Results 1 to 4 of 4
Thread: G Code
    May 2011
    New Zealand
    G Code
    Hi There Been setting up a mill and looking for somebody to do some G Code and send to Our Mach 3 Controller to see if Our machine recognises the Comands and works we
    Any body keen to help
    Jun 2008
    In the mach3\gcode folder there should be some sample code.
    The other option is to use one of the wizards to generate code.
    First I would go to the midi(alt F2) screen and enter gcodes into the input field and see if you get the correct response.
    George
    May 2011
    New Zealand
    Hi Ben thanks for the reply
    Our mill is pretty big 8 metres X axis and 5 Metres Y axis with 1.200 mm ZAxis
    We have found the sample Test G Code and cut out the Skull and Cross bones the intention of our Router is for large boat parts we in tend to cut out of Foam blocks coat them then re machine the surface again our background is building the machine and need help to operate the beast
    We are wanting to create G code of a Tank lid which is an Elipical shape on the end of a cylinder
    Registered atlasworxs's Avatar
    Aug 2009
    G Code
    Ben,
    I can help. Please email me the details.
    Regards
    Colin
    atlasworxs@gmail.com
  1. Replies: 4
    Last Post: 03-29-2011, 09:39 AM
  2. fanuc program code vs. Haas code
    By sixty8frbrd in forum Fanuc
    Last Post: 03-10-2011, 10:05 PM
  3. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum Siemens Sinumerik CNC controls
    Last Post: 02-20-2011, 11:02 AM
  4. Replies: 8
    Last Post: 12-15-2010, 03:32 PM
  5. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
    By troyswood in forum Ability Systems - LPT Indexer and G-Code
    Last Post: 12-24-2006, 10:21 PM
