Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > ArtCam Pro
ArtCam Pro Discuss ArtCam Pro software here.
Old 02-24-2005, 01:49 PM
coherent is on a distinguished road
Plasma G-code with Artcam?
I realise Artcam is a bit of overkill for plasma, but I also mount a router to my machine. I've had a chance to play with Artcam a little bit and the profiling, tabbing and lead in options would be great for plasma, but how would you set up a tool (plasma cutter) that doesn't have any cutting depth etc for use with a plasma cutter with a torch height control? The torch height controller would control the Z axis so just a 2 d profile is all thats needed. Any thoughts or ideas from you Artcam gurus, or should I just use sheetcam for the plasma?
-marc
Old 03-26-2005, 09:36 AM
jerryrigge is on a distinguished road
Artcam with plasma
I have used Artcam and cnc plasma cutters. Your question is similar to those I was asking before I learned a little more.
After you do your artcam drawing, you tell artcam to produce a tool path. That tool path can be G-code ( or others depending on your settings). There will be no z axis moves unless you put those in using artcam. In artcam you tell it the depth of each cut. So just tell it to cut at 0 depth. Next issue is to turn the torch off and on. Although I don't know the easiest way to do it....I do know that it is not complicated. According to the torch control you are using you may need to insert some kind of m3 command that turns on a switch on your board. Something like a spindle on/off control.
Old 09-30-2006, 02:24 AM
sunmix is on a distinguished road
I wrote myself a plasma post processor for ArtCAM and it works fine. Includes M3 and M5 for Torch on and Torch Off. But ArtCAM can't let me choose the starting point of a geometry.
Old 11-22-2006, 12:14 AM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
Thickness of material should be set to .001". Check off 'lead-in' on profile toolpath. You will need to write your own post or find one that works with your machine.
You can change the start point of any vector in ArtCAM by hovering your mouse over where you want the start point (green node) to be and press the 'P' key. You can do this in edit or node modes.
-Brady
Old 11-22-2006, 07:31 PM
todd71's Avatar
todd71 is on a distinguished road
Anybody using the "3D laser" toolpaths.
If so, how do you like it. Not having a laser I've yet to use that feature. Would like to hear about and see some examples of uses for this toolpath function.
Thanks,
Todd
http://www.innovative-accents.com
ArtCAM substitute? Arnie Rhino 3D 12 09-15-2010 08:31 AM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
ArtCam Feature???? Donald ArtCam Pro 8 05-09-2005 09:48 AM
RF shielding against plasma HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 6 11-18-2004 09:36 AM
