- China lathe turret. Horizontal Ld4
Hello some electrician question. Due to customer request we bought an lathe tool turret . The handbook only writes about. 400v so I asked the seller Is there a 230v ac version he sayed yes.
So maybe someone had same problem I got the machine and the power cables are a plug of 4 one looks like earth ( yellow black) the other 3 are just black
Is there a hint how to get that motor turning even if slower or less. Speed
Is there a condensator or so needed? Ideally someone had same issue or similar the control. And low voltage we sort out thx for your help. Thomas
Gesendet von iPad mit Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
