22.264 Y21.342 Z19.492
    N5471 G01 X22.327 Y21.32 Z19.5
    N5472 G01 X22.438 Y21.28
    N5473 G01 X22.467 Y21.275
    N5474 G01 X22.739 Y21.131
    N5475 G01 X22.939 Y21.115
    N5476 G01 X23.15 Y21.187
    N5477 G01 X23.341 Y21.361
    N5478 G01 X23.428 Y21.849
    N5479 G01 X23.508 Y22.409
    N5480 G01 X23.579 Y23.079
    N5481 G01 X23.63 Y23.799
    N5482 G01 X23.663 Y24.52
    N5483 G01 X23.683 Y25.242
    N5484 G01 X23.696 Y25.964
    N5485 G01 X23.723 Y26.686
    N5486 G01 X23.679 Y27.406
    N5487 G01 X23.692 Y27.496
    N5488 G01 X23.7 Y27.585
    N5489 G01 X23.708 Y27.766
    N5490 G01 X23.706 Y27.946
    N5491 G03 X23.107 Y27.917 I-0.3 J-0.015
    N5492 G03 X23.44 Y27.634 I0.3 J0.015
    N5493 G01 X29.55 Y28.329
    N5494 G02 X29.618 Y27.732 I0.034 J-0.298
    N5495 G02 X29.488 Y27.746 I-0.034 J0.298
    N5496 G01 X29.376 Y27.784
    N5497 G01 X29.242 Y27.809
    N5498 G01 X29.087 Y27.896
    N5499 G01 X28.891 Y27.916
    N5500 G01 X28.682 Y27.85
    N5501 G01 X28.493 Y27.686
    N5502 G01 X28.423 Y27.272
    N5503 G01 X28.355 Y26.753
    N5504 G01 X28.291 Y26.092
    N5505 G01 X28.247 Y25.371
    N5506 G01 X28.221 Y24.649
    N5507 G01 X28.206 Y23.928
    N5508 G01 X28.197 Y23.206
    N5509 G01 X28.177 Y22.484
    N5510 G01 X28.209 Y21.763
    N5511 G01 X28.201 Y21.673
    N5512 G01 X28.197 Y21.583
    N5513 G01 X28.193 Y21.402
    N5514 G01 X28.194 Y21.267
    N5515 G01 Y21.222
    N5516 G01 X28.174 Y21.181
    N5517 G01 X28.138 Y21.154
    N5518 G01 X28.094 Y21.145
    N5519 G01 X27.395 Y21.327
    N5520 G01 X27.242 Y21.379
    N5521 G01 X27.078 Y21.428
    N5522 G01 X26.882 Y21.479
    N5523 G01 X26.641 Y21.533
    N5524 G01 X25.931 Y21.665
    N5525 G01 X25.611 Y21.786
    N5526 G01 X24.89 Y21.753
    N5527 G01 X24.717 Y21.807
    N5528 G01 X24.533 Y21.823
    N5529 G01 X24.443 Y21.816
    N5530 G01 X24.353 Y21.805
    N5531 G01 X24.174 Y21.779
    N5532 G01 X24.13 Y21.787
    N5533 G01 X24.094 Y21.814
    N5534 G01 X24.074 Y21.854
    N5535 G01 X24.073 Y21.9
    N5536 G01 X24.381 Y22.553
    N5537 G01 X24.448 Y22.996
    N5538 G01 X24.514 Y23.568
    N5539 G01 X24.572 Y24.288
    N5540 G01 X24.608 Y25.009
    N5541 G01 X24.637 Y25.731
    N5542 G01 X24.667 Y26.452
    N5543 G01 X24.686 Y27.174
    N5544 G01 X24.658 Y27.259
    N5545 G01 X24.648 Y27.349
    N5546 G01 X24.649 Y27.439
    N5547 G01 X24.655 Y27.71
    N5548 G01 X24.675 Y27.75
    N5549 G01 X24.711 Y27.778
    N5550 G01 X24.755 Y27.786
    N5551 G01 X25.452 Y27.598
    N5552 G01 X26.152 Y27.42
    N5553 G01 X26.424 Y27.284
    N5554 G01 X27.145 Y27.244
    N5555 G01 X27.45 Y27.222
    N5556 G01 X27.863 Y27.198
    N5557 G01 X27.948 Y27.229
