#25
I'm very interested in trying your approach for a Router. I'm heading over to the USA in the next few weeks and would like to get a Hitachi M12VC router and use a 240V to 110V stepdown transformer but had the following questions; - what model of Milwaukee do you have? - what brand and rating of stepdown are you using? - how do I calculate the correct stepdown to use for the Hitachi? - Is the fact that they are still 60Hz an issue here, I guess they just run at a different speed? - Is it still running well? Thanks Claudio |
#26
| Hello Claudio. The Router is the Milwaukee HD Router model 5625-29.. 3.5HP variable speed. With regard to the stepdown transformer we had to have one made. I think that was around $450.00. The router is still going as good as the day we put it in. Overall, it will probably se you back $800 - 900.. cheers Frans |
#27
| Thanks for the Frans. The Milwaukee looks like a very solid and powerful router. I was hoping the stepdowns weren't that much. I think the Hitachi is only 11A 2 1/4 horse power and the Milwaukee is 15A 3 1/2 horse power so I might only need a slightly less powerful stepdown. I found a thread in the Electronics section that talked at length about using 60Hz 110V products in Europe 220V and some issues which might be experiences (ie. heat, reduced speed, etc). Interesting read. http://www.cnczone.com/forums/showthread.php?t=19877 Claudio |
#29
| Hi Richard, I did see that model but it's just a little too small I think. I also found this company and have sent an email to them to see which one would be suitable for what I'm after. http://www.tortech.com.au/ Claudio |
#30
| Here's the question I sent to Tortech and the reply I got; --- I was wanting to power a USA Wood Router as per the link below and was wondering what stepdown transformer would be suitable. http://www.hitachi-koki.com/powertoo...vc/km12vc.html --- Thank you for your enquiry. The calculations are: 115 x 11 =1265 /.8 =1581 va Our part SD115-1500 will be the correct unit. Advise if you need handles? Pricing: $385+GST |
#31
I took your advice you posted a while back and checked out some die grinders today and apart from the ones you have I found the following; Metabo GE700 - 710watt, 7000 to 27000 RPM, 1/4" collet, long neck $399 http://www.metabo.com.au/metabo/hand..._06303_19.html I was also just flicking through the Metabo catalogue and came across their router motor FME 737 - 710watt, 10000 to 27000 RPM, 1/4" collet, short neck ~$349 (at www.northwesttools.com.au) http://www.metabo.com.au/metabo/hand..._00737_00.html Both are made in Germany. They both look like suitable candidates (apart from the long neck one) along with the Bosch and Milwaukee. I'm still planning the build of my Joes CNC but thought I should look for a suitable spindle before I get too far down the track. Claudio |
#32
| Just got pricing from Northside Power Tools in Geebung (07) 3265 6388 Metabo FME737 $280 Metabo GE700 $341 (long neck) Milwaukee DG30QE $220 (current special) All inc GST. The FME737 seems like a great little option at 710w, 10K to 27K RPM, short neck, made in Germany. The DG30QE The GE700 runs at 7K to 27K RPM so I don't know if the lower speed will come in handy for cutting aluminium or other materials? Rod and others, what spindle speed and table speed do you normally cut your various materials at? Claudio |
#33
| Hi Claudio, I like the specs and price of the Metabo FME737. With out being smart what you have asked is a bit like how long is a piece of string. Feeds , speeds and depth of cut are difficult to define because of the variable nature of materials and the size of cutter you are using. Generally plastics at lowest speed fastest feed, aluminum low to mid speed and medium feed, timber at high speed and mid to fast speed. The routers do not have a speed indicator so it is a case of running the job and listening for the cutter to come on song by manually adjusting feed or router speed. I would not be concerned about the difference between the lowest speed of the Metabo verse Milwaukee. Hope that is of some small help to you.
__________________ cheers, Rod Perth, Western Australia |
#34
| Hi Rod, I guess I was looking for the simple answer, when there really isn't one. I should figure it all out when I build the machine and start cutting, but your guidelines will help take some of the guess work out of it so thanks for your input. I thought you might like the FME737! Claudio |
#35
i found some spindle are similar to HSD,but it's half price.
__________________ Specialist in machinery technology-HOBBY&DIY http://www.greatinfo.com.au/ |
