Starting a CNC build just wanting to know what the best software people use? from design to cut.
Will be using a TinyG board..
Cheers
Gavin
Hey Gavin,
Autodesk Fusion 360 is free for makers to use, it includes full CAD / CAM capabilities, 3-axis & 3+2 toolpathing is supported. Turning will be available in a few months as well. Plus it will work on a Mac if that tickles you fancy. Oh & loads of posts... as well as free post development for all but the weirdest and most complicated machines.
I work for the ANZ Autodesk CAM Master Reseller, selling & supporting HSMWorks, Inventor HSM & CAM for Fusion 360. Shapeoko 2 owner
Bobcad is the one I chose and do not regret the purchase. Very well priced specially as it is cad and cam. No the cad is not the best but once learnt is adequate. Being self taught in both cad/cam and not having tried more expensive programmes I find it out performs my ability. I have a Rong Fu cnc mill with a Syntec controller not a hobby machine.
Bobcad does from time to time receive what I think is unfair criticism.
It's a hybrid desktop / cloud product. So it needs to connect to sync files to the cloud & check licensing etc every 30 days I believe.. You need an internet connection to get it up & running, but then there is an offline mode, so you don't have to be connected to the internet to model parts, toolpath them & generate code. All the posts are open, so you can get in there and hack away at the javascript to your hearts content.
Oh btw Gavin, there is a TinyG post processor available already. & KOC62 what control do you want to drive? I can look to see if there is a generic post for you to use already.
fusion 360 is a very powerful cad/cam product it has all the fancy new cutting stuff in it
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
Well you can still use Fusion 360 as Standalone CAD. I'm not sure what you want to model, but T-Splines in Fusion 360 are epic. Check out the Fusion 360 Gallery for some of the stuff people are modelling with it. It's well supported, has a great community and active forums.
I've tried Fusion 360 over the past few days. Seems like a good product, and it's amazing that a fully featured CAD/CAM system is available free to hobbyists.
The easy to use parameters are a nice feature (I've always found Solidworks equations a bit buried and fiddly.)
However, there are two things that I struggled with and have turned me off for the present.
1) I couldn't for the life of me work out how to break / remove some coincident constraints. This is a deal breaker for decent CAD. I could remove horizontal, perpendicular etc, but could not find a way to break a coincident constraint when I'd sketched a rectangle up to a line.
2) There doesn't seem to be a nice way of making a sketch in to a component. I'm used to the solidworks way with parts that contain features and sketches.
You can delete coincident constraints as per the workflow shown in this video:
I'm not quite sure what you mean here. As soon as I extrude from a sketch, it creates a feature and a body, in the same way it does in Inventor & Solidworks. Did you notice the timeline at the bottom? That's where all your features are when you are modelling with History turned on.
I would have added images into my reply, but when I select a file from 'My Computer' there is no OK button on the dialog. The URL option kept telling me its an invalid image.
Enroute suits me.
I do do a fair bit of editing and file creation in Corel Draw though, then export as AI and import that into Enroute.
I use Gibbscam for machining and light editing of models, and mainly solidworks for complicated 3d solid creation.
HSMXpress is 2.5 axis, with some 3 axis strategies. You will be surprised what you can achieve with the high quality 2.5 axis toolpaths. Adaptive Clearing is a massive money maker for any shop removing material. It's remarkable how many shops only need 2.5-axis CAM, especially if they are just getting started with CAM.
Of course, with 4-5 axis machining free products your expectations are low, that's logical. However, the licensing model for Fusion 360 changes that. Free CAD / CAM, with positional multi-axis already in the product & simultaneous multi-axis, as well as turning on the way. All that is free for Students, Teachers, Schools, Colleges, Universities and hobbyists. As well as startups with sub US$100k in revenue per year. Outside of that commercial licensing applies. F360 uses the same CAM kernel as Inventor HSM & HSMWorks for Solidworks.
We use ArtCAM,JD for 3 axis CNC mainly, if 4-5 axis,we use UG/powermill.
Mary
[email]mary@xyz-tech.com[/email]
