Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 05-11-2009, 12:05 AM
cnc spook is on a distinguished road
a copper thread ?
has any one herd of a copper thread as such British standard copper ? i have and old thread chart with it on it. never seen it befor but we have and old grinder that we pulled down and the lead screw has such a thread. as we will be machineg this thread i need some more info on it if anyone can throw some light on this it would be great thanks
Old 05-11-2009, 05:15 AM
E.H.Bell is on a distinguished road
a copper thread
Just Google and you will find many references
such as http://www.engineeringtoolbox.com/co...sure-d_20.html
--- Hope this helps
signed Edward H. Bell
Old 05-11-2009, 05:21 AM
british copper threads
My apologies for the incorrect reference that I previously cited. My haste is embarrassing
- I did find this wiki reference as a possible source
http://en.wikipedia.org/wiki/British_Standard_Whitworth
- British Brass Thread is an imperial unit based screw thread. It adopts the Whitworth thread form with a pitch of 26 threads per inch for all diameters. It is often wrongly called British Standard Brass but is not actually covered by a British Standard.
Nominal sizes are usually in the range 1/8 to 2 inches.
Old 05-11-2009, 06:12 AM
Doug Baker is on a distinguished road
screw thread
Is the pitch of the tread 26tpi?
Regards
Doug
Old 05-11-2009, 06:42 AM
BSCopper
I found the following references
http://en.wikipedia.org/wiki/British...d_brass_thread
which states .......British Brass Thread thread is an imperial unit based screw thread. It adopts the Whitworth thread form with a pitch of 26 threads per inch for all diameters. It is often wrongly called British Standard Brass but is not actually covered by a British Standard.
another reference
which states ...... Other threads that used the Whitworth 55° angle include Brass Threads, British Standard Conduit (BSCon), Model Engineers (ME), and British Standard Copper (BSCopper).
I also found this in another forum
BA - British Association aka British Attachment
BSP - British Standard Pipe
BSB - British Standard Bicycle
BSF - British Standard Fine
BSC - British Standard Course
BSW - British Standard Whitworth.
BSBrass British Standard Brass
BSCon - British Standard Conduit
BSCopper - British Standard Copper
ME - Model Engineers
UNF - Unified National Fine
UNC - Unified National Coarse
NP - National Pipe
AN - Airforce/Navy.
ISO Metric Coarse (the common one)
ISO Metric fine (everyday but not as common as coarse, found for example on TRE's on modern cars)
With all things threadlike, a Zeuss chart, thread gauges and a micrometer/dial caliper are your friend.
here is a link to a Zeuss Chart
http://www.diytools.co.uk/diy/Main/s...zeus-chart.asp
I checked my various musty hard bound books and could not find anything more on this thread's dimensions
- that' all that I have on BSCopper
Old 05-11-2009, 06:45 AM
niggle is on a distinguished road
If it's a lead screw I'd doubt it's 26tpi?
If possible I'd consider machining a new leadscrew and nut either Acme or Metric Trapezoidal thread form.
You could even consider putting a new ballscrew inplace of the leadscrew.
Old 05-12-2009, 12:56 AM
bs copper
the zues chart does not cover B.S.copper and its not in machinery handbook.
the lead screw is an acme thread but the thread in question is for a attachment on one end of the shaft (lead screw). niggle its a 20 TPI thread
Old 05-12-2009, 01:02 AM
Talking b.s. copper
hey a modified whitworth thread ay. Thats awsome thanks guys that helps alot .
Need Help!- Thread spec for camera lens filter thread cmays General Metalwork Discussion 3 08-22-2010 02:14 PM
acme thread combos and thread mixing calaber40 Linear and Rotary Motion 5 05-15-2009 09:04 PM
Copper milling? jinu117 General Material Machining Solutions 4 11-29-2007 06:49 AM
copper? bowhunter General Metalwork Discussion 13 04-26-2007 01:41 PM
what tip to use for copper? HawainPand General Metalwork Discussion 1 09-22-2004 04:30 AM
