Hi Don't know if any body comes here any more, seems fairly quiet. Not sure if this post qualifies as chat, but I am after Australian information so if it gets moved it will be a bit pointless. Hey, this is only my second post so how would I know. Suggestions for converting my Emco PC 5 (the old steppers won't run accurately and being 5° and 71oz and 10 Ohm cannot be replaced) Existing suggestion is: Use Existing machine power supply Powermax II motors 252oz Gecko 202 drives Campbell breakout board Mach 3 to run it all on a PC If any one has any other ideas or has done a similar conversion could you let me know what you did. The guy who has given me this info has converted 3 Emco lathes. He knows what he is about and has been really helpful, I am just wondering what has been done in Australia. Thanks Nigel |
| Don't have one to hand, they are a lathe that was used in various education depts as cnc training lathes, desktop job with an 80mm chuck. Not very big, but mine does the job for me, just not accurate enough as the steppers lose steps. Will try and get one tomorrow. How do you attach a pic here just as an attachment or does it need hosting somewhere? |
| If you click the "Post Reply" button instead of writing in the quick reply area then you get more options...... Smileys, attachments, e-mail notifications all sorts of cool options. Give it a go. There is so much after market gear out there to build or retrofit just about any cnc device you can think of. I just made my own servo motors using 24Volt wheel chair motors and some opctical encoders from http://www.usdigital.com should be pretty gutsy. The reason I was interested in the EMCO was because I went down the path of purchasing one last year but did not go ahead with it. The machine was a cnc lathe which from memory had 12 tool positions 6 of which were powered so you could have rotating tooling shuch as end mills atacking the job. The demo on the website showed the lathe "C" axis in use with a slotdrill milling out the underside of a piston. Awesome machine. |
| Yes that would be awesome, 6 stations with live tooling. Sounds like it is only related to mine by the name. My Emco has a quick change toolpost. My Hercus 200 PC has a turret with 8 tool positions and is a much stronger machine. I could get a lot more use out of the Emco if I can make it run accurately. |
| No, same name but I live in Croydon and make auto-gas mixers. Nigel has Hercus, (which is how I got to know him) I have a Hercus and an Emco. His user name is Nigel I had to go with something else, he beat me to it. Any reason for asking? Nigel (the other one) |
| LOL ![]() I thought I might be able to put you in contact with Nigel. I've seen his shed and he would probably be the resident expert on those machines. But I was wrong, wrong, wrong ![]() on all counts. And you know him anyhow. |
#10
| Thanks for the thought anyway. Yes, what I need is Emco owners in Australia, they are bit slow putting their hands up, perhaps they are not on here. I must admit I am a machine user, not a machine builder and my electrical knowledge is limited to "if the smoke gets out of the wires, I need a new part" Having said that I think being on this forum might be bad for my health as I seem to be contemplating a drilling machine with a rotary table and an X axis. In fact I have previously told Nigel it was not worthwhile, but we are now getting up to around up to 5000/10,000 holes a month and our arms keep falling off. The holes are only 4.5mm but there seem to be an awful lot of them |
#11
| Hi Just went to advanced reply to attach a photo of the Emco and did not have much luck It says upload from your computer, does that mean just the once as in an attachment or does that mean my compter needs to be on for the photo to show? Do attachments need to be hosted on the web? Anynhow I browsed and found the photo but the uploading took for ever, so I thought I had better ask what to do to post a photo |
#12
| Nigel Not in Aus but I just found this post on the Mach support forum. http://machsupport.com/forum/index.php?topic=970.0 |
