Results 1 to 2 of 2
Thread: Need help with cutter/setup
    Nov 2009
    us
    I'm using a 3/32 round cutter for two woodruff key slots on a 4" bolt. I'm having a hard time repeating from part to part. Not exactly sure how to center the cutter. Any ideas/ help on setting this up?
    I was also wondering if an endmill would be a better way to go.
    Thanks in advance!
    Sorry if this is the wrong area to post, I'll move it if it is
    Jun 2010
    Quote Originally Posted by capnjack View Post
    Is the job important, and do you have more than a couple to do?
    Then start by making up a proper mounting jig. Takes time, but the end results are so much better.
    Depends on material, depth, shape ... Can't say in advance. Test.
    Cheers
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 01-12-2013, 10:57 PM
  2. Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding & Toolgrinding Machines
    Last Post: 09-13-2010, 01:25 PM
  3. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  4. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-05-2008, 07:30 PM
  5. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 08:19 AM
