Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Australia, New Zealand Club house
  #25   Ban this user!
Old 11-12-2006, 07:19 PM
phomann's Avatar
phomann is on a distinguished road
Originally Posted by -jon- View Post
Greetings fellow Aussies.
Jon from Townsville here, wondering where you guys source your stepper motors from. It seems like all the reliable sources with half decent motors are from USA, and the freight costs seem over the top.
I was all set to make a purchase from oceancontrols, but then I read a post that states that they arent very strong motors while spinning.
If I have to pay $80 in freight to get them from US, then I suppose I will, just like to purchase a bit closer to home. Recently had a bad experiece with missing freight from EU so am a bit more cautious now.
Jon
Hi Jon,
Check with Roger Cagill from Taig Machinery in the ACT. He has stepper motors for sale. single, double and tripple stack 23 steppers. And his prices are very reasonable.
Taig Machinery
59 Gilmore Crescent
Garran Act 2605
011-61 26 281 5660
011 61 26 285 2763 Fax
k1ergo@netspeed.com.au
(reads k one ergo@netspeed.com.au)
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
  #26   Ban this user!
Old 01-24-2007, 05:09 AM
tasrobotics is on a distinguished road
Hi all I just found a good supplyer in au.
http://www.oceancontrols.com.au/
Regards Stuart
  #27   Ban this user!
Old 08-02-2007, 08:17 PM
ClaudioG is on a distinguished road
Originally Posted by Greolt View Post
Alltronics have 300va toroidals on sale for $40.00 usualy $80
Just got myself on with 30v 5a - 30v 5a - 15v .5a - 15v .5a
Should suit my need just right. About 42v rectified at 10amps.
Can run some regulators for 5v control and 12v fans on the minor windings.
And I ordered yetserday arvo and it arrived at 8:30 this morning.
Can't complain at that
Greolt
Hi Greg,
Just starting to think about the electronics for my slow Joes build and have been looking at a kit from HobbyCNC with 305oz steppers but just need to source the power supply locally.
It appears the HCNCPRO can only be powered up to 42VDC max (http://www.hobbycnc.com/hcncpropkg.php) or am I reading it wrong. If so, I guess that means that the 30V transformer you got (part # MC5530?) would rectify slightly higher at 42.43VDC (30 x square root of 2) so would I need to go for the 25V version (part # M5525) which should provide 25VAC @ 12A or 35.36VDC once rectified if I'm calculating it correctly?
Unfortunately I'm way too late for the special, but I'm signing up as an Altronics Wholesaler for my A/V business so pricing should be good.
Are there any other transformers I should look at instead?
I've also noticed they now have an emergency stop button in their new catalogue (http://www.altronics.com.au/index.as...=item&id=S0820) which might be of interest.
Cheers
Claudio
- WidgitMaster Wide Router with Kress FME 800, HobbyCNC 305oz Stepper Kit
- WidgitMaster Midi Router with Dremel
  #28   Ban this user!
Old 08-03-2007, 06:07 PM
Greolt is on a distinguished road
Originally Posted by ClaudioG View Post
It appears the HCNCPRO can only be powered up to 42VDC max (http://www.hobbycnc.com/hcncpropkg.php) or am I reading it wrong. If so, I guess that means that the 30V transformer you got (part # MC5530?) would rectify slightly higher at 42.43VDC (30 x square root of 2) so would I need to go for the 25V version (part # M5525) which should provide 25VAC @ 12A or 35.36VDC once rectified if I'm calculating it correctly? catalogue (http://www.altronics.com.au/index.as...=item&id=S0820) which might
Claudio
There are many more electricly savvy people to ask but here is my take.
You will actually lose a small amount with the rectifier but it is probably not leaving much margin with the 30v one. I would go with the 25v one.
My idea of using the secondary 15v winding to run through a regulator for 5v control did not turn out to be practical.
The regulator chip had to disipate too much heat.
Tried to unwind a few turns on the secondary but it was wound on before the primary and I wasn't going to unwind the whole lot.
So I ended up putting another small 9v toroid in for that 5v regulator and to run 12v fans unregulated.
If you need a capacitor I have a box of 33,000uf ones I got cheap somewhere. They're about the size of a soup can.
Greg
  #29   Ban this user!
Old 08-07-2007, 06:38 AM
pump is on a distinguished road
Regards Stuart
Hi Stuart, do you know of anyone that has used any of this mobs products?
they seem to be priced quite well with there stepper motor drives compared
to a lot of the yank stuff.
I need to speak to them regarding 4 bipolar drive and a breakout board but it would be good if someone could give a bit of feedback on there products.
Cheers Pump.
