Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 12-31-2009, 09:10 PM
Djayness is on a distinguished road
Help me with my CNC for a case of beer.
Well it finally arrived and it was the biggest hassel ever to get this thing cleared by customs as there was an unbelievable amount of duties, tax, port charges, etc etc etc to pay on the way to picking it up.
Only thing is, I have never used a CNC before and I am totally new to all this.
I am leasing a small area at a factory to do my work and got it back into Brisbane for some unloading.
If anyone in Brisbane wants to come over and help me out for a case of beer then let me know. Contact me at epicpccases@gmail.com !
Problems so far
1. I cant find "the control card" where you plug in the power and usb
2. I havent explored what software is needed, I have autocad and they sent me "type 3". Is this all I need?
Old 01-01-2010, 01:05 AM
KIMFAB's Avatar
KIMFAB is on a distinguished road
Kick in plane fare and you're on.
I used to be appalled, now I'm just amused.
Old 01-01-2010, 01:36 AM
D.L D.L is offline
D.L is on a distinguished road
Wow, a nice bit of kit!
Be very careful for wiring the steppers to the driver cards, if the wires are not screwed into the control card you'll need an ohm meter to rectify and doubly check the hookup of cable.
If not, a puff of expensive smoke could come from your new toy.
An old pentium 4 running windows XP SP2 and mach 3 will be a treat. (switch off the firewall and the powersave / screensaver)
A null modem cable from the printer port on the computer to the printer port on the driver should be correct.
Carefully read the help files in mach 3 and your machine manual.
Tuning the motors will take patience, also the limits and travel settings are a nail biter when over travelling. (expensive things can happen when crunching)
Learn cad cam, night school tafe!
I'm in Melbourne so no cigar on the slab, by all means this forum will find you many top shelf home cncer's who will lend an ear and their time.
Best of luck.
D.L
Old 01-01-2010, 06:37 AM
It didnt come with a power cable so I dont know where to plug it in and I dont know if it came with a controller card since I cant find anywhere to plug it to the computer.
Am I suppose to buy these things?
Old 01-01-2010, 08:14 AM
mactec54 is on a distinguished road
Hi Djayness
That should be all the sofware that you need to get running, you will have to learn the Type3 as it is avery good software, you design the parts in your autocad & then take your drawing into Type3 to do your tool path/ G code for the machine control,
I think your machine is complete, just put power to the mains input, do you have the pendant, if not you may be missing some parts, open the cabinet on the side & see what is in there, everything may be packed in there.
The spec seem to say you should have everything to get running
Product Description
K6100A Series
Technical Parameter:
Model K6100A
X-Y-Z axis working area 600 x1,000 x 120mm
Machine size 1,300 x 1,700mm
Resolutions 0.025mm
X-Y-Z movement Ball screw drive/Germany
Max. speed 10,000mm/min
Max. cutting speed 6,000mm/min
Spindle 1.5kw
Spindle speed 18,000rpm
Inverter power 1.5kw
Drive motors stepper
Working voltage AC220V/50-60Hz
Command code G code
Computer interface USB 2.2
Collet ER25-12.7mm,6mm,3.175mm
Software Type3 Software/France
Controls DSP0401 (Digital Signal Processor)
Mactec54
3d beer mug zachf Vectric 0 06-10-2009 11:27 AM
Beer Can Launcher Build bigz1 CNCzone Club House 3 02-28-2007 07:53 AM
Beer-Fest '06 HighSpeed Trade Shows and Events 0 07-20-2006 09:53 AM
Beer drinking Bear!! HomeCNC CNCzone Club House 1 08-18-2004 10:28 PM
No more beer smilies.......... ynneb CNCzone Club House 9 07-26-2004 09:12 AM
