Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
Old 01-15-2008, 10:44 PM
cicio is on a distinguished road
Exclamation help with mach 3
hi
i live in brisbane northside and i need someone to teach me to use mach3
iam willing to pay for someone to teach me
regards cicio
Old 01-16-2008, 05:49 AM
Greolt is on a distinguished road
Cicio jump on a plane down to Vic and I will help you out.
Seriously are you a hobby user or is this for your business?
What machine are you needing to run with Mach3? Do you have experience with other CNC control systems?
If it is hobby I suggest you watch the videos on the Artsoft site.
They will give you a reasonable start and then there are many helpful members on this forum and the Artsoft forum who will help with questions.
Greg in Geelong
Old 01-19-2008, 12:27 AM
hi
thanks for the reply
but theres got to be someone in brisbane that can help.
well i built the plasma router for hobby and i am having all sorts of trouble getting started , like i down loaded some dxf files and saved them on desktop then went into sheeetcam and the dxf file wasnt in desktop(simalar with mach3) i could not import the file into the programs yet when i close the sheet cam and mach3 the files apear to be right there in desktop .so i couldnt do anything so i got slightly pissed off and gave up .because i dont know why.
Old 01-19-2008, 03:59 AM
ClaudioG is on a distinguished road
Hi Cicio
I'm in Zillmere and have limited experience with Mach3 running on my WidgitMaster Midi Router. I can show you the basics but as Greg said you should check out the videos on the Mach3 support site.
Where are you?
Cheers,
Claudio
- WidgitMaster Wide Router with Kress FME 800, HobbyCNC 305oz Stepper Kit
- WidgitMaster Midi Router with Dremel
Old 01-23-2008, 11:40 PM
hi
claudio can you ring me on 0401870239
or give me your no. so i can ring you so we can talk regards frank
Old 01-26-2008, 01:06 AM
Well I dropped in to see cicio today and we eventually got the machine setup properly with Mach3 and managed to plasma cut a 100mm circle. We were both very happy. Once we get the official specs of the rack on the x and y and the screw on the z then the cuts should be very acurate.
Next step is to find the best program that can handle plasma cutting and routing as this is a dual purpose machine.
Anyone had experience with using VCarve Pro on a plasma / router or any other suggestions?
Cheers,
Claudio
Old 01-27-2008, 03:51 AM
Smile thank lots
i would like to thank claudio
for spending afew hours with me and help me set up or configure the machine
it was very exciting to complete the first plasma cut on my home made machine after all the hard work and occasional problems and many phone calls
wow it does work ! so it was all worth it .
now i just realised i have an even bigger job in learning ,and how to use the
programs . but i realised this going to take some time and a lot off trial and error and slowly slowly less errors.
regards cicio
Old 01-27-2008, 03:55 AM
Hey Cicio, no problems at all. I learnt a lot too!
Give me a call as I have some more info for you that I will email through.
Cheers,
Claudio
EMC or Mach 2? grebator LinuxCNC (formerly EMC2) 2 06-12-2007 04:16 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Mach 3 no spindle - but OK in Mach 2 zcases Mach Software (ArtSoft software) 9 07-31-2006 07:38 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