    N5558 G03 X27.722 Y27.785 I-0.113 J0.278
    N5559 G03 X27.535 Y27.518 I0.113 J-0.278
    N5560 G01 X27.301 Y20.705
    N5561 G03 X27.895 Y20.636 I0.3 J-0.01
    N5562 G01 X28.028 Y21.434
    N5563 G01 X28.085 Y21.62
    N5564 G01 X28.061 Y21.834
    N5565 G01 X27.937 Y22.051
    N5566 G01 X27.663 Y22.256
    N5567 G01 X26.959 Y22.415
    N5568 G01 X26.304 Y22.607
    N5569 G01 X26.259 Y22.602
    N5570 G01 X25.54 Y22.664
    N5571 G01 X25.446 Y22.684
    N5572 G01 X25.356 Y22.696
    N5573 G01 X25.176 Y22.709
    N5574 G01 X25.131
    N5575 G01 X25.086 Y22.713
    N5576 G01 X25.048 Y22.737
    N5577 G01 X25.024 Y22.776
    N5578 G01 X25.019 Y22.82
    N5579 G01 X25.268 Y23.498
    N5580 G01 X25.327 Y23.773
    N5581 G01 X25.387 Y24.113
    N5582 G01 X25.487 Y24.828
    N5583 G01 X25.597 Y25.213
    N5584 G01 X25.55 Y25.571
    N5585 G01 X25.649 Y26.16
    N5586 G01 X25.606 Y26.335
    N5587 G01 X25.618 Y26.515
    N5588 G01 X25.629 Y26.876
    N5589 G01 X25.631 Y26.966
    N5590 G03 X24.977 Y27.553 I-0.595 J-0.005
    N5591 G03 X24.453 Y26.847 I0.06 J-0.592
    N5592 G01 X25.482 Y21.569
    N5593 G03 X26.641 Y21.533 I0.584 J0.114
    N5594 G01 X26.955 Y22.942
    N5595 G01 X26.917 Y23.159
    N5596 G01 X26.783 Y23.362
    N5597 G01 X26.554 Y23.512
    N5598 G01 X26.376 Y23.543
    N5599 G01 X26.016 Y23.576
    N5600 G01 X25.926 Y23.584
    N5601 G01 X25.888 Y23.607
    N5602 G01 X25.863 Y23.645
    N5603 G01 X25.858 Y23.69
    N5604 G01 X25.873 Y23.732
    N5605 G01 X26.283 Y24.138
    N5606 G01 X26.431 Y24.505
    N5607 G01 X26.426 Y24.686
    N5608 G01 X26.562 Y25.104
    N5609 G01 X26.527 Y25.463
    N5610 G01 X26.52 Y26.185
    N5611 G01 X26.544 Y26.316
    N5612 G01 X26.563 Y26.495
    N5613 G01 X26.572 Y26.675
    N5614 G01 X26.593 Y26.715
    N5615 G01 X26.63 Y26.741
    N5616 G01 X26.674 Y26.749
    N5617 G01 X26.717 Y26.736
    N5618 G01 X27.12 Y26.366
    N5619 G01 X27.469 Y26.245
    N5620 G01 X27.559 Y26.251
    N5621 G01 X27.65
    N5622 G01 X27.69 Y26.231
    N5623 G01 X27.717 Y26.195
    N5624 G01 X27.726 Y26.151
    N5625 G01 X27.715 Y26.107
    N5626 G01 X27.383 Y25.725
    N5627 G01 X27.27 Y25.366
    N5628 G01 X27.308 Y25.007
    N5629 G01 X27.221 Y24.381
    N5630 G01 X27.27 Y24.207
    N5631 G01 X27.228 Y23.486
    N5632 G01 X27.266 Y23.127
    N5633 G01 X27.255 Y23.038
    N5634 G01 X27.247 Y22.948
    N5635 G03 X27.264 Y22.832 I0.3 J-0.015
    N5636 G01 X27.287 Y22.769 Z19.492
    N5637 G01 X27.308 Y22.709 Z19.47
    N5638 G01 X27.327 Y22.656 Z19.435
    N5639 G01 X27.343 Y22.611 Z19.387
    N5640 G01 X27.355 Y22.577 Z19.33
    N5641 G01 X27.363 Y22.557 Z19.267
    N5642 G01 X27.365 Y22.549 Z19.2
    N5643 G00 Z-7.
