Results 1 to 3 of 3
Thread: Festo cylinder on bandsaw
    Registered EricBear's Avatar
    Jul 2011
    Hi all, Has anybody used a festo cylinder with oil for the drop control on there band saw?. I have a few of them all air operated. However I would like to use one on my band saw.
    Oct 2009
    Hi Mate if you were to use a variable flow restrictor on the outlet side you could just us it as an air cyl.This would let you lift it with no restriction and slow the drop to nothing if you wished. We use these to slow air cyl travel speed down on food equipment .
    Jul 2011
    Thanks for the advice and help
    Quote Originally Posted by Ozcad View Post
    Hi mate , I ended up using a 1 way festo exhaust valve and a festo manual adjustable valve ended up using a by pass line so i could raise the blade quickly. I am painting the machine shop at present however I will post some pic latter if you would like to see what I did. also I ended up filling the cylinder and lines with hyd oil all works really great no more broken bi-metal blades I hope.
  1. 5x6 bandsaw hydraulic feed cylinder
    By jakemestre in forum Benchtop Machines
    Last Post: 06-18-2011, 10:56 AM
  2. Converting a wood bandsaw to metal bandsaw
    By fatal-exception in forum General Metal Working Machines
    Last Post: 04-05-2010, 01:46 PM
  3. snc bandsaw
    By BeeleJuice in forum General Metal Working Machines
    Last Post: 11-05-2005, 01:45 PM
  4. need a bandsaw
    By tekno in forum General Metalwork Discussion
    Last Post: 08-09-2004, 07:44 PM
  5. Replies: 1
    Last Post: 12-28-2003, 08:06 PM
