Results 1 to 2 of 2
Thread: Al flat bar 10mm x 50m 6061T6
    Jun 2010
    Melbourne, Australia
    As the title says
    I'm having trouble finding some....
    I'm looking for some aluminium flat bar 10mm x 50mm in 6061T6
    I can find 6060T5 but do not want it as its difficult to machine
    I am from Melbourne
    Can any one help?
    thanx
    jbo
    jbo is offline
    Apr 2004
    Hi Chris
    you can get 6061 plate from Action Alum, they can cut the plate to the size you require.
    Action have branches in Bayswater Dandenong and Thomastown
    I hope this helps
  1. Newbie- 10mm Endmill speeds on Aluminium...?
    By goor in forum CNC Tooling
    Last Post: 03-24-2010, 12:02 PM
  2. Need A Quote- 6061T6 machining RFQ.
    By pheyden in forum Employment Opportunity
    Last Post: 04-29-2009, 01:23 AM
  3. cutting 10mm hardened steel shaft?
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-24-2007, 09:12 PM
  4. 10mm Aluminium Plate Not Flat
    By gtrdude in forum General Metalwork Discussion
    Last Post: 06-24-2006, 11:46 PM
  5. Best way to finish a 10mm bore
    By creep_pea in forum General Metalwork Discussion
    Last Post: 01-25-2006, 04:10 PM
