Results 1 to 3 of 3
Thread: Rack and Pinion in Australia?
    Sep 2009
    Hi Guys,
    Just wondering how much does rack and pinion cost in Australia?
    Where do we get it from?
    What is the size that is most used? is 15mm X 15mm M1 too small?
    Dan
    Mar 2010
    Rack & Pinion suppliers
    Most suppliers that sell Linear Bearings sell Rack & Pinion for CNC so if you lookup "Linear Bearings" in the Yellow Pages you should find someone fairly close to you.
    I find the guys a "Linear Technics" in Dandenong Vic., very helpfull and obliging.
    Cost varies depending on where the rack was manufactured i.e. China.
    15mm x 15mm is not too small but generally 19mm x 19mm is about right depending on the size you need for your bed length.
    2 types of rack & pinion are common, "spur gear" and "helcal gear" both are good but helical is much quieter because there is always more than one tooth engaged, but it's also more expensive and the pinion teeth have to be hardened to reduce wear.
    It's cost for a good China made rack is around AU$100 a meter, also it only comes in 2 M lengths so longer than that needs to be joined although the supplier will generaly supply a short length of rack to align the teeth with.
    Hope this helps
    Roger
    May 2007
    I recently bought some 15mm x 15mm module 1 gear rack and the pinions from Spur Gears - Mitre Gears - Rack & Pinions - TEA Transmissions Pty Ltd Australia. They're in SE Queensland cost me $50 per meter for the rack about $10 for each pinion and freight to SA was around $40 they also sell linear bearings V rail etc worth a look.
  1. Need Help!- dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-11-2011, 11:04 PM
  2. anti_backlash rack for rack and pinion
    Last Post: 05-25-2011, 03:25 PM
  3. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 01:05 PM
  4. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 09:54 AM
  5. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 05-18-2004, 10:36 PM
