- Australia Auto z and corner touch off plate code in metric
I've just finished building another cnc router. I bought the 4848 pro kit from cncrouterparts. Excellent bit if kit and I'm very happy with the unit apart from trying to find metric code to drive the touch plate. I bought the Z and corner finding touch plate from them and it works briliant except the code puts the Z axis into inch mode on the DRO. Is there anyone out there that has the same unit (z and corner touch plate) that has converted the supplied code to metric?
While I do appreciate all replies please do not direct me to random scripts that use pieces of aluminium etc. I've been down that route. I need the script for this particular touch off plate that has the dimensions for this plate.
I will include the code that is available off their site (so I don't think it is proprietary or sacred or anything like that). If any of you clever people can tell me how I change the code so that it thinks and displays in mm that would be most appreciated.
' Auto Z and Corner Finding Touch Plate Script version 1.2 - CNC Router Parts 2017
Public TouchPlateHeight, ProbeFeedRate, XProbeDistance, YProbeDistance, ZProbeDistance, TouchPlateWidth, XProbeDirection, YProbeDirection, ZTravelHeight, ZLiftHeight, ToolDiameter As Double
Public ProbeX, ProbeY, PauseProbe, Abort, isImperial, isImperialUOM As Boolean
Sub Main
NoPrompt = False ' False = Use UI to Prompt User for corner finding options
PauseProbe = True ' True = Prompt user to rotate tool before X and Y axis probing
WCSOrigin = 0 ' Default Corner 0=Left/Front 1=Left/Rear 2=Right/Front 3=Right/Rear
ProbeX = False ' By default, do not probe/zero X (change this to True to change the default)
ProbeY = False ' By default, do not probe/zero Y (change this to True to change the default)
ProbeFeedrate = 10 'IPM, Anything from 5-12 IPM will likely work well
TouchPlateHeight = 1 'CRP Touchplate is 1" nominal, can adjust this number to calibrate (usually not required)
TouchPlateWidth = 2.205 'Width of Touchplate is 2.205" (56mm) wide
XProbeDistance = 2 'How long to probe X Axis (inches)
YProbeDistance = 2 'How long to probe Y Axis (inches)
ZProbeDistance = 2 'How long to probe Z Axis (inches)
ZTravelHeight = TouchPlateHeight +.125 'How high to lift tool while probing X and Y (inches)
ZLiftHeight = TouchPlateHeight + .5 'How high to lift tool after script is complete (inches)
ToolDiameter = GetOEMDro(105)
isImperial = GetOEMLED(801)
isImperialUOM = isImperial
Abort = True
If (GetOEMLED(800)) Then
Message ("Error: Emergency Mode is Active ")
Exit Function
End If
If isImperial = False Then
ProbeFeedrate = ProbeFeedrate * 25.4
XProbeDistance = XProbeDistance * 25.4
YProbeDistance = YProbeDistance * 25.4
ZProbeDistance = ZProbeDistance * 25.4
ZTravelHeight = ZTravelHeight * 25.4
ZLiftHeight = ZLiftHeight * 25.4
TouchPlateWidth = TouchPlateWidth * 25.4
TouchPlateHeight = TouchPlateHeight * 25.4
End If
If NoPrompt = False Then
Begin Dialog DlgCheckAxis 15,32,215,90,"Select Axes to Auto Zero",.DlgCheckAxis
OKButton 140,8,40,14
CancelButton 140,30,40,14
GroupBox 10,3,45,50,"",.GroupAxesChk
CheckBox 12,10,30,8,"Z Axis",.ChkBoxZAxis
CheckBox 12,26,30,8,"X Axis",.ChkBoxXAxis
CheckBox 125,50,80,8,"Pause Between Axes",.ChkBoxPauseProbe
CheckBox 12,42,30,8,"Y Axis",.ChkBoxYAxis
GroupBox 62,3,55,68,"",.GroupAxesChk
OptionGroup .grp1
