Results 1 to 8 of 8
Thread: Places to buy router bits
    Mar 2009
    Hi - I am looking for somewhere to buy router bits. The particular bit that I want is a bullnose bit which is similar to an end mill but with slightly rounded edges. None of the retail type stores stock it that I have found so I'm thinking it's more an industrial thing. Anyway if anyone could recommend a supplier or website I would appreciate it. Thanks in advance.
    Cheers
    Rod
    Oct 2006
    Sutton have a range of bull nose bits with their B0204 series. Radius of 0.3, 0.5, 1, 2mm depending on the bit.
    8mm $45..$48
    6mm $31..$35
    4mm $25
    (3mm and 5mm also in the range.
    They have a catalog on them, 499980401_Endmill_CornerRad.pdf
    Home | Sutton Tools
    Last time I bought them, I got them from Prime Industrial Supplies, Prime Industrial Supplies
    They might not have them on the website, but just send them an email with the part numbers and they'll send you a quote. I think they actually get Sutton to drop ship them direct to you. www.bolt.com.au is another online place with Sutton bits, but their pricing has been the same or a few bucks more.
    Jun 2010
    Forgive me, but ... I am not a fan of Sutton. I have a range of new unused Sutton drill bits (1 mm - 8 mm), and half of them (very roughly) have visible runout at the tip when correctly mounted in a collet. Put them on a surface plate and you can see daylight under the middle. OK, I am talking maybe 0.1 mm, but that's too much for me.
    I have never had that problem with Dormer drill bits.
    Cheers
    Jul 2003
    qld australia
    try Shars, Discount tools or Wholesale tools in the states, they will be half the price at least
    Sep 2005
    I use centurion tools. They are located in the industrial air park, Louis Virginia.
    WWW.centuriontools.com
    I have been very happy with them for many years.
    Registered port_huon's Avatar
    Dec 2007
    I've bought a number of tools/bits from CTC. Good prices and service.
    Regards
    Geoff
    Mar 2009
    Cheers for the advice - much appreciated
    Registered LouF's Avatar
    Sep 2011
    Discount tools has good prices..
    1. Router bits
      By tyskkvinna in forum WoodWorking
      Last Post: 02-01-2010, 10:00 AM
    2. Router bits, End mills v bits
      By bogger44 in forum Commercial CNC Wood Routers
      Last Post: 12-03-2008, 01:06 PM
    3. Router bits?
      By jeffmorris in forum DIY CNC Router Table Machines
      Last Post: 05-10-2008, 05:32 AM
    4. ROUTER BITS
      By CABSPEC22 in forum WoodWorking
      Last Post: 01-17-2008, 10:35 PM
    5. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 09-23-2006, 04:33 PM
