Hi guys
I'm part way though a small
CNC project that I started so I could learn a bit more about the process. I've played with computers, lathes and mills over the years so now I want to learn to combine them. I joined the Perth Artifactory as I don't have a home work shop, the guys here are good but I like to get info from a range of sources before I filter this and see what makes sence to me.
I started to build my version of a 3D printer, I got side tracked while using the
CNC router to cut some of the pieces for my printer... I've now decided to make it into a light duty router so I can learn the procee before I start on a full size version.
Can anyone recomend a cheap simple driver setup that runs from USB? I'll be using vcarve generated files and Mach3. I'm ok with the hardware side of things but could do with a bit of help selecting the right electronics...
I'm sure there will be many more questions so thanks in advance.
Dave
