Results 1 to 3 of 3
Thread: RFQ: Aluminium Cover
    Dec 2011
    Hi guys,
    I'm looking for something relatively simple to be done in 6mm thick aluminium (or steel if its alot cheaper) the size is about 40cm x 13cm
    I also have the DXF file for this: cover.dxf
    Cheers,
    Ben
    Jan 2009
    Hi there:
    This would be relatively easy for me to do for you. I work exclusively in aluminum, 6061 T6, for the most part.
    I am curious as to the quantity of parts you need made.
    Also what is your "needed" date to receive the finished materials.
    Aluminum stock is reasonably priced, for the most part, and easily available, although not easily obtained in milometer thickness plates. What would be an acceptable thickness in "imperial" measurements that would suite your purpose?
    Shipping from the U.S. to Australia is not cheap, but if longer shipping times are tolerable, then that higher cost too can be overcome to some extent.
    You can see the kinds of stuff that I build at my web site:
    All My Products
    If you wish to email me directly you can at: george@mrrace.com
    Thanks for the opportunity to be of service,
    George Race
    Race Consulting
    Dec 2011
    Hi George,
    Thanks for replying, I'm sending you an email now.
    -Ben
  1. RFQ - Clip On Nut Cover
    By andygp in forum RFQ (Request for Quote)
    Last Post: 06-27-2011, 06:35 AM
  2. Aluminium passivation - for aluminium to be used outside
    By hudsonlighting in forum Mass finishing equipment/media/stratigies
    Last Post: 04-06-2011, 01:06 PM
  3. VF2 Z way Cover
    By Mic6 in forum Haas Mills
    Last Post: 07-10-2008, 03:18 AM
  4. Way cover repair?
    By SRT Mike in forum General Metal Working Machines
    Last Post: 09-12-2006, 11:14 AM
