Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 05-24-2008, 04:11 AM
rocabig's Avatar
rocabig is on a distinguished road
Angry need to find a replacement stepper motor urgently
Today whilst V carving a photo to a max depth of 1 mm in pine on my shg - 609 my z axis stepper motor snapped its drive shaft at the lower bearing ( see attached photos) i need a new one asap and would like to know if anyone knows where in Brisbane i can go to get a new one and an approx price.
all the info on the motor are as follows
57hs2a76-404
www.apexmotor.com
NO.20071031
considering i have only used this machine 5 times it has got me a bit peeved.
any help would be much appreciated
thanks
Richard
ID:	60186   Click image for larger version
ID:	60187   Click image for larger version
ID:	60188   Click image for larger version
ID:	60190   Click image for larger version
Old 05-24-2008, 11:56 PM
rocket67 is on a distinguished road
Is this machine from sh-cnc?
Hi rocabig , I read a post where you were looking for sys-e. Is this the machine that you bought through him?
If so, and the machine came from sh-cnc - why don`t you contact sh-cnc and find out if they can help you?
Rocket.
Old 05-25-2008, 04:18 AM
jallitt is on a distinguished road
Ocean controls may be able to suggest one of these as an alternative if you can find the exact specs from the apex site.
http://www.oceancontrols.com.au/moto...per_motors.htm
Old 05-25-2008, 09:03 AM
mactec54 is on a distinguished road
Hi roacbig
I can't help you with the motor but I would change the coupling as it broke because
of bad alignment the couping could not flex to take up the misalignment It can still be a solid design but with slots in & around it so it can flex or it will break again unless you can align it perfect.
Mactec54
Old 05-25-2008, 09:13 AM
Al_The_Man's Avatar
I would agree that changing the coupling to flexible type would be advisable, solid coupling is probably the reason for the break.
If you get the bellows type, I would suggest the stainless version over the aluminum type, which are really only suited for encoder loads.
Old 05-25-2008, 04:20 PM
rocabig's Avatar
Thankyou guys
yes it is the one i got through sys-e and will never deal with him again he stuffed me around he told me it would take 14 to 30 days to deliver three months later i got it, i had to pay import and customs fees twice once to him and again to customs.
have contacted sh-cnc and am awaiting them to reply
need somthing this week as i have a job due on it on friday
will checkout the mob in vic and a flex joint
thanks again
Richard
Old 05-25-2008, 05:40 PM
ERL31 is on a distinguished road
Hello
You might want to try lowcostcncretrofit.com, he might be able to help and is in QLD. Also try www.automationdirect.com.au.
Erl
Old 05-25-2008, 05:43 PM
rocabig's Avatar
just had a search around and am getting apex to send me the specs on the motor
was un able to find a flex coupling any ideas where to find one
thanks again
Richard
Old 05-25-2008, 05:56 PM
G'day
I looked around alot in Australia through standard suppliers and were very expensive. I got the ones for my mill at www.cncfusion.com for there X3 mill, they were the best price I could get. They are zero backlash type and only made for ally. Depending on the size of stepper, equals type of coupling torque rating, they have to match. Love-joy type work well and are cheap, but have backlash.
Erl
Old 05-26-2008, 12:56 AM
thanks again
Richard
believe it or not jaycar have cheap 1/4" flex couplings - I'm using them on a small lathe and they're OK-ish as far as backlash is concerned. They're not steel though so wouldn't stand up to huge loads like lovejoys. Might get your machine up and running while you look for better ones. Since the z-axis has the weight of the spindle on it shouldn't backlash be minimised since there's always some force on the coupling?
As for Sys-e - I see he's stopped listing on trademe (a NZ auction site).
  #11   Ban this user!
Old 05-26-2008, 05:54 PM
here's the jaycar part BTW:
http://www.jaycar.com.au/productView...Max=&SUBCATID=
  #12   Ban this user!
Old 05-27-2008, 03:48 PM
appicnc is on a distinguished road
Flexiable couplings
Hello Richard
Minature Bearings Australia - who are in Qld, have the flexiable couplings you need,
http://www.minibearings.com.au/cgi-b...al&Step=3=post
They aren't particularly cheap but using this style of coupler is cheaper than replacing the motor, at a pinch you could try oxyacletene ( sp? ) hose until you get a better coupler, I have seen it used on a homebuilt cnc router and it works fine, you may need to slow your cutting speed down, or not. Still a better option than a rigid coupler.
Hope this helps.
Ed
Possible replacement motor for an X3? tauntdesigns Benchtop Machines 6 05-16-2008 10:24 PM
Help with finding a replacement stepper? Brokengears Stepper Motors and Drives 0 11-05-2005 12:57 PM
SpectraLight Stepper replacement Brokengears General Metalwork Discussion 0 10-21-2005 08:33 PM
How to find out how much power (oz/in) do I need for stepper motor? max7687 Stepper Motors and Drives 8 09-18-2005 03:57 PM
Need stepper motor replacement help ProjectCNC General Electronics Discussion 2 01-29-2004 03:14 PM
