Hey Gary,
Thanks for your comments.
I'm not going to list all the reasons for using
CNC as it's a long one but a few reasons follow:
Fingerboard radius is compound, from approx 10" to 12" along its length - I could build a complex routing swing arm mechanism to achieve this but haven't the resources right now...
Neck profiles look simple but actually involve 2 faces that both taper and twist along their length, so possible but not the simplest to achieve otherwise...
Head to neck blend is a complex junction of 3 flat faces meeting a complex curved headstock shape and headstock profile...
Neck to body junction is similar, but I want 2 of the flat faces to sweep cleanly into the sides of the body (this is not evident on the pdf I posted but is where I want to go design-wise)...
Radiused cross sections to body need to be accurate, fit of neck to body too, shape of tuner cut is complex, etc etc etc etc
Plus... I don't have access to machinery or workshop myself at all at the moment at all so am relying on employing the help of someone else to get it to the point I can get my hand tools on it and know the critical elements are true...
And... if it all works out well (I reckon it'll be a corker) I want to be able to get into small batch production and having gone through this process will have the ability to make more much more easily.
Neck will be straight (no angle) on this one, although I have the design incorporating angle in another incarnation. I need to get my hands on the tuner/bridge especially but also all other hardware for a detailed measure up before going down the angled route (everything is currently in transit from all over the world). I'd love to do it but it has other implications especially around bridge and fingerboard height and subtle design / aesthetic considerations, but will remain open to change...
... unless you meant relief as in the slight concave curve to the neck necessary for proper playability? - that will be created by the use of a truss rod. Might also get into carbon fibre reinforcment of the neck, but not in the initial model(s), want to see how they perform.
Hope that helps...
Cheers,
Jonno
