Originally Posted by
civilseal
Hello
I have a proximity switch which the spindle move very slowly and then stops when passing this but the spindle has so low friction that it does not stop relaiably and sometime the timing belt to the motor makes it go backward a little bit after stopping.
So I wonder if I can use DC braking or something to make the spindle a little harder to turn?
Or any other suggestions?
I though about installing a small air cylinder to either press against the spindle to break it or to push in the cylinder so that the spindle stop agains a cam on the spindle but it would be best if it could be solved without any extra equipment :/
