Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 02-08-2008, 10:03 PM
cicio is on a distinguished road
Smile mach3 problem
hi can some one tell me why when i go to mach3 , file ,open dxf file ok
the the window comes up load file ,i select the dxf file then go to load g code a little window comes up saying it cannt be done9( error mach4) .
has any one had this problem
regards cicio
Old 02-09-2008, 03:54 PM
ClaudioG is on a distinguished road
Hi Cicio
I'm not an expert on Mach3 but I'm pretty sure you cannot open a dxf file directly in Mach3. You will need to open it in SheetCam (or another CAM program) and create a gcode file then load that into Mach3.
LazyCam (Mach3's free cam program) can import dxf's and then create gcode.
Try and download LazyCam here;
http://www.machsupport.com/artsoft/d.../downloads.htm
Not too sure if the latest version is compatible with your older version of Mach3.
Just remember the basic steps to CNCing;
1. Design your work in a CAD or Drawing Package
2. Use a CAM program to convert the drawing to gcode
3. Load the gcode into Mach3 and run the job
Cheers,
Claudio
- WidgitMaster Wide Router with Kress FME 800, HobbyCNC 305oz Stepper Kit
- WidgitMaster Midi Router with Dremel
Old 02-09-2008, 07:32 PM
ger21's Avatar
Sounds like you're using an old version of Mach3 before LazyCAM. Newer versions no longer have the old .dxf importer. Not sure if anyone's still using that version.
Old 02-21-2008, 02:54 AM
nemesis is on a distinguished road
regards cicio
cicio, don't waste your time.
LazyCam is barely worth the CPU cycles it takes to run it.
When you import the dxf, you get what it decides.
If that isn't what you need, tough.
There is very little you can do about it.
Get yourself a decent CAM program.
I have trialled rhino, edgecam (and the free version freemilll) and solidworks/solidcam.
Solidworks/cam is by far the easiest and most functional IMO. Full integration - no searching for the 'right' version of DXF.
- BTW the most common problem I had is that Lazy cam needed a specific version of dxf file to import - try 2000)
As claudio says:
1. Design your work in a CAD or Drawing Package (SolidWorks)
2. Use a CAM program to convert the drawing to gcode (SolidCAM)
3. Load the gcode into Mach3 and run the job (MACH3 all the way!)
problem with Mach3 jed102 Mach Software (ArtSoft software) 5 01-27-2008 04:38 PM
communication problem between mach3 and pc ataxy Mach Software (ArtSoft software) 4 01-21-2008 06:36 PM
Problem with G02 en Plane X-Z with Mach3 mariano_mdf Machines running Mach Software 1 10-29-2007 10:16 AM
Problem with Mach3 SCOTTY76SA SheetCam 3 05-27-2007 08:34 AM
problem with my z axis on mach3 thesaent14 Machines running Mach Software 18 04-06-2007 05:28 PM
