Results 1 to 2 of 2
Thread: Just started building a small CNC
    Feb 2008
    Hi Guys... I have decided to construct a small 1 meter by 600mm 3 axis CNC. So far I have organised the bed frame from 125mm x 8mm aluminium channel and settled on 16mm hi tensile Samson rods for driving (what I call) the 'bridge' supported by 6202 ball bearings in plates at each end. I have set a goal to have this machine up and going by Christmas this year
    A couple of questions I have....
    1. Should I use a stepper for each lead screw or connect them via a toothed belt to a single motor?
    2. Will a decent motor have enough grunt to turn the screws?
    Thought I'd get the mechanics sorted out first and worry about the electronics later.
    I realise it's a steep learning curve, although I have successfully turned a wood lathe into a metal lathe and made a small mill by fitting a cheap Ozito router to my drill press, although usually I only build cameras.
    Attached Thumbnails Attached Thumbnails Just started building a small CNC-pic_1.jpg
    Registered crocky's Avatar
    Dec 2006
    Hoppers Crossing, Vic, Aust
    You could use either/or stepper motor/s for the X-axis.
    1 is cheaper but only for the cost extra board it would take to drive 2.
    Mine is driven by one screw down the centre of the lower part of the gantry. I would probably pick two stepper motors and use rack and pinion to drive your gantry so you will need a four stepper set-up if that's the way that you go.
    Where in Aus are you!
    Cheers,
    Bob
  1. Started building new 5 X 10 table today
    By millman52 in forum Plasma, EDM and other similar machine Project Log
    Last Post: 02-09-2012, 09:10 PM
  2. Not sure I'm ready for this - I've started building!
    By Mike F in forum CNC Wood Router Project Log
    Last Post: 02-26-2011, 10:26 PM
  3. I just started building me a CNC router
    By mind_nl in forum DIY CNC Router Table Machines
    Last Post: 04-27-2008, 07:34 AM
  4. Started building at last!
    By The Wizard in forum CNC Wood Router Project Log
    Last Post: 09-05-2007, 04:16 AM
  5. I finally started building!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 07-10-2003, 09:12 AM
