Results 1 to 10 of 10
Thread: Where to get a 1.5KW 3Phase Motor
    Aug 2006
    Question Where to get a 1.5KW 3Phase Motor
    Hi Guys,
    Just got a VFD for my mill and I have now learned that there is such a thing as a "single phase motor", I thought it was a three phase with a capacitor "generating" the missing phase.
    Anyway, now I need to get my hands on a 1.5KW 3Phase motor. Searching ebay didn't come up with much, is there anywhere in the Brisbane area I can look? Are there any scrapyards in the area? Or does anybody have one they wouldn't mind parting with?
    Cheers,
    Alex
    Do it by the book.. but be the author!
    Dec 2003
    It may be worth a check of Motor re-winders in your area, often they have some 'surplus', make sure it is 220v rated.
    Probably a 4 pole would be best as you can take it up to 120hz.
    Apr 2007
    Hi Mate,
    I get all motors from a company called Mechtric is brissy. Their number is 3274 3327. Don is the guys i deal with
    You just need a 1.5Kw 240/415 motor. These motors are the ones used with single to 3 phase VFD's. All these motors will quite happily run at 60hz, which gives a little extra speed.
    Just remember when running the 3 phase motor from a VFD that you will have to change the motor terminal strips to the delta configuration, seen as the triangle on the back of the terminal housing cover.
    Brad
    Dec 2003
    Quote Originally Posted by abomination View Post
    Brad
    Are these 2 pole or 4 pole?
    The advantage with the 4 pole is you can take them up to 120hz if need be.
    Apr 2007
    Al,
    I usually run a 50Hz to match Australia's frequency, but will go to 60hz for a little extra speed, so regardless whether I use a 2 or 4 or 6 pole motor the displayed output frequency will always be to a maximum of 60hz. I have never tried 120Hz for a 4 pole motor.
    One other thing I do is that if the motor is to be run at a low speed/frequency for extended periods of time, I remove the stock fan and mount a separately powered 240v high volume axial fan on the back of the motor to give a constant cooling . This stop the motor overheating.
    Dec 2003
    With a new installation I guess it does not make alot of difference, but if you have an existing motor that matches the rpm of just under 1500rpm of a 4 pole motor then using a 4 pole motor up to 120hz will double the old rpm.
    Apr 2007
    Thanks Al, thats what's great about these forums, now matter how old you are there is always something new to learn.
    Sep 2006
    Quote Originally Posted by the_ball View Post
    Hi Guys,
    Cheers,
    Alex
    Hi Alex, I've got a 3Ph 1.5 HP motor I bought 3 years ago to build a rotary phase converter, but bought one instead.
    I'm down in Melbourne, and if'n you get real desperate you can have it for just the postage to your area.....a photo too if'n you want to see it and further specs.....email me at tarpear@iprimus.com.au
    Ian.
    Aug 2006
    Hi Ian,
    Thank you very much for that generous offer, but I eventually found one on ebay locally.
    Thanks again,
    Alex
    Sep 2006
    Hi Alex, good 'ol Ebay....cheers.
    Ian.
    1. 60 HZ to 50 Hz converter for 3phase motor
      By bherr in forum General Electronics Discussion
      Last Post: 08-12-2011, 01:54 PM
    2. Need Help!- Which 3phase supply ?
      By blodnob in forum Want To Buy...Need help!
      Last Post: 05-20-2011, 02:57 PM
    3. 3phase motor selection
      By AiR_GuNNeR in forum Industrial Hobbies (Support forum)
      Last Post: 04-06-2010, 09:54 AM
    4. * Please help - What do you use for 220V 3Phase imported DRIVE + MOTOR?
      By cjchands in forum General Electronics Discussion
      Last Post: 03-21-2007, 08:01 PM
    5. 3Phase motor, is it good.
      By Alan T. in forum General Electronics Discussion
      Last Post: 12-01-2003, 12:01 AM
