More likely a machine setting. Are you using G61 or G64
Hey guys, this issue has been driving me crazy for awhile now, and I don't know if it can be solved.
Whenever my machine reaches a corner or any radius, the machine pauses for a micro-second just before the corner/radius, then continues around the corner/radius and moves on.
Is there a way to keep the machine from doing this? It's causing tool marks on all of my parts.
Is there a setting in Fusion 360 that I can check to make sure the machine doesn't do this?
What control software are you using? In Mach3, there's a status bar listing the currently active g-codes.
UCCNC 2017 Screenset
Turn off CV Distance and CV Feedrate if they are on.
Check on the Settings page as well.
Those settings are for different things, but almost as bad as using exact stop mode. Talk about getting the jerk around.
Lee
Ideally, you want the cutter to slow down a bit in high speed machining so you're not putting crazy torque on your machine. Stopping completely is a little much though. You can control the acceleration and deceleration in mach which will override any jerky moves you might program, and fusion also has variables for acceleration and deceleration which can be useful for speeds faster than you're used to..
Make sure you are use I and J there is a problem with useing R
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
