Australia melbourne tool supplier
Results 1 to 6 of 6
Thread: melbourne tool supplier
    Sep 2017
    Default melbourne tool supplier
    Hi guys,
    looking for advice on tooling suppliers for small, quality end mills 6mm and under around the Melbourne area.
    I'm about done rewiring the new (mill, engraver, router, machining center) what ever it's proper name is for single phase operation -
    and am about to fire it up for some testing, but I ain't got no tools, except for about 1000 carbide 3mm 60 deg chamfer bits that came with it.
    these aren't going to be much help with commissioning.
    Cheers
    Simon
    Aug 2016
    Default Re: melbourne tool supplier
    Ausee Machines & Tools
    Dandenong. Mostly chinese imported stuff. All I've bought from them so far is a 20mm die wrench and the quality was better than the one that came in my set. Beyond that I can't vouch for them
    Member phomann's Avatar
    Aug 2005
    Hi
    I have a few metric and imperial sizes available here.
    https://www.homanndesigns.com/index....ex&cPath=58_33
    Peter
    Homann Designs - http://www.homanndesigns.com
    Sep 2017
    Quote Originally Posted by phomann View Post
    Hi
    Peter
    Thanks mate,
    will be starting up tonight - if there's any dramas, ill be blaming you.
    Also, if you can get the distance setting pieces for the bits, i'll buy a shirt ton of ya, and also the depth setting tool for said bits.
    Cheers
    Simon
    May 2013
    Ali Express for cheap tools.
    I use them for 316 and they are fine. I tend to use the cheap ones at a few bucks each which are what is sold here for 5x the mark up and then use expensive tools such as Sandvick and Iscar for the last passes to finish the part.
    No point killing a $100 tool for roughing, when a $4 tool will do it.
    ericks
    Guest
    Hi
    Peter
    That's good to know, i was just trying to find some myself
