Page 3 of 10 FirstFirst 123456 ... LastLast
Results 25 to 36 of 119
Thread: Diy steel router build
  1. #25
    Registered robe_uk's Avatar
    Apr 2005
    Northern Ireland
    Great build Michael,
    Can i ask you what size your gantry aluminium extrusion is and how stiff and rigid is it?
    Am currently planning my mk2 router and was considering a mdf gantry but have just found a UK site that has 45x90mm 1meter lengths for GB£23 which would be an acceptable price, any bigger and the cost rocket.
    Thanks Rob
  2. #26
    Jan 2009
    Hi there,
    Great job, I was wondering if we could have a chat, would contact me through eme@iinet.net.au,
    Regards
    Doug Baker
    Scarborough 6019
  3. #27
    Registered mkc2's Avatar
    May 2008
    Perth ,Australia
    Hi Rob
    The gantry size is 80mmX 80mm with the guides top and bottom, the lenght is 730mm and no flex, a lot stronger then i thought and very pleased with it.
    cost $50au.
    Hi Doug
    will give you a call to chat.
    cheers Michael
  4. #28
    May 2008
    Perth ,Australia
    Cut up all the 16mm plate for my y axis last night, should have this fitted during the week once i pick up some more caps screws.
    Cheers Michael
  • #29
    May 2008
    Perth ,Australia
    Diy Steel cnc upgrade
    Put in a few more hours after work,
    Cheers Michael
    Attached Thumbnails Attached Thumbnails Diy steel router build-dsc04217.jpg   Diy steel router build-dsc04218.jpg
  • #30
    May 2008
    Perth ,Australia
    CNC Upgrades
    Time for some progress updates, Z axis nearly completed.
    Cheers Michael
    Attached Thumbnails Attached Thumbnails Diy steel router build-dsc04223.jpg   Diy steel router build-dsc04224.jpg   Diy steel router build-dsc04225.jpg   Diy steel router build-dsc04226.jpg
  • #31
    May 2008
    Perth ,Australia
    Last update before xmas, z and y axis completed and running, mounted my router.
    Next step is to buy 12mm Ali plate for table top and a small piece for the front top section of the table, that way I can do edge facing.
    Cheers Michael
    Attached Thumbnails Attached Thumbnails Diy steel router build-dsc04240.jpg   Diy steel router build-dsc04241.jpg
  • #32
    Registered voltsandbolts's Avatar
    Aug 2005
    U.S.A.
    Hi Michael,
    You’re machine looks great and you have made some nice upgrades with the precision rails and guides. Have you noticed much improvement over the angle and bearing guides you removed and what voltage is you stepper power supply. Thanks for posting all the photos.
    Rob Wms
    Deeds not words...
    VoltsAndBolts is The Geek in the Garage! http://www.geekinthegarage.com/
  • #33
    May 2008
    Perth ,Australia
    Hi Rob
    Thanks for those great comments.
    The power supply is 72V dc .
    Upgrading to linear bearing guides seems to run a lot smoother, less weight and racking.
    The skate bearings on the angles were ok for starters but the angles need to be hardened steel as they start to wear.
    Cheers Michael
  • #34
    May 2008
    Perth ,Australia
    Click plc
    Install a cheap plc to handle all my inputs and outputs.
    It was very easy to set up as I'm a beginner with plc's.
    koyo click plc Price $120.00, supplied from automation direct.
    Cheers Michael
  • #35
    May 2008
    Perth ,Australia
    cable carrier chain fitted, turned out ok .
    cheers Michael
    Attached Thumbnails Attached Thumbnails Diy steel router build-dsc04255.jpg   Diy steel router build-dsc04254.jpg
  • #36
    May 2008
    Perth ,Australia
    back with some more updates.
    replaced the bottom beam on the gantry with 16mm ali plate, fitted all the limit switches, 12mm table top fitted, now just need to make some clamps and make a new dust boot for the shopvac.
    more to come!!
    cheers Michael
    Attached Thumbnails Attached Thumbnails Diy steel router build-dsc04320.jpg   Diy steel router build-dsc04327.jpg
  • Page 3 of 10 FirstFirst 123456 ... LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
      By Womble in forum DIY CNC Router Table Machines
      Last Post: 09-27-2008, 08:51 AM
    3. First Router Build - 4x4, steel, R&P
      By cxixer in forum CNC Wood Router Project Log
      Last Post: 02-09-2008, 03:15 PM
    4. Steel C-channel Build - Questions and pictures
      By olskool in forum DIY CNC Router Table Machines
      Last Post: 07-07-2007, 02:31 AM