OptionButton 65,10,50,8,"Left/Front",.ComboLeftFront
OptionButton 65,26,50,8,"Left/Rear",.ComboLeftRear
OptionButton 65,42,50,8,"Right/Front",.ComboRightFront
OptionButton 65,58,50,8,"Right/Rear",.ComboRightRear
Text 16,75,100,100,"Tool Diameter: ",.TextToolDiaLabel
TextBox 69,75,30,10,.TextToolDiameter
OptionGroup .grp2
OptionButton 104,75,35,10,"inches",.UnitImperial
OptionButton 139,75,35,10,"mm",.UnitMetric
End Dialog
Dim Dlg1 As DlgCheckAxis
Dlg1.TextToolDiameter = ""+ToolDiameter
Dlg1.grp1 = WCSOrigin 'default is left/front
Dlg1.grp2 = 0 'default is inches (Imperial)
Dlg1.grp2 = 1
End If
Dlg1.ChkBoxXAxis = ProbeX
Dlg1.ChkBoxYAxis = ProbeY
Dlg1.ChkBoxPauseProbe = PauseProbe
Button = Dialog ( Dlg1 )
ProbeX = Dlg1.ChkBoxXAxis
ProbeY = Dlg1.ChkBoxYAxis
Else
Select Case WCSOrigin
Case 0
XProbeDirection = 1
YProbeDirection = 1
Case 1
XProbeDirection = 1
YProbeDirection = -1
Case 2
XProbeDirection = -1
Case 3
YProbeDirection = 1
End Select
Abort = false
End If
If ( ProbeX Or ProbeY ) Then
If Not NoPrompt Then
If IsNumeric(Dlg1.TextToolDiameter) Then
ToolDiameter = CDbl(Dlg1.TextToolDiameter)
If (isImperial And Dlg1.grp2 = 1) Then
ToolDiameter = ToolDiameter/25.4
End If
If (Not isImperial And Dlg1.grp2 = 0) Then
ToolDiameter = ToolDiameter*25.4
End If
Else
Code "(Invalid Tool Diameter)"
Abort = true
End If
End If
ToolDiameterImperial = ToolDiameter
If Not isImperial Then
ToolDiameterImperial = ToolDiameter/25.4
End If
If (Not Abort And ToolDiameterImperial <= 0) Then
Code "(Tool Diameter is too small)"
Abort = true
End If
If (Not Abort And ToolDiameterImperial > 2) Then
Code "(Tool Diameter is too large)"
Abort = true
End If
If (Not Abort And Not NoPrompt) Then
SetOEMDro(105,ToolDiameter)
End If
End If
If Not Abort Then
Message ("Auto Tool Sequence Activating...")
AutoZeroMachine
End If
End Sub
Sub AutoZeroMachine()
If GetOEMLED(825) <> 0 Then 'Check to see if the touch plate is already activated
Code "(Touch plate is already activated, check connection and try again)"
Else
FeedCurrent = GetOemDRO(818) 'Get the current settings
XCurrent = GetDro(0)
YCurrent = GetDro(1)
ZCurrent = GetDro(2)
ToolRad = ToolDiameter/2
Code "G4 P1" 'Pause 1sec
Code "F" &ProbeFeedRate
'Always probe z
ZNew = ZCurrent - ZProbeDistance
Code "G31 Z" &ZNew
While IsMoving()
Wend
SetDro(2,TouchPlateHeight)
Code "G0 Z" &ZTravelHeight 'rapid move back off plate enough to travel
If ProbeX Then
If PauseProbe Then
MsgBox "Align Tool Flutes for X-Axis Travel and Press OK"
End If
XNew = XCurrent + (XProbeDistance * XProbeDirection) 'probe vector
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
Wend
SetDro(0,(TouchPlateWidth-ToolRad)*XProbeDirection)
If XProbeDirection = 1 Then
Code "G0 X" &(TouchPlateWidth/2)-ToolRad 'Center the tool on touch plate
Else
Code "G0 X" &((TouchPlateWidth/2)-ToolRad)*-1 'Center the tool on touch plate
End If
End If
If ProbeY Then
If PauseProbe Then
MsgBox "Align Tool Flutes for Y-Axis Travel and Press OK"
End If
YNew = YCurrent + (YProbeDistance * YProbeDirection) 'probe vector
Code "G31 Y" &YNew
Wend
SetDro(1,(TouchPlateWidth-ToolRad)*YProbeDirection)
If YProbeDirection = 1 Then
Code "G0 Y" &(TouchPlateWidth/2)-ToolRad 'Center the tool on touch plate
Else
Code "G0 Y" &((TouchPlateWidth/2)-ToolRad)*-1 'Center the tool on touch plate
End If
End If
Code "G0 Z" &ZLiftHeight
Code "F" &FeedCurrent 'restore starting feed rate
Message ("Auto Tool Sequence Complete.")
