Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: Convert pet photo to relief
    Jan 2009
    australia
    Hi.
    Can anyone convert this photo to a relief for artcam pro?
    The background and leash would have to be removed.The size would be 200mm or 8inches square approximately.
    I am willing to pay for an OK job.
    Thank you
    Denis
    Attached Thumbnails Attached Thumbnails Convert pet photo to relief-australian-cattle-dog10.jpg
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Question
    Denis,
    Can you email a larger image?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Registered 5xmill's Avatar
    Oct 2009
    Denis
    email me the photo and let me know how high you would like the relief to be.
    5xxmill@gmail.com
    Aug 2009
    USA Michigan
    can someone please help me. i have artcam but i can't get the RLF file from artcam to open, i tryed dragging and droping it in the program, but it didn't work. tryed importing and didn't work. what i'm i doing wrong?
    Registered todd71's Avatar
    Nov 2006
    U.S.A.
    Quote Originally Posted by electric2u View Post
    1) Create model, Pull down the relief tab, go to "paste"
    2) Find your RLF file
    3) Scale to size, if needed (Click the "Apply" tab or changes do not take effect)
    4) Done
    Well thats one way.
    Attached Thumbnails Attached Thumbnails Convert pet photo to relief-paste_rlf_1_drop_.jpg   Convert pet photo to relief-paste_rlf_2_find_file.jpg   Convert pet photo to relief-paste_rlf_3_2d_view.jpg   Convert pet photo to relief-paste_rlf_4_3d_view.jpg
    Web-site: http://www.innovative-accents.com/
    Blog: http://blue-collar-nobody.blogspot.com/
    Aug 2009
    USA Michigan
    can someone tell me how when you convert an image to bitmap, how to change the scale it goes the - way i would like to see it pop out at you in the + way. i have artcam
    thank you
    Nov 2006
    U.S.A.
    Invert relief Z function tab will reverse the relief. You can also try turning
    your bit map image into a negative in photo shop.
    Sometimes you can pull out more detail with a negative image,
    some color adjustments or image filters like "dust removal" functions.
    Depending how good you master image is.
    Attached Thumbnails Attached Thumbnails Convert pet photo to relief-invert_relief_z_.jpg   Convert pet photo to relief-invert_relief_z_.jpg
    Aug 2009
    USA Michigan
    thank you
    how do you make your reliefs. like what do you start with, how did you start the pheasant. i'm just getting started
    Nov 2006
    U.S.A.
    Well I started out reading the manual and working through the tutorials.
    Converting an image to relief, the relief still looks "flat" and in most cases is just lame. If you think about it there's only so much information in a bit map image. And ArtCAM, or any similar software, can only translate so much from it. So to make the pheasant "POP" I built a composite of (2) reliefs. A "Base" relief and an "Overlay" relief.
    1)Made a relief (.025 high) with a negative image of the pheasant.
    2)Save as "Overlay" relief layer/save "Overlay" file
    3)Open original image and build "Base" relief with vectors
    4)Build, sculpt, modify as needed. (this is the time consuming part)
    Save as "Base" relief layer/save "Base" file
    5)Paste "Overlay" relief on top the "Base" relief.
    Save as "Complete" relief layer/save "Complete" file
    6)Cut it, assemble it, ship it!!!!!!!!!
    There are other techniques and process that can be used.
    It's all about the "Layers"
    Attached Thumbnails Attached Thumbnails Convert pet photo to relief-1_overlay_relief_image.jpg   Convert pet photo to relief-2_overlay_relief.jpg   Convert pet photo to relief-3_base_relief_vectors.jpg   Convert pet photo to relief-4_base_relief.jpg
    Convert pet photo to relief-5_base_relief_overlay_relief_applied.jpg   Convert pet photo to relief-6_completed_gun_cabinet_face.jpg
    Dec 2009
    canada
    i use mastercam art
    i teach at a school and when done pictures there is a few things that we have found to be most helpful
    1) the photo in mastercam works better in gray scale
    2)do not resize it and change it to bitmap them go to cad program
    this seems to really make the photo suck
    3) be careful when you resize it maydistort the photo
    by the way to do a oic on a piece approx. 4 by 7 what would it cost
    kids do it at school- takes long time to run because use a 1/16 bit
    so not cost to school
    thanks dave
    Nov 2006
    U.S.A.
    Quote Originally Posted by daver59 View Post
    thanks dave
    Dave,
    I hope your in Quebec. And teaching in French, because your English grammar is atrocious. Sorry for giving you a hard time. But I just couldn't resist the opritunity to a teacher.
    I used a 1/2 flat bottom em to rough and a 1/8 ball mill to finish (2) birds at a time. Took about 40 minutes to cnc the both of them. As you can see on the tool path simulation image. The detail is not nearly was fine as the relief. So a dremel tool was used to tighten up some of the lost features.
    Attached Thumbnails Attached Thumbnails Convert pet photo to relief-pheasants_toolpath_simulation.jpg
    Feb 2007
    U.S.A.
    Question
    Dave Todd71,
    Are you a cabinet maker, what do you use Artcam for?
    Your work is awesome.
    Jeff...
  • Page 1 of 3 123 LastLast
    1. 3d relief
      By senor J. in forum DIY CNC Router Table Machines
      Last Post: 09-26-2012, 10:02 PM
    2. 3d scene to relief
      By Jack000 in forum OpenSource Software
      Last Post: 06-22-2009, 03:04 PM
    3. Convert Photo in 3D Model..My setup.....No Lazer, No stitching ;)
      By Khalid in forum Digitizing and Laser Digitizing
      Last Post: 03-29-2009, 12:40 PM
    4. 3D Map Relief
      By xtaffy in forum General CAM Discussion
      Last Post: 03-14-2005, 11:24 AM
