Is there a reason I can add tabs to a 2d contour but not a 3d contour? Is the option elsewhere and I'm missing something?Similar Threads: Alternative to tabs for work holding? Double-sided tap? 0.5mm thick, long tabs? 2D contour toolpath, manual tabs Inventor HSM Express – the Free CAM Solution for Inventor users – Beta Invitation 2d Tabs on contour to hold part in blank 2D Adaptive
3d contour has a totally different use than a 2d contour. I'm not sure what you're trying to do but you can always model in your own tabs if necessary.
View Tag Cloud
Forum Rules
