Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 05-13-2008, 08:29 PM
navnav2006 is on a distinguished road
Mold for aluminium casting
Hi
Can anyone tell me where I could find a pattern maker around Auckland.
I need to make a simple mold for casting aluminium.
Does anyone have a experiance in making mold from plaster.(refractory mastics)?????
Old 05-20-2008, 05:11 AM
appicnc is on a distinguished road
Casting
Hello navnav
Have a look on the casting forums, plaster is a dog, my experience is with Al', I have had some success with loast foam, I tried plaster over the foam but had problems with moisture, if you go to a site called buildyouridea ( do a googel - I'm not doing it all for you, and look around, if you need more than 1 try it your self, if not find a local foundry, they should have access to a pattern maker, good luck.
BTW, all molten metal is hot, if it get on you it won't hurt, much, but it will do a lot of damage and then it will HURT!! the stuff is dangerous, accidents have been know to kill so give it some thought.
Ed
Old 05-26-2008, 11:10 PM
dearlovr is on a distinguished road
Try Sand
try sand ! , hard-sand molds are best , use sodium silicate ( waterglass ) mixed with sand and expose to carbon dioxide to make hard or some special hardsand resins are available that go hard when mixed with hardner , you just need a male version of what you are trying to make ( slightly larger due to shrinkage ) . Am building a cnc router to make male patterns for experamental engine .
Aluminium Die Casting Mould ahmedrehan Moldmaking 4 02-02-2009 07:51 AM
Aluminium manual die casting technique.... axis_control Casting Metals 31 11-12-2008 07:40 AM
Help: Casting Aluminium djh82uk Casting Metals 6 12-10-2007 10:45 PM
Making a positive mold from a negative mold - how? SRT Mike Moldmaking 7 03-29-2007 04:30 PM
A guide to permanent mold casting. Splint Casting Metals 7 11-28-2004 05:36 PM
