- RFQ Mill bearing ways
Hi All,
I'm after someone in the Geelong/Melbourne area to do the final machining on my router table.
Just two channels up each side of my table about 4 mm deep.
Must be done in one clamp.
Base is made from 200 x 100 x 6 tube with a 100 x 16 plate stitch welded on each side.
Total base is 3300 long x 1400 wide
I can be contacted at "anealxr6@gmail.com"
Regards Alan.
- You may not post replies
- You may not edit your posts
Forum Rules
