Results 1 to 4 of 4
Thread: Newbie in Wellington
    Mar 2011
    New Zealand
    Hi IM new to cnc.Im thinking of retro fitting a mill about this size.https://www.machineryhouse.co.nz/Pro...Code=M603D.Was looking for some guidence and was woundering if there was anyone to answer my many questions.Thanks.Just tried link, also no good.It is a mill on same page as yours.Biggest one.May go bigger if conversion cost not to high.Would like to make things like motorcycle triple clamps and brake
    discs.
    Mar 2010
    New Zealand
    Your link to machineryhouse didn't work.
    But I'm in Wellington and I bought a Sieg X3 mill from Machineryhouse. I've fitted it with a stepper-motor/ballscrew kit from Promica in Australia. I drive the motors with a Gecko540 controller using an older PC with LPT port, running Mach3 software. I have a USB jog-shuttle controller, which has made life much easier. I have a couple of Tormach quick-change tool holders and am working on a power drawbar. I'm halfway through removing the spindle motor from the mill and replacing it with a three phase motor with a SEW-Eurodrive single phase variable speed drive.
    I'd be happy to discuss your plans and offer advice from what I've learned along the way.
    Mar 2011
    New Zealand
    Thanks.Try this link.https://www.machineryhouse.co.nz/Pro...ockCode=M126.I am hoping to do four axis.I have a 12inch rotary table for this.Do you think it is worth doing a cnc programing nightclass at weltec?Definitly going to do a nightclass on soildworks.
    Jul 2008
    New Zealand
    I'm down south and have converted a HM10 mill (aka X2). I'm very pleased with it but there are always things to do differently. The thread is in my signature below.
    For software I run solidworks, rhino, Mach3 and cambam (all legit). It's a pretty serious investment if you don't have a business which needs them anyway. I can't say enough good things about CAMBAM, there are free programs like Alibre which should do most of what you need for 3D modelling.
    My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
    Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
  1. Newbie needs help
    By breathe in forum Want To Buy...Need help!
    Last Post: 06-29-2010, 07:05 AM
  2. Mach3 guru in Wellington?
    By adam666 in forum Australia, New Zealand Club house
    Last Post: 08-19-2009, 05:24 PM
  3. Any Wellington Area CNC Builders out there?
    By Imagineering in forum Australia, New Zealand Club house
    Last Post: 03-15-2009, 10:23 PM
  4. Newbie checking in in Wellington>
    By John Hill in forum Australia, New Zealand Club house
    Last Post: 04-29-2008, 08:11 PM
  5. Brass rod/plate in Wellington NZ?
    By jallitt in forum Australia, New Zealand Club house
    Last Post: 04-02-2008, 09:48 PM