End If
End Sub
Function DlgCheckAxis( ControlID$, Action%, SuppValue%)
DlgValue "ChkBoxZAxis", 1
DlgEnable "ChkBoxZAxis",0
If DlgValue("ChkBoxPauseProbe") = 1 Then
PauseProbe = True
Else
PauseProbe = False
End If
If DlgValue("ChkBoxYAxis") = 1 Or DlgValue("ChkBoxXAxis") = 1 Then
DlgEnable "ComboLeftFront",1
DlgEnable "ComboLeftRear",1
DlgEnable "ComboRightFront",1
DlgEnable "ComboRightRear",1
DlgEnable "ChkBoxPauseProbe",1
DlgEnable "TextToolDiameter",1
DlgEnable "TextToolDiaLabel",1
DlgEnable "UnitImperial",1
DlgEnable "UnitMetric",1
Else
DlgEnable "ComboLeftFront",0
DlgEnable "ComboLeftRear",0
DlgEnable "ComboRightFront",0
DlgEnable "ComboRightRear",0
DlgEnable "ChkBoxPauseProbe",0
DlgEnable "TextToolDiameter",0
DlgEnable "TextToolDiaLabel",0
DlgEnable "UnitImperial",0
DlgEnable "UnitMetric",0
End If
If DlgValue("ChkBoxXAxis") = 1 Then
ProbeX = True
Else
ProbeX = False
End If
If DlgValue("ChkBoxYAxis") = 1 Then
ProbeY = True
Else
ProbeY = False
End If
If Action = 3 And ControlID$ = "TextToolDiameter" And Not IsNumeric(DlgText("TextToolDiameter")) Then
DlgText "TextToolDiameter",""+ToolDiameter
End If
If Action = 2 Then
If ControlID$ = "UnitMetric" And isImperialUOM Then
ToolDiameter = CDbl(DlgText("TextToolDiameter"))*25.4
isImperialUOM = false
End If
If ControlID$ = "UnitImperial" And Not isImperialUOM Then
ToolDiameter = CDbl(DlgText("TextToolDiameter"))/25.4
isImperialUOM = true
End If
If ControlID$ = "Ok" Then
Abort = False
If DlgValue ("ComboLeftFront") = 1 Then
XProbeDirection = 1
YProbeDirection = 1
ElseIf DlgValue ("ComboLeftRear") = 1 Then
XProbeDirection = 1
ElseIf DlgValue ("ComboRightRear") = 1 Then
ElseIf DlgValue ("ComboRightFront") = 1 Then
YProbeDirection = 1
End If
End If
End If
Any help, assistance, wise counsel is as always most appreciated.
Cheers
Anthony
Re: Auto z and corner touch off plate code in metric
Google didn't throw up any clues... Have you tried emailing CNC Parts and see if they have a metric version already?
If not they may be able to tell you what you need to change.
I'm not smart enough to help you...sorry.
Steve
Thanks Steve, but I feel a tad sheepish... it had nothing to do with the script. I had loaded their default xml file and it had the motor control in inches. I've changed it to metric (divide inch per steps by 25.4 and times velocity and accelleration by 25.4) and it now works as expected. I will check to see that all axis' move the correct amount before bringing it into service.
Thanks again and sorry to have wasted everyone's time...
I promise not to direct you to an ally touch plate I just Input metric dimensions gurubru gave me the clue on the script but alas it was for Mach,luck to you wasted time is an impossible thing to do .
No need to apologize. We have all found out the solution. Thanks for letting us know.I'm sure someone else will come across the same situation, one day, and maybe they will Google and find these posts.
I may be interested in the same touch plate so this will help definitely help me.
Steve
- You may not post replies
- You may not edit your posts
Forum Rules
