Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 04-24-2008, 03:41 AM
eggo is on a distinguished road
limit switches
well only took 30 minutes to find this page. Question I have just got"Mach3" and am fitting limit swiches to the mill, on the X & Y axis with only one micro switch is fitted to each axis with stop at each end of travel. (I would call the stops a cam) Is this ok and also plan to use this as a home switch can you see any difficulty with this set up?
Old 04-24-2008, 11:37 PM
Eclipze is on a distinguished road
Not sure about just one switch per axis, I believe it should work fine. I've used two per axis (for + and - limits). In fact, I string all the - limits in one chain to one input, then same for the + limits. I also use the - limits for the home position too.
Old 04-25-2008, 07:27 AM
Eclipze thank you I hadn't thought of setting up the switches that way.
Old 04-25-2008, 07:29 AM
Your welcome ;-)
Old 04-29-2008, 05:09 AM
Greolt is on a distinguished road
Yes this is OK. That is how I have my machines set up.
You can have both switches wired in series to one input. Mach can deal with that.
However if you have spare inputs it can be more convenient to use an input each.
A little easier for fault finding. You can also home both axis simultaneously if you wished.
Greg
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
Limit switches,again SPEEDRE Mach Software (ArtSoft software) 7 12-26-2005 10:56 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