    N5644 M05
    N5645 M30
    Thanks!
    Feb 2009
    Default Re: Fusion 360 CNC opposite Z axis and tool cutting in the air
    The Z moves look to be inverted. What we really need to see is your design file from Fusion. It's likely you have something setup wrong.
    C|
    Jan 2005
    Did you select the bottom of the part as the Zero position in the CAM?
    Also, you can post a .txt file rather that the whole g-code in the thread.
    Feb 2009
    Quote Originally Posted by 109jb View Post
    It looks to me like the part orientation is probably flipped in the job setup.
    C|
    Dec 2013
    Quote Originally Posted by cygnus x-1 View Post
    C|
    Hi Cygnus,
    I've attached the 3 files that I tried. I've also tried all sort of different setup with different WCS origin, etc.. Could you please have a look at the attached files and let me know what I'm doing wrong as they are all cutting in the air.
    Will do next time, sorry about that.
    C|
    Could you please explain where is the job setup orientation configured please?
    Thanks!
    Attached Files Attached Files
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    If you go through the learn section of the fusion forum it would help you a lot Help
    <img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
    Being Disabled is OK CNC is For fuN
  7. #7
    Dec 2013
    Quote Originally Posted by daniellyall View Post
    Hi daniellyall,
    I did, I spend like 4 days going through the tutorials and some webminars as well..
    Just couldn't find out why the Z-axis is moving up instead of going down for machining.
    cheers
  8. #8
    Sep 2009
    New Zealand
    the first file in your attached files was fine, you would be better of asking this on the fusion forum. it could be a post problem as well
  9. #9
    Oct 2008
    UK
    If you go back to setup and select the z axis arrow does it reverse it?
  10. #10
    Dec 2013
    Quote Originally Posted by JQ_Quint View Post
    No,
    I tried reversing the Z-axis in the setup and still won't fix the issue.
    So, the fix is to untick "Invert Z-coordinates" in WinPC NC. By default its tick and works fine with Aspire Vectric. For Fusion 360, you need to untick it and it should work. I tried cutting in the air and it seems to work. Tomorrow I'll try cutting some wood and I'll confirm.
    Fusion 360 CNC opposite Z axis and tool cutting in the air-invert-z-coordnates-png
    Thanks!
  11. #11
    Feb 2017
    I've replied on the Autodesk Fusion forums. The issue is in the Post Processor. The Z is being scaled to -1, which will reverse the Z axis. Suggest changing it and saving it to an area that is NOT the generic post folder.
    https://forums.autodesk.com/t5/compu...t/false#M24531
  12. #12
    Dec 2013
    Quote Originally Posted by liberty_machine View Post
    Thank you liberty_machine, i'll edit the post and set the scale to 1. Will test and update this thread.
    thanks
  13. #13
    Dec 2013
    Quote Originally Posted by spykey View Post
    thanks
    Hi liberty_machine,
    Changing the scale from -1 to 1 in the post did fix the z-axis movement.
    Thank you very much for yourhelp,
    Cheers!
