RFQ Aluminum Plate ATP-5 - 3D printer frame
Results 1 to 3 of 3
Thread: RFQ Aluminum Plate ATP-5 - 3D printer frame
    Oct 2017
    Default RFQ Aluminum Plate ATP-5 - 3D printer frame
    Hi Guys,
    I need some aluminum plate routed/cut etc. I will request a quote on one part of a 3d printer frame and the best quote will get the business for the full frame. Longer term I will need more stuff cut. The tighter the tolerances the better, but must not exceed +-0.01. I can supply the plate if required. The part step file is attached. Rough dimensions are 480mm x 70mm x 12.7. It would be good to establish a relationship with a service provider for prototype development longer term. I am very price sensitive.
    Hope to hear from you soon.
    Kind Regards,
    Peter
    Attached Files Attached Files
    Jul 2009
    Default Re: RFQ Aluminum Plate ATP-5 - 3D printer frame
    .0004" of inch across 18" talking about some $$$
    Member konwey's Avatar
    May 2017
    China
    Hi Peter,
    The price has been PM
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
