Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 07-14-2009, 01:09 PM
rocket67 is on a distinguished road
Joe`s 2006 R2 CNC. Has anybody cut the parts?
Hi Fellas, We have offered to help forum member BananaBoat by cutting out the MDF parts for his DIY build of a Joe`s R2 CNC Router.
There appears to be a couple of stumbling blocks to doing this.
1) The Solid Works files are in DWG format - which i believe means that we cannot import the files into V Carve Pro to create toolpaths and G Code to machine the parts.
2) The files need to be converted to Metric sizes in order to use our standard board sizes.
Has anybody succeeded in doing this? I have read quite a few threads on the forum where people have asked the same questions - but cannot find the answers.
From what i read there seems to be a lot of interest in DIY machines - so if anybody is willing to share - or help to create the files in V Carve Pro- we would be willing to asist members in cutting these parts for them.
Our new machine arrives mid August - so there is no rush.
Any takers? Would a carton of Crownies help? Unfortunately my computer skills are not good - so any help is much appreciated.
Here is a pic of our soon to arrive 1200 x 2400 CNC Router.
Thanks in advance.
Rocket.
Old 07-15-2009, 03:20 PM
I have been doing some research on this machine. Some results of this -
Joe will allow people to download his plans and build this machine for their own personal use - Not to be used for any commercial purpose.
Joes Website http://www.joescnc.com/kitsplans.php
The download ( Zip file ) http://rs134.rapidshare.com/files/13...l_2006_R-2.zip
One of Joes threads -very useful http://cnczone.com/forums/showthread.php?t=17279&page=4
My only interest in this is to find a file to cut the parts for another forum member. Does anybody have a file in V Carve Pro, or a file that can be imported into it.
Rocket.
A couple of photos of the kit - as supplied in the USA by joescnc.com
Name:	Wood Joes CNC.jpg‎
ID:	84457   Click image for larger version
Name:	Wood%201 More of Joes CNC.jpg‎
Old 07-15-2009, 06:08 PM
ger21's Avatar
If you download that .zip file, you'll find .dwg files that you should be able to load into V-Carve Pro. Is your MDF 18mm or 19mm down there? I haven't looked closely at the plans, so you may need to make some small changes to accommodate different thicknesses.
Old 07-16-2009, 12:08 AM
Hi Ger21, I have checked with our MDF supplier and found out that in Australia we have 18mm thickness.
The metric conversion of 3/4" to mm is 19.05. So we could machine a 25mm board down to 19.05mm, or as you suggest - change the dimensions to suit the 18mm board. Not sure which way to go yet.
Found another good thread which has a file for nested base cutting of the MDF board -
http://cnczone.com/forums/showthread.php?t=53757
Look at post no.2 from Joe.
For interested members, we will post more on this subject as progress is made.
Rocket
Old 07-17-2009, 06:49 PM
Excellent reading
Found this thread in the DIY section of the forum.
It is the story of two school students who built a joescncR2 machine using the cnc router in their wood work classes.
http://cnczone.com/forums/showthread.php?t=46425
Lots of great photos of the machine near the end.
Rocket.
Old 07-18-2009, 10:55 PM
Matty Zee is on a distinguished road
Hey Rocket,
Just sent you an email about this. I'd be happy to help create the V-carve files. I'll pop down sometime and help you out. I can mod the files to metric if you want as well.
Cheers
MattyZee
Old 07-18-2009, 11:43 PM
Matty, you are a legend.
I have scoured the forum looking for a thread where somebody has converted the files to metric specifications. Found lots of threads where people wanted to - but nobody followed up.
Appreciate it mate.
Rocket.
Old 07-19-2009, 06:38 AM
dhenry is on a distinguished road
Smile Converting drawings to metric
MDF forms a surface skin when pressed. To machine 25mm to 19mm would seriously reduce it strength. You would better to use 18mm with a 1 mm spacer where needed or to convert your plans to metric. If you can get me full solidworks plans I will convert them to metric for you.
Rocket
Old 07-19-2009, 09:39 AM
BananaBoat is on a distinguished road
I really wish Joe would update his plans for us Aussie battlers...!
C'mon Joe!
Old 07-19-2009, 09:45 AM
dhenry
you can grab them from here
http://b16a.gotdns.com/downloads/Joe...l_2006_R-2.zip
I sure hope you can convert these in Solidworks!
many thanks
  #11   Ban this user!
Old 07-19-2009, 09:24 PM
Smile File does not help
The file you sent me is an XML file. While I can read and veiw it I need the viewer file.
What I would like best is a PDF of the drawings so I can draw them in from scratch using standard metric components. What do you want back drawings or tool paths?
I have just designed an all aluminum mill 1200*600*150 which I will but on the forum shortly.
Doug
Originally Posted by BananaBoat View Post
dhenry
many thanks
  #12   Ban this user!
Old 07-20-2009, 02:11 AM
The link I provided it to a zip file, within it it contains various versions of the drawings, from Solidowrks, ProE to sketchup and DWG files.
WTD: nested parts for Joes 2006 R2 zachjowi Joes CNC Model 2006 3 01-28-2011 07:13 PM
Arboga G2508 Parts, Parts List, Manual omnimfg Want To Buy...Need help! 0 04-03-2009 12:59 PM
Need Help!- Starting a JOE 2006 Long parts cutting question Bimmerkc1 DIY-CNC Router Table Machines 5 07-01-2008 04:51 PM
Starting to cut my first Joes 2006 parts aolshove Joes CNC Model 2006 4 11-24-2007 08:48 AM
2006 jybute GibbsCAM 0 09-26-2006 01:45 PM
