Australia What software are you using and why?
Results 1 to 12 of 12
Thread: What software are you using and why?
    Registered FishyFill's Avatar
    Jul 2014
    Default What software are you using and why?
    Hi fello CNC nutters. I am wiring up my recently procured CNC 6040 with GECKO G540 driver. Getting close to needing software. I have been advised that Fusion 360 is quite functional. I have no issue with buying Mach 3 or better. I intend to do a fair bit of 3D carving in Hueon pine and other exotic Ozzy timbers. I also will be building a CNC plasma at a later stage to manufacture decorative steel screens.
    I dont need an overly verbose response just a quick note including what and why.
    not trying to start any IT storm. You can pm me if you like. Arohlf@bigpond.net.au.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: What software are you using and why?
    Control Software - UCCNC
    Like a modern version of Mach3. But better, and cheaper.
    Cad/CAM:
    AutoCAD - 90% of my CAD/CAM. Been using it daily for 20 years.
    Fusion 360 - for the Parametric CAD and assemblies.
    Aspire - for V Carving and relief modeling.
    MeshCAM - 3D CAM
    Lightwave - 3D modeling.
    UCCNC 2017 Screenset
    Jan 2007
    Corel Draw X3, with E-cut, and Enroute 4.
    Photoshop CS2 & 5.
    I like them, and they've kept me in business a long time- been using Corel since version 2.
    Jun 2006
    Spaceclaim - Very powerful and easy to use but no CAM (WAY better CAD than Fusion IMHO)
    Fusion 360 - Just getting started with it. Excellent CAM and collision detection and its full version, Free for hobbyists.
    Linuxcnc - as it is about the only TRUE cnc controller available and its also free.
    Fanuc - on my cnc lathe.
    Cheers
    Chich
    Sent from my GT-N8010 using Tapatalk
    Jun 2012
    Au
    Hi Fishy,
    I use CorelDrawX4 for CAD,
    Rhino for modelling & design.
    Export 2d to EPS or other & suck it into Vectric Cut2d to layout, create Gcode & simulate the cut.
    (Vectric also have Cut3d , I don't have it yet)
    Using EazyCNC for machine control.
    I chose my programs based on ergonomics & functionality + did some beta testing.
    toni.g
    Jun 2015
    Sweden
    Quote Originally Posted by FishyFill View Post
    I'm using UCCNC and Sheetcam for plasma and Vectric for router.
  7. #7
    Oct 2007
    australia
    Auto cad and sheet camTNG
    Sheet cam isquick very easy to learn and the backup is so dam good
  8. #8
    Mar 2003
    Shelby Township
    For 99% of the parts I make, I draw them in AutoCAD, and export g-code right from AutoCAD with a VBA macro I wrote.
    For 3D parts modeled in AutoCAD, I use MeshCAM.
    For more decorative stuff, I use Aspire.
    Occasionally use Lightwave for 3D organic modelling.
    Also using Fusion 360 for modelling machines and assemblies, and have just started learning the CAM. But for most things, I can get g-code out of AutoCAD in a fraction of the time it would take in Fusion 360.
    UCCNC for machine control.
  9. #9
    Jul 2014
  10. #10
    Registered diyhands's Avatar
    May 2017
    I also have 6040, 800kw (HUANYANG GDZ-65-800c) / HY01D523B 1.5kw Inverter
    Driver:
    GECKO G540
    COM:
    ESS (Ethernet Smooth Stepper)
    GUI:
    MACH 3
    Design suite:
    Autodesk Inventor with HSM CAM plugin
    So far everything is solid, running good...... just can't get the Inverter controlled by MACH 3 yet, but im close! I just control speeds manually for now with the appropriate stops placed in Gcode to accommodate for this. But in order to run taps effectively and peck-drilling and stuff I want to get it figured out. I do my taps on the press afterwards or by hand... oh well... it works..
    The design process is awesome.... been using Inventor for a while (6 years), now with the HSM CAM plugin its all handled right there in Inventor..... I model 3D (.step) or 2D (.dxf) and click a tab in inventor to set-up tools, stock, paths and rates...... simulate to double check my paths then generate my Gcode file that loads right into MACH 3...... Extremely simple once its given you atleast 5 or 6 more gray hairs..... honestly, took me about 2 weeks of coming home from work at 6 then of up all night when the house gets quiet and I can focus (till 12am or so) playing with it to really get my bearings enough to start feeling some sort of confidence getting it figured out.
  11. #11
    Member dharmic's Avatar
    May 2015
    I'd been using Creo for a while but switched last year to Fusion 360.
    There are things I don't like about Fusion - some functionality that's not implemented, the whole cloud aspect of it etc. But I do like the price. And I do like the huge user community and wealth of instructional and troubleshooting information on the web. The CAM part of it is pretty sweet, too: comparatively easy to use and some fairly intelligent toolpath generation algorithms.
    I run Mach3 on the machine - but I'll be switching to UCCNC as soon as they get their fourth axis support sorted out.
  12. #12
    Jul 2014
    Thank you for the info. Much appreciated.
    Phil
