Results 1 to 5 of 5
Thread: Need help with grinding down a M4 tap shank
    Registered phomann's Avatar
    Aug 2005
    I need to grind down the shank diameter of some M4 taps to 3.5mm The shanks are currently about 4.5mm dia.
    I need to do this so that the tap will fit into a Tapmatic NC/R00 tapping head.
    The max recommended tap size is M3, but as I'm going to be tapping aluminium sheet 2-3mm thick, I don't see this as an issue.
    Is anyone able to do the grinding for me? I'm guessing it will need to be done on a lathe with a toolpost grinder.
    I have 4-5 taps to be done.
    If anyone can help me out, please PM me.
    Cheers,
    Peter.
    Homann Designs - http://www.homanndesigns.com/store
    Registered neilw20's Avatar
    Jun 2007
    Peter,
    Have you thought of center-less grinding?
    It is easier than you think, once you set it up.
    Neil
    Here are some ideas.
    I have done really crude hand done ones.
    centerless grinding - Google Search
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    May 2004
    United Kingdom
    Quote Originally Posted by phomann View Post
    Cheers,
    Peter.
    I'd expect to do it between centres on a cylindrical grinder. The working end of small taps usually have a male centre - ie a point, and there will be a female centre at the gripping end. I'd offer to do it but we are literallly poles apart!
    AWEM
    Andrew Mawson
    East Sussex, UK
    Aug 2005
    Quote Originally Posted by neilw20 View Post
    Peter,
    Neil
    Hi Neil,
    Thanks for the suggestion. I don't want to do this myself though. No time, or is it lazyness. One or the other.
    Cheers,
    Peter.
    Aug 2005
    Quote Originally Posted by awemawson View Post
    AWEM
    Hi Andrew,
    Thanks for the reply. That's a shame, since they came from the UK. I bought them as they were reduced shank taps. Didn't realise that they then increase in diameter where they fit into the tap holder.
    It makes sense though. It's easier to grip the larger diameter.
    Some of the ones I ordered were these;
    Engineering Supplies - M 4x0.7 Metric Spiral Point Reduced Shank Tap DIN 376 Titanium Nitrided for longer life
    But they don't look like them. The shank also has a point unlike the picture. Also the picture shows the shank reduced all the way.
    Cheers,
    Peter.
    1. R8 Taper Shank
      By Sivart08 in forum G-Code Programing
      Last Post: 02-10-2010, 10:23 PM
    2. TTS shank max length?
      By Enraged in forum Tormach Personal CNC Mill
      Last Post: 02-06-2010, 10:06 AM
    3. 7/16 shank boring bar
      By knd in forum CNC Tooling
      Last Post: 12-21-2009, 08:22 PM
    4. MT5 shank to R8 socket sleeve
      By veggiedog in forum General Metalwork Discussion
      Last Post: 02-04-2009, 04:55 PM
    5. 1/2 Shank End Mill
      By duhtrev in forum CNC Tooling
      Last Post: 08-04-2008, 04:27 PM
