Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Help with the CNC 6040 router engraver
    Oct 2011
    Hi all i have just got a cnc 6040 router engraver and i have mach3 but it does not move the x,y,z axes can any one give me any help on were im going wrong
    thank you for any help
    Oct 2006
    Have you configured the IO for Mach3 to match your CNC's interface board?
    Oct 2011
    Hi Eclipze
    i have setup all the IO in mach3 as it says in the install pdf and still get no joy when i run the g code file on the screen you can see the info mation being sent to the xyz axis but no movment i can move the stepers by hand by the knob on the back of them so i know they are not locked and when you turn on the controler you can feel the steper get a input and lock
    Oct 2006
    Ok... so the stepper drivers are powering up, hence you can't turn them. Good sign. This directs our attention toward the step control signal... from Mach3 to the interface board.
    With Mach3... the red RESET button shouldn't be flashing (in-reset).
    Double check you have the input assignments for step and direction correct in Mach3. This must match the interface board on the CNC. I don't know what interface board you are using, but you won't find this information in the Mach3 PDF.
    Oct 2011
    Thanks Eclipze with this
    All i can tell you is that i got it off ebay aand all i had to do is plug the leads in to the controler and it a cnc 6040 router so what board it has in side i could not tell you
    Oct 2006
    You need to get the information on the control board... so you know which outputs Mach3 has to use to interface to the x,y and z step controls. If you have the wrong ones set in Mach3, then it will be driving the wrong lines = things aren't going to work.
    Oct 2011
    if i open the controler box up would the the info be on the board its self
    Oct 2006
    Well... if it has markings on the PCB, such as X_DIR = 3, X_STEP = 2... that's what you are after. If it doesn't have that printed on the PCB, then it's a fair bit harder. The easiest and expected source of such info should have be the guide the controller board came with. If it doesn't have one, that's disgraceful of the seller. I'II check their website for such info.
    Oct 2011
    it came with a pdf file thats ware i got the first set of IO info from had no joy with that so got the info of the net for the same cnc it had more settings in it but still no joy thats why i came here for some help
    Oct 2006
    Just remember... the usefulness of our advise is limited by the information you provide. Things like pictures, part numbers, screenshot of setup... that's all gold information. Without good info, it's more of a shotgun approach at finding the cause of problems.
    Can you post the PDF??? Something to go from?
    Oct 2011
    ok thanks ill get all the info i can and post it up for you
    Oct 2011
    Hi Eclipze
    i have got some info i hope it help
    on the front of the controller it says 3 Axis mini-cnc
    and on the axis boards inside they have on them YOOCNC x 4JKB
    and the step motors are
    Act motor
    model :23H58430B-PL14
  • Page 1 of 2 12 LastLast
    1. Any experiences with CNC 6040 ROUTER?
      By jaru-eri in forum Chinese Machines
      Last Post: Today, 02:35 AM
    2. Chinese CNC Router (CNCDIY 6040 )
      By Domenicxx in forum Australia, New Zealand Club house
      Last Post: 10-23-2012, 04:08 AM
    3. My opinion about my new EXLAS 6040 engraver (Part 1)
      By manolohpm in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 08-28-2011, 05:12 PM
    4. Router and Engraver
      By thanhct in forum WoodWorking
      Last Post: 05-04-2010, 06:59 AM
    5. CNC Router LASER Engraver mod?
      By woox in forum CNCzone Club House
      Last Post: 09-11-2008, 02:18 PM
