Yeah, I get your point. It does seem like a lot of headache already for what it's going to achieve.you know, if it were mine, I only change really the electronics..
fix Z issue, finding how much spacer need between the block that nut is mounted on and the fron aluplate..
and from front would try to tie the nut to the aluplate..
Still haven't given up on the idea, but I probably will end up leaving it as it is at least for now and just concentrate on getting the thing working good and running it with the new software and electronics to see how it is to live with like that.
Certainly will try to lock in that Z aluplate to the nut that moves up and down.
Is your machine any good... I was put of looking at Chinese routers because I'd heard (half rumors probably) that they weren't to good, un-level beds etc.I just got to my shop a machine.. it was a demo machine in the factory.. showing customers what they going to get..
the gantry lets using 8 inches under, with two simple block I can rise about 2-3 inches and Z movement still ok..
it was at the door 5400.. this price including 1500 of broker, and other fees, plus 250 shipping from bonded warehouse.. no pump came with...
but, it works with simple G code and virtually any cad cam..
so im really not sure if it worth to working weeks, and investing hundreds, or even thiushands to retrofitting, redesigning your router..
My reasoning to retrofit was that this router seems to have a pretty sturdy base to start with, with a vacuum table and decent spindle. So I thought that with the upgrade, as long as it DID'NT go into the thousands, that it would be worth at least as much and be as good as a cheapo China machine....I could be wrong.
Of course there is the hassle of it all, retrofitting and working it all out and the machine being down etc.
Thanks for the feedback....definitely got me questioning whether I really want to go down this road.
