Australia 3 phase 220v servo drives
Results 1 to 5 of 5
Thread: 3 phase 220v servo drives
    Registered edmunns's Avatar
    Dec 2017
    Default 3 phase 220v servo drives
    Hi all,
    Was wondering if any sparkies/electrical engineers have experience with hooking up 240v 3 phase servo drives in metro areas in Australia.
    I have seen 3 phase 240v induction cooktops with similar requirements but they are hardwired. I would assume that it could be done through
    a normal 3 phase outlet if there are 3 240 actives to the meter box, but it may be a transformer jobbie. Wouldn't mind running a 2kw servo as a spindle motor.
    Anyone had any experience with this?
    Thanks in advance
    Ed.
    Dec 2003
    Default Re: 3 phase 220v servo drives
    What is the nature of the servo you have in mind?
    Modern ones would be BLDC mainly, but these still require a controller to convert any 3phase supply to BLDC, unless you were thinking of controlling one with a VFD, I have tried this with poor success, there are I believe some that will do it supposedly.
    If you have the original controller then you should be OK.
    I did use a Fanuc servo motor as a spindle, but had to change the encoder as the one on the Fanuc has a proprietary commutation method.
    Sep 2017
    Quote Originally Posted by edmunns View Post
    Hi all,
    Thanks in advance
    Ed.
    Have a look at the Bosch rexroth drives - pretty sure they do a 2kw unit that can be wired for single phase in.
    Dec 2017
    Looking at second hand units out of South Korea, Samsung, Panasonic etc. Seems anything over 750 watt is 3 phase 220 volt.
    For this exact reason.
    What was your experience with torque with a servo as a spindle Al? I am thinking of using one as a main spindle on a benchtop mill so position is not really a big factor.
    Thanks, I think I saw one of them a while back, I will check it out. Just a bit worried the power point will cost more than the whole machine haha.
    Sep 2017
    Mate, a normal GPO / powerpoint will handle that no problems.
    Relax, put a bit of spit on the plug and stick it in. its all good.
