OK i slammed McJings as they are mongrels but there are great traders out there too www.Oztion.com.au has a new vendor George Vesley who has stopped trading on ebay and moved to Oztion where he is "offcuts-galore" i have been buying from him for over a year. 0ver 100 purchases to date all exactly as described and realistic starting prices. 4140, 4130, 1020, 1030, 1040 steel tool steels 2011 6T, 6061 6T Aluminium brass copper stainless Delrin sintered metals he has 40 tonnes of offcuts as a minimum stock level if you dont see it ask.. he has been able to get me everything i have ever needed with the exception of 0.6mm spring steel sheet ( i needed 8, 1200 x 1800 mm sheets, he had 2 only) i did a comparision of his prices v's other places and found his stuff 20% cheaper on average and never higher.. ( unless you go crazy at the auction) i would have posted this in the suppliers lists but its locked cheers folks jack |
| Agree with you on this one Jack ![]() I just received my latest bits and pieces from George. I wasn't aware that he would source stuff for you, must remember that. Getting metal (aluminium in my case) in small amounts is very hard in Sydney.
__________________ Regards Geoff |
| one more tip about george he gets Kilo lots of tool bits! i got one and only one bit was worn!! in the one kilo lot i recived there where 15 mills (metric 2 and 4 flutes sizes 4mm -16mm) there was 3 Taps that i did not need ( i work small stuff mainly) but used one to make a reamer for a MT3 taper shaft the other big tap i'll get around to make a offset taper centre paid $20 for the lot! a single woodruff cutter is $25 and i got a 1/8" and 1/4" wf cutters in the deal. still in the plastic!!! and in his last email he is getting some more packs together ready to auction in the coming days. maybe i'm cutting my throat on these as there have been few bids on these packs to date but what the heck the more the merrier i say cheers folks jack PS where you bidding on the thick wall 25mm OD tube?? if so, sorry but the alternative was a full length so i did go silly on it but still way cheaper than a lenth of tube i'll use 280mm of and probably never use again ( 4mm wall) |
| Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? | vroemm | Linear and Rotary Motion | 7 | 08-16-2007 12:26 PM |
| where do you all get your supplies at? | boosted | General Metal Working Machines | 6 | 07-05-2007 11:54 AM |
| How many power supplies?? | biotech1 | General Electronics Discussion | 1 | 02-07-2007 07:13 AM |
| Accessible Supplies | RepairmanSki | Open Source CNC Machine Designs | 2 | 06-15-2006 02:46 PM |
| mcmaster supplies 80/20! | sixpence | 80/20, TSLOTS and other Aluminum Framing Systems | 3 | 03-15-2005 12:22 AM |
