New Zealand: Looking for a leadscrew supplier
Results 1 to 2 of 2
Thread: New Zealand: Looking for a leadscrew supplier
    Dec 2016
    New Zealand
    Default New Zealand: Looking for a leadscrew supplier
    I am new here. I am also pretty new to the CNC machine game.
    I just bought a small CNC milling/engraving/routing kit from aliexpress.
    https://www.aliexpress.com/item/Diy-...608.0.0.fS8GoE
    I want to modify it to increase the X axis. It should be a straightforward task. I will source some longer extrusions for the frame - most likely from Ullrich Aluminium but I will also need to find a longer leadscrew and guide rods for the additional X-axis movement.
    Can anyone suggest a likely supplier in the Auckland area?
    Tak
    Registered VikingNZ's Avatar
    May 2015
    New Zealand
    Default Re: New Zealand: Looking for a leadscrew supplier
    Hi Tak,
    The guys at Linearmotion.co.nz stock trapezoidal screws I believe, otherwise Saeco Wilson are a good bet.
    Personally though, I'd head on over to eBay - delivery for lead screws from China is usually only a couple of weeks, or else you can get stuff FedEx 'd from Europe of the states in a few days.
    Good luck!
