| Hi all. I am a total newcomer to milling, CNC and this site, so I would appreciate some help please. I have a Taig 3-axis CNC mill with Mach3Mill 3.04 software, and I need to cut PCB traces. I'm using a slow feed, and cutting a large(ish) PCB takes a long time. The problem is I need some sleep and (more importantly) my wife hates the noise. I noticed that Mach3 has a 'Pause' button. I pause the software no problem, but how do I make everything continue from there? My idea is to pause the software, turn off the mill and controller for a while (ie get some sleep), and then turn on the mill etc and continue from where I paused. How do I do that? Your help would be appreciated! Thanks Russell Archer racher2@unitec.ac.nz |
In the morning, hit F5 to turn the spindle back on and then hit start. cntrl/s If your machine has home switches, you could shut down completely and then do a start from here after homing the machine befroe resuming cutting. You would just need to remember which line you stopped on and make sure to turn the coolant and spindle on before restating from that line you stopped on. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| TotallRC gave u a very concise and easy-to-understand explanation... I normally do that when i get some problem.like...If i see my tool going to strike the holding clamp, i just press the pause button..adjust the clamp and then press the start button... |
| An alternative is to split up the milling tasks. So you only do a portion of the job, then load the next file. One one job has finished, you can return the CNC to a known position by the command line, such as G0x0y0z10 and turn everything off. You will likely only loose the precision of <1 step. How big are the PCBs though? It may be you can decrease the time to mill the PCBs by using faster feedrates (including Z axis), lower tool clearance from surface, better V-tips / fast spindle RPM and using 90 degree V-tips to remove bulk areas to save time. I usually mill the copper tracks around 1000mm/min at 20,000rpm with a 60 degree bit. Z axis at 350mm/min with 2mm clearance. Sometime bump the X/Y to 1200mm/min (if I'm impatient). |
I have split my 5 hour run time g-code programme into 5 x 1 hour sections returning to X0 Y0 Z5 as you suggested Turning off in between sessions so far I have only done two but I can see it will work Thank you. |
Hello I am not making PCBs I am hobbyist making small ( 8" x 4" x 3") 3D vacuum forming moulds, trying to fit my hobby around my job and family so I do not get long consecutive periods in my workshop. I have a micro mill (toy) that will not attain the feed speeds that you mention. Now a can do an hour each night it will help my project along. Paul |
#10
| Here is the way I've "paused" then restarted. When you need to break off press "stop" and note the line number (presuming you have them, otherwise use edit to insert one) and write down the number. Go to zeros and shut down. When you need to resume set zeros to current position and use run from here. You can give yourself a few lines leeway and let the machine retrace some of it's work.
__________________ "Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson |
#11
| The only problem with shutting down and then restarting from a line is if you don't have home switches you can be a supprising amount of when you restart. You can be a few steps off when you repower the drives. Mike
#12
| That is why you "go to zeros" before shutting down and reset everything to zero when you start up again! :-)
| Tags |
| continue, mach3, pause |
| MACH3 -> LPT Problem! Help. | spotlite | Mach Mill | 3 | 08-06-2008 07:37 PM |
| mach3 problem | cicio | Australia, New Zealand Club house | 3 | 02-21-2008 02:54 AM |
| problem with Mach3 | jed102 | Mach Software (ArtSoft software) | 5 | 01-27-2008 04:38 PM |
| Problem with Mach3 Brains... | Jonne | Mach Wizards, Macros, & Addons | 3 | 01-14-2008 06:48 AM |
| Problem with Mach3 | SCOTTY76SA | SheetCam | 3 | 05-27-2007 08:34 AM |
