Looking for a cheap ATC spindle - is there such a thing?
Results 1 to 7 of 7
Thread: Looking for a cheap ATC spindle - is there such a thing?
    Member guru_florida's Avatar
    Nov 2007
    Default Looking for a cheap ATC spindle - is there such a thing?
    An sub-$1500 ATC VFD spindles out there? Or am I just full of wishful thinking. I am looking at one the chinese spindles but they arent ATC able. I am looking to do aluminum, probably around a 2.3 - 3Kw motor. Could do more. I am upgrading from a simple Taig spindle and I want to increase my DOC and IPMs. Not concerned much about the toolholder type, BT, ISO, etc...as long as the toolholders are not expensive or hard to find...BT probably. I am not an expert here either. I've been reading a lot lately but dont know much about VFDs out there.
    Thanks,
    Colin
    Jun 2007
    canada
    Default Re: Looking for a cheap ATC spindle - is there such a thing?
    wishful thinking.
    you can get a belt drive bt30 spindle under $1000us. then you need a motor, pulley, belt, drive, tool release mechanism, air regulation and solenoid systems, wiring, mounting block/plates/adapters etc. probably north of $3000 by the time youve got it running.
    for internal motor spindles, its usually more. $4000 min all in - even for cheap chinese ones.
    Nov 2007
    I figured so after searching but wanted a second opinion. Thanks! I will go for a chinese spindle for now from CNCShop on Amazon. Should be better than what I have now and will be a good learning experience before investing $3500 or more later.
    I can't believe Walmart is selling CNC tooling though. shocking.
    Jun 2007
    canada
    Quote Originally Posted by guru_florida View Post
    walmart (and sears) in the US sells everything online, kinda like amazon. sadly they dont actually have that stuff in actual stores (that i know of)
    Registered Machinaria's Avatar
    Nov 2009
    Nov 2009
    this one is for 65mm spindles
    Automatic Tool Changing Systems CNC CATLooking for a cheap ATC spindle - is there such a thing?-china_water-cooled_spindle-jpg
  7. #7
    May 2017
    Brazil
    Have any of you used this adapter ?? I need to talk to someone who have used it.
