Results 1 to 2 of 2
Thread: All thread ball screw
    Apr 2009
    New Zealand
    Hi guys
    Anyone see any problems using threaded rode and a nylon nut as a simple and light ball screw? I want to build another small router / engraver and was thinking about using threaded rod as the ball screws.
    Should work ok, right??
    Cheers Dave
    Feb 2007
    New Zealand
    Hi Dave...
    Yes, for a light weight machine threaded rod from a hardware store and a nylon nut is fine. My current small machine used 6mm threaded rod and nylon cutting board nuts for about 3 years before I 'upgraded' to dumpstercnc.com M6 leadnuts as the cutting board slabs gave out.
    Also, fyi: Ball screws are a particular type of lead screw, but what you're looking for asking for is lead screw.
    Ball screws = expensive, accurate and efficient. Lead screws = Anything that does the job.
    Cheers, Chris H.
  1. Acme Thread, Ball Screw Or Belt Drive for Laser Cutter/Engraver?
    By pyrofx in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-08-2009, 04:59 AM
  2. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 12:15 PM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 12:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-15-2005, 09:42 PM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 01:10 AM
