Patterning a 3D feature 40x20 times doesn't give me this issue.
Is a 40x20 pattern of a simple square really too much? I'm trying to model a vacuum table and my 40x20 pattern is absolutely destroying fusion 360. It runs great otherwise, but I turned down all the graphics settings regardless. Not surprisingly, didn't help. This is a sketch pattern. Using spacing, not extent.
When you do patterns you pattern feature not sketch, Yes sketch patterns blow, pattern feature is fine
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
Fusion certainly has a long way to go yet in terms of sketching performance. But even still, sketch patterns should only be used when absolutely necessary. Feature/component patterns are nearly always faster and easier to work with.
C|
