Hi
Iam not in Canberra but would be happy to put together a few ideas, I would need more info on you linear rails and other equipment you have
Cheers
Chris
hey,
i have built one but one of the ball screws is bent, so am going to be order ing a replacement ballscrew, but i am increasing the size and was thinking of building it with aluminium, but i don't have any tools.
what i am hoping for is someone in Canberra that would love to help me design and build a moving gantry with dual on the x axis. 260mm x 600mm x 75mm (X x Y x Z)
i have the ball-screws and liner rails
cheers brad
Hi
Cheers
Chris
thanks
do you use any 3d design program?
i could make the parts i have
cheers
I have solidworks, I am currently in Canada at the moment and will be back in about 6 weeks,i only have my iPad which unfortunately doesn't have any cad software available, but would be happy to throw around ideas then.
What linear motion do you have?
rails,
sbr12 @200mm for z axis
sbr20 @400mm for X axis
https://www.google.com.au/search?hl=...Fc2JmQX1waWJCA
20mm Pillow Block with 800mm or 900mm for the gantry.
http://linearbearing.net/img/images/I/31NptZQT6sL.jpg
and 16mm ballscrews
750mm ballscrew
330mm ballscrew x2
130mm ballscrew
i have designed the parts in sketchup
So you want a cutting area of 400x750? You have plenty enough Z rail to give 75mm for z travel, it's with the x and y you would minus about 150mm for gantry thickness / width so on them it brings that down to only 250mm of travel on your Y, if you want 400mm cutting area youwouldwant roughly a 550-600mm rail and same on the 750mm you would want about a 900-950mm rail
Chris
nah the cutting area i want is around 270x600 which should be doable with the stuff i have. and what you just said
i have just chucked something together
edited first post
