no instructions
Results 1 to 14 of 14
Thread: no instructions
    Jan 2018
    Default no instructions
    I purchased a Chinese CNC 6040 router. It proved to be surprisingly well made but came with zero assembly or software setup instructions, not even in flawed English.
    No problems putting it together and I purchased the Mach3 software required. Unfortunately that's as far as I've got. I've no idea how to write this machine's settings in Mach3. Can anybody send me an appropriate link? Any help appreciated.
    cheers,
    Peter
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: no instructions
    Welcome to the CNC world where anything is possible depending on the programmer`s skill first things first when you just bought a CNC router, 1mm=1mm on all axis, so you need to calibrate it first on the X,Y,Z after that test route a 25.4mm square, 25.4mm circle, when all procedures are all set and you are contented with the cut it`s time to proceed anything you want it`s either you want to cut, engrave, drill, reface all those sorts of things
    Jun 2010
    Have you read the Mach3Mill_1.84.pdf manual?You should read ALL of it several times over. By and large, the info you need is in there, but it is not a 'novice hand-hold'.
    Cheers
    Roger
    Jan 2018
    Quote Originally Posted by KH0UJ View Post
    Thanks KHOUJ,
    I appreciate your advice. Got a lot to learn.
    Jan 2018
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Thanks Roger. I had a brief look at it when I got Mach3. Will now read it in depth. My concern was that the settings it discussed would be different for every brand of router. Not having a manual specifically for this machine has made the task very daunting. Don't want to make a mistake and bust it.
    Cheers,
    Peter
    Jan 2018
    Just to make things even more fun, I've just discovered Mach3 isn't compatible with my router because it has a USB setup. :-(
  7. #7
    Jun 2010
    Not so fast!
    Mach3 can drive a USB motion controller just fine. The Warp9 USB Smooth Stepper is the benchmark, but there are others. Mind you, I don't personally like using the USB interface for an industrial machine, but that is a whole different story.
    To interface Mach3 to your USB controller and your CNC, you will HAVE TO have some sort of instructions and a device driver. Typically what you need to know is what pins on the pseudo-parallel-port are for what functions. You don't actually have to have a lot of info for the USB device itself.
    The Mach3 manual will tell you how to set this up. Read carefully: it only says things once.
    Cheers
    Roger
  8. #8
    Member jalessi's Avatar
    Feb 2007
    DadaVinci ,
    Open the cover on your CNC controller and post a few good images, I will determine what you have then if you want I can remote access your computer and attempt to correctly configure your CNC.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  9. #9
    Jan 2018
    Thanks Roger, I've been obeying your advice and methodically reading the manual. I also found a video online produced by the manufacturer that shows the entire assembly and Mach 3 settings. No dialogue so it's a bit challenging, but I've got a handle now on most of the procedure.
    Not so fast!
    Cheers
    Roger
  10. #10
    Jan 2018
    Thanks Jeff. I'm almost at startup. If I hit any more problems I'll take you up on that offer.
    Peter
    Quote Originally Posted by jalessi View Post
    DadaVinci ,
    Jeff...
  11. #11
    Jan 2018
    Thought I was close to finding a solution but no such luck. As expected the Mach 3 manual is based on parallel ports. There's no reference to USB connections so I'm none the wiser about how this affects the config settings. It's all based on ports and pins but how does that work when there's no parallel port involved? (groan)
    The machine is trade-marked CNCEST but a bit of detective work reveals it was made by Foshan Puruite Technology. A search of their website shows their present machines are parallel port controlled. My guess is they built a bunch of USB machines, had problems, then dumped them on Ebay under a pseudonym. Or am I being too cynical?
  12. #12
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    You could say that there are issues with all of the chinese machines on Ebay. When buying the cheapest machines available, You get what you pay for.
    UCCNC 2017 Screenset
  13. #13
    Nov 2011
    You might try putting up a picture or two of the boards. Some one may have already travelled this road...
  14. #14
    Jun 2010
    Well Gerry is absolutely right: we see an endless stream of pleas for help over cheap Chinese machines. They are bodgey jobs. Sorry, but that is reality.
    However, re the USB bit. What you have to understand is that the USB is simply a sort of extension to the interface. The default or standard interface for modern CNC controllers these days is the 'parallel port'. Older PCs have an actual hardware version of this; more modern machines don't. What the USB and ethernet interfaces do is to simulate one or more parallel ports. So with my Ethernet Smooth Stepper (ESS) I have three parallel ports available.
    When I go into Mach3/Config/Ports&Pins I see all the usual stuff and have to assign a port number and a pin number to each function. Read sections 4 and 5 of the Mach3Mill_1.84.pdf manual. Then read them again, slowly. It is all there.
    Cheers
    Roger
no instructions
no instructions
